    4. Motioneye Zeitliche Video Aufnahme
    • Yoda
      Yoda @wendy2702 last edited by
      @wendy2702
      Eingabe am Raspi3 / Terminal wo Motioneye läuft:
      • wendy2702
        wendy2702 @Yoda last edited by
        @yoda so geht das auch nicht.
        Das file muss mit einem Editor geöffnet und bearbeitet werden.
        z.B.
        sudo nano /etc/motioneye/motioneye.conf
        Yoda 1 Reply Last reply Reply Quote 0
        • Yoda
          @wendy2702 soory aber die Befehle über das Terminal sind mir grade mal zu 1 % Bekannt 😞
          habe die conf. nun aufgerufen - möchte da nun aber auch nichts falsch machen - wie geht es da weiter?
          # path to the configuration directory (must be writable by motionEye)
          conf_path /etc/motioneye
          # path to the directory where pid files go (must be writable by motionEye)
          run_path /var/run
          # path to the directory where log files go (must be writable by motionEye)
          log_path /var/log
          # default output path for media files (must be writable by motionEye)
          media_path /var/lib/motioneye
          # the log level (use quiet, error, warning, info or debug)
          log_level info
          # the IP address to listen on
          # (0.0.0.0 for all interfaces, 127.0.0.1 for localhost)
          listen 0.0.0.0
          # the TCP port to listen on
          port 8765
          # path to the motion binary to use (automatically detected if commented)
          #motion_binary /usr/bin/motion
          • Yoda
            Yoda @Yoda last edited by Yoda
            ich habe über WinCSP mal die Datei gesucht und gefunden:
            run_path /var/run
            log_path /var/log
            log_level info
            listen 0.0.0.0
            port 8765
            # whether motion HTTP control interface listens on
            # localhost or on all interfaces
            motion_control_localhost true
            # the TCP port that motion HTTP control interface listens on
            motion_control_port 7999
            # interval in seconds at which motionEye checks if motion is running
            motion_check_interval 10
            # whether to restart the motion daemon when an error occurs while communicating with it
            motion_restart_on_errors false
            # interval in seconds at which motionEye checks the SMB mounts
            mount_check_interval 300
            # interval in seconds at which the janitor is called
            # to remove old pictures and movies
            cleanup_interval 43200
            # timeout in seconds to wait for response from a remote motionEye server
            remote_request_timeout 10
            # timeout in seconds to wait for mjpg data from the motion daemon
            mjpg_client_timeout 10
            # timeout in seconds after which an idle mjpg client is removed
            # (set to 0 to disable)
            mjpg_client_idle_timeout 10
            # enable SMB shares (requires motionEye to run as root)
            smb_shares false
            # the directory where the SMB mount points will be created
            smb_mount_root /media
            # path to the wpa_supplicant.conf file
            # (enable this to configure wifi settings from the UI)
            #wpa_supplicant_conf /etc/wpa_supplicant.conf
            # path to the localtime file
            # (enable this to configure the system time zone from the UI)
            #local_time_file /etc/localtime
            # enables shutdown and rebooting after changing system settings
            # (such as wifi settings or time zone)
            enable_reboot false
            # timeout in seconds to use when talking to the SMTP server
            smtp_timeout 60
            # timeout in seconds to wait for media files list
            list_media_timeout 120
            # timeout in seconds to wait for media files list, when sending emails
            list_media_timeout_email 10
            # timeout in seconds to wait for zip file creation
            zip_timeout 500
            # timeout in seconds to wait for timelapse creation
            timelapse_timeout 500
            # enable adding and removing cameras from UI
            add_remove_cameras true
            # enables HTTP basic authentication scheme (in addition to, not instead of the signature mechanism)
            http_basic_auth false
            # overrides the hostname (useful if motionEye runs behind a reverse proxy)
            # server_name motionEye
            Wenn ich das Richtig lese wäre das doch ok auf True:
            • wendy2702
              @yoda Ja.
              Und damit lauscht er nur auf dem eigenen Interface. Wohl aber nicht auf denen die von extern kommen.
              Stell den mal auf "false" und starte Motioneye neu und teste dann mal das http kommando.
              Yoda 1 Reply Last reply Reply Quote 1
              • Yoda
                @wendy2702
                ok habe es gemacht -
                • Wert steht nun auf False.
                • Neustart vom ganzen Raspi3 zur Sicherheit
                • Befehl im Blocky und auch mal im Browser ausgeführt : http://192.168.178.47:7999/1/detection/start
                x Eine Video Datei wird allerdings nicht auf dem Raspi angelegt.
                Was mich nun aber grade etwas verwundert, bisschen konfus:
                Bei einer Bewegung wird über die Kamera eigene Software ein Video (per Handy zugriff - cloud) erzeugt.
                Dieses sollte aber eigentlich auch auf dem Raspi angelegt werden. - Tut es heute aber nicht mehr.
                Ich habe hier gestern noch etwas mit der Kamera Einstellungen von Motion eye rumgespielt,
                und nie Aufnahmen gesehen.
                Heute sehe ich die von Gestern - aber nicht die von grade Aktuell.
                Vielleicht macht er also den Befehl - nur wird die Video Datei nicht angelegt?...
                Oh man was für ein durcheinander....
                Aufnahmen nur von Gestern bzw. die Nacht auf dem Raspi:
                @wendy2702 Danke schon mal, das du dir die Zeit für mich genommen hast!
                LG
                • Yoda
                  ich habe hier nun noch folgendes rausgefunden.
                  Stelle ich in der Motion Software den "Recording Mode" auf "Motion Trigger"
                  • wird keine Datei angelegt.
                  Stelle ich auf " Continuous Recording"
                  • werden dauerhaft Dateien erzeugt.
                  Wenn man nun die zwei Einstellungen per Befehl (idealerweise im Blocky) wechseln könnte - wäre es doch die Lösung...
                  Zumindest zeigt es ja schon mal das die Berechtigungen und Pfade wie ich sie habe in Ordnung wären.
                  • FredF
                    FredF Most Active Forum Testing @Yoda last edited by
                    @yoda Ich habs selber noch nicht umgesetzt, nur den Link mir gemerkt. Hier hat das jemand mit Blockly beschrieben.
                    • wendy2702
                      Mit der velinkten Anleitung sollte es ja eigentlich klappen.
                      Zu Datum und Uhrzeit, sicherheitshalber auch mal die Systemzeiten der Rechner prüfen falls die noch nie gestellt worden sind.
                      • Yoda
                        Yoda @FredF last edited by
                        @fredf Danke für den Link, das ist sehr passend.
                        @wendy2702 Danke auch nochmal für deine Hilfe.
                        Ich habe das soweit nun auch nachgebaut. Die Position wäre dann wohl für mich Interessant
                        Run A Command: ON .........curl <IP-Adresse ....tEventStart
                        Run An End Command: ON .......curl <IP-Adresse tEventStop
                        Im Combination mit den beiden Datenpunkten
                        javascript.0.motioneye.getEventStart
                        javascript.0.motioneye.getEventStop
                        Ist für für die externe Triggerung wohl der Richtige weg, klappt aber noch nicht bei mir- ich frage dort einmal nach.
                        https://forum.iobroker.net/topic/40016/bewegungserkennung-mit-motioneye-lösung-komplett-in-blockly
                        LG
                        blockly javascript monitoring
                        2173
