    5. Fehler in Blocky - und keine Ahnung warum!
    • hanan
      hanan last edited by
      @wendy2702
      cd /opt/iobroker
      npm install iobroker.javascript@5.0.10 --production
      • wendy2702
        wendy2702 @hanan last edited by
        @hanan 5.10 geht nicht. War nie auf NPM. Hatte da vorhin leider ein falsche Info bekommen.
        WIe geschrieben bitte 5.09 nutzen
        chucky666 1 Reply Last reply Reply Quote 0
        • chucky666
          chucky666 @wendy2702 last edited by
          @wendy2702
          ich habe auch einen Fehler
          javascript.0	2021-03-07 13:48:20.003	error	(1230) at processImmediate (internal/timers.js:463:21)
          javascript.0	2021-03-07 13:48:20.003	error	(1230) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
          javascript.0	2021-03-07 13:48:20.003	error	(1230) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
          javascript.0	2021-03-07 13:48:20.002	error	(1230) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
          javascript.0	2021-03-07 13:48:20.002	error	(1230) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
          javascript.0	2021-03-07 13:48:20.002	error	(1230) at Object.createScript (vm.js:261:10)
          javascript.0	2021-03-07 13:48:20.002	error	(1230) at new Script (vm.js:88:7)
          javascript.0	2021-03-07 13:48:20.002	error	(1230) SyntaxError: missing ) after argument list
          javascript.0	2021-03-07 13:48:20.002	error	(1230) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
          javascript.0	2021-03-07 13:48:20.002	error	(1230) on({id: new RegExp('zigbee\\.0\\.00158d000204790f\\.occupancy' + "$|" + 'zigbee\\.0\\.00158d0001d7adf4\\.opened'$), val: true}, async function (obj) {
          javascript.0	2021-03-07 13:48:20.002	error	at script.js.Vorgarten_Reolink_Cam_Blocky:24
          javascript.0	2021-03-07 13:48:20.002	error	(1230) script.js.Vorgarten_Reolink_Cam_Blocky compile failed:
          • hanan
            @wendy2702
            Jep, mit 5.0.09 hat es geklappt.
              Homoran Global Moderator Administrators @chucky666 last edited by
              @chucky666 sagte in Fehler in Blocky - und keine Ahnung warum!:
              was willst du uns damit sagen?
              Hast du noch weitere Infos?
              .occupancy' + "$
              • chucky666
                chucky666 @Homoran last edited by
                Ich habe das Update gemacht auf 5.11 danach bekomme ich diesen Fehler .
                Jetzt bin ich zurück auf 5.09 aber leider ist der Fehler immer noch da
                wendy2702 Homoran 2 Replies Last reply Reply Quote 0
                • wendy2702
                  wendy2702 @chucky666 last edited by
                  @chucky666 Blockly löschen und neu machen
                    @chucky666
                    den Thread hast du aber gelesen, oder?
                    hat das Blockly vorher existiert?
                    Wenn ja, mit welcher Version hast du das Blockly angelegt?
                    • hanan
                      hanan last edited by hanan
                      Bin zurück auf Version 5.0.09 und habe den Mehrfach-Trigger-Block gelöscht und neu angelegt. Leider immer noch das $-Zeichen nach dem + ".
                      Hier der Log beim starten dieses Scriptes:
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) at processImmediate (internal/timers.js:463:21)
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) at Object.createScript (vm.js:261:10)
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) at new Script (vm.js:88:7)
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) SyntaxError: missing ) after argument list
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) ^^^^^^^^^^^^^^^^
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) on({id: new RegExp('0_userdata\\.0\\.Variablen\\.Uebe...\\.Bewe...' + "$|" + 'scene\\.0\\.Tanz...' + "$|" + 'hm-rpc\\.1\\.0000D\\.1\\.STATE' + "$|" + 'hm-rpc\\.1\\.00
                      javascript.0	2021-03-07 13:58:22.951	error	at script.js.common.Sonstiges.Deko_tanzentes_Tier:1
                      javascript.0	2021-03-07 13:58:22.951	error	(21836) script.js.common.Sonstiges.Deko_tanzentes_Tier compile failed:
                        Homoran Global Moderator Administrators @hanan last edited by
                        @hanan sagte in Fehler in Blocky - und keine Ahnung warum!:
                        danach zwischengespeichert?
                        • hanan
                          @Homoran
                          Habe es nochmals mit zwischenspeichern versucht. Das $-Zeichen bleibt.
                          • wendy2702
                            @Homoran
                            Habe es nochmals zwischenspeichern versucht. Das $-Zeichen bleibt.
                            iobroker list adapters |grep javascript
                            • hanan
                              @wendy2702 sagte in Fehler in Blocky - und keine Ahnung warum!:
                              Guter Tipp...
                              Habe immer noch die Version 5.0.11
                              • chucky666
                                @wendy2702
                                Danke euch , musste 2 Blockys neu machen .
                                Ich habe die java version 5.09 installiert , Neustart gemacht und dann die betroffenen Blockys neuprogrammiert
                                erstmal klappt alles
                                • hanan
                                  @wendy2702
                                  Habe jetzt folgenden Zustand und iobroker neu gestartet:
                                  Adapter    "javascript"      :   5.0.11      , installad 5.0.9 [Updateable]
                                    Homoran Global Moderator Administrators @hanan last edited by Homoran
                                    klingt gut!
                                    und jetzt noch einmal zurück auf LOS!
                                    • hanan
                                      @Homoran
                                      Neuse Blockly mit dem Mehrfach-Trigger-Block erstelt und immer noch Fehlermeldung wegen dem $-Zeichen:
                                      javascript.0	2021-03-07 14:40:32.582	error	(8378) at processImmediate (internal/timers.js:463:21)
                                      javascript.0	2021-03-07 14:40:32.582	error	(8378) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
                                      javascript.0	2021-03-07 14:40:32.582	error	(8378) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) at Object.createScript (vm.js:261:10)
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) at new Script (vm.js:88:7)
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) SyntaxError: missing ) after argument list
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) on({id: new RegExp('0_userdata\\.0\\.Variablen\\.Ueber...\\.Bewe...' + "$|" + 'scene\\.0\\.Tanz...'$), change: "ne"}, async function (obj) {
                                      javascript.0	2021-03-07 14:40:32.581	error	at script.js.common.Sonstiges.Deko...:1
                                      javascript.0	2021-03-07 14:40:32.581	error	(8378) script.js.common.Sonstiges.Deko... compile failed:
                                      Gebe jetzt auf und wart mal ab.
                                      Das Skript ist nur für Deko, also Prio 3 mit leichtem negativem WAF welche ich übeleben werde 🙄
                                      • wendy2702
                                        Wie du willst.
                                        actionbyte 1 Reply Last reply Reply Quote 0
                                        • actionbyte
                                          actionbyte @wendy2702 last edited by
                                          Ich hänge nun auch seit 2 Stunden vor dem problem der doppelten Trigger und war am verzweifeln bis ich gerade den Thread hier gefunden habe.
                                          Aber wie komme ich auf 5.0.9 zurück?
                                          Nach
                                          cd /opt/iobroker
                                          npm install iobroker.javascript@5.0.9 --production
                                          und Neustart vom via iobroker stop oder kompletten reboot kommt nach
                                          trotzden "javascript : javascript - v5.0.11"
                                          In der Adapterübersicht wird mir allerdings der 5.0.9 angezeigt, aber die Fehlermeldung nach complieren vom doppelten Trigger kommt trotzdem.
                                          Was mache ich falsch?
                                          Homoran wendy2702 2 Replies Last reply Reply Quote 0
                                            Homoran Global Moderator Administrators @actionbyte last edited by
                                            @actionbyte sagte in Fehler in Blocky - und keine Ahnung warum!:
                                            iobroker upload javascript ausführen?
                                            3019
