    5. Fehler in Blocky - und keine Ahnung warum!
    • wendy2702
      wendy2702 @hanan last edited by
      @hanan 5.10 geht nicht. War nie auf NPM. Hatte da vorhin leider ein falsche Info bekommen.
      WIe geschrieben bitte 5.09 nutzen
      chucky666 1 Reply Last reply Reply Quote 0
      • chucky666
        chucky666 @wendy2702 last edited by
        @wendy2702
        ich habe auch einen Fehler
        javascript.0	2021-03-07 13:48:20.003	error	(1230) at processImmediate (internal/timers.js:463:21)
        javascript.0	2021-03-07 13:48:20.003	error	(1230) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
        javascript.0	2021-03-07 13:48:20.003	error	(1230) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
        javascript.0	2021-03-07 13:48:20.002	error	(1230) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
        javascript.0	2021-03-07 13:48:20.002	error	(1230) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
        javascript.0	2021-03-07 13:48:20.002	error	(1230) at Object.createScript (vm.js:261:10)
        javascript.0	2021-03-07 13:48:20.002	error	(1230) at new Script (vm.js:88:7)
        javascript.0	2021-03-07 13:48:20.002	error	(1230) SyntaxError: missing ) after argument list
        javascript.0	2021-03-07 13:48:20.002	error	(1230) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
        javascript.0	2021-03-07 13:48:20.002	error	(1230) on({id: new RegExp('zigbee\\.0\\.00158d000204790f\\.occupancy' + "$|" + 'zigbee\\.0\\.00158d0001d7adf4\\.opened'$), val: true}, async function (obj) {
        javascript.0	2021-03-07 13:48:20.002	error	at script.js.Vorgarten_Reolink_Cam_Blocky:24
        javascript.0	2021-03-07 13:48:20.002	error	(1230) script.js.Vorgarten_Reolink_Cam_Blocky compile failed:
        • hanan
          @wendy2702
          Jep, mit 5.0.09 hat es geklappt.
            Homoran Global Moderator Administrators @chucky666 last edited by
            @chucky666 sagte in Fehler in Blocky - und keine Ahnung warum!:
            was willst du uns damit sagen?
            Hast du noch weitere Infos?
            .occupancy' + "$
            • chucky666
              chucky666 @Homoran last edited by
              Ich habe das Update gemacht auf 5.11 danach bekomme ich diesen Fehler .
              Jetzt bin ich zurück auf 5.09 aber leider ist der Fehler immer noch da
              wendy2702 Homoran 2 Replies Last reply Reply Quote 0
              • wendy2702
                wendy2702 @chucky666 last edited by
                @chucky666 Blockly löschen und neu machen
                  @chucky666
                  den Thread hast du aber gelesen, oder?
                  hat das Blockly vorher existiert?
                  Wenn ja, mit welcher Version hast du das Blockly angelegt?
                  • hanan
                    hanan last edited by hanan
                    Bin zurück auf Version 5.0.09 und habe den Mehrfach-Trigger-Block gelöscht und neu angelegt. Leider immer noch das $-Zeichen nach dem + ".
                    Hier der Log beim starten dieses Scriptes:
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) at processImmediate (internal/timers.js:463:21)
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) at Object.createScript (vm.js:261:10)
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) at new Script (vm.js:88:7)
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) SyntaxError: missing ) after argument list
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) ^^^^^^^^^^^^^^^^
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) on({id: new RegExp('0_userdata\\.0\\.Variablen\\.Uebe...\\.Bewe...' + "$|" + 'scene\\.0\\.Tanz...' + "$|" + 'hm-rpc\\.1\\.0000D\\.1\\.STATE' + "$|" + 'hm-rpc\\.1\\.00
                    javascript.0	2021-03-07 13:58:22.951	error	at script.js.common.Sonstiges.Deko_tanzentes_Tier:1
                    javascript.0	2021-03-07 13:58:22.951	error	(21836) script.js.common.Sonstiges.Deko_tanzentes_Tier compile failed:
                      Homoran Global Moderator Administrators @hanan last edited by
                      @hanan sagte in Fehler in Blocky - und keine Ahnung warum!:
                      danach zwischengespeichert?
                      • hanan
                        @Homoran
                        Habe es nochmals mit zwischenspeichern versucht. Das $-Zeichen bleibt.
                        • wendy2702
                          @Homoran
                          Habe es nochmals zwischenspeichern versucht. Das $-Zeichen bleibt.
                          iobroker list adapters |grep javascript
                          • hanan
                            @wendy2702 sagte in Fehler in Blocky - und keine Ahnung warum!:
                            Guter Tipp...
                            Habe immer noch die Version 5.0.11
                            • chucky666
                              @wendy2702
                              Danke euch , musste 2 Blockys neu machen .
                              Ich habe die java version 5.09 installiert , Neustart gemacht und dann die betroffenen Blockys neuprogrammiert
                              erstmal klappt alles
                              • hanan
                                @wendy2702
                                Habe jetzt folgenden Zustand und iobroker neu gestartet:
                                Adapter    "javascript"      :   5.0.11      , installad 5.0.9 [Updateable]
                                  Homoran Global Moderator Administrators @hanan last edited by Homoran
                                  klingt gut!
                                  und jetzt noch einmal zurück auf LOS!
                                  • hanan
                                    @Homoran
                                    Neuse Blockly mit dem Mehrfach-Trigger-Block erstelt und immer noch Fehlermeldung wegen dem $-Zeichen:
                                    javascript.0	2021-03-07 14:40:32.582	error	(8378) at processImmediate (internal/timers.js:463:21)
                                    javascript.0	2021-03-07 14:40:32.582	error	(8378) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
                                    javascript.0	2021-03-07 14:40:32.582	error	(8378) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) at Object.createScript (vm.js:261:10)
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) at new Script (vm.js:88:7)
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) SyntaxError: missing ) after argument list
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) on({id: new RegExp('0_userdata\\.0\\.Variablen\\.Ueber...\\.Bewe...' + "$|" + 'scene\\.0\\.Tanz...'$), change: "ne"}, async function (obj) {
                                    javascript.0	2021-03-07 14:40:32.581	error	at script.js.common.Sonstiges.Deko...:1
                                    javascript.0	2021-03-07 14:40:32.581	error	(8378) script.js.common.Sonstiges.Deko... compile failed:
                                    Gebe jetzt auf und wart mal ab.
                                    Das Skript ist nur für Deko, also Prio 3 mit leichtem negativem WAF welche ich übeleben werde 🙄
                                    • wendy2702
                                      Wie du willst.
                                      actionbyte 1 Reply Last reply Reply Quote 0
                                      • actionbyte
                                        actionbyte @wendy2702 last edited by
                                        Ich hänge nun auch seit 2 Stunden vor dem problem der doppelten Trigger und war am verzweifeln bis ich gerade den Thread hier gefunden habe.
                                        Aber wie komme ich auf 5.0.9 zurück?
                                        Nach
                                        cd /opt/iobroker
                                        npm install iobroker.javascript@5.0.9 --production
                                        und Neustart vom via iobroker stop oder kompletten reboot kommt nach
                                        trotzden "javascript : javascript - v5.0.11"
                                        In der Adapterübersicht wird mir allerdings der 5.0.9 angezeigt, aber die Fehlermeldung nach complieren vom doppelten Trigger kommt trotzdem.
                                        Was mache ich falsch?
                                        Homoran wendy2702 2 Replies Last reply Reply Quote 0
                                          Homoran Global Moderator Administrators @actionbyte last edited by
                                          @actionbyte sagte in Fehler in Blocky - und keine Ahnung warum!:
                                          iobroker upload javascript ausführen?
                                          • wendy2702
                                            wendy2702 @actionbyte last edited by
                                            cd /opt/iobroker npm install iobroker.javascript@5.0.9 --production
                                            Würde gerne das log dazu sehen und frage mich warum du nicht den downgrade über den Admin machst?
                                            3021
