    4. [ Geklärt ] Problem bei Influx Installation
      Altersrentner @wendy2702 last edited by
      @wendy2702 sagte in [ Geklärt ] Problem bei Influx Installation:
      sudo systemctl status grafana-server
      pi@raspberrypi:/opt/iobroker $ sudo systemctl status grafana-server
      ● grafana-server.service - Grafana instance
         Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2021-03-07 14:28:17 CET; 3h 59min ago
           Docs: http://docs.grafana.org
       Main PID: 606 (grafana-server)
          Tasks: 17 (limit: 4915)
         CGroup: /system.slice/grafana-server.service
                 └─606 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.
      Mar 07 18:19:44 raspberrypi grafana-server[606]: t=2021-03-07T18:19:44+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:23 raspberrypi grafana-server[606]: t=2021-03-07T18:21:23+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:27 raspberrypi grafana-server[606]: t=2021-03-07T18:21:27+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:33 raspberrypi grafana-server[606]: t=2021-03-07T18:21:33+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:34 raspberrypi grafana-server[606]: t=2021-03-07T18:21:33+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:37 raspberrypi grafana-server[606]: t=2021-03-07T18:21:37+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:44 raspberrypi grafana-server[606]: t=2021-03-07T18:21:44+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:47 raspberrypi grafana-server[606]: t=2021-03-07T18:21:47+0100 lvl=info msg="Request Completed" logger=co
      lines 1-19/19 (END)...skipping...
      • wendy2702
        wendy2702 @Altersrentner last edited by
        @altersrentner Also Grafane läuft. Ich gehe davon aus das es noch deine alte HDD ist.
        Hat er jetzt ein Grafana Backup erstellt?
        Wenn es noch die alte HDD ist kopiere die Backup files per FTP runter.
        Boote wieder von SSD und mach ein Restore von Influx und Grafana mit Backitup
          @wendy2702 Ja es ist noch die alte HDD angeschlossen
          Nein erhat kein Grafana Backup gemacht.
          Habe eben gesehen, das unter
          Backitup Grafana der Hostname und der Grafana API Key fehlen
          Was sollich dort eintragen bzw wie bekomme ich den Key
          wendy2702 crunchip 2 Replies Last reply Reply Quote 0
            Altersrentner @crunchip last edited by
            @crunchip
            pi@raspberrypi:~ $ systemctl daemon-reload
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
            Authentication is required to reload the systemd state.
            Authenticating as: ,,, (pi)
            Password:
            ==== AUTHENTICATION COMPLETE ===
            pi@raspberrypi:~ $ systemctl enable influxdb
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
            Authentication is required to manage system service or unit files.
            Password:
            Password:
            pi@raspberrypi:~ $ systemctl start influxdb
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
            Authentication is required to start 'influxdb.service'.
            Password:
            pi@raspberrypi:~ $
              crunchip Forum Testing Most Active @Altersrentner last edited by
              @altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
              Was kann ich hinsichtlich cifs machen?
              ich habe keine Ahnung was du alles eingerichtet hast, bzw was du wohin schickst um backup's zu machen. Nutzt du überhaupt cifs oder nur google drive?
              grafana läuft, aber du hast wahrscheinlich die Einstellungen für das Grafana Backup nicht richtig gesetzt.(benutzername/passwort/api-key)
              • wendy2702
                @altersrentner Hostname sollte der hier sein:
                raspberrypi
                Key... keine Ahnung.
                Vielleicht ist es einfacher wenn du über die Grafana GUI gehst und deine Dashboards einfach exportierst.
                  crunchip Forum Testing Most Active @Altersrentner last edited by crunchip
                  Des Weiteren muss in der Grafana-Weboberfläche ein Api-Key erzeugt werden, um Zugriff auf die Dashboards zu bekommen.
                  Der Api-Key kann unter "Configuration → API Keys" erstellt werden.
                  Edit:
                  Nochmal zusammengefasst, du hast möchtest umziehen von einer Hdd auf eine SSD. Iobroker hast du dort schon laufen, mittels Backup.
                  Was du vergessen/nicht beachtet hast, das Grafana und InfluxDB zwei separate Installationen sind, die mit dem Backup des Iobrokers nichts zu tun haben, daher musst du beide entsprechend wieder auf deiner SSD installieren.
                  wenn du beide Backups(via backitup) von Influx und Grafana hast, kannst du diese auch wieder per backitup zurückspielen, wenn nicht, musst du dir die Daten entsprechend aus deiner HDD holen und wieder in deiner SSD einfügen
                    Altersrentner @crunchip last edited by Altersrentner
                    @crunchip sagte in [ Geklärt ] Problem bei Influx Installation:
                    Nur Google Drive
                    Den Key habe ich erstellt.
                    Nun der Hostname
                    Wo finde ich den?
                    crunchip wendy2702 2 Replies Last reply Reply Quote 0
                      Nun der Hostname
                      gib einfach deine Ip Adresse ein
                      Nur Google Drive
                      dann hast du NAS/Kopieren scheinbar angehakt, in den Haupteinstellungen, daher der Fehler
                      • wendy2702
                        @altersrentner Hatt ich zwar schon geschrieben kannst aber auch gerne nochmal hier schauen
                        cat /etc/hosts
                        A 3 Replies Last reply Reply Quote 0
                          @crunchip
                          Danke!
                          Jetz mache ich noch ein Backup
                          mal sehen was dann ist
                            @wendy2702 super Danke😊 👍
                              @wendy2702
                              Es erscheint wieder ein Error bei Grafana
                              DEBUG] [grafana] - Start Grafana Backup ...
                              [DEBUG] [grafana] - Created grafana_tmp directory
                              [DEBUG] [grafana] - Created dashboard directory
                              [DEBUG] [grafana] - Created dashboards_manually_restore directory
                              [DEBUG] [grafana] - Created datasource directory
                              [DEBUG] [grafana] - start Grafana request ...
                              [DEBUG] [grafana] - Grafana is available ... Status: 200
                              [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
                              [DEBUG] [grafana] - start Grafana backup compress ...
                              [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                              [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                              [DEBUG] [grafana] - cannot found Grafana Backup files
                              [DEBUG] [grafana] - done
                              [DEBUG] [cifs] - done
                              [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_08_53_influx grafana_backupiobroker.tar.gz...
                                Falschen Benutzerdaten oder Api-Key falsch
                                Grafana ist erreichbar (siehe Status 200)
                                A 2 Replies Last reply Reply Quote 0
                                  @crunchip
                                  Danke, habe jetzt beim Host die IP eingestellt
                                  und ein neuer Versuch
                                    @crunchip
                                    Started iobroker ...
                                    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
                                    Unable to find suitable address.
                                    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
                                    [DEBUG] [iobroker] - host.raspberrypi 14084 states saved
                                    [DEBUG] [iobroker] - host.raspberrypi 16331 objects saved
                                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz
                                    [DEBUG] [iobroker] - done
                                    [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                    [DEBUG] [influxDB] - Packed 15MB so far...
                                    [DEBUG] [influxDB] - Packed 47MB so far...
                                    [DEBUG] [influxDB] - Packed 79MB so far...
                                    [DEBUG] [influxDB] - Packed 149MB so far...
                                    [DEBUG] [influxDB] - Packed 235MB so far...
                                    [DEBUG] [influxDB] - Packed 313MB so far...
                                    [DEBUG] [influxDB] - Packed 405MB so far...
                                    [DEBUG] [influxDB] - Packed 481MB so far...
                                    [DEBUG] [influxDB] - Packed 562MB so far...
                                    [DEBUG] [influxDB] - Packed 646MB so far...
                                    [DEBUG] [influxDB] - Packed 727MB so far...
                                    [DEBUG] [influxDB] - Packed 817MB so far...
                                    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz
                                    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                    [DEBUG] [influxDB] - done
                                    [DEBUG] [grafana] - Start Grafana Backup ...
                                    [DEBUG] [grafana] - found Dashboard: n1-aussen-wz
                                    [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2021_03_07-19_42_25_backupiobroker.tar.gz
                                    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz...
                                    [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz...
                                    Ich glaube jetzt hat es geklappt👍 oder👎
                                      @altersrentner sieht so aus, grafana und influx, dein cifs hast aber noch aktiv(was du ja nicht nutzt), also Haken noch raus bei Nas.
                                      aber deine Backups sind gemacht
                                      musst nur dran denken, das du bei deiner SSD Influx und Grafana installiert haben musst um das backup ein zu spielen
                                        @crunchip OK
                                        wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                        source /etc/os-release
                                        echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                        sudo apt update
                                        sudo apt install -y influxdb
                                        sudo systemctl unmask influxdb.service
                                        sudo systemctl start influxdb.service
                                        sudo systemctl enable influxdb.service
                                        Damit installiere ich Influx.
                                        Kannst Du mir bitte noch den Code für Grafana mitteilen?
                                        Mit freundlichen Grüßen
                                        Michael
                                          @altersrentner
                                          apt-Schlüssel zufügen
                                          wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                                          grafana repository hinzufügen
                                          echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
                                          installieren
                                          sudo apt-get update
                                          sudo apt-get install -y grafana
                                          aktivieren und starten
                                          sudo /bin/systemctl enable grafana-server
                                          sudo /bin/systemctl start grafana-server
                                          aufrufen dann über http://<ip address>:3000
                                          Name und Kennwort ist standard
                                          admin
                                          admin
                                            @crunchip D A N K E !
                                            Michael
                                            influxdb
                                            12
                                            178
                                            33062
