    4. FB-Checkpresence Adapter wird nicht grün [gelöst]
    • wendy2702
      wendy2702 @MM2029 last edited by
      @mm2029 Kannst du diese Schritte alle nochmal verifizieren:
      https://www.janrufmonitor.de/tr-064-aktivieren/
        MM2029 @wendy2702 last edited by wendy2702
        @wendy2702 Habe jetzt nochmal einen neuen Benutzer angelegt. Überall Haken gesetzt ohne Erfolg.
        Adapter gelöscht und neu installiert.
        fb-checkpresence.0	2021-03-07 20:29:50.688	info	(9051) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
        fb-checkpresence.0	2021-03-07 20:29:50.653	info	(9051) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
        host.raspberrypi4	2021-03-07 20:29:49.097	info	instance system.adapter.fb-checkpresence.0 started with pid 9051
        host.raspberrypi4	2021-03-07 20:29:46.593	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        fb-checkpresence.0	2021-03-07 20:29:45.974	info	(9032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0	2021-03-07 20:29:45.973	info	(9032) terminating
        fb-checkpresence.0	2021-03-07 20:29:45.972	error	(9032) onUnload: TypeError: Cannot read property 'exitRequest' of null
        host.raspberrypi4	2021-03-07 20:29:45.970	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
        fb-checkpresence.0	2021-03-07 20:29:45.970	info	(9032) Got terminate signal TERMINATE_YOURSELF
        host.raspberrypi4	2021-03-07 20:29:45.960	info	stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
        fb-checkpresence.0	2021-03-07 20:29:11.060	info	(9032) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 1 Min. - interval members: 60 s
        fb-checkpresence.0	2021-03-07 20:29:11.027	info	(9032) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
        host.raspberrypi4	2021-03-07 20:29:09.651	info	instance system.adapter.fb-checkpresence.0 started with pid 9032
        host.raspberrypi4	2021-03-07 20:29:07.060	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        fb-checkpresence.0	2021-03-07 20:29:06.478	info	(9003) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0	2021-03-07 20:29:06.476	info	(9003) terminating
        fb-checkpresence.0	2021-03-07 20:29:06.475	error	(9003) onUnload: TypeError: Cannot read property 'exitRequest' of null
        MOD EDIT: LOG IN CODE TAGS </>
        wendy2702 1 Reply Last reply Reply Quote 1
        • wendy2702
          @mm2029 Gab es bei der Adapter Installation irgendwelche Error oder so?
            @wendy2702
            $ ./iobroker add fb-checkpresence  --host raspberrypi4
            NPM version: 6.14.11
            npm install iobroker.fb-checkpresence@1.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
            host.raspberrypi4 install adapter fb-checkpresence
            upload [5] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/words.js words.js application/javascript
            upload [4] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/style.css style.css text/css
            upload [3] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.js index_m.js application/javascript
            upload [2] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/index_m.html index_m.html text/html
            upload [1] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/fb-checkpresence.png fb-checkpresence.png image/png
            upload [0] fb-checkpresence.admin /opt/iobroker/node_modules/iobroker.fb-checkpresence/admin/admin.d.ts admin.d.ts video/mp2t
            host.raspberrypi4 object system.adapter.fb-checkpresence created/updated
            host.raspberrypi4 create instance fb-checkpresence
            host.raspberrypi4 object fb-checkpresence.0.info created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.logLevel created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.sigKill created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.eventLoopLag created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.outputCount created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.inputCount created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.uptime created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.memRss created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.memHeapTotal created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.memHeapUsed created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.cputime created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.cpu created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.compactMode created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.connected created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0.alive created
            host.raspberrypi4 object system.adapter.fb-checkpresence.0 created
            process exited with code 0
            • wendy2702
              @mm2029 Hast du im Adapter SSL aktiviert ?
                @wendy2702 Diese Möglichkeit sehe ich dem Adapter nicht
                • wendy2702
                  @mm2029 Hm,
                  steht in Anleitung:
                    @wendy2702 kann leider nichts dazu finden.. 😞
                    • wendy2702
                      @mm2029 Kann dir heute nicht mehr helfen. Muss noch für Dienstreise packen,
                      Auf die schnelle fällt mir nichts mehr ein.
                        @wendy2702 vielen Dank trotzdem und gute Reise
                          Dragon @MM2029 last edited by
                          @mm2029 Neben dem Feld zur Passworteingabe kann man ssl deaktivieren...
                          Winni 1 Reply Last reply Reply Quote 0
                          • Winni
                            Winni @Dragon last edited by
                            @dragon ich glaube aber erst ab der Version 1.11 wenn ich das read.me richtig verstehe. Im stable ist erst die 1.10.
                              Dragon @Winni last edited by
                              @winni achso, oki...
                                MM2029 @Dragon last edited by
                                @dragon @wendy2702 Hab den Adapter wieder grün, was genau schief lief kann ich nicht sagen.
                                Mit neuen Benutzer lief er heute wieder. Vielen Dank für eure Bemühungen. Hätte noch eine Frage zum Broadling2 Adapter. Habe den RM4 pro hier und der taucht auch im Adapter auf nur ohne Datenpunkte zum Anlernen. Hat jemand eine Idee ?
                                D wendy2702 2 Replies Last reply Reply Quote 0
                                  @mm2029 Ich hatte mit allen Geräten Probleme außer dem RM Pro +. Ich würde es mit dem versuchen...
                                  • wendy2702
                                    @mm2029 sagte in FB-Checkpresence Adapter wird nicht grün:
                                    Mach dafür besser ein neues Thema auf und setze das hier bitte auf [Gelöst]
                                    1383
