    3. Entwicklung
    4. Galapara Thermostat / Zigbee / wird nicht konfiguriert
      arteck Developer Most Active @flitze-fitz last edited by
      @flitze-fitz nein ich meine die JETZIGE Version vor 5 min... die ich gerade aktualisiert habe
        flitze-fitz @arteck last edited by
        @arteck erster Versuch leider mit Fehler. Ich versuche es nochmal. Vorab schonmal danke für deine Mühe.
        $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
        install ioBroker/ioBroker.zigbee#master
        NPM version: 6.14.11
        npm install ioBroker/ioBroker.zigbee#master --loglevel error (System call)
        npm ERR! code EPERM
        npm ERR! syscall unlink
        npm ERR! path C:\Program Files\iobroker\SmartHome1\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node
        npm ERR! errno -4048
        npm ERR! Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartHome1\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node'
        npm ERR!  [OperationalError: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartHome1\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node'] {
        npm ERR!   cause: [Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartHome1\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node'] {
        npm ERR!     errno: -4048,
        npm ERR!     code: 'EPERM',
        npm ERR!     syscall: 'unlink',
        npm ERR!     path: 'C:\\Program Files\\iobroker\\SmartHome1\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\node_modules\\@serialport\\bindings\\build\\Release\\bindings.node'
        npm ERR!   },
        npm ERR!   path: 'C:\\Program Files\\iobroker\\SmartHome1\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\node_modules\\@serialport\\bindings\\build\\Release\\bindings.node',
        npm ERR!   parent: 'zigbee-herdsman'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It's possible that the file was already in use (by a text editor or antivirus),
        npm ERR! or that you lack permissions to access it.
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     C:\Program Files\iobroker\SmartHome1\env\npm-cache\_logs\2021-03-07T18_41_24_682Z-debug.log
        ERROR: host.NUC(SmartHome1) Cannot install ioBroker/ioBroker.zigbee#master: 4294963248
        ERROR: process exited with code 25
          flitze-fitz @arteck last edited by flitze-fitz
          @arteck
          Jetzt geht gar nichts mehr. Adapter bleibt rot. Ist jetzt doch wieder grün, aber ich konnte deine neueste Version nicht installieren.
          2021-03-07 20:21:59.549 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" enabled
          2021-03-07 20:21:59.594 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 started with pid 1448
          2021-03-07 20:22:01.187 - error: host.NUC(SmartHome1) Caught by controller[0]: C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:121
          2021-03-07 20:22:01.188 - error: host.NUC(SmartHome1) Caught by controller[0]: throw e;
          2021-03-07 20:22:01.188 - error: host.NUC(SmartHome1) Caught by controller[0]: ^
          2021-03-07 20:22:01.188 - error: host.NUC(SmartHome1) Caught by controller[0]: Error: The module '\\?\C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node'
          2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: was compiled against a different Node.js version using
          2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
          2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
          2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
          2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
          2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at bindings (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:112:48)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object. (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\lib\win32.js:1:36)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2021-03-07 20:22:01.191 - info: host.NUC(SmartHome1) Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
          2021-03-07 20:22:01.191 - info: host.NUC(SmartHome1) system.adapter.zigbee.0 will be rebuilt
          2021-03-07 20:22:01.192 - warn: host.NUC(SmartHome1) adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
          2021-03-07 20:22:01.192 - info: host.NUC(SmartHome1) iobroker rebuild zigbee
          2021-03-07 20:22:03.670 - info: host.NUC(SmartHome1) iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee"
          2021-03-07 20:22:07.820 - info: host.NUC(SmartHome1) iobroker npm-rebuild:
          2021-03-07 20:22:07.820 - info: host.NUC(SmartHome1) iobroker npm-rebuild: Rebuild zigbee done
          2021-03-07 20:22:08.840 - info: host.NUC(SmartHome1) iobroker npm-rebuild: exit 0
          2021-03-07 20:22:08.883 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 started with pid 3108
          2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:121
          2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: throw e;
          2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: ^
          2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: Error: The module '\\?\C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node'
          2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: was compiled against a different Node.js version using
          2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
          2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at bindings (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:112:48)
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object. (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\lib\win32.js:1:36)
          2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          2021-03-07 20:22:09.919 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          2021-03-07 20:22:09.919 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          2021-03-07 20:22:09.919 - error: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2021-03-07 20:22:09.919 - info: host.NUC(SmartHome1) Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
          2021-03-07 20:22:09.919 - info: host.NUC(SmartHome1) system.adapter.zigbee.0 will be rebuilt
          2021-03-07 20:22:09.919 - warn: host.NUC(SmartHome1) adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
          2021-03-07 20:22:09.919 - info: host.NUC(SmartHome1) iobroker rebuild zigbee --install
          2021-03-07 20:22:10.935 - info: host.NUC(SmartHome1) iobroker npm-rebuild: npm install --loglevel error --production (System call) in "C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee"
          2021-03-07 20:22:53.011 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" disabled
          2021-03-07 20:23:20.361 - info: host.NUC(SmartHome1) iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
          2021-03-07 20:23:29.662 - info: host.NUC(SmartHome1) iobroker install ioBroker/ioBroker.zigbee#master
          2021-03-07 20:23:39.296 - info: host.NUC(SmartHome1) iobroker NPM version: 6.14.11
          2021-03-07 20:23:39.299 - info: host.NUC(SmartHome1) iobroker npm install ioBroker/ioBroker.zigbee#master --loglevel error (System call)
          2021-03-07 20:28:28.572 - info: host.NUC(SmartHome1) iobroker npm ERR! code EBUSY
          2021-03-07 20:28:28.573 - info: host.NUC(SmartHome1) iobroker npm ERR! syscall rmdir
          npm ERR! errno -4082
          2021-03-07 20:28:28.576 - info: host.NUC(SmartHome1) iobroker npm ERR! EBUSY: resource busy or locked, rmdir 'C:\Program Files\iobroker\SmartHome1\node_modules\iobroker.zigbee'
          2021-03-07 20:28:28.649 - info: host.NUC(SmartHome1) iobroker
          2021-03-07 20:28:28.650 - info: host.NUC(SmartHome1) iobroker npm ERR! A complete log of this run can be found in:
          npm ERR! C:\Program Files\iobroker\SmartHome1\env\npm-cache\_logs\2021-03-07T19_28_28_593Z-debug.log
          2021-03-07 20:28:28.781 - error: host.NUC(SmartHome1) iobroker host.NUC(SmartHome1) Cannot install ioBroker/ioBroker.zigbee#master: 4294963214
          2021-03-07 20:28:29.821 - info: host.NUC(SmartHome1) iobroker exit 25
            arteck Developer Most Active @flitze-fitz last edited by arteck
            @flitze-fitz du sollst nicht 5 sachen auf einmal machen und hoffen das wir das nicht sehen...
            warum installierst du neues node .. die Versionen passen nicht zueinander..
            ... und meckerst dass nix geht.. ist schon schwer genug das dein system auf windows läuft
              @arteck
              außer über die Katze den Adapter von GIT zu installieren, hab ich gar nichts gemacht. Wirklich nicht. Ich hab keine Ahnung woher diese Logs kommen.
              Meine node version ist 12.21. Muss ich eine andere Version haben?
              Mir liegt es fern Leuten die mir helfen können/wollen die Arbeit zu erschweren und verstecken wollte ich auch nichts.
                @flitze-fitz wenn du auf die node 12 bist dann hast du ein update gemacht.. wann keine ahnung .. auf jeden fall hast du den adapter nicht neu generiert...
                also kein plan was da schief oder was weiss ich gelaufen ist...
                folgendes
                zigbee adapter stoppen
                dann löschen aus dem
                folgende Ordner
                serialport
                @serialport
                zigbee-herdsman
                zigbee-herdsman-converters
                iobroker.zigbee
                dann über die Katze den adapter neu installieren
                dann adapter starten...log posten
                  :@arteck vielen Dank. Jetzt ging es durch. Das Thermostat geht aber leider immer noch nicht.
                  2021-03-07 21:03:50.354 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" disabled
                  2021-03-07 21:03:50.356 - info: host.NUC(SmartHome1) stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2021-03-07 21:03:50.350 - info: zigbee.0 (10728) Got terminate signal TERMINATE_YOURSELF
                  2021-03-07 21:03:50.361 - info: host.NUC(SmartHome1) stopInstance system.adapter.zigbee.0 send kill signal
                  2021-03-07 21:03:50.352 - info: zigbee.0 (10728) cleaned everything up...
                  2021-03-07 21:03:50.354 - info: zigbee.0 (10728) Zigbee: disabling joining new devices.
                  2021-03-07 21:03:50.877 - info: zigbee.0 (10728) terminating
                  2021-03-07 21:03:50.877 - info: zigbee.0 (10728) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2021-03-07 21:03:51.390 - info: host.NUC(SmartHome1) stopInstance system.adapter.zigbee.0 killing pid 10728
                  2021-03-07 21:03:51.444 - warn: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated due to SIGTERM
                  2021-03-07 21:03:51.445 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated with code null ()
                  2021-03-07 21:08:24.034 - info: host.NUC(SmartHome1) iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
                  2021-03-07 21:08:29.334 - info: host.NUC(SmartHome1) iobroker install ioBroker/ioBroker.zigbee#master
                  2021-03-07 21:08:34.423 - info: host.NUC(SmartHome1) iobroker NPM version: 6.14.11
                  2021-03-07 21:08:34.426 - info: host.NUC(SmartHome1) iobroker npm install ioBroker/ioBroker.zigbee#master --loglevel error (System call)
                  2021-03-07 21:17:53.521 - info: host.NUC(SmartHome1) iobroker upload [250] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/sylvania_rt.png img/sylvania_rt.png image/png
                  2021-03-07 21:17:57.802 - info: host.NUC(SmartHome1) iobroker upload [200] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                  2021-03-07 21:18:01.968 - info: host.NUC(SmartHome1) iobroker upload [150] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/lumi_remote_b286opcn01.png img/lumi_remote_b286opcn01.png image/png
                  2021-03-07 21:18:06.186 - info: host.NUC(SmartHome1) iobroker upload [100] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ikea_open_close_switch.png img/ikea_open_close_switch.png image/png
                  2021-03-07 21:18:06.967 - info: host.NUC(SmartHome1) iobroker upload [90] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27.png img/ikea_bulb_E27.png image/png
                  2021-03-07 21:18:07.827 - info: host.NUC(SmartHome1) iobroker upload [80] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/hs1sa.png img/hs1sa.png image/png
                  2021-03-07 21:18:08.639 - info: host.NUC(SmartHome1) iobroker upload [70] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/gq8b1uv.png img/gq8b1uv.png image/png
                  2021-03-07 21:18:09.437 - info: host.NUC(SmartHome1) iobroker upload [60] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/fnb56zsw01.png img/fnb56zsw01.png image/png
                  2021-03-07 21:18:10.374 - info: host.NUC(SmartHome1) iobroker upload [50] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ewelink_DS01.png img/ewelink_DS01.png image/png
                  2021-03-07 21:18:11.218 - info: host.NUC(SmartHome1) iobroker upload [40] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                  2021-03-07 21:18:12.062 - info: host.NUC(SmartHome1) iobroker upload [30] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                  2021-03-07 21:18:12.843 - info: host.NUC(SmartHome1) iobroker upload [20] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_motion_a.png img/bitron_motion_a.png image/png
                  2021-03-07 21:18:12.922 - info: host.NUC(SmartHome1) iobroker upload [19] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                  2021-03-07 21:18:13.015 - info: host.NUC(SmartHome1) iobroker upload [18] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_AV2010_24A.png img/bitron_AV2010_24A.png image/png
                  2021-03-07 21:18:13.093 - info: host.NUC(SmartHome1) iobroker upload [17] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                  2021-03-07 21:18:13.187 - info: host.NUC(SmartHome1) iobroker upload [16] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_902010_29.png img/bitron_902010_29.png image/png
                  2021-03-07 21:18:13.281 - info: host.NUC(SmartHome1) iobroker upload [15] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
                  2021-03-07 21:18:13.374 - info: host.NUC(SmartHome1) iobroker upload [14] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
                  2021-03-07 21:18:13.468 - info: host.NUC(SmartHome1) iobroker upload [13] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
                  2021-03-07 21:18:13.546 - info: host.NUC(SmartHome1) iobroker upload [12] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/basiczbr3.png img/basiczbr3.png image/png
                  2021-03-07 21:18:13.624 - info: host.NUC(SmartHome1) iobroker upload [11] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                  2021-03-07 21:18:13.702 - info: host.NUC(SmartHome1) iobroker upload [10] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
                  2021-03-07 21:18:13.780 - info: host.NUC(SmartHome1) iobroker upload [9] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
                  2021-03-07 21:18:13.859 - info: host.NUC(SmartHome1) iobroker upload [8] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
                  2021-03-07 21:18:13.937 - info: host.NUC(SmartHome1) iobroker upload [7] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
                  2021-03-07 21:18:14.030 - info: host.NUC(SmartHome1) iobroker upload [6] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
                  2021-03-07 21:18:14.109 - info: host.NUC(SmartHome1) iobroker upload [5] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                  2021-03-07 21:18:14.187 - info: host.NUC(SmartHome1) iobroker upload [4] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                  2021-03-07 21:18:14.265 - info: host.NUC(SmartHome1) iobroker upload [3] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                  2021-03-07 21:18:14.374 - info: host.NUC(SmartHome1) iobroker upload [2] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
                  2021-03-07 21:18:14.468 - info: host.NUC(SmartHome1) iobroker upload [1] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                  2021-03-07 21:18:14.577 - info: host.NUC(SmartHome1) iobroker upload [0] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                  2021-03-07 21:18:15.752 - info: host.NUC(SmartHome1) iobroker exit 0
                  2021-03-07 21:18:17.710 - info: host.NUC(SmartHome1) Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                  2021-03-07 21:20:17.886 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" enabled
                  2021-03-07 21:20:17.919 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 started with pid 1136
                  2021-03-07 21:20:29.196 - info: zigbee.0 (1136) starting. Version 1.4.5 in C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
                  2021-03-07 21:20:30.002 - info: zigbee.0 (1136) Starting Zigbee npm ...
                  2021-03-07 21:20:31.126 - info: zigbee.0 (1136) Installed Version: ioBroker/ioBroker.zigbee#master
                  2021-03-07 21:20:32.927 - info: zigbee.0 (1136) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                  2021-03-07 21:20:32.936 - info: zigbee.0 (1136) --> transmitPower : normal
                  2021-03-07 21:20:32.945 - info: zigbee.0 (1136) Currently 21 devices are joined:
                  2021-03-07 21:20:32.983 - info: zigbee.0 (1136) 0x00124b0022265671 (addr 43125): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:32.986 - info: zigbee.0 (1136) 0x00124b0022e8f6bd (addr 15727): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2021-03-07 21:20:32.987 - info: zigbee.0 (1136) 0x00124b00226b164e (addr 44423): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2021-03-07 21:20:32.989 - info: zigbee.0 (1136) 0x00124b00223628f7 (addr 56025): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:32.990 - info: zigbee.0 (1136) 0x00124b002225ba8f (addr 17687): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:32.991 - info: zigbee.0 (1136) 0x00124b0022cd55b2 (addr 10549): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2021-03-07 21:20:32.992 - info: zigbee.0 (1136) 0x00124b0022265dd7 (addr 24577): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:32.992 - info: zigbee.0 (1136) 0x00124b002235e616 (addr 26415): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:32.993 - info: zigbee.0 (1136) 0x00124b002267004f (addr 57958): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:32.999 - info: zigbee.0 (1136) 0x00124b0022670bb3 (addr 40869): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:33.000 - info: zigbee.0 (1136) 0x00124b0022697ab6 (addr 16500): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:33.001 - info: zigbee.0 (1136) 0x00124b002266f956 (addr 25269): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:33.001 - info: zigbee.0 (1136) 0x00124b00226705f5 (addr 7257): SNZB-04 - SONOFF Contact sensor (EndDevice)
                  2021-03-07 21:20:33.002 - info: zigbee.0 (1136) 0x842e14fffe52ef2d (addr 62946): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                  2021-03-07 21:20:33.003 - info: zigbee.0 (1136) 0xec1bbdfffed3e561 (addr 23918): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                  2021-03-07 21:20:33.003 - info: zigbee.0 (1136) 0x00124b0022eb6fe7 (addr 62555): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2021-03-07 21:20:33.004 - info: zigbee.0 (1136) 0x00124b0022cf6d65 (addr 58236): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2021-03-07 21:20:33.004 - info: zigbee.0 (1136) 0x00124b0022cf77c1 (addr 3866): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2021-03-07 21:20:33.005 - info: zigbee.0 (1136) 0x00124b0022cd397d (addr 7782): SNZB-03 - SONOFF Motion sensor (EndDevice)
                  2021-03-07 21:20:33.006 - info: zigbee.0 (1136) 0x000d6f0011b41cb0 (addr 55765): 4058075816459 - OSRAM Smart+ switch (EndDevice)
                  2021-03-07 21:20:33.006 - info: zigbee.0 (1136) 0x5c0272fffec57d1e (addr 57018): Not supported (model TS0601)(EndDevice)
                  2021-03-07 21:20:33.006 - info: zigbee.0 (1136) Zigbee started
                  2021-03-07 21:20:33.130 - error: zigbee.0 (1136) Device 0x5c0272fffec57d1e "TS0601" not described in statesMapping.
                  2021-03-07 21:21:10.084 - info: zigbee.0 (1136) Zigbee: allowing new devices to join.
                  2021-03-07 21:21:11.165 - warn: zigbee.0 (1136) Device '0x5c0272fffec57d1e' announced itself
                    @flitze-fitz einz nach dem anderen..
                    du hast ein cc2531... jetzt ist die frage ob der tuya nicht zigbee3 ist.. wenn doch dann hast du ein Problem.. das wird nicht gehen mit deinem Stick
                    hast mal ein Bild von dem Teil ... wo hast du es gekauft,, Link ??
                      @arteck
                      Das Thermostat hab ich bei Amazon gekauft:
                      https://www.amazon.de/gp/product/B08M3LBMYP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                      Der Stick ist von ebay. Allerdings sind die Sonoff Geräte ja auch alle Zigbee 3 und die funktionieren ja, dann sollten andere Zigbee 3 Komponenten doch auch gehen oder sehe ich das falsch?
                      https://www.ebay.de/itm/CC2531-ZigBee-USB-Stick-zigbee2mqtt-ioBroker-FHEM-Xiaomi-SMA-Antenne/372933930792?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                      arteck Asgothian 2 Replies Last reply Reply Quote 0
                        @Asgothian ne idee ?? mir sind die gerade ausgegangen
                        • Asgothian
                          Asgothian Developer @flitze-fitz last edited by Asgothian
                          @flitze-fitz sagte in Galapara Thermostat / Zigbee / wird nicht konfiguriert:
                          • Dieser Thermostat kann prinzipiell unterstützt werden.
                          • Er ist bei zigbee2mqtt.io nicht als unterstützt gelistet.
                          • Es handelt sich um ein Tuya rebranded Thermostat. Da ist alles möglich.
                          Der wird ohne eine explizite Implementierung im Zigbee-Herdsman-Converters nicht funktionieren.
                          Das Fehler auftreten wenn er mit einem falschen Typ (TS0601) verbunden wird ist nicht weiter verwunderlich.
                          Nebenbei: Eine Suche bei Zigbee2mqtt.io nach TS0601 liefert 28 Geräte. Nur wenige davon sind Thermostate.
                          A.
                          Nachtrag: siehe auch Hier:https://forum.iobroker.net/topic/41439/closed-moes-zigbee-radiator-thermostat-aka-tuya?_=1615152678120 - da gab es schon einmal Diskussionen zu. Dieser Thermostat verhält sich nicht so wie die 'neueren' TuYa Thermostate.
                            flitze-fitz @Asgothian last edited by
                            @asgothian @arteck
                            Vielen Dank für eure Hilfe. Das klingt nicht so als wäre das ne kleine Sache. Also wahrscheinlich eher zurück mit dem Ding!?
                            Wisst ihr zufällig ein anderes Zigbee Heizkörperthermostat, dass mit dem Adapter auf jeden Fall funktioniert?
                            • Asgothian
                              @asgothian @arteck
                              Ich empfehle die Lektüre von https://www.zigbee2mqtt.io/information/supported_devices.html
                              Die dort hinterlegten Thermostate werden gehen. Es kann sein das bei einzelnen Funktionen im ioBroker noch Arbeit notwendig ist, das ist aber machbar.
                              A.
                              zigbee thermostat
                              1931
