    4. [ Geklärt ] Problem bei Influx Installation
      Altersrentner @wendy2702 last edited by
      @wendy2702 super Danke😊 👍
        @wendy2702
        Es erscheint wieder ein Error bei Grafana
        DEBUG] [grafana] - Start Grafana Backup ...
        [DEBUG] [grafana] - Created grafana_tmp directory
        [DEBUG] [grafana] - Created dashboard directory
        [DEBUG] [grafana] - Created dashboards_manually_restore directory
        [DEBUG] [grafana] - Created datasource directory
        [DEBUG] [grafana] - start Grafana request ...
        [DEBUG] [grafana] - Grafana is available ... Status: 200
        [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
        [DEBUG] [grafana] - start Grafana backup compress ...
        [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        [DEBUG] [grafana] - cannot found Grafana Backup files
        [DEBUG] [grafana] - done
        [DEBUG] [cifs] - done
        [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_08_53_influx grafana_backupiobroker.tar.gz...
          crunchip Forum Testing Most Active @Altersrentner last edited by
          @altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
          Falschen Benutzerdaten oder Api-Key falsch
          Grafana ist erreichbar (siehe Status 200)
          A 2 Replies Last reply Reply Quote 0
            Altersrentner @crunchip last edited by
            @crunchip
            Danke, habe jetzt beim Host die IP eingestellt
            und ein neuer Versuch
              @crunchip
              Started iobroker ...
              [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
              [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
              Unable to find suitable address.
              [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
              [DEBUG] [iobroker] - host.raspberrypi 14084 states saved
              [DEBUG] [iobroker] - host.raspberrypi 16331 objects saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz
              [DEBUG] [iobroker] - done
              [DEBUG] [influxDB] - Start InfluxDB Backup ...
              [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
              [DEBUG] [influxDB] - Packed 15MB so far...
              [DEBUG] [influxDB] - Packed 47MB so far...
              [DEBUG] [influxDB] - Packed 79MB so far...
              [DEBUG] [influxDB] - Packed 149MB so far...
              [DEBUG] [influxDB] - Packed 235MB so far...
              [DEBUG] [influxDB] - Packed 313MB so far...
              [DEBUG] [influxDB] - Packed 405MB so far...
              [DEBUG] [influxDB] - Packed 481MB so far...
              [DEBUG] [influxDB] - Packed 562MB so far...
              [DEBUG] [influxDB] - Packed 646MB so far...
              [DEBUG] [influxDB] - Packed 727MB so far...
              [DEBUG] [influxDB] - Packed 817MB so far...
              [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz
              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
              [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
              [DEBUG] [influxDB] - done
              [DEBUG] [grafana] - Start Grafana Backup ...
              [DEBUG] [grafana] - found Dashboard: n1-aussen-wz
              [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2021_03_07-19_42_25_backupiobroker.tar.gz
              [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz...
              [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz...
              Ich glaube jetzt hat es geklappt👍 oder👎
                @altersrentner sieht so aus, grafana und influx, dein cifs hast aber noch aktiv(was du ja nicht nutzt), also Haken noch raus bei Nas.
                aber deine Backups sind gemacht
                musst nur dran denken, das du bei deiner SSD Influx und Grafana installiert haben musst um das backup ein zu spielen
                  @crunchip OK
                  wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                  source /etc/os-release
                  echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                  sudo apt update
                  sudo apt install -y influxdb
                  sudo systemctl unmask influxdb.service
                  sudo systemctl start influxdb.service
                  sudo systemctl enable influxdb.service
                  Damit installiere ich Influx.
                  Kannst Du mir bitte noch den Code für Grafana mitteilen?
                  Mit freundlichen Grüßen
                  Michael
                    @altersrentner
                    apt-Schlüssel zufügen
                    wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                    grafana repository hinzufügen
                    echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
                    installieren
                    sudo apt-get update
                    sudo apt-get install -y grafana
                    aktivieren und starten
                    sudo /bin/systemctl enable grafana-server
                    sudo /bin/systemctl start grafana-server
                    aufrufen dann über http://<ip address>:3000
                    Name und Kennwort ist standard
                    admin
                    admin
                      @crunchip D A N K E !
                      Michael
                        @crunchip Hallo,
                        Die neue SSD ist angeschlossen.
                        ioBroker läuft,
                        InfluxDB ist wieder hergestellt,
                        Influx Adapter ist grün,
                        Grafana ist wieder hergestellt,
                        API Key ist eingegeben
                        In vis kommt bei den Graphen die Meldung:
                        IP hat Verbindung abgelehnt.
                        Wenn ich Grafana öffne erscheinen meine angelegten
                        Dashboards nicht.
                        Gibt es eine Möglichkeit sie zu finden?
                        Ist das Protokoll so ok?
                        Michael
                          crunchip Forum Testing Most Active @Altersrentner last edited by crunchip
                          du meinst bei der Einbindung eines Dashboards in vis? dein Rechner hat ja nun ne neue Ip oder? Dann stimmt ja der Pfad nicht mehr(IP).
                          in deinem Screen, sofern ichs richtig entziffern kann, steht dein api key, bez. Nutzername/Passwort falsch
                          du musst auch wieder die Grafana.ini bearbeiten
                          sudo nano /etc/grafana/grafana.ini
                          dort musst du folgende Einträge anppassen(ebenfalls das ; vor jeder dieser Zeilen entfernen, damit dies aktiv werden
                          orgName musst du natürlich mit deinem ersetzen
                          [security]
                          allow_embedding = true
                          [auth.anonymous]
                          enabled = true
                          org_name = Main Org.
                          org_role = Viewer
                          [users]
                          allow_sign_up = false
                          anschliesssend grafana-server neustarten
                          sudo service grafana-server restart
                          A 3 Replies Last reply Reply Quote 0
                            @crunchip sagte in [ Geklärt ] Problem bei Influx Installation:
                            Neindie IP ist geblieben. Benutzer und Passwort solten auch richtig sein..
                            Ich stecke nochmal die alte FP an. Mal sehen ob ich was finde
                            MfG Michael
                              @crunchip
                              Bei mir steht ei Semikolon vor.
                              Bleibt das stehen?
                                @crunchip
                                Die ini ist bearbeitet
                                DEBUG] [grafana] - Start Grafana Restore ...
                                [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2021_03_08-02_18_32_backupiobroker.tar.gz
                                [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
                                [DEBUG] [grafana] - start decompress
                                [DEBUG] [grafana] - Grafana request started
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
                                [DEBUG] [grafana] - datasoure restore "InfluxDB-1" finish: {"datasource":{"id":2,"uid":"s1r54cgRz","orgId":1,"name":"InfluxDB-1","type":"influxdb","typeLogoUrl":"","access":"proxy","url":"http://192.168.178.41:8086","password":"","user":"admin","database":"iobroker","basicAuth":false,"basicAuthUser":"","basicAuthPassword":"","withCredentials":false,"isDefault":false,"jsonData":{"httpMode":"GET"},"secureJsonFields":{},"version":1,"readOnly":false},"id":2,"message":"Datasource added","name":"InfluxDB-1"}
                                [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/n1-aussen-wz.json
                                [DEBUG] [grafana] - cannot restore dashboard "n1-aussen-wz": {"message":"invalid API key"}
                                [DEBUG] [grafana] - Grafana request ended
                                [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
                                [DEBUG] [grafana] - Grafana Restore completed successfully
                                [EXIT] Grafana restore done
                                Da stehen die Daten:
                                irgend etwas stimmt noch nicht
                                  @altersrentner laut deinem log
                                  • hast du ne InfluxDB.json und eine InfluxDB.json1, InfluxDB.json existiert aber scheinbar schon
                                  • für n1-aussen-wz.json stimmt scheinbar dein api key nicht
                                  ich bin da nicht so fit drin, da ich diese backup Funktion via backitup nicht verwende
                                  du hast doch ein backup von Grafana erstellt grafana_2021_03_07-19_42_25_backupiobroker.tar.gz und dieses muss zurückgespielt werden.
                                  was beinhaltet dieses backup?
                                    @crunchip
                                    Das Backup habe ich schon mehrmals zurückgespielt.
                                    Es ist von der alten Platte .
                                    Habe mir jetzt das Skript aus Grafana der alten Platte geladen
                                      "datasource": "InfluxDB-1",
                                      "aliasColors": {
                                        "Temperatur Wohnzimmer": "rgb(221, 176, 63)"
                                      "bars": false,
                                      "dashLength": 10,
                                      "dashes": false,
                                      "decimals": 1,
                                      "fill": 1,
                                      "fillGradient": 0,
                                      "gridPos": {
                                        "h": 9,
                                        "w": 12,
                                        "x": 12,
                                        "y": 0
                                      "hiddenSeries": false,
                                      "id": 4,
                                      "legend": {
                                        "avg": false,
                                        "current": true,
                                        "max": true,
                                        "min": true,
                                        "show": true,
                                        "total": false,
                                        "values": true
                                      "lines": true,
                                      "linewidth": 1,
                                      "nullPointMode": "null",
                                      "options": {
                                        "dataLinks": [
                                            "title": "",
                                            "url": ""
                                      "percentage": false,
                                      "pointradius": 2,
                                      "points": false,
                                      "renderer": "flot",
                                      "seriesOverrides": [
                                          "alias": "Außentemperatur",
                                          "fill": 3,
                                          "fillGradient": 0,
                                          "yaxis": 1
                                          "alias": "Temperatur Wohnzimmer",
                                          "yaxis": 1
                                          "alias": "Power",
                                          "yaxis": 2
                                      "spaceLength": 10,
                                      "stack": false,
                                      "steppedLine": false,
                                      "targets": [
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "measurement": "mihome.0.devices.weather_v1_158d00023213f6.temperature",
                                          "orderByTime": "ASC",
                                          "policy": "default",
                                          "refId": "A",
                                          "resultFormat": "time_series",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                          "alias": "Temperatur Heizkessel",
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "measurement": "fhem.0.Temp_Heizkessel.temperature",
                                          "refId": "B",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                          "alias": "Temperatur Puffer",
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "measurement": "hm-rpc.0.OEQ0673599.2.TEMPERATURE",
                                          "refId": "C",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                          "alias": "Power",
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "measurement": "shelly.0.SHSW-PM#8CAAB542C16C#1.Relay0.Power",
                                          "refId": "E",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                      "thresholds": [],
                                      "timeFrom": null,
                                      "timeRegions": [],
                                      "timeShift": null,
                                      "title": "Temperatur Außen  / Temperatur Kessel /Temperatur Puffer9 / KesselStatus",
                                      "tooltip": {
                                        "shared": true,
                                        "sort": 0,
                                        "value_type": "individual"
                                      "type": "graph",
                                      "xaxis": {
                                        "buckets": null,
                                        "mode": "time",
                                        "name": null,
                                        "show": true,
                                        "values": []
                                      "yaxes": [
                                          "decimals": 1,
                                          "format": "celsius",
                                          "label": null,
                                          "logBase": 1,
                                          "max": null,
                                          "min": null,
                                          "show": true
                                          "decimals": 1,
                                          "format": "watt",
                                          "label": null,
                                          "logBase": 1,
                                          "max": null,
                                          "min": null,
                                          "show": true
                                      "yaxis": {
                                        "align": false,
                                        "alignLevel": null
                                    Kann man das einbinden?
                                    MfG Michael
                                    crunchip 2 Replies Last reply Reply Quote 0
                                      @altersrentner ist das dein einziges Dashboard? Ja das kann man einfügen.
                                      Auf deiner Grafana Seite, links auf das +,dann Import
                                      unterhalb von Import via panel json, kannst du es einfügen.
                                      dann ist es ja scheinbar schon vorhanden. Schau doch mal unter folgendem Pfad was du so findest
                                      var/lib/grafana
                                        @altersrentner ansonsten, wenn es speziell um's Backup geht, könntest du dort mal nachfragen
                                          @crunchip Guten Morgen,
                                          Hier ist auch die heutige eingefügte grafanaDB zu sehen.
                                          Nur es gibt keine graphische Darstellung.
                                          Michael
                                            Lässt sich das Dashboard nicht öffnen, oder ist leer?
                                            influxdb
                                            12
                                            178
                                            33083
