    4. SayIt - Ausgabe bei Wetterwarnung (DWD)
    • Bluefox
      Bluefox last edited by
      @baluderbär:
      Hallo Pix,
      hab es nun abgeändert in:
      ` > var idSayIt = "sayit.0.tts.text";
      var Severity = "dwd.0.warning.severity"/Warning severity/;
      on(Severity, function (obj) {
      if (obj.newState.val !==0) {
      var Begin = getState("dwd.0.warning.begin"/Warning begin/).val;
      var End = getState("dwd.0.warning.end"/Warning end/).val;
      var Headline = getState("dwd.0.warning.headline"/Warning headline/).val;
      var Description = getState("dwd.0.warning.description"/Warning description/).val;
      setState (idSayIt, "Achtung Wetterwarnungen " + Headline + " gültig vom " + Begin + " bis " + End + ': ' + Description);
      if (obj.newState.val === 0) {
      setState(idSayIt, "Alle Wetterwarnungen des Deutschen Wetterdienstes wurden aufgehoben") ;
      Log ("Achtung Wetterwarnungen " + Headline + " gültig vom " + Begin + " bis " + End + ': ' + Description);
      Jetzt erhalte ich im Log folgendes:
      19:17:18.192 [info] javascript.0 Stop script script.js.common.DWD_sayit
      19:17:18.213 [info] javascript.0 Start javascript script.js.common.DWD_sayit
      19:17:18.214 [info] javascript.0 script.js.common.DWD_sayit: registered 1 subscription and 0 schedules
      19:17:55.558 [error] host. ReferenceError: Log is not defined at Object. (script.js.common.DWD_sayit:15:5) at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1251:48) at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:571:48 at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3018:17) at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3037:28) at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:567:17) at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:245:17) at that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2120:37) at RedisClient. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:88:25) at emitThree (events.js:97:13) at RedisClient.emit (events.js:175:7) `
      log muss man klein schreiben
        baluderbär last edited by
        Hallo bluefox, danke.
        Zwar funktioniert nun die LOG-Ausgabe, jedoch höre ich immer noch nicht alles.
        sayit-0 2016-10-05 20:06:33.149 info saying: Achtung Wetterwarnungen gültig vom 05.10.2016 20:00 bis 06.10.2016 20:00:
        Datum wird immer noch falsch vorgelesen. Headline und Description fehlen.
        Sobald die Meldung verschwindet erscheint folgendes im LOG:
        __sayit-0 2016-10-05 20:09:57.632 info saying: Alle Wetterwarnungen des Deutschen Wetterdienstes wurden aufgehoben
        host-ioBroker-Pi 2016-10-05 20:09:55.132 info instance system.adapter.dwd.0 terminated with code 0 (OK)
        sayit-0 2016-10-05 20:09:54.627 info saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
        javascript-0 2016-10-05 20:09:54.621 info script.js.common.DWD_sayit: Achtung Wetterwarnungen undefined gültig vom undefined bis undefined: undefined
        dwd-0 2016-10-05 20:09:54.352 info starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.dwd__
        Gruß Balu
        • Bluefox
          Ich glaube google hat Begrenzung auf 80 oder 100 Symbole.
            Hallo BlueFox,
            evtl. liegt es daran. Habe mal versucht, anstatt Headline Description zu nehmen und es hat funktioniert.
            Bleibt nur das Problem mit dem Datum, dass es falsch vorgelesen wird. Monat und Tag vertauscht.
            05.10. wird als 10. Mai vorgelesen und 06.10. wird als 10. Juni vorgelesen.
            Woran kann das liegen?
            Gruß Balu
              cybertron last edited by
              Abweichend vom Grundthema , mal die Frage, worauf läuft bei Euch Sayit und worüber lässt ihr die Ausgabe laufen ( z.b. Raspberry interner Sound, Raspi USB-Sound…)
              Silvio
              • Bluefox
                @baluderbär:
                Hallo BlueFox,
                Gruß Balu `
                Da jedes Text2Speech System unterschiedlich das Datum vorliegt, darfst du nicht erwarten, dass dein Datum richtig vorgelesen wird. Du musst schon mit formatDate das Datum so vorbereiten, wie es System haben will.
                https://github.com/ioBroker/ioBroker.ja … formatdate
                  Semenchkare last edited by
                  ich habe ebenfalls das Problem, dass mir sayit zwar läuft, aber eben alles ohne description, headline oder Text ansagt:
                  sayit-2	2016-10-28 23:43:17.221	info	saying: Wetterwarnungen : gültig vom 28.10.2016 20:15 bis 29.10.2016 10:00:
                  sayit-1	2016-10-28 23:43:15.201	info	saying: Wetterwarnungen : gültig vom 28.10.2016 20:15 bis 29.10.2016 10:00:
                  host-bananapim2	2016-10-28 23:43:14.678	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                  sayit-2	2016-10-28 23:43:14.208	info	saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
                  sayit-1	2016-10-28 23:43:14.196	info	saying: /opt/iobroker/node_modules/iobroker.sayit/scifi.mp3
                  javascript-0	2016-10-28 23:43:14.113	info	script.js.Sayit.DWD: Wetterwarnungen gültig vom 28.10.2016 20:15 bis 29.10.2016 10:00:
                  dwd-0	2016-10-28 23:43:13.742	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.dwd
                  host-bananapim2	2016-10-28 23:43:10.541	info	instance system.adapter.dwd.0 started with pid 2598
                  host-bananapim2	2016-10-28 23:43:10.496	info	instance scheduled system.adapter.dwd.0 3 * * * *
                  hier mein script. Habe 2 Instanzen von sayit am laufen, eine via browser, andere via m24player mit ftpserver.
                  Grundsätzlich läuft sayit. es sieht für mich so aus, dass die Variablen für description, headline oder von mir zugefügtem "text" übergeben werden.
                  Gegen die Version mit den 70 Buchstaben spricht:
                  1. müsste dann gar kein Text kommen.
                  2. müsste die LOG die Inhalte aller Variablen anzeigen, Tatsächlich aber nur Beginn und Ende zusätzlich zum fixen Text.
                  Natürlich habe ich auch mal Description und Headline weggelassen und es stattdessen mit "Text", der ultrakurzen Variante probiert.
                  Immer wieder nur Ansage:
                  "Wetterwarnungen : gültig vom 28.10.2016 20:15 bis 29.10.2016 10:00"
                  hier das -leicht abgeänderte und hoffentlich keine Fehler enthaltende- Skript
                  var idSayIt = "sayit.1.tts.text";
                  var idSayIt2 = "sayit.2.tts.text";
                  var Severity = "dwd.0.warning.severity"/*Warning severity*/;
                  var Begin = getState("dwd.0.warning.begin"/*Warning begin*/).val;
                  var End = getState("dwd.0.warning.end"/*Warning end*/).val;
                  var text = getState("dwd.0.warning.text"/*Warning text*/).val;
                  var Headline = getState("dwd.0.warning.headline"/*Warning headline*/).val;
                  var Description = getState("dwd.0.warning.description"/*Warning description*/).val;
                  setState (idSayIt, "Wetterwarnungen " + ': ' + " gültig vom " + Begin + " bis " + End + ': ' + Description);
                  setState (idSayIt2, "Wetterwarnungen " + ': ' + text + " gültig vom " + Begin + " bis " + End + ': ' + Description);
                  //setState (idSayIt2, "Achtung Wetterwarnungen " + Headline + " gültig vom " + Begin + " bis " + End + ': ' + Description);
                  setState(idSayIt, "de;80;Alle Wetterwarnungen des Deutschen Wetterdienstes wurden aufgehoben") ;
                  setState(idSayIt2, "de;80;Alle Wetterwarnungen des Deutschen Wetterdienstes wurden aufgehoben") ;
                  //log ("Achtung Wetterwarnungen " + Headline + " gültig vom " + Begin + " bis " + End + ': ' + Description);
                  log ("Wetterwarnungen " + text + " gültig vom " + Begin + " bis " + End + ': ' + Description)
                  Daten sind vorhanden, ich teste ständig im Wechsel von zwei Landkreisen. Die Entwarnung wird problemlos gesprochen.
                  ![](</s><URL url=)http://www.joe-lion.de/old/dwd.JPG" />
                  • N
                    Nordlicht last edited by
                    @Semenchkare:
                    >! hier mein script. Habe 2 Instanzen von sayit am laufen, eine via browser, andere via m24player mit ftpserver.
                    >! Grundsätzlich läuft sayit. es sieht für mich so aus, dass die Variablen für description, headline oder von mir zugefügtem "text" übergeben werden.
                    >! Gegen die Version mit den 70 Buchstaben spricht:
                    >! 1\. müsste dann gar kein Text kommen.
                    >! 2\. müsste die LOG die Inhalte aller Variablen anzeigen, Tatsächlich aber nur Beginn und Ende zusätzlich zum fixen Text.
                    >! Natürlich habe ich auch mal Description und Headline weggelassen und es stattdessen mit "Text", der ultrakurzen Variante probiert.
                    >! Immer wieder nur Ansage:
                    >! "Wetterwarnungen : gültig vom 28.10.2016 20:15 bis 29.10.2016 10:00"
                    >! hier das -leicht abgeänderte und hoffentlich keine Fehler enthaltende- Skript
                    >! on(Severity, function (obj) {
                    >! setState (idSayIt, "Wetterwarnungen " + ': ' + " gültig vom " + Begin + " bis " + End + ': ' + Description);
                    ![](</s><URL url=)http://www.joe-lion.de/old/dwd.JPG" /> ` ~~Hi Semenchkare,
                    nach dem Du hier schon relativ weit gekommen bist eine Frage….
                    werden bei Dir auch manchmal Teile eines Satzes am Ende einfach abgeschnitten /(verschluckt)?
                    z.B. "Amtliche Warnung vor Stur" anstelle von "Amtliche Warnung vor Sturmböen"
                    Hast Du hierzu eventuell Erkenntnisse woran es liegen kann?
                    Thomas~~
                      leider nein. die Beschreibung spricht mir die Google-Tante nicht.
                      und Ivona bekomme ich auch mit Zertifikat nicht zum laufen.
                      LG Seme
                      • wendy2702
                        wendy2702 last edited by
                        ich hatte auch am Anfang ein kleines Problem mit Ivony.
                        Bei mir lag es am kopieren des Access und Secret keys.
                        Auf der Ivony Seite exact die keys markiert und im SayIt Adapter wurde trotzdem beim Einfügen noch ein leerzeichen davor gesetzt.
                        Nachdem ich das gefunden hatte klappte die Ansage bei mir.
                        An den Rot markierten Pfeilen war bei mir jeweils ein leerzeichen
                        Mirko
                          derrapf last edited by
                          Hallo alle
                          Habe auch gekämpft.
                          Vernünftige Ansagen bekommt man nur mit Ivona, da die google API bei 72 Zeichen Schluss macht.
                          D.h. längere Sätze werden erst gar nicht ausgegeben.
                          Gruss Ralf
                          • wendy2702
                            Wie habt ihr das Gelöst damit die Ansagen nicht Nachts gemacht werden?
                            Oder ändert der DWD den Status in der Nacht nicht?
                            • N
                              @wendy2702:
                              Oder ändert der DWD den Status in der Nacht nicht? `
                              Hi Mirko,
                              ich habe die Aktualisierung (Cron) des Adapters so eingestellt, dass nachts keine Daten geholt werden.
                              18 6-22 * * *
                              Damit ist dann Ruhe.
                              Thomas
                              • wendy2702
                                Also holt der DWD Adapter keine Upates im Zeitraum 6-22 Uhr.
                                Hm,
                                weißt du ob es auch ne Möglichkeit gibt nur die Ansage zu verhindern?
                                Mir wäre es lieber der DWD Adapter wäre ständig aktuell und nur die Ansage setzt aus.
                                • N
                                  @wendy2702:
                                  Hm,
                                  Mir wäre es lieber der DWD Adapter wäre ständig aktuell und nur die Ansage setzt aus. `
                                  Von 6-22 Uhr wird aktualisiert, von 22-6 Uhr dann nicht.
                                  Leider nein, so gut bin ich bei ioBroker noch nicht und Lösungen habe ich hier noch nicht gefunden.
                                  Deswegen mache ich es bisher so, besser als nachts nicht nur durch den Sturm geweckt zu werden sondern auch noch von ioBroker :mrgreen:
                                  • wendy2702
                                    OK.
                                    Mache das jetzt auch erstmal so.
                                      Hi
                                      Ich hab das so gemacht:
                                      Die Unter-Routine bekommt eine Zeitdauer in Minuten übergeben in welchem Abstand die Meldung wiederholt werden soll. 0 heisst keine Wiederholung.
                                      Dazu legt sie einen Timer, abhängig von der id mit der getriggert wurde, an. Der wird zurückgesetzt, wenn sich der Triggerwert
                                      so ändert, dass nichts mehr gesagt oder was anderes gesagt werden muss.
                                      Die Routine bestimmt die Tageszeit und sagt zwischen 11 und 9 nichts. Damit ich auch nachts testen kann gibt es eine debug Variable die man dann auf true setzen kann. Dann wird immer geredet.
                                      // --------------------------------------Unterprogramme --------------------------------
                                      function saySomething(idGeraet, text, zeit)
                                         var zeitms = zeit *60*1000;
                                         var wiederholung = true;
                                         if (zeit ===  0) {
                                             wiederholung = false;
                                         // Sage zum ersten Mal
                                         var d = new Date ();
                                         var h = d.getHours();
                                         if (debug || (h < 23) && (h > 9)) // nur zwischen 9 und 23 Uhr
                                            log('attempt Saying: ('+zeitms+"):" + text);
                                           if (wiederholung) {
                                             if (timer[idGeraet] === null) {
                                               log('Saying every:'+zeitms+" ms:"+text);
                                               timer[idGeraet] = setInterval(function() {
        log('Repeated Saying:'+text);
        setState(idSprache, text);
        }, zeitms);
                                             } else {
                                               log('timer ['+idGeraet+'] already set.');
                                           } else {
                                             log('Saying nly once:'+text);
                                         else
                                             log("Not saying anything, because it's too late");
                                      Gruss Ralf
                                      • wendy2702
                                        Danke!
                                        Allerdings habe ich nicht viel Kenntnis von Javascript.
                                        Hast du das direkt in das Ansagescript gepackt?
                                          Hi
                                          Ich warte bis sich die description des Datenpunkts ändert:
                                          Du kannst in IOBroker ja mal ein Script anlegen und das hier unten reinkopieren.
                                          Ich hoffe es läuft. Ist nur ein Ausschnitt aus meinem Gesamtkunstwerk.
                                          Gruss Ralf
                                          var idSprache        = 'sayit.0.tts.text';       // Sprachausgabe Browser
                                          var idDWD            = 'dwd.0.warning.description'; //Warning description
                                          var timer = {};
                                          var debug = false;
                                          on(idDWD, function(obj) {
                                                log("trigger DWD-Meldung:" + obj.newState.val);
                                                var description = obj.newState.val;
                                                if (description !== "") {
                                                    log("aktuell DWD-Meldung:" + description);
                                                    log("alt     DWD-Meldung:" + obj.oldState.val);
                                                    if (description !== obj.oldState.val) {
                                                        log("Meldung geändert -> Timer clear");
                                                        if (timer[idDWD] !== null) { clearInterval(idDWD); timer[idDWD] = null; }
                                                    var headline = getState("dwd.0.warning.headline"/*Warning headline*/).val;
                                                    var message = headline +". "+description;
                                                    var headline2 = getState("dwd.0.warning1.headline").val+". ";
                                                    log("Headline2:"+headline2);
                                                    var description2 = getState("dwd.0.warning1.description").val+".";
                                                    log("description2:"+description2);
                                                    message = message + ". "+ headline2 + description2 +". ";
                                                    log("-->DWD-Meldung" + message);
                                                    saySomething(idDWD, message, 60); //alle 60 min wiederholen
                                                } else {
                                                    log("clear DWD-Meldung");
                                             if (zeit ===  0) {
                                               if (wiederholung) {
                                                 log ("Timer= " + timer[idGeraet] !== null);
        }, zeitms);
                                                 } else
                                               } else {
                                                 log('Saying once:'+text);
                                             else
                                                 log("Not Saying because it's too late");
                                            Habe gerade einen Fehler bemerkt.
                                            So müsste es richtiger sein:
                                               if (zeit ===  0) {
                                                 if (wiederholung) {
        }, zeitms);
                                                   } else
                                                 } else {
                                               else
                                            Gruss Ralf
                                            40
                                            5452
