    4. Forecast.solar mit dem Systeminfo Adapter
    • JB_Sullivan
      JB_Sullivan @Gargano last edited by
      @gargano
      const SolarJSON1        = "javascript.0.SolarForecast.JSON1";
      const SolarJSON2        = "javascript.0.SolarForecast.JSON2";
      const SolarJSONAll1        = "javascript.0.SolarForecast.JSONAll1";
      const SolarJSONAll2        = "javascript.0.SolarForecast.JSONAll2";
      const SolarJSONGraphAll1        = "javascript.0.SolarForecast.JSONGraphAll1";
      const SolarJSONGraphAll2        = "javascript.0.SolarForecast.JSONGraphAll2";
      const SolarJSONTable    = "javascript.0.SolarForecast.JSONTable";
      const SolarJSONGraph    = "javascript.0.SolarForecast.JSONGraph";
      const creatStateList = [
          {name :SolarJSON1, type:"string", role : "value"},
          {name :SolarJSON2, type:"string", role : "value"},
          {name :SolarJSONAll1, type:"string", role : "value"},
          {name :SolarJSONAll2, type:"string", role : "value"},
          {name :SolarJSONGraphAll1, type:"string", role : "value"},
          {name :SolarJSONGraphAll2, type:"string", role : "value"},
          {name :SolarJSONTable, type:"string", role : "value"},
          {name :SolarJSONGraph, type:"string", role : "value"}
      creatStateList.forEach (function(item) {
          createState(item.name, {
              type: item.type,
              min: 0,
              def: 0,
              role: item.role
      var request = require('request');
      var options1 = {url: 'https://api.forecast.solar/estimate/xx.35/xx.24/40/90/7.26', method: 'GET', headers: { 'User-Agent': 'request' }};
      var options2 = {url: 'https://api.forecast.solar/estimate/xx.35/xx.24/40/-90/2.64', method: 'GET', headers: { 'User-Agent': 'request' }};
      var urls = [
        {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},
        {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2}
      var promises = urls.map(myAsyncRequest);
      schedule('6 6-22 * * *', getSolar);
      getSolar();
      function myAsyncRequest(myUrl) {
        log('Request '+myUrl.myUrl.url);
        return new Promise((resolve, reject) => {
           request(myUrl.myUrl.url, function(error, response, body) {
              if (!error && response.statusCode == 200) {
                  let today = formatDate(new Date(), 'YYYY-MM-DD');
                  let watts = JSON.parse(body).result.watts;
                  setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);
                  let table = [];
                  for(let time in watts) {
                      let pos = time.indexOf(':00:00');
                      if(pos != -1) {
                          let entry = {};
                          entry.Uhrzeit = time;
                          entry.Leistung = watts[time];
                          table.push(entry);
                  log ('JSON: '+myUrl.mySolarJSON);
                  setState(myUrl.mySolarJSON, JSON.stringify(table), true);
              // make GraphTable
                  let graphTimeData = [];
                          let graphEntry ={};
                          graphEntry.t = Date.parse(time);
                          graphEntry.y = watts[time];
                          graphTimeData.push(graphEntry);
                  var graph = {};
                  var graphData ={};
                  var graphAllData = [];
                  graphData.data = graphTimeData;
                  graphAllData.push(graphData);
                  graph.graphs=graphAllData;
                  setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);
                  resolve (body);
      function makeTable () {
          log ('MakeTable');
          let watts1 = JSON.parse(getState(SolarJSON1).val);
          let watts2 = JSON.parse(getState(SolarJSON2).val);
          log ('Items: '+watts1.length);
          let table = [];
          for(var n=0;n<watts1.length;n++) {
                  let entry = {};
                  let graphEntry ={};
                  let thisTime = watts1[n].Uhrzeit;
                  log (thisTime);
                  entry.Uhrzeit = watts1[n].Uhrzeit;
                  entry.Leistung1 = watts1[n].Leistung;
                  entry.Leistung2 = watts2[n].Leistung;
                  entry.Summe = watts1[n].Leistung + watts2[n].Leistung;
                  table.push(entry);
                  graphEntry.t = Date.parse(thisTime);
                  graphEntry.y = watts1[n].Leistung + watts2[n].Leistung;
          var graph = {};
          var graphData = {};
          var graphData = {"datalabel_rotation":-90,"datalabel_color":"lightgreen","datalabel_fontSize":10};
          setState(SolarJSONTable, JSON.stringify(table), true);
          setState(SolarJSONGraph, JSON.stringify(graph), true);
      function getSolar() {
        Promise.all(promises)
        .then(function(bodys) {
          console.log("All url loaded");
          makeTable();
      Gargano 1 Reply Last reply Reply Quote 0
      • Gargano
        Gargano @JB_Sullivan last edited by Gargano
        @jb_sullivan Du hast zweimal graphData als Variable in
        deklariert.
        Lösch mal die Zeile
        var graphData = {};
        JB_Sullivan 2 Replies Last reply Reply Quote 0
        • JB_Sullivan
          @gargano Achso - mache ich schnell wieder rein - moment
          • JB_Sullivan
            JB_Sullivan @Gargano last edited by JB_Sullivan
            @gargano sagte in Forecast.solar mit dem Systeminfo Adapter:
            Lösch mal die Zeile
            var graphData = {};
            OK, damit ist der Fehler aus Zeile 121 weg - ein fehler in Zeile 90 bleibt noch. Liegt bestimmt auch an meinen Drag & Drop "Künsten" 😉
            Im übrigen gibt es keine "makeResponse" - das hat mich sowieso gewundert.
                    type: item.type,
                    min: 0,
                    def: 0,
                    role: item.role
            var urls = [
            getSolar();
                        let table = [];
                            if(pos != -1) {
                                let entry = {};
                                table.push(entry);
                    // make GraphTable
                                let pos1 = time.indexOf(':00:00');
                                let pos2 = time.indexOf(':30:00');
                                if((pos1 != -1) || (pos2 != -1)) {
                                let graphEntry ={};
                        var graph = {};
                        var graphData ={};
                        resolve (body);
                log ('MakeTable');
                let table = [];
                        let entry = {};
                        let graphEntry ={};
                        log (thisTime);
                        table.push(entry);
                var graph = {};
                makeTable();
            • Gargano
              @jb_sullivan Da fehlt noch eine Klammer:
                                      let graphEntry ={};
                                  }  // -< die fehlt
              • JB_Sullivan
                @gargano Jupp - Fehler ist weg und in den Einzelgraphen wird auch die :30 gesetzt. Allerdings fehlt dieser Zeitraum dann in den Additiations Tabellen.
                jsonGraph & jsonTable
                • Gargano
                  @jb_sullivan Weiter oben Zeile 57 mußt Du noch das Gleiche machen
                                  if(pos != -1) {
                  ändern in
                                  if((pos1 != -1) || (pos2 != -1)){
                  Bei den Einzelgraphen brauchst Du eigentlich keine Abfrage der Zeit, da diese nur für die Synchronisation der Summenbildung benötigt wird. Zeile 72..74 kann entfallen, nicht vergessen wieder die Klammer unten zu entfernen.
                  • JB_Sullivan
                    @gargano
                    Auch das funktioniert jetzt 👍 - das wird ja immer perfekter 😉
                    Jetzt stellt sich mir nur noch eine Frage - in den Nachstunden wird es ja nachweislich nie zu PV Produktion kommen. Im Diagramm belegen diese Zeiten aber unnötigen Leerraum, was wiederum verhindert, das die Balken breiter und somit die Texte übersichtlicher daher kommen können.
                    Kann man den ganzen Zeitbereich der Darstellung (Ausgabe) evtl. noch irgendwie eingrenzen, sodaß die Tage nur von 6:00 - 21:30 dargestellt werden?
                    • Gargano
                      @jb_sullivan Antwort vom Scrounger :
                      Das ist leider so, die zeitachse wird immer optimal für den Zeitraum (start / ende) erstellt.
                      Geht nur mit eigenem Ertsellen der x -Achse Labels :
                          log ('MakeTable');
                          let table = [];
                         let axisLabels = [];
                         /*         let entry = {};
                                  let graphEntry ={};
                                  log (thisTime);
                                  table.push(entry);
                                 graphTimeData.push( watts1[n].Leistung + watts2[n].Leistung);
                                let time = watts1[n].Uhrzeit.substr(11, 12);
                                axisLabels.push(time);
                          var graph = {};
                          var graphData = {};
                          graph.axisLabels =  axisLabels;
                      • JB_Sullivan
                        @gargano
                        Kannst du nochmal den ganzen Code posten? Wenn ich diesen Code Schnippsel oben einfüge, wird mir an diversen Stellen wieder etwas als falsch unterstrichen ( Zeile 42,44,131,147)
                        • Gargano
                          Gargano last edited by Gargano
                          @jb_sullivan
                                  type: item.type,
                                  min: 0,
                                  def: 0,
                                  role: item.role
                          var urls = [
                          getSolar();
                                      let table = [];
                                                          let entry = {};
                                                          table.push(entry);
                                  // make GraphTable
                                              let graphEntry ={};
                                      var graph = {};
                                      var graphData ={};
                                      resolve (body);
                              log ('MakeTable');
                              let table = [];
                                      let entry = {};
                                      let graphEntry ={};
                                      log (thisTime);
                                      table.push(entry);
                          //            graphEntry.t = Date.parse(thisTime);
                          //            graphEntry.y = watts1[n].Leistung + watts2[n].Leistung;
                          //            graphTimeData.push(graphEntry);
                          			graphTimeData.push(watts1[n].Leistung + watts2[n].Leistung);
                                      let time = watts1[n].Uhrzeit.substr(11, 5);
                              var graph = {};
                              makeTable();
                          • JB_Sullivan
                            @gargano
                            Welche Version hat dein js-engine? Ich habe 5.0.12.
                            Mit dem Code wird mir Zeile 113 (watts3) unterstrichen, das dass falsch sein soll
                            javascript.0	2021-03-09 12:52:04.412	error	(3804) at process._tickCallback (internal/process/next_tick.js:68:7)
                            javascript.0	2021-03-09 12:52:04.411	error	(3804) at script.js.Solar.SolarForcast:133:5
                            javascript.0	2021-03-09 12:52:04.411	error	(3804) at makeTable (script.js.Solar.SolarForcast:113:65)
                            javascript.0	2021-03-09 12:52:04.408	error	(3804) script.js.Solar.SolarForcast: ReferenceError: watts3 is not defined
                            • Gargano
                              @jb_sullivan ja, wirf mal das watts3 raus:
                              Das ist von mir, ich benutze das um die Einstrahlung der Sonne in die Fenster zu schätzen und habe da 3 Seiten
                              • JB_Sullivan
                                @gargano
                                Schräg - sieht schon ziemlich gut aus - aber irgendwas ist ja immer 😲
                                Vorher fand ich die Time Line etwas aufgeräumter. Beim rüber hoovern mit der Maus bekommt man ja auch eine Legende mit Zeiten angezeigt. Von daher bedarf es für mich nicht unbedingt einer X-Achse mit allen Zeiten.
                                ALT:
                                NEU:
                                • Gargano
                                  @jb_sullivan Das macht der JsonChart von alleine.
                                  Schau mal in den Editor Porperties der x-Achse. Evtl. kannst Du da noch was einstellen. Oder ganz weglassen
                                  • JB_Sullivan
                                    @gargano
                                    Einfach über die Widget Konfiguration scheint es nur begrenzt zu gehen. Allerdings kann man da wohl wieder was mit Code tweaken erzwingen wenn man spezielle Zeitabschnitte (z.B. Tag) haben will - aber da bin ich wieder raus.
                                    EDIT: Ich sehe gerade die json Tabelle gibt es mit dem neuen Code nicht mehr? Der Datenpunkt ist leer.
                                    • Gargano
                                      @jb_sullivan Sorry, hab da was zuviel auskommentiert. Ich habs in dem Code oben geändert ab Zeile 102
                                      • JB_Sullivan
                                        @gargano
                                        Jupp, geht wieder 👍
                                        • Gargano
                                          @jb_sullivan Hab noch etwas rumgespielt , Es geht auch 'stacked'
                                          Du kannst auch noch die Sekunden in der X-Achse wegfallen lassen : Zeile 117 die 12 in 5 ändern
                                          • JB_Sullivan
                                            @gargano
                                            gestapelt ist auch cool - Da bekommt man in einem Balken quasi die Werte für OST / West angezeigt?
                                            json solar systeminfo
                                            15
                                            188
                                            20767
