    4. Forecast.solar mit dem Systeminfo Adapter
    • JB_Sullivan
      JB_Sullivan @Gargano last edited by
      @gargano Achso - mache ich schnell wieder rein - moment
      • JB_Sullivan
        JB_Sullivan @Gargano last edited by JB_Sullivan
        @gargano sagte in Forecast.solar mit dem Systeminfo Adapter:
        Lösch mal die Zeile
        var graphData = {};
        OK, damit ist der Fehler aus Zeile 121 weg - ein fehler in Zeile 90 bleibt noch. Liegt bestimmt auch an meinen Drag & Drop "Künsten" 😉
        Im übrigen gibt es keine "makeResponse" - das hat mich sowieso gewundert.
        const SolarJSON1        = "javascript.0.SolarForecast.JSON1";
        const SolarJSON2        = "javascript.0.SolarForecast.JSON2";
        const SolarJSONAll1        = "javascript.0.SolarForecast.JSONAll1";
        const SolarJSONAll2        = "javascript.0.SolarForecast.JSONAll2";
        const SolarJSONGraphAll1        = "javascript.0.SolarForecast.JSONGraphAll1";
        const SolarJSONGraphAll2        = "javascript.0.SolarForecast.JSONGraphAll2";
        const SolarJSONTable    = "javascript.0.SolarForecast.JSONTable";
        const SolarJSONGraph    = "javascript.0.SolarForecast.JSONGraph";
        const creatStateList = [
            {name :SolarJSON1, type:"string", role : "value"},
            {name :SolarJSON2, type:"string", role : "value"},
            {name :SolarJSONAll1, type:"string", role : "value"},
            {name :SolarJSONAll2, type:"string", role : "value"},
            {name :SolarJSONGraphAll1, type:"string", role : "value"},
            {name :SolarJSONGraphAll2, type:"string", role : "value"},
            {name :SolarJSONTable, type:"string", role : "value"},
            {name :SolarJSONGraph, type:"string", role : "value"}
        creatStateList.forEach (function(item) {
            createState(item.name, {
                type: item.type,
                min: 0,
                def: 0,
                role: item.role
        var request = require('request');
        var options1 = {url: 'https://api.forecast.solar/estimate/xx.35/xx.24/40/90/7.26', method: 'GET', headers: { 'User-Agent': 'request' }};
        var options2 = {url: 'https://api.forecast.solar/estimate/xx.35/xx.24/40/-90/2.64', method: 'GET', headers: { 'User-Agent': 'request' }};
        var urls = [
          {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},
          {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2}
        var promises = urls.map(myAsyncRequest);
        schedule('6 6-22 * * *', getSolar);
        getSolar();
        function myAsyncRequest(myUrl) {
          log('Request '+myUrl.myUrl.url);
          return new Promise((resolve, reject) => {
             request(myUrl.myUrl.url, function(error, response, body) {
                if (!error && response.statusCode == 200) {
                    let today = formatDate(new Date(), 'YYYY-MM-DD');
                    let watts = JSON.parse(body).result.watts;
                    setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);
                    let table = [];
                    for(let time in watts) {
                        let pos = time.indexOf(':00:00');
                        if(pos != -1) {
                            let entry = {};
                            entry.Uhrzeit = time;
                            entry.Leistung = watts[time];
                            table.push(entry);
                    log ('JSON: '+myUrl.mySolarJSON);
                    setState(myUrl.mySolarJSON, JSON.stringify(table), true);
                // make GraphTable
                    let graphTimeData = [];
                            let pos1 = time.indexOf(':00:00');
                            let pos2 = time.indexOf(':30:00');
                            if((pos1 != -1) || (pos2 != -1)) {
                            let graphEntry ={};
                            graphEntry.t = Date.parse(time);
                            graphEntry.y = watts[time];
                            graphTimeData.push(graphEntry);
                    var graph = {};
                    var graphData ={};
                    var graphAllData = [];
                    graphData.data = graphTimeData;
                    graphAllData.push(graphData);
                    graph.graphs=graphAllData;
                    setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);
                    resolve (body);
        function makeTable () {
            log ('MakeTable');
            let watts1 = JSON.parse(getState(SolarJSON1).val);
            let watts2 = JSON.parse(getState(SolarJSON2).val);
            log ('Items: '+watts1.length);
            let table = [];
            for(var n=0;n<watts1.length;n++) {
                    let entry = {};
                    let graphEntry ={};
                    let thisTime = watts1[n].Uhrzeit;
                    log (thisTime);
                    entry.Uhrzeit = watts1[n].Uhrzeit;
                    entry.Leistung1 = watts1[n].Leistung;
                    entry.Leistung2 = watts2[n].Leistung;
                    entry.Summe = watts1[n].Leistung + watts2[n].Leistung;
                    table.push(entry);
                    graphEntry.t = Date.parse(thisTime);
                    graphEntry.y = watts1[n].Leistung + watts2[n].Leistung;
            var graph = {};
            var graphData = {"datalabel_rotation":-90,"datalabel_color":"lightgreen","datalabel_fontSize":10};
            setState(SolarJSONTable, JSON.stringify(table), true);
            setState(SolarJSONGraph, JSON.stringify(graph), true);
        function getSolar() {
          Promise.all(promises)
          .then(function(bodys) {
            console.log("All url loaded");
            makeTable();
        Gargano 1 Reply Last reply Reply Quote 0
        • Gargano
          Gargano @JB_Sullivan last edited by
          @jb_sullivan Da fehlt noch eine Klammer:
                                  let graphEntry ={};
                              }  // -< die fehlt
          • JB_Sullivan
            @gargano Jupp - Fehler ist weg und in den Einzelgraphen wird auch die :30 gesetzt. Allerdings fehlt dieser Zeitraum dann in den Additiations Tabellen.
            jsonGraph & jsonTable
            • Gargano
              Gargano @JB_Sullivan last edited by Gargano
              @jb_sullivan Weiter oben Zeile 57 mußt Du noch das Gleiche machen
                              if(pos != -1) {
              ändern in
                              if((pos1 != -1) || (pos2 != -1)){
              Bei den Einzelgraphen brauchst Du eigentlich keine Abfrage der Zeit, da diese nur für die Synchronisation der Summenbildung benötigt wird. Zeile 72..74 kann entfallen, nicht vergessen wieder die Klammer unten zu entfernen.
              • JB_Sullivan
                @gargano
                Auch das funktioniert jetzt 👍 - das wird ja immer perfekter 😉
                Jetzt stellt sich mir nur noch eine Frage - in den Nachstunden wird es ja nachweislich nie zu PV Produktion kommen. Im Diagramm belegen diese Zeiten aber unnötigen Leerraum, was wiederum verhindert, das die Balken breiter und somit die Texte übersichtlicher daher kommen können.
                Kann man den ganzen Zeitbereich der Darstellung (Ausgabe) evtl. noch irgendwie eingrenzen, sodaß die Tage nur von 6:00 - 21:30 dargestellt werden?
                • Gargano
                  @jb_sullivan Antwort vom Scrounger :
                  Das ist leider so, die zeitachse wird immer optimal für den Zeitraum (start / ende) erstellt.
                  Geht nur mit eigenem Ertsellen der x -Achse Labels :
                      log ('MakeTable');
                      let table = [];
                     let axisLabels = [];
                     /*         let entry = {};
                              let graphEntry ={};
                              log (thisTime);
                              table.push(entry);
                             graphTimeData.push( watts1[n].Leistung + watts2[n].Leistung);
                            let time = watts1[n].Uhrzeit.substr(11, 12);
                            axisLabels.push(time);
                      var graph = {};
                      var graphData = {};
                      graph.axisLabels =  axisLabels;
                  • JB_Sullivan
                    @gargano
                    Kannst du nochmal den ganzen Code posten? Wenn ich diesen Code Schnippsel oben einfüge, wird mir an diversen Stellen wieder etwas als falsch unterstrichen ( Zeile 42,44,131,147)
                    • Gargano
                      Gargano last edited by Gargano
                      @jb_sullivan
                              type: item.type,
                              min: 0,
                              def: 0,
                              role: item.role
                      var urls = [
                      getSolar();
                                  let table = [];
                                                      let entry = {};
                                                      table.push(entry);
                              // make GraphTable
                                          let graphEntry ={};
                                  var graph = {};
                                  var graphData ={};
                                  resolve (body);
                          log ('MakeTable');
                          let table = [];
                                  let entry = {};
                                  let graphEntry ={};
                                  log (thisTime);
                                  table.push(entry);
                      //            graphEntry.t = Date.parse(thisTime);
                      //            graphEntry.y = watts1[n].Leistung + watts2[n].Leistung;
                      //            graphTimeData.push(graphEntry);
                      			graphTimeData.push(watts1[n].Leistung + watts2[n].Leistung);
                                  let time = watts1[n].Uhrzeit.substr(11, 5);
                          var graph = {};
                          makeTable();
                      • JB_Sullivan
                        @gargano
                        Welche Version hat dein js-engine? Ich habe 5.0.12.
                        Mit dem Code wird mir Zeile 113 (watts3) unterstrichen, das dass falsch sein soll
                        javascript.0	2021-03-09 12:52:04.412	error	(3804) at process._tickCallback (internal/process/next_tick.js:68:7)
                        javascript.0	2021-03-09 12:52:04.411	error	(3804) at script.js.Solar.SolarForcast:133:5
                        javascript.0	2021-03-09 12:52:04.411	error	(3804) at makeTable (script.js.Solar.SolarForcast:113:65)
                        javascript.0	2021-03-09 12:52:04.408	error	(3804) script.js.Solar.SolarForcast: ReferenceError: watts3 is not defined
                        • Gargano
                          @jb_sullivan ja, wirf mal das watts3 raus:
                          Das ist von mir, ich benutze das um die Einstrahlung der Sonne in die Fenster zu schätzen und habe da 3 Seiten
                          • JB_Sullivan
                            @gargano
                            Schräg - sieht schon ziemlich gut aus - aber irgendwas ist ja immer 😲
                            Vorher fand ich die Time Line etwas aufgeräumter. Beim rüber hoovern mit der Maus bekommt man ja auch eine Legende mit Zeiten angezeigt. Von daher bedarf es für mich nicht unbedingt einer X-Achse mit allen Zeiten.
                            ALT:
                            NEU:
                            • Gargano
                              @jb_sullivan Das macht der JsonChart von alleine.
                              Schau mal in den Editor Porperties der x-Achse. Evtl. kannst Du da noch was einstellen. Oder ganz weglassen
                              • JB_Sullivan
                                @gargano
                                Einfach über die Widget Konfiguration scheint es nur begrenzt zu gehen. Allerdings kann man da wohl wieder was mit Code tweaken erzwingen wenn man spezielle Zeitabschnitte (z.B. Tag) haben will - aber da bin ich wieder raus.
                                EDIT: Ich sehe gerade die json Tabelle gibt es mit dem neuen Code nicht mehr? Der Datenpunkt ist leer.
                                • Gargano
                                  @jb_sullivan Sorry, hab da was zuviel auskommentiert. Ich habs in dem Code oben geändert ab Zeile 102
                                  • JB_Sullivan
                                    @gargano
                                    Jupp, geht wieder 👍
                                    • Gargano
                                      @jb_sullivan Hab noch etwas rumgespielt , Es geht auch 'stacked'
                                      Du kannst auch noch die Sekunden in der X-Achse wegfallen lassen : Zeile 117 die 12 in 5 ändern
                                      • JB_Sullivan
                                        @gargano
                                        gestapelt ist auch cool - Da bekommt man in einem Balken quasi die Werte für OST / West angezeigt?
                                        • Gargano
                                          @jb_sullivan ja.
                                                  type: item.type,
                                                  min: 0,
                                                  def: 0,
                                                  role: item.role
                                          var urls = [
                                          getSolar();
                                                      let table = [];
                                                              let entry = {};
                                                              table.push(entry);
                                                  // make GraphTable
                                                              let graphEntry ={};
                                                      var graph = {};
                                                      var graphData ={};
                                                      resolve (body);
                                              log ('MakeTable');
                                              let table = [];
                                                      let entry = {};
                                                      let graphEntry ={};
                                                      table.push(entry);
                                          	let graphTimeData1 = [];
                                              	graphTimeData1.push(watts1[n].Leistung);
                                                  let time = watts1[n].Uhrzeit.substr(11,5);
                                          	let graphTimeData2 = [];
                                              for(var n=0;n<watts2.length;n++) {
                                             		graphTimeData2.push(watts2[n].Leistung);
                                              var graph = {};
                                              var graphData = {"legendText": "West","yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":"green","barStackId":1,"datalabel_rotation":-90,"datalabel_color":"lightgreen","datalabel_fontSize":10};
                                              graphData.data = graphTimeData1;
                                          	graphData = {"legendText": "Ost","yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":"red","barStackId":1,"datalabel_rotation":-90,"datalabel_color":"lightblue","datalabel_fontSize":10};
                                              graphData.data = graphTimeData2;
                                              makeTable();
                                          Bei "legendText" musst Du noch schauen , welcher Ost und West ist
                                          • JB_Sullivan
                                            @gargano MEGA !!!
                                            Da kann man gleich sehen wann von welcher Dachseite mit welchem Ertrag zu rechnen ist 👍 👍
                                            json solar systeminfo
                                            15
                                            188
                                            20767
