    4. Forecast.solar mit dem Systeminfo Adapter
    • JB_Sullivan
      JB_Sullivan @Gargano last edited by
      @gargano
      Kannst du nochmal den ganzen Code posten? Wenn ich diesen Code Schnippsel oben einfüge, wird mir an diversen Stellen wieder etwas als falsch unterstrichen ( Zeile 42,44,131,147)
      • Gargano
        Gargano last edited by Gargano
        @jb_sullivan
        const SolarJSON1        = "javascript.0.SolarForecast.JSON1";
        const SolarJSON2        = "javascript.0.SolarForecast.JSON2";
        const SolarJSONAll1        = "javascript.0.SolarForecast.JSONAll1";
        const SolarJSONAll2        = "javascript.0.SolarForecast.JSONAll2";
        const SolarJSONGraphAll1        = "javascript.0.SolarForecast.JSONGraphAll1";
        const SolarJSONGraphAll2        = "javascript.0.SolarForecast.JSONGraphAll2";
        const SolarJSONTable    = "javascript.0.SolarForecast.JSONTable";
        const SolarJSONGraph    = "javascript.0.SolarForecast.JSONGraph";
        const creatStateList = [
            {name :SolarJSON1, type:"string", role : "value"},
            {name :SolarJSON2, type:"string", role : "value"},
            {name :SolarJSONAll1, type:"string", role : "value"},
            {name :SolarJSONAll2, type:"string", role : "value"},
            {name :SolarJSONGraphAll1, type:"string", role : "value"},
            {name :SolarJSONGraphAll2, type:"string", role : "value"},
            {name :SolarJSONTable, type:"string", role : "value"},
            {name :SolarJSONGraph, type:"string", role : "value"}
        creatStateList.forEach (function(item) {
            createState(item.name, {
                type: item.type,
                min: 0,
                def: 0,
                role: item.role
        var request = require('request');
        var options1 = {url: 'https://api.forecast.solar/estimate/xx.35/xx.24/40/90/7.26', method: 'GET', headers: { 'User-Agent': 'request' }};
        var options2 = {url: 'https://api.forecast.solar/estimate/xx.35/xx.24/40/-90/2.64', method: 'GET', headers: { 'User-Agent': 'request' }};
        var urls = [
          {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},
          {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2}
        var promises = urls.map(myAsyncRequest);
        schedule('6 6-22 * * *', getSolar);
        getSolar();
        function myAsyncRequest(myUrl) {
          log('Request '+myUrl.myUrl.url);
          return new Promise((resolve, reject) => {
             request(myUrl.myUrl.url, function(error, response, body) {
                if (!error && response.statusCode == 200) {
                    let today = formatDate(new Date(), 'YYYY-MM-DD');
                    let watts = JSON.parse(body).result.watts;
                    setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);
                    let table = [];
                    for(let time in watts) {
                                    let pos1 = time.indexOf(':00:00');
                                    let pos2 = time.indexOf(':30:00');
                                    if((pos1 != -1) || (pos2 != -1)) {
                                        let entry = {};
                                        entry.Uhrzeit = time;
                                        entry.Leistung = watts[time];
                                        table.push(entry);
                    log ('JSON: '+myUrl.mySolarJSON);
                    setState(myUrl.mySolarJSON, JSON.stringify(table), true);
                // make GraphTable
                    let graphTimeData = [];
                            let graphEntry ={};
                            graphEntry.t = Date.parse(time);
                            graphEntry.y = watts[time];
                            graphTimeData.push(graphEntry);
                    var graph = {};
                    var graphData ={};
                    var graphAllData = [];
                    graphData.data = graphTimeData;
                    graphAllData.push(graphData);
                    graph.graphs=graphAllData;
                    setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);
                    resolve (body);
        function makeTable () {
            log ('MakeTable');
            let watts1 = JSON.parse(getState(SolarJSON1).val);
            let watts2 = JSON.parse(getState(SolarJSON2).val);
            log ('Items: '+watts1.length);
            let table = [];
        	let axisLabels = [];
            for(var n=0;n<watts1.length;n++) {
                    let entry = {};
                    let graphEntry ={};
                    let thisTime = watts1[n].Uhrzeit;
                    log (thisTime);
                    entry.Uhrzeit = watts1[n].Uhrzeit;
                    entry.Leistung1 = watts1[n].Leistung;
                    entry.Leistung2 = watts2[n].Leistung;
                    entry.Summe = watts1[n].Leistung + watts2[n].Leistung;
                    table.push(entry);
        //            graphEntry.t = Date.parse(thisTime);
        //            graphEntry.y = watts1[n].Leistung + watts2[n].Leistung;
        //            graphTimeData.push(graphEntry);
        			graphTimeData.push(watts1[n].Leistung + watts2[n].Leistung);
                    let time = watts1[n].Uhrzeit.substr(11, 5);
                    axisLabels.push(time);
            var graph = {};
            var graphData = {"datalabel_rotation":-90,"datalabel_color":"lightgreen","datalabel_fontSize":10};
        	graph.axisLabels =  axisLabels;
            setState(SolarJSONTable, JSON.stringify(table), true);
            setState(SolarJSONGraph, JSON.stringify(graph), true);
        function getSolar() {
          Promise.all(promises)
          .then(function(bodys) {
            console.log("All url loaded");
            makeTable();
        • JB_Sullivan
          @gargano
          Welche Version hat dein js-engine? Ich habe 5.0.12.
          Mit dem Code wird mir Zeile 113 (watts3) unterstrichen, das dass falsch sein soll
          javascript.0	2021-03-09 12:52:04.412	error	(3804) at process._tickCallback (internal/process/next_tick.js:68:7)
          javascript.0	2021-03-09 12:52:04.411	error	(3804) at script.js.Solar.SolarForcast:133:5
          javascript.0	2021-03-09 12:52:04.411	error	(3804) at makeTable (script.js.Solar.SolarForcast:113:65)
          javascript.0	2021-03-09 12:52:04.408	error	(3804) script.js.Solar.SolarForcast: ReferenceError: watts3 is not defined
          Gargano 1 Reply Last reply Reply Quote 0
          • Gargano
            Gargano @JB_Sullivan last edited by Gargano
            @jb_sullivan ja, wirf mal das watts3 raus:
            Das ist von mir, ich benutze das um die Einstrahlung der Sonne in die Fenster zu schätzen und habe da 3 Seiten
            • JB_Sullivan
              @gargano
              Schräg - sieht schon ziemlich gut aus - aber irgendwas ist ja immer 😲
              Vorher fand ich die Time Line etwas aufgeräumter. Beim rüber hoovern mit der Maus bekommt man ja auch eine Legende mit Zeiten angezeigt. Von daher bedarf es für mich nicht unbedingt einer X-Achse mit allen Zeiten.
              ALT:
              NEU:
              • Gargano
                @jb_sullivan Das macht der JsonChart von alleine.
                Schau mal in den Editor Porperties der x-Achse. Evtl. kannst Du da noch was einstellen. Oder ganz weglassen
                • JB_Sullivan
                  JB_Sullivan @Gargano last edited by JB_Sullivan
                  @gargano
                  Einfach über die Widget Konfiguration scheint es nur begrenzt zu gehen. Allerdings kann man da wohl wieder was mit Code tweaken erzwingen wenn man spezielle Zeitabschnitte (z.B. Tag) haben will - aber da bin ich wieder raus.
                  EDIT: Ich sehe gerade die json Tabelle gibt es mit dem neuen Code nicht mehr? Der Datenpunkt ist leer.
                  • Gargano
                    @jb_sullivan Sorry, hab da was zuviel auskommentiert. Ich habs in dem Code oben geändert ab Zeile 102
                    • JB_Sullivan
                      @gargano
                      Jupp, geht wieder 👍
                      • Gargano
                        @jb_sullivan Hab noch etwas rumgespielt , Es geht auch 'stacked'
                        Du kannst auch noch die Sekunden in der X-Achse wegfallen lassen : Zeile 117 die 12 in 5 ändern
                        • JB_Sullivan
                          @gargano
                          gestapelt ist auch cool - Da bekommt man in einem Balken quasi die Werte für OST / West angezeigt?
                          • Gargano
                            @jb_sullivan ja.
                                    type: item.type,
                                    min: 0,
                                    def: 0,
                                    role: item.role
                            var urls = [
                            getSolar();
                                        let table = [];
                                                let entry = {};
                                                table.push(entry);
                                    // make GraphTable
                                                let graphEntry ={};
                                        var graph = {};
                                        var graphData ={};
                                        resolve (body);
                                log ('MakeTable');
                                let table = [];
                                        let entry = {};
                                        let graphEntry ={};
                                        table.push(entry);
                                        let time = watts1[n].Uhrzeit.substr(11, 12);
                            	let graphTimeData1 = [];
                                	graphTimeData1.push(watts1[n].Leistung);
                                    let time = watts1[n].Uhrzeit.substr(11,5);
                            	let graphTimeData2 = [];
                                for(var n=0;n<watts2.length;n++) {
                               		graphTimeData2.push(watts2[n].Leistung);
                                var graph = {};
                                var graphData = {"legendText": "West","yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":"green","barStackId":1,"datalabel_rotation":-90,"datalabel_color":"lightgreen","datalabel_fontSize":10};
                                graphData.data = graphTimeData1;
                            	graphData = {"legendText": "Ost","yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":"red","barStackId":1,"datalabel_rotation":-90,"datalabel_color":"lightblue","datalabel_fontSize":10};
                                graphData.data = graphTimeData2;
                                makeTable();
                            Bei "legendText" musst Du noch schauen , welcher Ost und West ist
                            • JB_Sullivan
                              @gargano MEGA !!!
                              Da kann man gleich sehen wann von welcher Dachseite mit welchem Ertrag zu rechnen ist 👍 👍
                              • Gargano
                                @jb_sullivan Wie hast Du denn die x-Achse hinbekommen ?
                                Ich hab oben nochmal geändert wegen Legende , wenn Du magst
                                • JB_Sullivan
                                  @gargano
                                  X-Achse ist getrickst - "Heute +1 , +2, +3" sind einfache VIS Textfelder und die Werte habe ich im Widget begrenzt.
                                  Wie kann man die Darstellung drehen? Also die Stapelwerte mit der höheren Wertigkeit (WEST) nach hinten und die niederen (OST) nach vorne?
                                  Außerdem scheint im Widget ein kleiner BUG zu sein. Wenn man im Tooltip Layout "text Anhang" auswählt und etwas einträgt, wird das nirgends hinzu gefügt.
                                  Gargano 2 Replies Last reply Reply Quote 0
                                  • Gargano
                                    @jb_sullivan Also oben und unten vertauschen ?
                                    Einfach displayOrder ändern in 2 und 1 in Zeile 136 und 139
                                    • Gargano
                                      @jb_sullivan ToolTip Anhang geht auch im Script :
                                      "tooltip_AppendText": " kWh"
                                      Wieder in Zeile 136 und 139 voranstellen.
                                      • JB_Sullivan
                                        @gargano
                                        Ich bin glücklich !!!! Super alles so wie ich es mir vorgestellt hatte - PERFEKT !!!
                                        Deine Änderungen haben auch gegriffen - aber trotzdem bleibt aus dem Widget heraus der BUG bestehen das er die Eingabe nicht annimmt. Wenn man es über Script macht so wie du oben geschrieben hast - dann funktioniert es. Aber wie gesagt aus dem Widget heraus nicht (zumindest bei mir)
                                        Gargano G 2 Replies Last reply Reply Quote 0
                                        • Gargano
                                          @jb_sullivan Das Widget ist vom Scrounger.
                                          Wenn Du magst, kannst ein Issue im Github aufmachen.
                                          • JB_Sullivan
                                            @gargano
                                            Ja werde ich mal machen. Was mir gerade auffällt - hast du noch was an den Zeiten geändert?
                                            Bei dem Diagramm weiter oben (#112) hat das Diagramm quasi genau so begonnen und geendet, wie aus den Rohdaten auch kommt - jetzt sind alle Diagramme fix von 8:00 bis 16:30 Uhr formatiert.
                                            json solar systeminfo
                                            15
                                            188
                                            20766
