    • simatec
      simatec Developer Most Active @Altersrentner last edited by simatec
      @altersrentner
      Hast du denn in deiner neuen Installation von Grafana die gleichen Benutzerdaten und auch dort einen ApiKey angelegt
      Laut Log stimmen bei deinem Restore weder Username und Passwort als auch ApiKey nicht.
      Konfiguriere Backitup mit den Benutzerdaten aus grafana (inkl. ApiKey) und führe im Anschluss den restore durch
      A L 2 Replies Last reply Reply Quote 0
        Altersrentner @simatec last edited by
        @simatec
        Wieder das selbe Ergebnis:
        Started restore ...
        [DEBUG] [grafana] - Start Grafana Restore ...
        [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2021_03_08-02_18_32_backupiobroker.tar.gz
        [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
        [DEBUG] [grafana] - start decompress
        [DEBUG] [grafana] - Grafana request started
        [DEBUG] [grafana] - Grafana is available ... Status: 200
        [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
        [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
        [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
        [DEBUG] [grafana] - cannot restore datasource "InfluxDB-1": "data source with the same name already exists"
        [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/n1-aussen-wz.json
        [DEBUG] [grafana] - cannot restore dashboard "n1-aussen-wz": {"message":"invalid API key"}
        [DEBUG] [grafana] - Grafana request ended
        [DEBUG] [grafana] - Try deleting the Grafana tmp directory
        [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
        [DEBUG] [grafana] - Grafana Restore completed successfully
        [EXIT] Grafana restore done
        Das ist der Key, oberste Zeile
        eyJrIjoiUkNLdUFsa0JReUppazAwS3RUN0tYWjAwbGtGbFVDMFAiLCJuIjoiaW9Ccm9rZXIiLCJpZCI6MX0=
        curl -H "Authorization: Bearer eyJrIjoiUkNLdUFsa0JReUppazAwS3RUN0tYWjAwbGtGbFVDMFAiLCJuIjoiaW9Ccm9rZXIiLCJpZCI6MX0=" http://192.168.178.41:3000/api/dashboards/home
        • simatec
          @altersrentner sagte in Test Adapter Backitup v2.0.x:
          Hast du den Key mit Adminrechten angelegt?
            @simatec
            Werde ich sofort in der alten HDD überprüfen.
            Danke für den Hinweis
            MfG Michael
            • simatec
              @altersrentner
              Denke aber bitte daran, dass du in deiner neuen Umgebung auch einen neuen ApiKey benötigst, der natürlich dann auch in Backitup aktualisiert werden muss
              A 2 Replies Last reply Reply Quote 0
                @simatec
                Bin jetzt auf de alten HDD
                werde einen neuen API Key als admin generieren
                Dann ein Backup erstellen
                Platte tauschen
                Auf der SSD unter Backitup den neuen Key, Login un Passwort eintragen
                Und Restore machen
                Ist das so OK
                MfG Michael
                • simatec
                  @altersrentner Login und ApiKey müssen mit den Grafana System auf deiner SDD passen.
                  Also lege den ApiKey dort an.
                  Der alte ApiKey von dem HDD System ist für den restore nicht relevant
                    @simatec sagte in Test Adapter Backitup v2.0.x:
                    Auch oder den neu generierten Key? der alten Platte
                    • simatec
                      @altersrentner Nein den auf deinem neuen System generierten Key
                        @simatec Hallo,
                        Ich bedanke mich für die Unterstützung.
                        Jetzt ist wieder alles online.
                        Problem war vermutlich,
                        dass ich den API Key nicht als admin angelegt hatte.
                        Mit freundlichen grüßen
                        Michael
                        • simatec
                          @altersrentner Gerne ... Kein Problem 😉
                          • simatec
                            Ab sofort steht die Version 2.0.4 auf Github und in Kürze auch im latest zur Verfügung.
                            Changelog
                            2.0.4 (10.03.2021)
                            • (simatec) Bugfix history json
                            • (simatec) BugFix Redis backup
                            • (simatec) chmod for backup directory added
                            • (simatec) error handling for Grafana backup added
                            • simatec
                              Ab sofort steht die Version 2.0.5 auf Github und in Kürze auch im latest zur Verfügung.
                              Changelog
                              2.0.5 (14.03.2021)
                              • (simatec) error handling for redis backup added
                              • (simatec) error handling for history backup added
                              • (simatec) BugFix Grafana backup
                              O crunchip R 3 Replies Last reply Reply Quote 1
                              • O
                                Oli @simatec last edited by
                                @simatec
                                erstmal danke für den genialen Adapter, hat mir schon etliche mal das arbeiten mit ioBroker erleichtert.
                                Da ich leider versehentlich ein Script gelöscht hatte, suchte ich nach einer einfachen Methode nur die Scripte aus dem letzten Backup wieder herzustellen, habe dazu aber leider nichts einfaches im Forum oder im Internet gefunden. Daher die Frage, wäre es möglich so eine Möglichkeit in deinen Adapter zu integrieren?
                                  Thomas Braun Most Active @Oli last edited by
                                  @oli Gibt es doch schon.
                                  • O
                                    Oli @Thomas Braun last edited by
                                    wo finde ich das im Adapter, habe alles durchsucht und nicht gefunden
                                      @oli Welche Version?
                                      In 2.0.4 findet sich das in den Einstellungen. Nennt sich Javascript dort.
                                      • O
                                        @thomas-braun, @simatec
                                        sorry, wer lesen kann ist klar im Vorteil, bin auf stable Version unterwegs
                                          crunchip Forum Testing Most Active @simatec last edited by crunchip
                                          @simatec habe gerade versucht zu installieren, von 2.0.4 auf 2.0.5, siehe screen
                                          js-controller 3.2.16
                                          2021-03-15 23:40:29.194 - info: host.IoBroker iobroker upgrade backitup
                                          2021-03-15 23:40:32.840 - error: host.IoBroker iobroker /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674 res.forEach(aliveState => { ^TypeError: Cannot read property 'forEach' of undefined at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674:21) at processImmediate (internal/timers.js:463:21)
                                          2021-03-15 23:40:32.855 - info: host.IoBroker iobroker exit 1
                                          • simatec
                                            simatec Developer Most Active @crunchip last edited by simatec
                                            @crunchip
                                            Du hast doch zu dem gleichen Fehler bereits ein Thread offen. Es ist doch eindeutig, dass es der gleiche Fehler wie in deiner letzten Anfrage ist und dementsprechend nicht Adapter spezifisch
                                            https://forum.iobroker.net/topic/38377/tr-064-adapter-kann-icht-installiert-werden/30?_=1615875479116
                                            crunchip 1 Reply Last reply Reply Quote 1
                                            170
                                            2780
                                            2378894
