    4. [ Geklärt ] Problem bei Influx Installation
      Altersrentner @crunchip last edited by
      @crunchip
      Bei mir steht ei Semikolon vor.
      Bleibt das stehen?
        @crunchip
        Die ini ist bearbeitet
        DEBUG] [grafana] - Start Grafana Restore ...
        [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2021_03_08-02_18_32_backupiobroker.tar.gz
        [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
        [DEBUG] [grafana] - start decompress
        [DEBUG] [grafana] - Grafana request started
        [DEBUG] [grafana] - Grafana is available ... Status: 200
        [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
        [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
        [DEBUG] [grafana] - datasoure restore "InfluxDB-1" finish: {"datasource":{"id":2,"uid":"s1r54cgRz","orgId":1,"name":"InfluxDB-1","type":"influxdb","typeLogoUrl":"","access":"proxy","url":"http://192.168.178.41:8086","password":"","user":"admin","database":"iobroker","basicAuth":false,"basicAuthUser":"","basicAuthPassword":"","withCredentials":false,"isDefault":false,"jsonData":{"httpMode":"GET"},"secureJsonFields":{},"version":1,"readOnly":false},"id":2,"message":"Datasource added","name":"InfluxDB-1"}
        [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
        [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/n1-aussen-wz.json
        [DEBUG] [grafana] - cannot restore dashboard "n1-aussen-wz": {"message":"invalid API key"}
        [DEBUG] [grafana] - Grafana request ended
        [DEBUG] [grafana] - Try deleting the Grafana tmp directory
        [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
        [DEBUG] [grafana] - Grafana Restore completed successfully
        [EXIT] Grafana restore done
        Da stehen die Daten:
        irgend etwas stimmt noch nicht
          crunchip Forum Testing Most Active @Altersrentner last edited by
          @altersrentner laut deinem log
          • hast du ne InfluxDB.json und eine InfluxDB.json1, InfluxDB.json existiert aber scheinbar schon
          • für n1-aussen-wz.json stimmt scheinbar dein api key nicht
          ich bin da nicht so fit drin, da ich diese backup Funktion via backitup nicht verwende
          du hast doch ein backup von Grafana erstellt grafana_2021_03_07-19_42_25_backupiobroker.tar.gz und dieses muss zurückgespielt werden.
          was beinhaltet dieses backup?
            @crunchip
            Das Backup habe ich schon mehrmals zurückgespielt.
            Es ist von der alten Platte .
            Habe mir jetzt das Skript aus Grafana der alten Platte geladen
              "datasource": "InfluxDB-1",
              "aliasColors": {
                "Temperatur Wohnzimmer": "rgb(221, 176, 63)"
              "bars": false,
              "dashLength": 10,
              "dashes": false,
              "decimals": 1,
              "fill": 1,
              "fillGradient": 0,
              "gridPos": {
                "h": 9,
                "w": 12,
                "x": 12,
                "y": 0
              "hiddenSeries": false,
              "id": 4,
              "legend": {
                "avg": false,
                "current": true,
                "max": true,
                "min": true,
                "show": true,
                "total": false,
                "values": true
              "lines": true,
              "linewidth": 1,
              "nullPointMode": "null",
              "options": {
                "dataLinks": [
                    "title": "",
                    "url": ""
              "percentage": false,
              "pointradius": 2,
              "points": false,
              "renderer": "flot",
              "seriesOverrides": [
                  "alias": "Außentemperatur",
                  "fill": 3,
                  "fillGradient": 0,
                  "yaxis": 1
                  "alias": "Temperatur Wohnzimmer",
                  "yaxis": 1
                  "alias": "Power",
                  "yaxis": 2
              "spaceLength": 10,
              "stack": false,
              "steppedLine": false,
              "targets": [
                  "groupBy": [
                      "params": [
                        "$__interval"
                      "type": "time"
                      "params": [
                        "previous"
                      "type": "fill"
                  "measurement": "mihome.0.devices.weather_v1_158d00023213f6.temperature",
                  "orderByTime": "ASC",
                  "policy": "default",
                  "refId": "A",
                  "resultFormat": "time_series",
                  "select": [
                        "params": [
                          "value"
                        "type": "field"
                        "params": [],
                        "type": "max"
                  "tags": []
                  "alias": "Temperatur Heizkessel",
                  "groupBy": [
                      "params": [
                        "$__interval"
                      "type": "time"
                      "params": [
                        "previous"
                      "type": "fill"
                  "measurement": "fhem.0.Temp_Heizkessel.temperature",
                  "refId": "B",
                  "select": [
                        "params": [
                          "value"
                        "type": "field"
                        "params": [],
                        "type": "max"
                  "tags": []
                  "alias": "Temperatur Puffer",
                  "groupBy": [
                      "params": [
                        "$__interval"
                      "type": "time"
                      "params": [
                        "previous"
                      "type": "fill"
                  "measurement": "hm-rpc.0.OEQ0673599.2.TEMPERATURE",
                  "refId": "C",
                  "select": [
                        "params": [
                          "value"
                        "type": "field"
                        "params": [],
                        "type": "max"
                  "tags": []
                  "alias": "Power",
                  "groupBy": [
                      "params": [
                        "$__interval"
                      "type": "time"
                      "params": [
                        "previous"
                      "type": "fill"
                  "measurement": "shelly.0.SHSW-PM#8CAAB542C16C#1.Relay0.Power",
                  "refId": "E",
                  "select": [
                        "params": [
                          "value"
                        "type": "field"
                        "params": [],
                        "type": "max"
                  "tags": []
              "thresholds": [],
              "timeFrom": null,
              "timeRegions": [],
              "timeShift": null,
              "title": "Temperatur Außen  / Temperatur Kessel /Temperatur Puffer9 / KesselStatus",
              "tooltip": {
                "shared": true,
                "sort": 0,
                "value_type": "individual"
              "type": "graph",
              "xaxis": {
                "buckets": null,
                "mode": "time",
                "name": null,
                "show": true,
                "values": []
              "yaxes": [
                  "decimals": 1,
                  "format": "celsius",
                  "label": null,
                  "logBase": 1,
                  "max": null,
                  "min": null,
                  "show": true
                  "decimals": 1,
                  "format": "watt",
                  "label": null,
                  "logBase": 1,
                  "max": null,
                  "min": null,
                  "show": true
              "yaxis": {
                "align": false,
                "alignLevel": null
            Kann man das einbinden?
            MfG Michael
            crunchip 2 Replies Last reply Reply Quote 0
              @altersrentner ist das dein einziges Dashboard? Ja das kann man einfügen.
              Auf deiner Grafana Seite, links auf das +,dann Import
              unterhalb von Import via panel json, kannst du es einfügen.
              @altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
              dann ist es ja scheinbar schon vorhanden. Schau doch mal unter folgendem Pfad was du so findest
              var/lib/grafana
                @altersrentner ansonsten, wenn es speziell um's Backup geht, könntest du dort mal nachfragen
                  @crunchip Guten Morgen,
                  Hier ist auch die heutige eingefügte grafanaDB zu sehen.
                  Nur es gibt keine graphische Darstellung.
                  Mit freundlichen Grüßen
                  Michael
                    Lässt sich das Dashboard nicht öffnen, oder ist leer?
                      @crunchip Hallo,
                      Ich bedanke mich für die Unterstützung.
                      Die dortige Nachfrage hat mich auf den richtigen Weg gebracht.
                      Ich hatte vermutlich den API key nicht als Admin angelegt sondern als viewer.
                      Michael
                        Altersrentner @wendy2702 last edited by
                        @wendy2702 Hallo,
                        Auch Dir nochmal besten Dank für die Unterstützung
                        Michael
                          @altersrentner habe es dort gerade gelesen
                          dann läuft ja wieder alles👍
                          • wendy2702
                            wendy2702 @Altersrentner last edited by
                            @altersrentner Habe gerne im Rahmen meiner Möglichkeiten geholfen.
                            Schön das es wieder läuft.
                              A Former User @crunchip last edited by
                              @crunchip
                              Hi, der Beitrag ist zwar schon etwas älter aber habe hier am meisten zu meinem influxdb Problem gefunden.
                              Habe eben den Raspberry Pi aktualisiert und seitdem läuft mir der log mit Verbindungsproblemen zur influxdb voll. Ja, influxdb wurde auch etwas aktualisiert genau habe ich es aber nicht in der Kommandozeile lesen können.
                              Nach Versuchen in der conf habe ich festgestellt, dass influxdb gar nicht startet, aber warum?
                              Nach Netzsuche bekäme ich jetzt höchsten die influxdb gelöscht und frisch installiert, aber dann wären meine Daten futsch.
                              Habt ihr einen Tip? Besten Dank vorab!
                              pi@IOBroker:~ $ apt policy influxdb
                              influxdb:
                                Installiert:           1.8.7-1
                                Installationskandidat: 1.8.7-1
                                Versionstabelle:
                               *** 1.8.7-1 500
                                      500 https://repos.influxdata.com/debian buster/stable armhf Packages
                                      100 /var/lib/dpkg/status
                                   1.6.4-1+deb10u1 500
                              pi@IOBroker:~ $ sudo systemctl unmask influxdb.service
                              pi@IOBroker:~ $ sudo systemctl start influxdb
                              Job for influxdb.service failed because the control process exited with error code.
                              See "systemctl status influxdb.service" and "journalctl -xe" for details.
                              pi@IOBroker:~ $ sudo systemctl stop influxdb
                              pi@IOBroker:~ $ systemctl status influxdb.service
                              ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                                 Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Thu 2021-07-29 23:21:03 CEST; 3min 31s ago
                                   Docs: https://docs.influxdata.com/influxdb/
                                Process: 7021 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
                              Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                              Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                              Jul 29 23:21:03 IOBroker systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                              Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Start request repeated too quickly.
                              Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Failed with result 'exit-code'.
                              Jul 29 23:21:03 IOBroker systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                              pi@IOBroker:~ $
                                picky @Guest last edited by
                                @pete0815 Hatte gestern meinen Raspi auch updatet, und auch das Problem gehabt das influxdb nicht mehr starten konnte. Bei mir hat geholfen
                                sudo chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                                und dann ließ es sich starten mit
                                ? P 2 Replies Last reply Reply Quote 2
                                  A Former User @picky last edited by A Former User
                                  @picky
                                  Vielen Dank!!!! Das war Lösung und läuft wieder.
                                  Hatte auch einen Beitrag ergoogelt im computerbase forum, dort wird gezeigt, dass der Ordner /usr/lib/influxdb/scripts/ sich verändert hat und hier genau die1 Datei (influxd-systemd-start.sh) hinzu gekommen ist. Wie genau die Nutzerechte hier den services und skripte funktionieren bzw. sich geändert haben muss ich passen, aber es läuft wieder.
                                  Links zu anderen Foren waren nicht erlaubt, aber die Info darf man zitieren?
                                  (Quelle: ComputerBaseForum
                                    PeterHansen @picky last edited by
                                    @picky Hi, nach 3 Tagen Google-Suche - Forenstöbern etc. ... BIST DU MEINe Mann/Frau !!!.
                                    Du hast den heutigen HeldenGlobe von mir gewonnen !!!
                                    Das war die Lösung für meine Fehlermeldung:
                                    endlich 🙂
                                    • Basti97
                                      Basti97 Most Active last edited by
                                      nachdem ich influx eingeben habe kommt ein >
                                      bei mir. Was muss ich bei dieser Meldung machen?
                                      ERR: error parsing query: found Mira, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
                                      Warning: It is possible this error is due to not setting a database.
                                      Please set a database with the command "use <database>".
                                      > database
                                      Folgende Anleitung habe ich genutzt
                                      https://www.verdrahtet.info/2020/02/14/installation-von-influxdb-grafana-inkl-verbindung-zu-iobroker/
                                      und bin bis zum Anbschnitt influxdb gekommen
                                        crunchip Forum Testing Most Active @Basti97 last edited by crunchip
                                        @basti97 sagte in [ Geklärt ] Problem bei Influx Installation:
                                        Das macht die InfluxDb Instanz automatisch für dich, wenn du die Datenbank einträgst und die Instanz gestartet hast
                                        Dann brauchst du nicht uber die Influx CLI extra eine Datenbank anlegen.
                                        Basti97 1 Reply Last reply Reply Quote 0
                                        • Basti97
                                          Basti97 Most Active @crunchip last edited by
                                          @crunchip Danke für deine Hilfe jetzt funktioniert es. Die Anleitungen im Internet verwirren sehr.
                                            benziman @Altersrentner last edited by benziman
                                            @altersrentner said in [[ Geklärt ] Problem bei Influx Installation](/post
                                            Hi, ich muss den Post mal aufnehmen da ich an dieser Stelle mit der DB scheitere!
                                            Connected to http://localhost:8086 version 1.8.3
                                            InfluxDB shell version: 1.8.3
                                            > show databases
                                            name
                                            _internal
                                            iobroker
                                            > use iobroker
                                            Using database iobroker
                                            Da mein Startwert für meinen Wasserverbrauch in Grafana viel zu hoch ist, wollte ich diesen einen Wert aus der InfluxDB löschen. Allerdings bekomme ich bei show databases nur:
                                            ERR: unable to parse authentication credentials
                                            und wenn ich die Datenbank auswähle die ich ja erstellt habe und die auch Daten für Grafana bereitstellt erahtle ich:
                                            DB does not exist!
                                            jemand eine Idee was ich falsch mache?
                                            influxdb
                                            12
                                            178
                                            33062
