    4. JavaScript
    5. Node.js Script in iobroker integrieren
      rettroo @UncleSam last edited by
      @unclesam
      Danke für deine Hilfe. Habe die variablen nun in "" gesetzt. Jetzt bekomme ich folgenden Fehler:
      javascript.0	2021-01-27 13:30:19.894	error	(954) at Script.runInContext (vm.js:130:18)
      javascript.0	2021-01-27 13:30:19.894	error	(954) at script.js.Dahua:517:1
      javascript.0	2021-01-27 13:30:19.894	error	(954) at new DahuaVTO (script.js.Dahua:88:26)
      javascript.0	2021-01-27 13:30:19.894	error	(954) TypeError: DigestFetch is not a constructor
      javascript.0	2021-01-27 13:30:19.894	error	(954) ^
      javascript.0	2021-01-27 13:30:19.894	error	(954) this.digestClient = new DigestFetch(
      javascript.0	2021-01-27 13:30:19.894	error	(954) script.js.Dahua: script.js.Dahua:88
      javascript.0	2021-01-27 13:30:19.893	error	(954) at Script.runInContext (vm.js:130:18)
      javascript.0	2021-01-27 13:30:19.893	error	(954) at script.js.Dahua:5:13
      javascript.0	2021-01-27 13:30:19.893	error	(954) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:389:36)
      javascript.0	2021-01-27 13:30:19.892	error	(954) at require (internal/modules/cjs/helpers.js:74:18)
      javascript.0	2021-01-27 13:30:19.892	error	(954) at Module.require (internal/modules/cjs/loader.js:903:19)
      javascript.0	2021-01-27 13:30:19.892	error	(954) script.js.Dahua: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../md5'
      javascript.0	2021-01-27 13:30:19.891	error	(954) at Script.runInContext (vm.js:130:18)
      javascript.0	2021-01-27 13:30:19.891	error	(954) at script.js.Dahua:1:21
      javascript.0	2021-01-27 13:30:19.891	error	(954) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:389:36)
      javascript.0	2021-01-27 13:30:19.891	error	(954) at require (internal/modules/cjs/helpers.js:74:18)
      javascript.0	2021-01-27 13:30:19.891	error	(954) at Module.require (internal/modules/cjs/loader.js:903:19)
      javascript.0	2021-01-27 13:30:19.891	error	(954) script.js.Dahua: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../digest-fetch'
      javascript.0	2021-01-27 13:30:19.883	info	(954) Start javascript script.js.Dahua
      UncleSam 1 Reply Last reply Reply Quote 0
      • UncleSam
        UncleSam Developer @rettroo last edited by
        @rettroo Hast du denn digest-fetch bei den benötigten Node Modulen im JavaScript Adapter angegeben?
          @unclesam
          ist das so korrekt?
          Ich komme der Sache näher, zumindest war MQTT schon kurz verbunden. nun geht aber die javascript Instanz auf Rot kurz nach dem Start des Scriptes.
          host.debian	2021-01-27 14:43:01.777	info	Restart adapter system.adapter.javascript.0 because enabled
          host.debian	2021-01-27 14:43:01.777	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:214:10)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:273:9)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at addChunk (_stream_readable.js:298:12)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at DahuaVTO.receive (script.js.Dahua:288:12)
          host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
          host.debian	2021-01-27 14:43:01.775	error	Caught by controller[0]: TypeError: console.info is not a function
          mqtt.0	2021-01-27 14:43:01.772	info	(9477) Client [mqttjs_d9328b8b] connection closed: closed
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at Socket.Readable.push (_stream_readable.js:214:10)
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at readableAddChunk (_stream_readable.js:273:9)
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at addChunk (_stream_readable.js:298:12)
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at Socket.EventEmitter.emit (domain.js:483:12)
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at Socket.emit (events.js:314:20)
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at DahuaVTO.receive (script.js.Dahua:288:12)
          javascript.0	2021-01-27 14:43:01.751	error	(9509) at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
          javascript.0	2021-01-27 14:43:01.750	error	(9509) script.js.Dahua: TypeError: console.info is not a function
          mqtt.0	2021-01-27 14:43:01.717	info	(9477) Client [mqttjs_d9328b8b] connected with secret 1611754981716_9127
          javascript.0	2021-01-27 14:43:01.610	info	(9509) script.js.Dahua: registered 0 subscriptions and 0 schedules
          javascript.0	2021-01-27 14:43:01.554	info	(9509) Start javascript script.js.Dahua
          javascript.0	2021-01-27 14:43:01.554	info	(9509) script.js.Test: registered 1 subscription and 0 schedules
          javascript.0	2021-01-27 14:43:01.552	info	(9509) Start javascript script.js.Test
          javascript.0	2021-01-27 14:43:01.551	info	(9509) script.js.Feueralarm: registered 1 subscription and 0 schedules
          javascript.0	2021-01-27 14:43:01.550	info	(9509) Start javascript script.js.Feueralarm
          javascript.0	2021-01-27 14:43:01.548	info	(9509) script.js.Magic: registered 5 subscriptions and 0 schedules
          javascript.0	2021-01-27 14:43:01.547	info	(9509) Start javascript script.js.Magic
          javascript.0	2021-01-27 14:43:01.546	info	(9509) script.js.Licht_WZ: registered 3 subscriptions and 0 schedules
          javascript.0	2021-01-27 14:43:01.540	info	(9509) Start javascript script.js.Licht_WZ
          javascript.0	2021-01-27 14:43:01.540	info	(9509) script.js.BWM: registered 1 subscription and 0 schedules
          javascript.0	2021-01-27 14:43:01.523	info	(9509) Start javascript script.js.BWM
          javascript.0	2021-01-27 14:43:01.419	info	(9509) received all states
          javascript.0	2021-01-27 14:43:01.395	info	(9509) received all objects
          javascript.0	2021-01-27 14:43:00.835	info	(9509) requesting all objects
          javascript.0	2021-01-27 14:43:00.834	info	(9509) requesting all states
          javascript.0	2021-01-27 14:43:00.782	info	(9509) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
          host.debian	2021-01-27 14:42:59.455	info	instance system.adapter.javascript.0 started with pid 9509
          host.debian	2021-01-27 14:42:29.445	info	Restart adapter system.adapter.javascript.0 because enabled
          host.debian	2021-01-27 14:42:29.445	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.debian	2021-01-27 14:42:29.445	error	Caught by controller[0]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
          host.debian	2021-01-27 14:42:29.445	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:214:10)
          host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:273:9)
          host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at addChunk (_stream_readable.js:298:12)
          host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
          host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
          host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at DahuaVTO.receive (script.js.Dahua:288:12)
          host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
          host.debian	2021-01-27 14:42:29.442	error	Caught by controller[0]: TypeError: console.info is not a function
          mqtt.0	2021-01-27 14:42:29.442	info	(9477) Client [mqttjs_d19a512b] connection closed: Error: read ECONNRESET
          mqtt.0	2021-01-27 14:42:29.378	info	(9477) Client [mqttjs_d19a512b] connected with secret 1611754949376_714
          javascript.0	2021-01-27 14:42:29.410	error	(9494) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
          javascript.0	2021-01-27 14:42:29.410	error	(9494) at Socket.Readable.push (_stream_readable.js:214:10)
          javascript.0	2021-01-27 14:42:29.410	error	(9494) at readableAddChunk (_stream_readable.js:273:9)
          javascript.0	2021-01-27 14:42:29.410	error	(9494) at addChunk (_stream_readable.js:298:12)
          javascript.0	2021-01-27 14:42:29.409	error	(9494) at Socket.EventEmitter.emit (domain.js:483:12)
          javascript.0	2021-01-27 14:42:29.409	error	(9494) at Socket.emit (events.js:314:20)
          javascript.0	2021-01-27 14:42:29.409	error	(9494) at DahuaVTO.receive (script.js.Dahua:288:12)
          javascript.0	2021-01-27 14:42:29.409	error	(9494) at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
          javascript.0	2021-01-27 14:42:29.407	error	(9494) script.js.Dahua: TypeError: console.info is not a function
          javascript.0	2021-01-27 14:42:29.270	info	(9494) script.js.Dahua: registered 0 subscriptions and 0 schedules
          javascript.0	2021-01-27 14:42:29.206	info	(9494) Start javascript script.js.Dahua
          • UncleSam
            @rettroo Jawohl, alles richtig. Das einzige was du wohl noch anpassen musst: alles was console.<irgendwas>()ist musst du umschreiben nach log(). Denn Konsolen-Logging gibt es keines im JavaScript Adapter.
              rettroo @UncleSam last edited by rettroo
              @unclesam
              Danke, das Script läuft!
                Ich benötige hier bitte noch Unterstützung. Ich bekomme in MQTT folgenden String
                {"Data":{"CardNo":"b01xx636","CardType":null,"LocaleTime":"2021-01-28 15:47:08","Method":1,"Name":"OpenDoor","Password":"","ReaderID":"1","RecNo":96,"SnapURL":"","Status":1,"Type":"Entry","UTC":1611848828,"UserID":"2"},"deviceType":"VTO4202F","serialNumber":"6K0xxxxxxx20A0"}
                Ich benötige in dem Fall nur die User ID in 0_userdata.0.DahuaUserID
                  rettroo @rettroo last edited by rettroo
                  @UncleSam
                  Ich habe mir nun was zusammengebastelt.
                  Der Datenpunkt "serialNumber" wird geschrieben, der "UserID" nicht. Wie gebe ich den richtig an, da er ja nochmal in "Data" verschachtelt ist.
                  on({id: "mqtt.0.DahuaVTO.AccessControl.Event", change: "any"}, function (obj) { ParseCommand(obj); });
                  function ParseCommand(obj) {
                    let value = obj.state.val;
                    let serialNumber = "";
                    let UserID = "";
                    try {
                      obj = JSON.parse(value);
                      serialNumber = obj.serialNumber;
                      UserID = obj.UserID;
                      setState('0_userdata.0.serialNumber', (serialNumber));
                      setState('0_userdata.0.UserID', (UserID));
                    } catch (e) {
                      return;
                  Sonst sauber programmiert?
                  • UncleSam
                    @rettroo sagte in Node.js Script in iobroker integrieren:
                    Einfach mit einem Punkt dazwischen: obj.Data.UserID
                    • pseudoreal
                      pseudoreal last edited by
                      könntest Du bitte eine Anleitung für "Dummies" erstellen? Was genau muss zu erst installiert werden? Danke
                        rettroo @pseudoreal last edited by
                        @pseudoreal
                        Hi, kann ich machen sobald ich alles fertig habe. Die Dahua hängt zur Zeit auch noch nicht an der Tür sondern in meinem Büro 😉
                        pseudoreal 1 Reply Last reply Reply Quote 1
                          Hi @unclesam,
                          das Script hat soweit schon ganz gut funktioniert, nun startet es aber nicht mehr und ich bekomme folgenden Fehler.
                          Was hat es mit dem MD5 auf sich?
                          host.debian	2021-03-10 14:02:45.431	info	instance system.adapter.javascript.0 started with pid 2673
                          host.debian	2021-03-10 14:02:15.418	info	Restart adapter system.adapter.javascript.0 because enabled
                          host.debian	2021-03-10 14:02:15.418	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
                          host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:214:10)
                          host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:273:9)
                          host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at addChunk (_stream_readable.js:298:12)
                          host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                          host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
                          host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.receive (script.js.DAHUA.Dahua_Script:287:12)
                          host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.handleFirstLoginPayload (script.js.DAHUA.Dahua_Script:330:27)
                          host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.genMD5Hash (script.js.DAHUA.Dahua_Script:401:24)
                          host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: TypeError: md5 is not a function
                          mqtt.0	2021-03-10 14:02:15.400	info	(1533) Client [mqttjs_09066ccf] connection closed: closed
                          javascript.0	2021-03-10 14:02:15.386	error	(2658) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.Readable.push (_stream_readable.js:214:10)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at readableAddChunk (_stream_readable.js:273:9)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at addChunk (_stream_readable.js:298:12)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.EventEmitter.emit (domain.js:483:12)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.emit (events.js:314:20)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.receive (script.js.DAHUA.Dahua_Script:286:12)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.handleFirstLoginPayload (script.js.DAHUA.Dahua_Script:329:27)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.genMD5Hash (script.js.DAHUA.Dahua_Script:400:24)
                          javascript.0	2021-03-10 14:02:15.385	error	(2658) script.js.DAHUA.Dahua_Script: TypeError: md5 is not a function
                          mqtt.0	2021-03-10 14:02:15.356	info	(1533) Client [mqttjs_09066ccf] connected with secret 1615381335356_7933
                          javascript.0	2021-03-10 14:02:15.292	info	(2658) script.js.DAHUA.Dahua_Script: registered 0 subscriptions and 0 schedules
                          javascript.0	2021-03-10 14:02:15.246	error	(2658) at Script.runInContext (vm.js:130:18)
                          javascript.0	2021-03-10 14:02:15.246	error	(2658) at script.js.DAHUA.Dahua_Script:518:3
                          javascript.0	2021-03-10 14:02:15.246	error	(2658) at script.js.DAHUA.Dahua_Script:5:13
                          javascript.0	2021-03-10 14:02:15.245	error	(2658) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:397:36)
                          javascript.0	2021-03-10 14:02:15.245	error	(2658) at require (internal/modules/cjs/helpers.js:74:18)
                          javascript.0	2021-03-10 14:02:15.245	error	(2658) at Module.require (internal/modules/cjs/loader.js:903:19)
                          javascript.0	2021-03-10 14:02:15.245	error	(2658) script.js.DAHUA.Dahua_Script: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../md5'
                          • UncleSam
                            @rettroo Hast du das md5 Modul installiert?
                            const md5 = require('md5');
                            Sollte eigentlich schief gehen, wenn du md5 nicht installiert hast, was ich etwas komisch finde. Hast du das etwa aus dem Skript gelöscht?
                            • pseudoreal
                              pseudoreal @rettroo last edited by
                              @rettroo
                              also ich habe jetzt den MQTT server installiert. Das Script in Javascript erstellt und alle Instanzen gestartet. Ich bekomme den Fehler:
                              (20360) FetchError: request to https://192.168.178.10:443/cgi-bin/magicBox.cgi?action=getSystemInfo failed, reason: unable to verify the first certificate
                              Unter Instanzen ist jedoch MQTT gelb und auch im Script sebst sind mir einige Zeilen als Fehler unterstrichen - zB const DigestFetch = require('digest-fetch');
                              md5 und digest-fetch sind aber in der JavaScript instanz aktiviert.
                              UncleSam R 2 Replies Last reply Reply Quote 0
                              • UncleSam
                                UncleSam Developer @pseudoreal last edited by
                                @pseudoreal sagte in Node.js Script in iobroker integrieren:
                                Da steht ja die Fehlermeldung. Du machst HTTPS und das Zertifikat ist ungültig. Muss es denn HTTPS sein? Wie du die Zertifikatsüberprüfung ausschaltest, kann ich dir leider auch nicht sagen (ich kenne digest-fetch nicht).
                                  @pseudoreal
                                  wie von @UncleSam angemerkt würde ich das "s" mal weglassen also "http://
                                  MQTT sollte erst grün werden wenn sich das Script mit Dahua verbindet
                                  pseudoreal 1 Reply Last reply Reply Quote 0
                                  • pseudoreal
                                    @rettroo @UncleSam
                                    ok, ich habe das https weggelassen uns nun klappt die Verbindung und ich sehe auch im Script log, wenn sich jemand bewegt (VideoEvent) oder jemand klingelt (Invite).
                                    Jetzt fehlt mir nur noch die Information wie ich diese in iobroker weiterverarbeite, damit mir zB eine WhatsApp geschickt wird. Habe hier schon gesucht, aber leider nichts gefunden - wahrscheinlich falsche Suchbegriffe. Habt ihr irgendwo ein gutes Tutorial, wie man nun mit den Werten in MQTT weiterarbeitet?
                                    • UncleSam
                                      @pseudoreal Du füllst Datenpunkte ab und schreibst Skripte, Blocklys oder machst Rules. Das hat dann nichts mehr mit deinem Skript zu tun sondern ist ganz gewöhnliches Skripting in ioBroker.
                                      • pseudoreal
                                        pseudoreal @UncleSam last edited by
                                        @unclesam @rettroo
                                        Danke - das stimmt. Ich habe das via blockly hinbekommen. Habe aber noch folgendes Problem, wie kann ich aus MQTT einen speziellen String aus dem Wert in den Objekten rauslesen und in Blockly verarbeiten?
                                        • UncleSam
                                          @pseudoreal was meinst du damit? Kannst du mal in einem Screenshot zeigen, was du wo hast und was du daraus haben willst?
                                          • pseudoreal
                                            @unclesam
                                            im Objekt von MQTT habe ich eines der VTO, welches FingerPrintCheck heißt. Das dazugehörige Event hat unter Wert, den folgenden Eintrag:
                                            {"Data":{"FingerPrintID":6,"LocaleTime":"2021-05-03 08:17:42","UTC":1620026262},"deviceType":"VTO4202F","serialNumber":"xxxxxxxxxx"}
                                            Ich bräuchte nun den Datenpunkt FingerPrintID im Blockly, da ich gerne nur bei nicht erfolgreichen Fingerabdruckscans eine Aktion auslösen möchte. In einem anderen Thread wurde mir diese Seite empfohlen - https://www.machs-smart.de/json-blockly-einlesen-parsen-verarbeiten/
                                            Ich schau mir das mal an.
                                            UncleSam oldi-2000 2 Replies Last reply Reply Quote 0
                                            1.2k
                                            40
                                            6804
