      M.M. @FoxRo last edited by M.M.
      @foxro Das ist was dauernd (jede Millisekunde ein Eintrag) durch das log läuft.
      Ein eigenes Skript kann das nicht verursachen denn das würde auch getriggert werden wenn shuttercontrol nicht läuft.
      2021-03-10 10:06:21.480  - debug: shuttercontrol.0 (26608) Starting up shutters living area: 07:30 debug 8
      2021-03-10 10:06:21.481  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 08:00
      2021-03-10 10:06:21.481  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 07:30
      2021-03-10 10:06:21.481  - debug: shuttercontrol.0 (26608) check IsEqual : 07:30 08:00
      2021-03-10 10:06:21.481  - debug: shuttercontrol.0 (26608) check IsEqual : 07:17 08:00
      2021-03-10 10:06:21.481  - debug: shuttercontrol.0 (26608) check IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.482  - debug: shuttercontrol.0 (26608) yes, IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.482  - debug: shuttercontrol.0 (26608) Starting up shutters sleep area: 07:30 debug 8
      2021-03-10 10:06:21.482  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 08:00
      2021-03-10 10:06:21.483  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 07:30
      2021-03-10 10:06:21.483  - debug: shuttercontrol.0 (26608) check IsEqual : 07:30 08:00
      2021-03-10 10:06:21.483  - debug: shuttercontrol.0 (26608) check IsEqual : 07:17 08:00
      2021-03-10 10:06:21.483  - debug: shuttercontrol.0 (26608) check IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.483  - debug: shuttercontrol.0 (26608) yes, IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.483  - debug: shuttercontrol.0 (26608) Starting up shutters children area: 07:30 debug 8
      2021-03-10 10:06:21.484  - debug: shuttercontrol.0 (26608) check IsLater : 18:49 20:00
      2021-03-10 10:06:21.484  - debug: shuttercontrol.0 (26608) check IsEarlier : 18:49 20:00
      2021-03-10 10:06:21.484  - debug: shuttercontrol.0 (26608) yes, IsEarlier : 18:49 20:00
      2021-03-10 10:06:21.484  - debug: shuttercontrol.0 (26608) Shutdown shutters living area: 18:49 debug 7
      2021-03-10 10:06:21.484  - debug: shuttercontrol.0 (26608) shutterDownLiving
      2021-03-10 10:06:21.485  - debug: shuttercontrol.0 (26608) Shutdown shutters children area: 18:49 debug 7
      2021-03-10 10:06:21.486  - debug: shuttercontrol.0 (26608) Shutdown shutters sleep area: 18:49 debug 7
      2021-03-10 10:06:21.487  - debug: shuttercontrol.0 (26608) late down at 22:15
      2021-03-10 10:06:21.487  - debug: shuttercontrol.0 (26608) complete down at 22:00
      2021-03-10 10:06:21.488  - debug: shuttercontrol.0 (26608) Auto Living is: false
      2021-03-10 10:06:21.491  - debug: shuttercontrol.0 (26608) shutterDriveCalc
      2021-03-10 10:06:21.491  - debug: shuttercontrol.0 (26608) calculate astrodata ...
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) goldenHourEnd today: 07:29
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) goldenHour today: 17:37
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) current day: 3
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) Sunrise today: 06:47
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) Sunset today: 18:19
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) Starting up shutters GoldenHour area: 07:59
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) Shutdown shutters GoldenHour area: 18:07
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) Starting up shutters Sunrise area: 07:17
      2021-03-10 10:06:21.492  - debug: shuttercontrol.0 (26608) Shutdown shutters Sunset area: 18:49
      2021-03-10 10:06:21.495  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 08:00
      2021-03-10 10:06:21.495  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 07:30
      2021-03-10 10:06:21.495  - debug: shuttercontrol.0 (26608) check IsEqual : 07:30 08:00
      2021-03-10 10:06:21.495  - debug: shuttercontrol.0 (26608) check IsEqual : 07:17 08:00
      2021-03-10 10:06:21.495  - debug: shuttercontrol.0 (26608) check IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.495  - debug: shuttercontrol.0 (26608) yes, IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.495  - debug: shuttercontrol.0 (26608) Starting up shutters living area: 07:30 debug 8
      2021-03-10 10:06:21.496  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 08:00
      2021-03-10 10:06:21.496  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 07:30
      2021-03-10 10:06:21.496  - debug: shuttercontrol.0 (26608) check IsEqual : 07:30 08:00
      2021-03-10 10:06:21.498  - debug: shuttercontrol.0 (26608) check IsEqual : 07:17 08:00
      2021-03-10 10:06:21.499  - debug: shuttercontrol.0 (26608) check IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.499  - debug: shuttercontrol.0 (26608) yes, IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.499  - debug: shuttercontrol.0 (26608) Starting up shutters sleep area: 07:30 debug 8
      2021-03-10 10:06:21.501  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 08:00
      2021-03-10 10:06:21.501  - debug: shuttercontrol.0 (26608) check IsLater : 07:17 07:30
      2021-03-10 10:06:21.501  - debug: shuttercontrol.0 (26608) check IsEqual : 07:30 08:00
      2021-03-10 10:06:21.501  - debug: shuttercontrol.0 (26608) check IsEqual : 07:17 08:00
      2021-03-10 10:06:21.502  - debug: shuttercontrol.0 (26608) check IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.502  - debug: shuttercontrol.0 (26608) yes, IsEarlier : 07:17 07:30
      2021-03-10 10:06:21.502  - debug: shuttercontrol.0 (26608) Starting up shutters children area: 07:30 debug 8
      2021-03-10 10:06:21.503  - debug: shuttercontrol.0 (26608) check IsLater : 18:49 20:00
      2021-03-10 10:06:21.503  - debug: shuttercontrol.0 (26608) check IsEarlier : 18:49 20:00
      2021-03-10 10:06:21.503  - debug: shuttercontrol.0 (26608) yes, IsEarlier : 18:49 20:00
      2021-03-10 10:06:21.503  - debug: shuttercontrol.0 (26608) Shutdown shutters living area: 18:49 debug 7
      2021-03-10 10:06:21.503  - debug: shuttercontrol.0 (26608) shutterDownLiving
      2021-03-10 10:06:21.504  - debug: shuttercontrol.0 (26608) Shutdown shutters children area: 18:49 debug 7
      2021-03-10 10:06:21.505  - debug: shuttercontrol.0 (26608) Shutdown shutters sleep area: 18:49 debug 7
      2021-03-10 10:06:21.506  - debug: shuttercontrol.0 (26608) late down at 22:15
      2021-03-10 10:06:21.506  - debug: shuttercontrol.0 (26608) complete down at 22:00
      2021-03-10 10:06:21.506  - debug: shuttercontrol.0 (26608) Auto Sleep is: false
      2021-03-10 10:06:21.548  - info: host.buanet-iobroker instance system.adapter.shuttercontrol.0 terminated with code 0 (NO_ERROR)
      Der letzte Eintrag war als ich den Adapter gestoppt habe.
      • simatec
        simatec Developer Most Active @M.M. last edited by
        @m-m Was hast du denn im Config Menü eingetragen?
          M.M. @simatec last edited by
          @simatec Der Screenshot kommt vom Handy daher sieht das so verschoben aus.
          Sag nicht dass ich mir damit eine eigene Feedback Schleife gebaut habe?!
          Ich habe dort nicht meinen DP hinterlegt weil der über einen Toggle in der VIS 0 und 1 (type number) zurück liefert und nicht true oder false.
            @simatec Das ist das Blockly Skript was nach Änderung meines DP die DP in shuttercontrol ändert:
            • simatec
              @m-m sagte in Test Adapter shuttercontrol v1.1.x:
              Da hast du dir eine sehr schöne Schleife gebaut ... Die Objekte werden von shuttercontrol gesetzt und dürfen da nicht eingetragen werden, da im Umkehrschluss die Objekte auf den Eintrag in der Config reagieren.
              Also hast du jetzt immer schön eine true ... false ... true ... Schleife
                @simatec Perfekt 😐
                Ich lese mal etwas über virtuelle Datenpunkte nach und wie ich aus 0 und 1 true und false generiere, bzw. zuerst ob ich dort evtl. einen DP vom Typ number eintragen kann.
                Vielen Dank!
                • simatec
                  @m-m Nein ... der state, der dort eingetragen werden kann muss true/false sein
                  S M 2 Replies Last reply Reply Quote 1
                    StefanW @simatec last edited by
                    kann ich mit diesem Punkt eine Steuerung bei zu starkem Wind einbauen?
                    Wert des Fenster/Tür Sensors im geschlossenen Zustand:
                    Hier wird der Wert festgelegt den der Auslöser unter Objekt-ID des Fenster/Tür Kontaktes (z.B. Fenster- oder Drehgriffkontakt) hat, bei der die Rollladenautomatik unbegrenzt fahren darf.
                    Es können Werte wie true, false, 0, 1 oder 2 ausgewählt werden.
                    Ist der Rollladen nicht in der obersten Position und ändert sich der hier angegebene Sensorstatus, fährt der Rollladen auf die Rollladenhöhe bei öffnen des Fensters oder Tür.
                    Wenn ich in einem Blockly mir einen Datenpunkt erstelle, der bei true die Steuerung zulässt und eben bei false nicht.
                    Wenn sich der Wert ändert fährt die Jalousie nach oben?
                      M.M. @StefanW last edited by M.M.
                      @stefanw Das wird nicht funktionieren aber Du kannst ja ein Script schreiben was bei Bedarf den entsprechenden Button zum schließen bzw. öffnen in shuttercontrol „drückt“ (über aktualisiere).
                        @simatec Ich habe mir jetzt unter userdata die drei DP erstellt und steuere die im JS an. Diese DP habe ich dann in shuttercontrol in die config übernommen. Läuft.
                        Danke nochmals.
                          mabeca96 @FoxRo last edited by
                          @foxro Cool das habe ich gefunden 🙂
                          machst du auch eine Verknüpfung zum tr64 Adapter um die Anwesenheit zu setzen, oder machst du das "manuell"
                            StefanW @M.M. last edited by
                            schade, dachte das wäre eine gute Idee 😵
                            Allerdings habe ich dann die Herausforderung, das ich die Jalousien & Rollläden unterschiedlich behandeln muss da eine Markise ja viel früher eingefahren wird.
                            Also hilft mir der Button "open all" nicht weiter, deshalb habe ich mir überlegt das ich dafür dann den Schlafbereich benutze.
                            Die Jalousie wird aber durch Sonnenauf- bzw. Sonnenuntergang gesteuert, da habe ich ja dann keine Möglichkeit den Bereich zu definieren.
                            Wäre Super wenn noch jemand eine Idee hätte, Danke.
                            Stefan
                            da_Woody F 2 Replies Last reply Reply Quote 0
                            • da_Woody
                              da_Woody @StefanW last edited by
                              @stefanw wieso? du kannst in den zeiteinstellungen ja extra einstellen.
                                FoxRo @mabeca96 last edited by
                                @mabeca96 said in Test Adapter shuttercontrol v1.1.x:
                                Nein, bin da noch manuell unterwegs, allerdings in Kombination mit der Kalenderintegration für Ferienabwesenheit, Alarmanlage und Anwesenheitssimulation. Bei Ferien wird zusätzlich die Heizung runter und rechtzeitig wieder hoch gefahren, damit wir nicht in eine kalte Bude zurück kommen 😂
                                  FoxRo @StefanW last edited by
                                  @stefanw said in Test Adapter shuttercontrol v1.1.x:
                                  Stefan
                                  Was für Aktoren hast Du? Viele Aktoren haben auch direkte Objekte für "Wetter Alarme" zb. Wind, Regen, Frost.
                                  Dann könntest bei Wind da direkt drauf einwirken und die Markise würde auch nicht rausfahren, wenn jemand diese bei Wind oder Regen versehentlich ausfahren will.
                                    StefanW @FoxRo last edited by
                                    @foxro
                                    Ich habe die Rollladen Aktoren von HM im Einsatz, da ist mir keine Funktion bekannt.
                                    Eventuell wenn ich eine Wetterstation von HM hätte könnte ich es in der CCU umsetzen, bei mir ist aber eine Froggit 1000 Pro.
                                    Stefan
                                    • Z
                                      zahnheinrich last edited by
                                      @simatec
                                      Hallo simatic,
                                      vielen Dank für Deinen tollen Adapter, mit dem ich seit längerem erfolgreich meine Rolläden betreibe.
                                      Kürzlich habe ich ein Feature schmerzlich vermisst:
                                      Einer der vielen Rolladen hatte sich verhakt. Ein schnelles stoppen der Fahrt wäre toll gewesen.
                                      Den zugehörigen Rolladen in der App herauszusuchen, in der Visualisierung zu öffnen und zu stoppen (was natürlich geht) hat gefühlt ziemlich lange gedauert.
                                      Ein Datenpunkt "stopAll", analog dem "openAll"/"closeAll", im Adapter wäre Klasse!
                                      Evtl. könntest Du einen solchen in zukünfige releases einbauen?
                                      Vielen Dank für Deine Arbeit!!
                                      Ein schönes WE
                                      Ulrich
                                        Ja.rod last edited by
                                        von meinen drei Rolläden im Wohnbereich wird einer unter "Art der Steuerung für schließen des Rollläden" = Wohnbereich geschlossen und diese beiden anderen mit "Wohnbereich (Automatik)". Geöffnet werden sie aber alle drei ohne die Automatik.
                                        Ich habe jetzt festgestellt, dass ich über den Button "closeliving" nur den ersten ohne "Automatik" schließen kann, die anderen beiden bleiben offen. Öffnen kann ich wiederum alle drei Rollläden. Ist das so? Gibt es evtl eine Einstellung die ich noch machen muss?
                                        Ich hoffe ich habe mich verständlich ausgedrückt.
                                        Gruß Jarod
                                        • Negalein
                                          @FoxRo
                                          Mir ist heute was aufgefallen und möchte kurz nachfragen, ob das normal/gewollt ist.
                                          Ich hab als Auf/Zu Sonnenauf- und Untergang eingestellt. Funktioniert auch perfekt.
                                          Nachmittag hat die Kleine das Rollo manuell mit der Wippe ein Stück zu gemacht.
                                          Dann wurde es bei Sonnenuntergang (Rollo war noch in der Position wie Nachmittag) aber nicht automatisch geschlossen.
                                          Auch ein komplettes öffnen des Rollo, nachdem es nicht automatisch geschlossen wurde, änderte nichts. Es blieb offen.
                                          Kann man das einstellen, dass es trotzdem fährt, auch wenn es vor der Schaltzeit manuell betätigt wurde?
                                          • da_Woody
                                            da_Woody @Negalein last edited by
                                            @negalein d'ere, war da nicht schon mal was? schon mal in die extraeinstellungen gelinst? da is was mit automode...
                                            332
                                            7408
                                            10566966
