    4. [gelöst > thx] Parser -> Bitte, Starthilfe benötigt!
      liv-in-sky @Homoran last edited by
      @homoran soll ich mal versuchen - in javascript ist das einfacher ?
        @metaxa
        @sigi234
        Hier mein hoffentlich jetzt richtiges Ergebnis:
         <variables>
           <variable id="=E+T~M83h!;Qa@1%T5]V">counter</variable>
           <variable id="#i8`+4mTz`V/Q{ZFJ6}^">Impfdaten</variable>
           <variable id=".oZgZ5?e1dk=ET7O7KXj">result</variable>
           <variable id="@.m!76$[8INh~|yVWDuZ">Start</variable>
           <variable id="?#3=k3K!$DG9x}|GzS{T">Ende</variable>
           <variable id="`=s$RTDY)K?p7V,KpNX,">Tagesdaten</variable>
           <variable id="X+fC8r`0g9rhY;Z[YX(+">Teilergebnis</variable>
           <variable id="-7H9Yz)Y2FoU6iJN*[/T">Pos1</variable>
           <variable id="C~Mb5oUlMSvvfp)+)1X0">Pos2</variable>
           <variable id="$/[ywb.QkhZ9z%UOIK!5">Erstimpfung</variable>
           <variable id="|i,(bTMSZ{7s8EF#]t~5">Pos3</variable>
           <variable id="398zAvUbUxJ#LFFMRlz5">Pos4</variable>
           <variable id="QCLZY+BsFY+*JHi:(b-b">Zweitimpfung</variable>
         </variables>
         <block type="request" id="AIbk+la{/y6KNTpb$m$A" disabled="true" x="-437" y="12">
           <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
           <field name="WITH_STATEMENT">TRUE</field>
           <field name="LOG"></field>
           <value name="URL">
             <shadow type="text" id="Yn1;:g1?,_wv=nV*Aagk">
               <field name="TEXT">https://pipe.orf.at/corona-dashboard/data/timeline-eimpfpass.csv?origin=orf.at</field>
             <block type="debug" id="X?M%.P(}(C(RuJG)d#XH">
               <value name="TEXT">
                 <shadow type="text" id="RUUwjL1`]J5|-/-bZ*AJ">
                 <block type="variables_get" id="EG*~/|l,0d!RWTl916.y">
                   <field name="VAR" id=".oZgZ5?e1dk=ET7O7KXj">result</field>
                 <block type="update" id="B]i-rmX=69,UOWca;x+5">
                   <field name="OID">0_userdata.0.Oesi_Impfen.all</field>
                   <field name="DELAY_MS">1000</field>
                   <field name="UNIT">ms</field>
                     <block type="variables_get" id=":Y#fi{;uneuI`o+su~mm">
         <block type="variables_set" id="aIY%0e*L_kdj{*2/DhM{" x="-437" y="287">
           <field name="VAR" id="=E+T~M83h!;Qa@1%T5]V">counter</field>
             <block type="math_number" id="{AIDi6+[bJOfrTUWUK#/">
               <field name="NUM">0</field>
             <block type="variables_set" id="at?bJ-16v:@)%y1Z=gQ^">
               <field name="VAR" id="#i8`+4mTz`V/Q{ZFJ6}^">Impfdaten</field>
                 <block type="get_value" id="(f]kR}6``3Zwm3cPQ=PZ">
                 <block type="variables_set" id="FM9U5-BGK6YFY(#G?Mi*">
                   <field name="VAR" id="@.m!76$[8INh~|yVWDuZ">Start</field>
                     <block type="lists_indexOf" id="=p{f%4O!t8ny|cDxZZi[">
                       <field name="END">LAST</field>
                         <block type="variables_get" id="t_nSadkK?QO4=Lrm.vnP">
                       <value name="FIND">
                         <block type="text" id="9Cd-X%3+wExtAQjxCVLc">
                           <field name="TEXT">Österreich</field>
                     <block type="variables_set" id="PU!?%_9ibNFHf,dpk/V^">
                       <field name="VAR" id="?#3=k3K!$DG9x}|GzS{T">Ende</field>
                         <block type="lists_length" id="nNX^gTFFt~$lT6hK.!Y9">
                             <block type="variables_get" id=".k50ns`o|vgxBSe/zTq5">
                         <block type="variables_set" id="t:=GP@cNa/x4s]0w|qb2">
                           <field name="VAR" id="`=s$RTDY)K?p7V,KpNX,">Tagesdaten</field>
                             <block type="text_getSubstring" id="T!)bvx,eAHmRszaMODaZ">
                               <mutation at1="true" at2="true"></mutation>
                               <field name="WHERE1">FROM_START</field>
                               <field name="WHERE2">FROM_START</field>
                               <value name="STRING">
                                 <block type="variables_get" id="~($09)5T`EROzX8?ySI-">
                               <value name="AT1">
                                 <block type="variables_get" id="jo9:]V{4BRN|/ve$YY|K">
                               <value name="AT2">
                                 <block type="variables_get" id="c=^;3s:m#={7l?mbK?bb">
                             <block type="variables_set" id="py_f*U{~=Wyn3ot5I|QR">
                                 <block type="math_arithmetic" id="SDc,9:Mye![|+hdHWm`#">
                                   <field name="OP">ADD</field>
                                     <shadow type="math_number" id="l{!!%m4!ew|SVh*1K/K4">
                                       <field name="NUM">1</field>
                                     <block type="lists_indexOf" id="+f,/mWhnml8gDZc3Vz$/">
                                       <field name="END">FIRST</field>
                                         <block type="variables_get" id="{ymsj406HXe,9fBAEV_l">
                                       <value name="FIND">
                                         <block type="text" id="[=byRNb(a[wGCc6o^RpS">
                                           <field name="TEXT">;</field>
                                     <shadow type="math_number" id="KdyoU$cEt+_[2?9a^j^I">
                                 <block type="variables_set" id="Lq:9(l.xlqgwv6HPLmJ)">
                                     <block type="math_arithmetic" id="nmy7Y#{6I;]KD+f5S]xd">
                                         <shadow type="math_number" id="6/Scvx*[#r}+5H?+K~ra">
                                         <block type="variables_get" id="$1a/4]S_b1A0jO:2{gt=">
                                         <shadow type="math_number" id="@qj_]UZz]a5av8le2|SN">
                                           <field name="NUM">2</field>
                                     <block type="variables_set" id="nj9tIj$~zO*aq4Y8%i|^">
                                         <block type="lists_length" id="6N2j8h@[eW8g!5HwtVbj">
                                             <block type="variables_get" id="F~Q4[m/^Xu+cRZExXtz_">
                                         <block type="variables_set" id="~7ZoKLA[/ucCaAy^+^?N">
                                           <field name="VAR" id="X+fC8r`0g9rhY;Z[YX(+">Teilergebnis</field>
                                             <block type="text_getSubstring" id="Ww]R.sc+)~*%76#7k[|D">
                                                 <block type="variables_get" id="r-L/FkO917r()g/tV2Q=">
                                               <value name="AT1">
                                                 <block type="variables_get" id="E)}(^*mQ9(GG~$P(lR;L">
                                               <value name="AT2">
                                                 <block type="variables_get" id="BCWg8r^}#wY`jo$)lUI9">
                                             <block type="controls_repeat_ext" id="($e.(dE+$k,]U6`[E;bj">
                                               <value name="TIMES">
                                                 <shadow type="math_number" id="t{3W(}(uez%+xLdPl_VH">
                                               <statement name="DO">
                                                 <block type="variables_set" id="Tk7JCI=Mb;mBw+q*kfZx">
                                                     <block type="math_arithmetic" id="F{QQ{j2@r.`Kl1wgDPk5">
                                                         <shadow type="math_number">
                                                         <block type="lists_indexOf" id="}|(zy1fFNUG.`wWcJvvU">
                                                             <block type="variables_get" id="oyTb@8-bk[gf41+SpnrM">
                                                           <value name="FIND">
                                                             <block type="text" id="eBPm;Ht5srZZ0?oaKJWF">
                                                         <shadow type="math_number" id=":SJD9?wy7CfMJvAIOvzP">
                                                     <block type="variables_set" id="SO,W?od/~fd=Vd|K-gzS">
                                                         <block type="lists_length" id="{SM:`R5WoTUvg:a,9M}p">
                                                             <block type="variables_get" id="R0[zZLXWBQcv4c%{4D.U">
                                                         <block type="variables_set" id="23{2IYpU$+o%pu2ut@EF">
                                                             <block type="math_arithmetic" id="SPU];Z}}+gHX75rnN.rY">
        <shadow type="math_number" id="))!J]Js,3Mh,T|X2^4B/">
        <block type="variables_get" id="U@nC6_YQ$QpOW*vTXP*!">
        <shadow type="math_number" id="G))41V@qC7{U:]fvzTf8">
        <block type="variables_get" id="~}#0VO-jealcBYu0Ei*H">
                                                             <block type="variables_set" id="]dZui;IrrOo4MeTDyr:4">
        <block type="text_getSubstring" id="=$[PEr?a*Fq|e!?$,GoI">
        <block type="variables_get" id="?P/[TZYVMp_Ie!CX;?+p">
        <value name="AT1">
        <block type="variables_get" id=":0^+9@6,-n,HpakbkCMc">
        <value name="AT2">
        <block type="variables_get" id="ol2P(W:YKHq(a4]!FSw`">
                                                 <block type="variables_set" id="=EFzl7b1ChLP@VqT~!1$">
                                                   <field name="VAR" id="-7H9Yz)Y2FoU6iJN*[/T">Pos1</field>
                                                     <block type="variables_get" id="2?m]ExDCNZ)]B:N_d*j8">
                                                     <block type="variables_set" id="{C))E{o%!,5j%|.W_8Mx">
                                                       <field name="VAR" id="C~Mb5oUlMSvvfp)+)1X0">Pos2</field>
                                                         <block type="math_arithmetic" id="Pds?)JXtU5e(P6Qt*]b7">
                                                             <shadow type="math_number" id="Dx#6)lsllsi:Ga/B63T6">
                                                             <block type="variables_get" id="LeAuB265K_r6)(YDW+e}">
                                                             <shadow type="math_number" id="!*:%ou8x).uFAlG3+s.A">
                                                             <block type="math_arithmetic" id="7zPLP.N$m=_cdX4lfaq9">
        <shadow type="math_number" id=".S@F~lKXa{JgS{v$r]bN">
        <block type="lists_indexOf" id="Zs62[~m|Pq!Z3c~8Qm{R">
        <block type="variables_get" id="P2CLO]U#7A^Q5SJ?m)}Y">
        <value name="FIND">
        <block type="text" id="L4=KEOZ_|O?|xuf(VEU+">
        <shadow type="math_number" id="N!|oCk6lV.@%LZm_?_z4">
                                                         <block type="variables_set" id="UIL{b^#/MHLgBZ4KOZQi">
                                                           <field name="VAR" id="$/[ywb.QkhZ9z%UOIK!5">Erstimpfung</field>
                                                             <block type="text_getSubstring" id="kjEB!|@nC,EH}yNg[ml:">
        <block type="variables_get" id="5{=*^zSTKgf=_h(WM5B^">
                                                               <value name="AT1">
        <block type="variables_get" id="u[jOr.3?*_LPlT?n4bN3">
                                                               <value name="AT2">
        <block type="variables_get" id="k6:_Wqo/AZ8^6Hk8mHTk">
                                                             <block type="controls_repeat_ext" id="x/53-*+~1-!r5lKkeBO6">
        <shadow type="math_number" id="|siu`WDO(9JXhB%AYEAu">
        <block type="variables_set" id="r|`a]8lhIBor2!|`$qjC">
        <block type="math_arithmetic" id="g;iHhXH$csn%5Ec.kwr,">
        <block type="lists_indexOf" id="IFj2T,ek5D7/Tt_.%zo$">
        <block type="variables_get" id="D}_ihYTa)(/x%~^u-]dQ">
        <value name="FIND">
        <block type="text" id="$YZq6(}R2ds7vUyp-,`K">
        <shadow type="math_number" id="rpCIxSjdR@287a8LXEGC">
        <block type="variables_set" id="bGo6V#gj7X?u7~`*U:~B">
        <block type="lists_length" id=":Lc.W/{#]H4u+/Dw7R1C">
        <block type="variables_get" id="=]_rS+D]q}g$*fq9fh?c">
        <block type="variables_set" id="2;TxG9acF5AQ-%`eGhin">
        <block type="math_arithmetic" id="1fA[.%0uCKAUjG+6e=!m">
        <block type="variables_get" id="pGQdMIv`wRO_;Bm0UceR">
        <block type="variables_get" id="2@vS0uVSus*lxz8zUjFw">
        <block type="variables_set" id="etPN6X)cS%A~.{e4JCwM">
        <block type="text_getSubstring" id="b_5FhF}wpiV0#oE,vmuQ">
        <block type="variables_get" id="`y1L?pECLh(,AL2+PrXd">
        <value name="AT1">
        <block type="variables_get" id="Ef4(Fj=^jkfUx^]nGhu+">
        <value name="AT2">
        <block type="variables_get" id="g%98c_GZ?X~Mgipt|1Z;">
        <block type="variables_set" id="Z#qG9{gELx2JQ7w%@T7h">
        <field name="VAR" id="|i,(bTMSZ{7s8EF#]t~5">Pos3</field>
        <block type="math_arithmetic" id="?Qx]9FemEOpDqBW3aXOM">
        <shadow type="math_number" id="(%}cL=PDGIu$ic_.0@l]">
        <block type="variables_get" id="RNpw;.)QeQB^npdI[Rze">
        <shadow type="math_number" id="/GskCsitr.s)ZlI377x3">
        <block type="variables_set" id="i0hUq`GvMvK|g%^bTQS|">
        <field name="VAR" id="398zAvUbUxJ#LFFMRlz5">Pos4</field>
        <block type="math_arithmetic" id="`cQs.hTIk5t?0+ri/j[%">
        <block type="variables_get" id="uPJ*XiDa~+_e2;r%z+{r">
        <block type="math_arithmetic" id=")R{.fbxk7Q6sXdU|kj.q">
        <block type="lists_indexOf" id="IH-%=d5:B-|ozrwp_,2e">
        <block type="variables_get" id="@JnB!Y/u]2E0U1d=3Zd/">
        <value name="FIND">
        <block type="text" id="fe2K~0AT]?MUC+,[7:ZC">
        <shadow type="math_number" id="4YI:e3AJ[sXD2daPpXF}">
        <block type="variables_set" id="PgloG#*oh.@4}bY@+eWO">
        <field name="VAR" id="QCLZY+BsFY+*JHi:(b-b">Zweitimpfung</field>
        <block type="text_getSubstring" id="[AfOJJ^1KDL!#i_#K)T*">
        <block type="variables_get" id="7-/IRvqG|a7Wjm@]??42">
        <value name="AT1">
        <block type="variables_get" id="|(yy_=(1paS4?6M_eNyw">
        <value name="AT2">
        <block type="variables_get" id="tfCc63h[64rJac(B/wT#">
        <block type="debug" id="_^,/P(k@O)MV_@SXBo$c" disabled="true">
        <value name="TEXT">
        <shadow type="text" id="L|H6mZ;tnSz98{=J7$o8">
        <block type="variables_get" id="se[mjppOT_6$PeBcm@)4">
        <block type="debug" id=";dzlDD#(wXqaM5K2COlv">
        <value name="TEXT">
        <shadow type="text" id="}^67J##hn,9E,@{3G#cv">
        <block type="text_join" id="MrQG0inZ+,s|2YooEoiq">
        <mutation items="4"></mutation>
        <value name="ADD0">
        <block type="text" id="8E%8RFIcjjE=f*^XlvPk">
        <field name="TEXT">Anzahl Erstimpfungen: </field>
        <value name="ADD1">
        <block type="variables_get" id="!_*p1+!gpJor8c%+jV(q">
        <value name="ADD2">
        <block type="text" id="0zpc$;#}Do)PzfJW-29n">
        <field name="TEXT">; Anzahl Zweitimpfungen: </field>
        <value name="ADD3">
        <block type="variables_get" id="BeFHRkL;*go=%9{,k/{6">
          Homoran Global Moderator Administrators @liv-in-sky last edited by
          @liv-in-sky sagte in Parser -> Bitte, Starthilfe benötigt!:
          gerne!
          Das Ganze ist sowieso nur eine riesige Krücke.
          Wenn das jemand sieht, der Ahnung davon hat wird der lachend vom Stuhl fallen.
          Wie bereits früher geschrieben nutze ich solche Aufgaben auch um mich selber weiterzubilden.
          Das beginnt ja schon damit, dass ich keine zwei Zahlen aus der Website herausbekomme, sondern nur die im Hintergrund liegende Tabelle, die täglich länger wird.
          Damals hatte mir bei einem ähnlichen fall @OliverIO geholfen (glaube ich zumindest) versteckte Daten zu finden.
          Hab das Thema jetzt genutzt um es auch auf diese Weise zu versuchen.
          Der zweite Dilettantismus beginnt dann mit meiner Unfähigkeit diese csv-Datei in sinnvolle Fragmente zu zerlegen, auf die dann einfach zuzugreifen ist.
          Statt dessen arbeite ich hier mit Stringsuchen, zählvariablen usw. und bekomme selbst das nicht so hin, wie ich es will, so dass ich empirisch an den Zählvariablen schraube damit das Ergebnis reproduzierbar (??) gleich bleibt
          liv-in-sky 1 Reply Last reply Reply Quote 1
            @homoran solange dich das nicht stört
            die zeilen habe ich - mein problem:
            @sigi234 - was genau für daten brauchst du - eine zeile enthält 64 einträge - die kann ich nicht alle anzeigen - wir müssen das einschränken - welche spalten interessieren ?
            die über 800 zeilen sind nicht das problem - da kann man dann filtern oder suchen nach einer bestimmten region
            Homoran metaxa 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @liv-in-sky last edited by Homoran
              Sieh dir das mal an:
              https://forum.iobroker.net/assets/uploads/files/1615385390117-oesiimpfen_tabelle.png
              Interessant sind die Spalten G und I, sowie evtl. die Quoten in H und J
              die zeilen habe ich
              aus "wissenschaftlichem" Interesse: wie?
                @homoran ja, das kenne ich - wenn du das csv file bis zum ende nach rechts ansiehst, sind das 64 spalten - das paßt auf keinen bildschirm - selbs wenn du dir in der vis eine ganze eite dafür nimmst, werden wohl nur 20 spalten sinn machen - aber die sinnvollen muss man erst finden - bzw evtl müßte man mehrere spalten in eine addieren oder sowas
                • metaxa
                  metaxa @liv-in-sky last edited by metaxa
                  Als Urheber dieser Bitte (Anforderung):
                  • Datum (Filter)
                  • BundeslandID (Filter)
                  • Bevölkerung
                  • Name
                  • Teilgeimpfte
                  • Vollimmunisierte
                  Ansich hätten mir die paar - aber aktuellen - Zahlen von https://orf.at/corona/daten/impfung interessiert, da wußte ich nch nicht was @Homoran findet. Leider sind in der csv keine aktuellen Zahlen.
                  Lieben Dank Euch Allen!
                  mxa
                  Homoran liv-in-sky 2 Replies Last reply Reply Quote 0
                    @liv-in-sky Ja!
                    die interessanten Daten liegen eigentlich alle vorne.
                    Mit
                    • Name [D]
                    • Einwohnerzahl [C]
                    • Teilgeimpfte [G]
                    • Vollimmunisierte [I]
                    kann man auch die Impfquoten errechnen
                      Homoran Global Moderator Administrators @metaxa last edited by Homoran
                      @metaxa sagte in Parser -> Bitte, Starthilfe benötigt!:
                      doch!
                      die vom Vortag
                      gaaaaanz unten
                      Da kommen genau deine markierten Werte
                      und @sigi234 hat kurze Zeit später die csv heruntergeladen und schon die Werte von gestern bekommen
                      16:41:30.142 info javascript.0 (6191) script.js.Oesi_Impfen: Anzahl Erstimpfungen: 608045; Anzahl Zweitimpfungen: 252097;
                      • OliverIO
                        OliverIO last edited by
                        @homoran said in Parser -> Bitte, Starthilfe benötigt!:
                        gerne!
                        1. Es lohnt sich immer mal nachzuschauen, ob die Seiten solche Daten nicht selbst irgendwo laden. Das wird heute immer moderner, da dann die Server entlastet werden, da die Rechenarbeit alles in den Clients statt finden und man keine HTML-Seiten auf dem Server erzeugen muss. So werden einfach der HTML-Rahmen, Javascript und die Daten statisch ausgeliefert und der einzelne erzeugt dann sein Layout selbst.
                        2. Der Regex-Parser funktioniert nur, wenn die Daten ohne größere Verschlüsselung oder Login (Basic-Authentication mal ausgenommen, obwohl das eigentlich heute nicht mehr funktionieren sollte) erreichbar ist.
                          Sobald eine mehrstufige Analyse der Daten notwendig ist, wird es schwierig.
                        Aus CSV-Daten ein bestimmtes Feld herauszusuchen, ist für mich 2 Stufig.
                        Zuerst die Zeile lesen, dann innerhalb einer Zeile das richtige Feld heraussuchen.
                        allerdings würde ich mich bei CSV nicht mit RegEx herumschlagen, sondern einfach eine der zahlreichen Bibliotheken verwenden, die es wirklich extrem einfach macht, die zu handhaben.
                        ich selbst habe vor kurzem die folgende unter node verwendet:
                        https://www.npmjs.com/package/csv-parse
                        scheint auch im browser verwendbar zu sein, das hab ich selbst aber noch nicht ausprobiert, da brauch man wahrscheinlich noch requirejs dazu.
                        die bibliothek kann auch mit extrem großen csv dateien umgehen, die gar nicht mehr in den speicher passen, da diese im stream verarbeitet wird.
                        das einlesen einer CSV-Datei sieht dann bspw bei synchroner Anwendung wie folgt aus
                        const parse = require('csv-parse/lib/sync')
                        const input = `
                        "key_1","key_2"
                        "value 1","value 2"
                        const records = parse(input, {
                          columns: true,
                          skip_empty_lines: true
                          @metaxa
                          @sigi234
                          zwischenstand:
                          datum ist eigentlich überflüssig, wenn täglich update ist - ich verarbeite nur daten, die nicht älter als 24h sind - könnte anstatt (0/0) stehen
                          evtl noch ältere daten evtl gestern oder so
                          was fällt euch noch ein
                            die Quoten = %-Bevölkerung
                              liv-in-sky last edited by liv-in-sky
                              @metaxa
                              @sigi234
                              das bundesland evtl weg und dafür der name an den anfang ? oder braucht ihr diese nummer ?
                              evtl die zahlen in tusend mit einer kommastelle ?
                                sigi234 Forum Testing Most Active @liv-in-sky last edited by sigi234
                                @metaxa
                                @sigi234
                                Als Option?
                                Ja
                                  liv-in-sky @sigi234 last edited by
                                  @sigi234
                                  @metaxa
                                  wie wär's damit
                                  Homoran 1 Reply Last reply Reply Quote 2
                                    @liv-in-sky Das ist Spitze!
                                    stell dich aber schon mal darauf ein, dass sich die Tabelle ändern wird, wenn noch Johnson&Johnson und noch weitere Hersteller kommen
                                    Wie hast du jetzt die csv in Zeilen umgebrochen?
                                      @homoran ist nicht so wild - sind nur 3 zeilenänderungen mehr pro impfstoff 🙂
                                        liv-in-sky @metaxa last edited by
                                        @metaxa die beiden anderen zahlen , die du wolltest sind ja in der tabell drin - soll ich die irgendwie markieren oder ist es so ok ?
                                        metaxa 1 Reply Last reply Reply Quote 0
                                          hier das script - zum testen
                                          datenpunkt unter " javascript.0.Tabellen@Liv.ImpfenAUTTabelleVIS " als binding ( {javascript.0.Tabellen@Liv.ImpfenAUTTabelleVIS} ) in html standard widget unter HTML eintragen
                                           //@liv-in-sky 2021  13.3.-09:00
                                          // DAS WIDGET IN DER VIS
                                          // das Standard html-Widget wird genutzt in der VIS - dazu den DP javascript.x.Tabellen@Liv.TestTabelleVIS.HTMLTableVis als binding angeben d.h.
                                          // im html-teil des widgets wird dier daten punkt in geschweiften klammern angegeben z.B. {javascript.0.Tabellen@Liv.TestTabelleVIS.HTMLTableVis}
                                          // @ts-ignore
                                          let braucheEinVISWidget=true;                          // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                          let  dpVIS="ImpfenAUTTabelleVIS"                            // WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  Ist der Name zum datenpunkt anlegen
                                          let braucheEinJSON=false;                               // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                          let  dpJSON="ImpfenAUTTabelleJSON"                          // WICHTIG wenn braucheEinJSON auf true gesetzt !!   Ist der Name zum datenpunkt anlegen
                                          let mySchedule=" 5,30 5,12,14 * * * ";                         // jede minute
                                          //ZUSÄTZLICH VARIABLEN
                                          let sortierenEIN=true;
                                          let welcheSortierung=1;          // je nach spalte von 0 bis 6
                                          let geteiteVersionsAnzeige=false; // not in use "!!!!!!"
                                          const schalterUmrahmung="1" ;                             //wenn überschriften buttons sind , den rahmen mit 0 wegmachen
                                          let myFav="Oberösterreich";
                                          let myFavColor="#9CD8EE";                     // normal: den selben wert wie hier :htmlFarbFelderschrift  eintragen
                                          let mitTausendBezeichner=true;
                                          let myFavColor1Zeile="#F5F9FA"               //Österreich   // normal: den selben wert wie hier :htmlFarbFelderschrift eintragen
                                          let sichtbareBlaender=["Österreich","Wien","Niederösterreich","Vorarlberg","Tirol","Salzburg","Oberösterreich","Steiermark","Kärnten","Burgenland","KeineZuordnung"];
                                          let mitAbkuerzungenVonBL=true;
                                          //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3 - es MÜSSEN in allen Arrays die GLEICHE Anzahl für die Werte sein
                                          let htmlFeld=        ["NAME","EZ","GESAMT","TEIL","TEIL%","IMMUN","IMMUN%","ASTRA","PFIZER","MODERNA"];                        // GLEICHE ANZAHL !! NAME/ÜBERSCHRIFT DER SPALTE
                                          let val=             ["true","true","true","true","true","true","true","true","true","true"];             // GLEICHE ANZAHL !! HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WERDEN -  jeder val[x] muss unten in der schleife gesetzt werden !!
                                          let Feld1lAlign=     ["left","right","right","right","right","right","right","right","right","right"];                     // GLEICHE ANZAHL !! AUSRICHTUNG IN DER SPALTE
                                          let htmlSpalte1Weite=["50","auto","auto","auto","auto","auto","auto","80","80","80"];                             // GLEICHE ANZAHL !! BREITE DER SPALTE, wenn nicht auto
                                          let schalterInSpaltenUeberschrift=[false,true,true,true,true,true,true,true,true,true];                            // WENN BUTTONS INSTALLIERT WERDEN - sonst false
                                          let symbolSchalter=               ["na","&check;","&cross;"];   // SYMBOLE DER BUTTONS - standardmäßig sind die spaltennamen (htmlFeld) genutzt - werden im standard nicht genutzt
                                          //Symbole für Tabelle z.b.: ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀 🔹 ✅ ❌ ⚠️ mehr: https://emojiterra.com/de/ oder https://unicode-table.com/de/html-entities/
                                          //hier werden die styles für die tabelle definiert
                                          //ÜBERSCHRIFT ÜBER TABELLE
                                          const htmlUberschrift=true;                             // mit Überschrift über der tabelle
                                          const htmlSignature=false;                               // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                          const htmlFeldUeber='IMPFUNG';                // für Überschrift und Signature falls htmlUberschrift und htmlSignature ist true
                                          const htmlFarbUber="white";                              // Farbe der Überschrift
                                          const htmlSchriftWeite="normal";                         // bold, normal - Fettschrift für Überschrift
                                          const htmlUEberFontGroesse="18px";                       // schriftgröße überschrift
                                          //SEITENLEISTE
                                          const ichWillSeitenLeiste=true;                          // links einblenden einer Seitenleiste
                                          const nameSeitenLeiste="IMPFUNG"
                                          const breiteSeitenleiste=25;
                                          const schriftGroesseSeitenleiste=18;
                                          const abstandSeitentextVonOben=1;
                                          const htmlFarbSeiteSchrift="white";
                                          const htmlBackgroundFarbeSeitenliste="transparent";
                                          //MEHRERE TABELLEN NEBENEINANDER
                                          let mehrfachTabelle=1;                                   // bis zu 3 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3 !!!
                                          var trennungsLinie="2";                                // extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                                          const farbetrennungsLinie="#5590CA";                     // bei mehreren Tabellen nebeneinander wird ein Strich zw. den Tabellen gezogen
                                          const htmlFarbTableColorUber="white"                     // Spalten-Überschrift in der tabelle - für die einzelnen Spalten //"#BDBDBD";
                                          const htmlFarbZweiteTabelle="white";                     // Farbe der Spalten-Überschrift bei jeder 2.ten Tabelle
                                          //ÜBERSCHRIFT SPALTEN - OBERSTE ZEILE IN TAB
                                          const UeberSchriftHoehe="45";                            // Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                                          const LinieUnterUeberschrift="2";                        // Liniehoehe nur unter Spaltenüberschrift
                                          const farbeLinieUnterUeberschrift="blue";               // LinienFarbe unter Spaltenüberschrift
                                          const groesseUeberschrift=16;
                                          const UeberschriftStyle="normal"                         // möglich "bold"
                                          const UeberschriftSpalten=true;                          // ein- oder ausblenden der spatlen-überschriften
                                          //GANZE TABELLE
                                          const abstandZelle="4";                                  // legt den abstand in den zellen zum rahmen fest
                                          const zeilenAbstand=7;                                   // legt den abstand zwischen den zeilen fest
                                          const farbeUngeradeZeilen="#000000";                     // Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2 - bei "transparent" gewinnt htmlFarbTableColorGradient1
                                          const farbeGeradeZeilen="#151515";                       // Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2   - bei "transparent" gewinnt htmlFarbTableColorGradient2
                                          const weite="auto";                                      // Weite der Tabelle - verhindert das dynamische breiter werden, wenn werte unterschiedliche werte haben
                                          const zentriert=true;                                    // ganze tabelle zentriert im html Widget
                                          const backgroundAll="#000000";                           // Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                                          const htmlSchriftart="Ubuntu-Regular"                    // "Jura-DemiBold"   //"RobotoCondensed-Bold"   //"Helvetica"; .....
                                          const htmlSchriftgroesse="16px";                         // schriftgröße in den zellen
                                          const rahmenBreite="1px";                                //mit 0 ist äußerer rahmen weg
                                          //FELDER UND RAHMEN
                                          const htmlFarbFelderschrift="#CBCBCA";                   // SchriftFarbe der Felder
                                          const htmlFarbFelderschrift2="#CBCBCA";                  // SchriftFarbe der Felder für jede 2te Tabelle
                                          const htmlGragient=[150,15,50];                          // einstellung des gradienten
                                          const htmlFarbTableColorGradient1="blue";         // Gradient - Hintergrund der Tabelle - Verlauffarbe
                                          const htmlFarbTableColorGradient2="#5590CA";              // Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                          const htmlFarbTableBorderColor="grey";                   // Farbe des Rahmen - ist dieser gleich den gradienten, sind die rahmen unsichtbar
                                          let htmlRahmenLinien="cols";                             // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                          // falls eine extra html datei gebraucht wird
                                          const path = "/htmlexample.html";                        //FIlenamen definieren
                                          const home ='vis.0'                                      //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                          let   braucheEinFile=false;                              // bei true wird ein file geschrieben
                                          // AB HIER NICHTS  ÄNDERN -------------------------------------------------------------------------------------------------
                                          // AB HIER NICHTS  ÄNDERN ---------------------------------erst wieder ab Zeile 134----------------------------------------
                                          let borderHelpBottum;
                                          let borderHelpRight;
                                          let htmlcenterHelp;
                                          let htmlcenterHelp2;
                                          if(String(htmlRahmenLinien)=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                                          if(String(htmlRahmenLinien)=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                                          if(String(htmlRahmenLinien)=="none") {borderHelpBottum=0;borderHelpRight=0;}
                                          if(String(htmlRahmenLinien)=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                                          zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                                          zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                                          const htmlZentriert='<center>'
                                          const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html;  http-equiv=\"refresh\" content=\"30\"; charset=utf-8\">"+
                                                             "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                                             " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                                            // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                                             " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                                             " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                                             "td:nth-child(1) {width: "+htmlSpalte1Weite[0]+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite[1]+"}"+
                                                             " </style></head><body> <div>";
                                          //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                                          const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\""+rahmenBreite+"\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+zeilenAbstand+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
        "; font-family:"+htmlSchriftart+";background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%);\">";
                                          let htmlTabUeber4="<tr  style=\" font-family:"+htmlSchriftart+" ; height:"+UeberSchriftHoehe+"px; color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                                          const htmlTabUeber3="</tr>";
                                             let valSpalte=[] ;
                                             for(let kk=0;kk<val.length;kk++){
                                               valSpalte.push(val[kk])
                                             let extraScript=`$(document).ready(function() { `
                                             let extraScriptEnd=` });` ;
                                          for (let ff=0;ff<valSpalte.length;ff++){
        // log(valSpalte[ff]);
        if (valSpalte[ff]=="false") {
        ichWillSeitenLeiste?   extraScript=extraScript.concat(`$('td:nth-child(${(ff)+1}).toDel${dpVIS},th:nth-child(${(ff)+2}).toDel${dpVIS}').hide();`) :
        extraScript=extraScript.concat(`$('td:nth-child(${(ff)+1}).toDel${dpVIS},th:nth-child(${(ff)+1}).toDel${dpVIS}').hide();`) }
                                          const buttonScript =   '<script> function setOnOtherValue(myval) {	var Self = this;	Self.servConn.getStates(myval, (error, states) => {  console.log(states); self.servConn.setState(myval, !states[myval].val);}  )}; '
                                                              +' $( \"button.myButt'+dpVIS+'\").click(function() {  $( this ).slideUp() });'
                                                             //  +'$( "button" ).click(function() {  $(".myButt).slideUp(); setTimeout(function() { $( ".mySpan" ).text(\"wait ...\")}, 1000);  });'
                                                              +  extraScript  +  extraScriptEnd        //` $(document).ready(function() {  $('td:nth-child(10).toDel${dpVIS},th:nth-child(11).toDel${dpVIS}').hide();  $('td:nth-child(9).toDel${dpVIS},th:nth-child(10).toDel${dpVIS}').hide(); $('td:nth-child(8).toDel${dpVIS},th:nth-child(9).toDel${dpVIS}').hide(); });`    //$('#myId').trigger('change');
                                                               +'</script>'
                                          //log(extraScript  +  extraScriptEnd )
                                          //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                                          let  htmlTabUeber2_1=""
                                          for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { htmlTabUeber2_1=htmlTabUeber2_1.concat("<td width="+htmlSpalte1Weite[ue]+" align="+Feld1lAlign[ue]+" style=\"color:"+htmlFarbZweiteTabelle+"\">"+htmlFeld[ue]+"</td>")}
                                          if ( !(val.length == Feld1lAlign.length && htmlSpalte1Weite.length == htmlFeld.length && val.length == htmlFeld.length) || (mehrfachTabelle<1 || mehrfachTabelle>3) )
                                               { log("Anzahle der Definitions Arrays sind ungleich ODER mehrfachTabelle ist falsch - Script wurde gestoppt !!!","error");
                                                   // @ts-ignore
                                                   stopScript();}
                                          if(ichWillSeitenLeiste)   trennungsLinie="0" ;
                                          let langeGesamt=0;
                                          let htmlTabUeber="";
                                          let htmlOut="";
                                          let mix;
                                          let counter;
                                          let makeJsonWidget;
                                          let myObject=[];
                                          let aktiv=0; let inaktiv=0;
                                          let mitAlphabet=false;
                                          needDP();
                                          function writeHTML(){
                                                aktiv=0;  inaktiv=0;
                                              aktiv=0;  inaktiv=0;
                                          let seitenLeistenTest="";
                                          let htmlTabUeber1=htmlTabUeber4
                                          myObject=[]
                                          let helperLeerzeile=""
                                          let makeJsonWidget=[];
                                          htmlOut="";
                                          counter=-1;
                                          //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                                          //---------alle val[x] werte müssen von euch bestimmt werden - val[0],val[1],val[2] !!!-------------------------------------------------------------
                                          let myJsonLine=[]
                                          try {
                                           require("request")('https://info.gesundheitsministerium.gv.at/data/timeline-eimpfpass.csv', async function (error, response, result) {
                                            // console.log(result);
                                           setStateDelayed("0_userdata.0.Oesi_Impfen.all", result, true, 1000, false);
                                          let myArrZeilen=[]
                                          let  myLine=[]
                                          myJsonLine=[]
                                            myArrZeilen=result.split("\r\n")
                                          // log(myArrZeilen.length)
                                          myArrZeilen.reverse()
                                          //log(myArrZeilen[0].toString())
                                           for(let i=0;i<myArrZeilen.length;i++) {
                                            myLine=myArrZeilen[i].split(";");
                                           if(i<11){ myJsonLine.push({
                                             "Datum":myLine[0],
                                             "BundeslanLand":myLine[1],
                                             "Bevoelkerung":myLine[2],
                                             "Name":myLine[3],
                                             "Teilgeimpfte":myLine[6],
                                             "Vollimunisierte":myLine[8],
                                             "ProTeil" :myLine[7],
                                             "ProImun":myLine[9],
                                             "Astra":String(Number(myLine[63])+Number(myLine[60]) ),
                                             "Moderna":String(Number(myLine[62])+Number(myLine[59])),
                                             "Pfizer" : String(     Number(myLine[61])+Number(myLine[58]) ) ,
                                             "Eingetragende":myLine[4]
                                          //   log(JSON.stringify(myJsonLine))
                                          // }).on("error", function (e) {console.error(e);});
                                          //} catch (e) { console.error(e); }
                                          let valueuptime
                                          //log(myArrZeilen.length+" --- "+myJsonLine[0].Name)
                                          //if (myArrZeilen.length>0) {
                                          for (let aa=0;aa<myJsonLine.length;aa++) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!  myJsonLine.length
                                             if(sichtbareBlaender.includes(myJsonLine[aa].Name)){
                                                    val[0]=myJsonLine[aa].Name
                                                  myJsonLine[aa].Bevoelkerung!="" ? val[1]=myJsonLine[aa].Bevoelkerung : val[1]="na";
                                                  val[2]=myJsonLine[aa].Eingetragende
                                                   val[3]=myJsonLine[aa].Teilgeimpfte
                                                      val[4]=myJsonLine[aa].ProTeil
                                                  val[5]=  myJsonLine[aa].Vollimunisierte
                                                  val[6]=  myJsonLine[aa].ProImun ;
                                                  val[7]=  myJsonLine[aa].Astra
                                                  val[8]=  myJsonLine[aa].Pfizer   ;
                                                  val[9]=  myJsonLine[aa].Moderna
                                                  myObject.push({                "value0" : val[0],            //  "INSTANCE"
        "value1" : val[1],            //  "SINCE"
        "value2" : val[2],            //  "STATUS"
        "value3" : val[3],            //  "INSTANCE"
        "value4" : val[4],            //  "SINCE"
        "value5" : val[5],
        "value6" : val[6],
        "value7" : val[7],
        "value8" : val[8],
        "value9" : val[9]
        //   ID
                                                    makeJsonWidget.push({        [htmlFeld[0]] : val[0],  //  "INSTANCE"
        [htmlFeld[1]] : val[1],  //  "SINCE"
        [htmlFeld[2]] : val[2]
                                                    val[1]!="na" ? setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".EinwohnerAnzahl",Number(val[1]),2000) : setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".EinwohnerAnzahl",0,5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".TeilGeimpft",Number(val[3]),5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".Immunität",Number(val[5]),5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".Teilgeimpft_%",Number(val[4]),5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".EingetrageneImpfungen",Number(val[2]),5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".Teilimmun_%",Number(val[6]),5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".Astra",Number(val[7]),5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".Pfizer",Number(val[8]),5000);
                                                    setStateDelayed("Tabellen@Liv."+dpVIS+".Daten."+val[0]+".Moderna",Number(val[9]),5000);
        // diese function muss als letztes in der eigenen schleife aufgerufen werden
                                          }};                                            // Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                            // Sortierungen---------------------------------------------------------
                                            //welcheSortierung=3
                                            if( sortierenEIN ) {
                                              switch (welcheSortierung) {
                                                 case 0: break;
                                                 case 1: sortMe("num","value1");break;
                                                 case 2: sortMe("num","value2");break;
                                                 case 3: sortMe("num","value3");break;
                                                 case 4: sortMe("num","value4");break;
                                                 case 5: sortMe("num","value5");break;
                                                 case 6: sortMe("num","value6");break;
                                                 case 7: sortMe("num","value7");break;
                                                 case 8: sortMe("num","value8");break;
                                                 case 9: sortMe("num","value9");break;
                                               //  case 10: sortMe("num","value10");break;
                                             for(let zz=0;zz<myObject.length;zz++){
                                           // Unterüberschften ------------------------------------------------------
                                                  if (mitAlphabet){
                                                    if( myObject[zz].value0[0]!=helperLeerzeile){ tabelleAusbessern();
        counter=-1;  for(let ic=0;ic<mehrfachTabelle;ic++ ) { for (let tt=0 ;tt<val.length;tt++)
        { tt==0 && ic==0 ? val[tt]=(myObject[zz].value0[0]).toUpperCase() : val[tt]="&ensp;"
        counter++;tabelleBind();langeGesamt++; }
                                                    helperLeerzeile=myObject[zz].value0[0] } ; sortierenEIN=false;}
                                           // Zuteilung der Tabellenspalten-------------------------------------------
                                              val[0]=myObject[zz].value0;//log("-"+myObject[zz].value1)
                                              if (myObject[zz].value1 !="na" ) { if( mitTausendBezeichner)  { val[1]= (Number(myObject[zz].value1)/1000).toFixed(1)+"T"} else {val[1]= myObject[zz].value1}}  else { val[1]=""}
                                              if (myObject[zz].value0=="Österreich" && mitTausendBezeichner) val[1]= (Number(myObject[zz].value1)/1000000).toFixed(1)+"M"
                                               mitTausendBezeichner ? val[2]=(Number(myObject[zz].value2)/1000).toFixed(1)+"T" :val[2]=myObject[zz].value2 ;
                                               mitTausendBezeichner ? val[3]=(Number(myObject[zz].value3)/1000).toFixed(1)+"T" :val[3]=myObject[zz].value3 ;
                                               myObject[zz].value4!="" ? val[4]=myObject[zz].value4+"%" : val[4]=myObject[zz].value4;
                                               mitTausendBezeichner ? val[5]=(Number(myObject[zz].value5)/1000).toFixed(1)+"T" :val[5]=myObject[zz].value5 ;
                                              myObject[zz].value6!="" ? val[6]=myObject[zz].value6+"%" : val[6]=myObject[zz].value6;
                                               mitTausendBezeichner ? val[7]=(Number(myObject[zz].value7)/1000).toFixed(1)+"T" : val[7]=myObject[zz].value7;
                                              mitTausendBezeichner ? val[8]=(Number(myObject[zz].value8)/1000).toFixed(1)+"T" : val[8]=myObject[zz].value8 ;
                                              mitTausendBezeichner ? val[9]=(Number(myObject[zz].value9)/1000).toFixed(1)+"T" :val[9]=myObject[zz].value9;
                                                   if(mitAbkuerzungenVonBL) {
                                                 val[0]=val[0].replace("Oberösterreich","OÖ");
                                                 val[0]=val[0].replace("Niederösterreich","NÖ");
                                                 val[0]=val[0].replace("Steiermark","STMK");
                                                 val[0]=val[0].replace("Vorarlberg","VLBG");
                                                 val[0]=val[0].replace("Burgenland","BGLD");
                                                 val[0]=val[0].replace("KeineZuordnung","OHNE");
                                                 val[0]=val[0].replace("Salzburg","SBG");
                                                 val[0]=val[0].replace("Tirol","TIROL");
                                                 val[0]=val[0].replace("Kärnten","KTN");
                                                  val[0]=val[0].replace("Wien","WIEN");
                                                   val[0]=val[0].replace("Österreich","AUT");
                                              if (myObject[zz].value0==myFav) {     val[0]="<font color=\""+myFavColor +"\">"+val[0]+"</font>";
        val[1]="<font color=\""+myFavColor +"\">"+val[1]+"</font>";
        val[2]="<font color=\""+myFavColor +"\">"+val[2]+"</font>";
        val[3]="<font color=\""+myFavColor +"\">"+val[3]+"</font>";
        val[4]="<font color=\""+myFavColor +"\">"+val[4]+"</font>";
        val[5]="<font color=\""+myFavColor +"\">"+val[5]+"</font>";
        val[6]="<font color=\""+myFavColor +"\">"+val[6]+"</font>";
        val[7]="<font color=\""+myFavColor +"\">"+val[7]+"</font>";
        val[8]="<font color=\""+myFavColor +"\">"+val[8]+"</font>";
        val[9]="<font color=\""+myFavColor +"\">"+val[9]+"</font>";
                                               if (myObject[zz].value0=="Österreich") {    val[0]=  "<span style=\"color:"+myFavColor1Zeile +"; font-weight: bold\">"+val[0]+"</span>";
        val[1]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[1]+"</b></font>";
        val[2]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[2]+"</b></font>";
        val[3]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[3]+"</b></font>";
        val[4]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[4]+"</b></font>";
        val[5]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[5]+"</b></font>";
        val[6]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[6]+"</b></font>";
        val[7]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[7]+"</b></font>";
        val[8]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[8]+"</b></font>";
        val[9]="<font color=\""+myFavColor1Zeile +"\"><b>"+val[9]+"</b></font>";
                                               counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                               tabelleBind();                                   // HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT
                                               langeGesamt++;                                   // WICHTIG Seitenleiste
                                          //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                          // Seitenleiste------------------------------------------------------------
                                           let htmlTabUeber2=""
                                          let langeSpalten=htmlSpalte1Weite.length;
                                          /*for (let ue=0;ue<htmlSpalte1Weite.length;ue++){ if(ue==0){htmlTabUeber2=htmlTabUeber2.concat("<td width="+htmlSpalte1Weite[ue]+" align="+Feld1lAlign[ue]+" style=\"color:"+htmlFarbTableColorUber+"\">"+htmlFeld[ue]+"<span style=\"font-size: 80% \">&ensp;"+formatDate(getDateObject(myJsonLine[0].Datum), "(TT.MM.YY-SS:mm)")+"</span></td>")} else
                                             {htmlTabUeber2=htmlTabUeber2.concat("<td width="+htmlSpalte1Weite[ue]+" align="+Feld1lAlign[ue]+" style=\"color:"+htmlFarbTableColorUber+"\">"+htmlFeld[ue]+"</td>")}
                                          for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { //log(valSpalte.length.toString())
                                                               if (!schalterInSpaltenUeberschrift[ue] ) {
                                                             htmlTabUeber2=htmlTabUeber2.concat("<th class=\"toDel"+dpVIS+"\"  width="+htmlSpalte1Weite[ue]+" align="+Feld1lAlign[ue]+" style=\"color:"+htmlFarbTableColorUber+"\">"+htmlFeld[ue]+"</th>")}
                                                             else {let valButton="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+ue;
                                                              if(ue==htmlSpalte1Weite.length-1) {htmlTabUeber2=htmlTabUeber2.concat("<th class=\"toDel"+dpVIS+"\" width="+htmlSpalte1Weite[ue]+" align="+Feld1lAlign[ue]+">"+""+
        "<button class=\"myButt"+dpVIS+"\" style=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundFarbeSeitenliste+"\; color: "
        +htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text\-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton+"\')\">"
        +htmlFeld[ue]+"</button>"+" <font style=\"; font-weight: normal; font-size :"+groesseUeberschrift+"; color: "+htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+";\" ></th>")} else{
        +"<button class=\"myButt"+dpVIS+"\" style\=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundFarbeSeitenliste+"\; color: "
        +htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton+"\')\">"
        +htmlFeld[ue]+"</button></th>")} } //symbolSchalter[ue]
                                          let testing="<td  style=\" background-color: "+htmlBackgroundFarbeSeitenliste+"; margin-top: 200px; color: "+htmlFarbSeiteSchrift+ ";font-size:"+schriftGroesseSeitenleiste+"px; vertical-align:top; text-align:center \" width=\""+breiteSeitenleiste+"\" rowspan=\""+(langeGesamt+1)+"\">"+seitenLeistenTest+"</td>"
                                          let testing2="<td  style=\" background-color: "+htmlBackgroundFarbeSeitenliste+"; margin-top: 200px; color: "+htmlFarbSeiteSchrift+ ";font-size:"+schriftGroesseSeitenleiste+"px; vertical-align:top; text-align:center \" width=\""+((((Number(breiteSeitenleiste))/8).toFixed(0)))+"\" rowspan=\""+(langeGesamt+1)+"\">"+seitenLeistenTest+"</td>"
                                          for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { let valButton="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+ue;
                                             if(ue==htmlSpalte1Weite.length-1) {htmlTabUeber2_1=htmlTabUeber2_1.concat("<td width="+htmlSpalte1Weite[ue]+" align="+Feld1lAlign[ue]+">"+""
        +htmlFeld[ue]+"</button></td>"+testing)}
                                             else{ if(ue==0){htmlTabUeber2_1=htmlTabUeber2_1.concat(testing2+"<td width="+htmlSpalte1Weite[ue]+" align="+Feld1lAlign[ue]+">"+""
        +htmlFeld[ue]+"</button></td>")
                                             } else{
        +htmlFeld[ue]+"</button></td>")}}  }
                                            let einmalAbstand=`</br>
                                           for (let f=0;f<abstandSeitentextVonOben;f++){
                                               seitenLeistenTest=seitenLeistenTest+`<br>
                                           for (let i=0;i<nameSeitenLeiste.length;i++){
                                               seitenLeistenTest=seitenLeistenTest+nameSeitenLeiste[i]+`<br>
                                           htmlTabUeber="";
                                           if (ichWillSeitenLeiste) htmlTabUeber1=htmlTabUeber1+"<td  style=\" background-color: "+htmlBackgroundFarbeSeitenliste+"; margin-top: 200px; color: "+htmlFarbSeiteSchrift+ ";font-size:"+schriftGroesseSeitenleiste+"px; vertical-align:top; text-align:center \" width=\""+breiteSeitenleiste+"\" rowspan=\""+(langeGesamt+1)+"\">"+seitenLeistenTest+"</td>"
                                           switch (mehrfachTabelle) {
                                             case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                                             case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                             case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2_1+htmlTabUeber3; break;
                                             case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                            if (!UeberschriftSpalten) {htmlTabUeber=""}
                                                tabelleFinish();
                                                if (braucheEinJSON ) {setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".JSONVis",JSON.stringify(makeJsonWidget),1000 )}
                                          //else {log("keine Impfdaten vorhanden","warn")}
                                          } // function ende
                                          //MAIN:
                                          schedule(mySchedule,  function () {
                                           writeHTML();
                                           if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                          setTimeout(function () {writeHTML();  }, 2050);
                                           function tabelleBind(){
                                             case 1: if(counter%2==0)    {htmlOut=htmlOut+"<tr  cellspacing=\""+abstandZelle+"\"  bgcolor=\""+farbeGeradeZeilen+"\">";
        for(let u=0;u<val.length;u++)    {  htmlOut=htmlOut.concat("<td class=\"toDel"+dpVIS+"\" align="+Feld1lAlign[u]+">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");   break;
        } else   {htmlOut=htmlOut+"<tr  cellspacing=\""+abstandZelle+"\"  bgcolor=\""+farbeUngeradeZeilen+"\">";
                                             case 2: if(counter%4==0){  if(counter%2==0)  {htmlOut = htmlOut+"<tr cellspacing=\""+abstandZelle+"\"  bgcolor=\""+farbeGeradeZeilen+"\">";
        for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td align="+Feld1lAlign[u]+">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td style=\" border-right:"+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\" align="+Feld1lAlign[u]+">"+val[u]+"</td>")}
        } else { for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td align="+Feld1lAlign[u]+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  } break;
        } else {
        if(counter%2==0)  {htmlOut=htmlOut+"<tr cellspacing=\""+abstandZelle+"\"  bgcolor=\""+farbeUngeradeZeilen+"\">";
        }  htmlOut=htmlOut.concat("</tr>");  }  break;}
                                             case 3: if(counter%2==0)  {  if(counter%3==0 ) {htmlOut = htmlOut+"<tr cellspacing=\""+abstandZelle+"\"  bgcolor=\""+farbeGeradeZeilen+"\">";
        for(let u=0;u<val.length;u++){if(u<val.length-1) {htmlOut=htmlOut.concat("<td align="+Feld1lAlign[u]+">"+val[u]+"</td>");} else
        } else { if(counter%3==1)  {for(let u=0;u<val.length;u++){  if(u<val.length-1) {htmlOut=htmlOut.concat("<td align="+Feld1lAlign[u]+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td  align="+Feld1lAlign[u]+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+ "; color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>")}
        } else  { for(let u=0;u<val.length;u++){  htmlOut=htmlOut.concat("<td align="+Feld1lAlign[u]+">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  } }  break;
        else {
        if(counter%3==0 )  {htmlOut = htmlOut+"<tr cellspacing=\""+abstandZelle+"\"  bgcolor=\""+farbeUngeradeZeilen+"\">";
        } else{ if(counter%3==1 )  { for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td align="+Feld1lAlign[u]+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");} else
                                                  } //switch ende
                                           function tabelleAusbessern() {         // bessert mei mehrfachtabellen die nicht vollen zeilenn aus - bevor die unterüberschriften kommen
                                                 case 1:    break;
                                                 case 2:    let helpMehrfach="</td>";
                                                            for(let w=0;w<val.length;w++){helpMehrfach=helpMehrfach.concat("<td>&ensp;</td>")};helpMehrfach=helpMehrfach.concat("</tr>")
                                                            if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach);
                                                            break;
                                                 case 3:   let helpMehrfach2="</td>";
                                                           for(let w=0;w<val.length;w++){helpMehrfach2=helpMehrfach2.concat("<td>&ensp;</td>")};helpMehrfach2=helpMehrfach2.concat("</tr>")
                                                           if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                           if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach2);
                                                           let helpMehrfach3="</td>";
                                                           let helpMehrfach31="";for(let w=0;w<val.length;w++){helpMehrfach31=helpMehrfach31.concat("<td>&ensp;</td>")}
                                                           for(let w=0;w<val.length;w++){if(w<val.length-1) {helpMehrfach3=helpMehrfach3.concat("<td>&ensp;</td>")} else
        {helpMehrfach3=helpMehrfach3.concat("<td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td>"+helpMehrfach31)}
        };helpMehrfach3=helpMehrfach3.concat("</tr>")
                                                           if(counter%3==0)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach3);  break; }}
                                           function tabelleFinish() {
                                                 case 1:    break;
                                                            break;
                                                   var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlUEberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), "SS:mm:ss")+"</p>";
                                                 var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: center;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), "SS:mm:ss");+"</div>";
                                                  if (!htmlSignature) htmlUnter="";
                                                       var htmlOutVIS="";
                                                       if (htmlUberschrift)
                                                          { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+"</center>"+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+"</center>"+ buttonScript ;
                                                      } else {
                                                         zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+"</center>"+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+"</center>"+ buttonScript;
                                            // log("bin raus aus tabelleBind");
                                                     if (braucheEinVISWidget)  setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis", htmlOutVIS ,1000);
                                           var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), "SS:mm:ss");+"</div>"
                                            var htmlEnd="</table>"+htmlUnter+"</div></body>";
                                           //mit oder ohne überschrift - zentriert oder links
                                          htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                                           //log(htmlOut);
                                          async function needDP(){
                                             for(let s=0;s<schalterInSpaltenUeberschrift.length;s++){ if(schalterInSpaltenUeberschrift[s]){
                                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+s))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Spalte"+s, false,{type: "boolean", name: "Schalter_Spalte"+s, role: "value", read: true, write: true, } ); }
                                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".HTMLTableVis", "empty",{type: "string", name: "HTML_Standard_Widget_mit_Binding", role: "value", read: true, write: true, } ); }
                                              if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".JSONVis"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".JSONVis", "",{type: "string", name: "JSON Format", role: "value", read: true, write: true, } ); }
                                             for(let s=0;s<sichtbareBlaender.length;s++) {
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".EinwohnerAnzahl"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".EinwohnerAnzahl", 0,{type: "number", name: sichtbareBlaender[s]+" EinwohnerAnzahl", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".TeilGeimpft"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".TeilGeimpft", 0,{type: "number", name: sichtbareBlaender[s]+" TeilGeimpft", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Immunität"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Immunität", 0,{type: "number", name: sichtbareBlaender[s]+" Immunität", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Teilgeimpft_%"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Teilgeimpft_%", 0,{type: "number", unit: "%", name: sichtbareBlaender[s]+" Teilgeimpft_%", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".EingetrageneImpfungen"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".EingetrageneImpfungen", 0,{type: "number", name: sichtbareBlaender[s]+" EingetrageneImpfungen", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Teilimmun_%"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Teilimmun_%", 0,{type: "number", unit: "%", name: sichtbareBlaender[s]+" Teilimmun_%", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Astra"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Astra", 0,{type: "number", name: sichtbareBlaender[s]+" Astra", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Pfizer"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Pfizer", 0,{type: "number", name: sichtbareBlaender[s]+" Pfizer", role: "value", read: true, write: true, } ); }
                                                 if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Moderna"))) {
                                                 await createStateAsync("Tabellen@Liv."+dpVIS+".Daten."+sichtbareBlaender[s]+".Moderna", 0,{type: "number", name: sichtbareBlaender[s]+" Moderna", role: "value", read: true, write: true, } ); }
                                             let arrTriggerSchalter=[]
                                             $("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte*").each(function(id, i) {
                                                    arrTriggerSchalter.push(id)
                                           //  log(arrTriggerSchalter.toString())
                                             on({id: arrTriggerSchalter, ack: false, change: "any"}, function (obj) {
                                               //  log(obj.id)
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte1") welcheSortierung=1;
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte2" )  welcheSortierung=2 ;
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte3" )  welcheSortierung=3;
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte4")  welcheSortierung=4;
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte5" )  welcheSortierung=5;
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte6") welcheSortierung=6
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte7" )  welcheSortierung=7;
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte8" )  welcheSortierung=8;
                                               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte9" )  welcheSortierung=9;
                                             //  if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte10" )  welcheSortierung=9;
                                             //  if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte10" )  welcheSortierung=10;
                                             //  log(String(mehrfachTabelle))
                                                 writeHTML();
                                          }, 900);
                                             });}, 5050);
                                          //SORTIEREN
                                          function sortMe(myType,value){
                                          if(myType=="alpha" ){ myObject.sort(function (alpha, beta) {
                                                      if ((alpha[value].toString().toUpperCase()).trim() > (beta[value].toString().toUpperCase()).trim())
                                                         return 1;
                                                      if ((beta[value].toString().toUpperCase()).trim()> (alpha[value].toUpperCase().toString()).trim())
                                                         return -1;
                                                      return 0;
                                          if(myType=="bool" ) {
                                            myObject .sort(function(x, y) { return x[value] - y[value] }); }
                                            if(myType=="num" )   { myObject.sort(function (alpha, beta) {
                                                               return  Number(beta[value]) -Number(alpha[value]);   });}
                                            @liv-in-sky
                                            Ev. die T als Option möglich?
                                            communication javascript
                                            3919
