    4. Zigbee Adapter startet nicht
      consoleman @Thomas Braun last edited by
      Das iobroker Update läuft nicht durch.... 1000 Fehler. Kein Bock mehr
      arteck Homoran 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @consoleman last edited by
        @consoleman ach komm. ist halt ein lebends system.. das braucht zeit 🙂
        also was sagt das LOG.. dass das Update fehler schmeisst ist normal.. ist ja nicht NUR für dein System geschrieben
          Homoran Global Moderator Administrators @consoleman last edited by
          @consoleman sagte in Zigbee Adapter startet nicht:
          .... 1000 Fehler.
          bei einem Controller v1 ist das kein Wunder
          hast du da zuerst die aktuelle Version installiert?
            consoleman @arteck last edited by
            @arteck
            Update js-controller from @1.5.14 to @3.2.16
            NPM version: 6.14.11
            npm install iobroker.js-controller@3.2.16 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm ERR! code ELIFECYCLE
            npm ERR! errno 22
            npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
            npm ERR! Exit status 22
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /root/.npm/_logs/2021-03-10T07_33_07_734Z-debug.log
            arteck Thomas Braun 2 Replies Last reply Reply Quote 0
              arteck Developer Most Active @consoleman last edited by arteck
              @consoleman
              mach hardcore
              cd /opt/iobroker
              npm i iobroker.js-controller@3.2.16 —production
              danach den fixer
              iobroker fix
              dann schau nochmal ob der adapter läuft
                Thomas Braun Most Active @consoleman last edited by Thomas Braun
                /root/.npm/
                Da sollte sich nichts in /root abspielen.
                Ist deine node-Installation jetzt senkrecht?
                  @arteck
                  Jetzt bin ich auf dem aktuellen Stand.... unfassbar!
                  Adapter läuft.... alles grün, ein Traum.
                  Nun frag ich mich gerade wie ich Geräte mit dem Zigbee Stick paire?
                    @consoleman dann lies dich mal ein.. es gibt eine Wiki zu dem adapter
                      @arteck
                      Läuft alles.... JS engine verabschiedet sich nach dem Pairen, lässt sich aber direkt neu starten... kann ich mit leben
                      Vielen Dank an alle die mir geholfen haben!
                        @consoleman Das dürfte aber auch nicht normal sein. Und halt dein System regelmäßig aktuell. Dann sind die Klimmzüge auch nicht so groß.
                        1421
