    4. Test Adapter radar2 v1.2.x GitHub
    • lobomau
      lobomau @a1development last edited by
      @a1development I don`t understand how it works. BT has not such a long range!? Does it only work together with Samsung and the SmartThings-App?
        a1development @lobomau last edited by
        @lobomau i know.
        I was surprised when it showed up in ioBroker under radar2.0_uBTs List of unknown BT devices.
        I tested it in my house and placed it as far apart as possible ( one level down into the basement in the farest corner that i can think of ) and it still picks it up.
        The Gigaset Keeper Tag does lose its connection on the same level about 10-12m away from the BT dongle that is used for radar2.
        Not sure what Samsung is doing there, but to me this looks very promising. BUT with the rolling BT addresses, it s no use for radar2.
          OK. I switched to "Tile Pro" BT Beacons. I did some tests and compared to the Gigaset Gatekeeper, they are working alot further.
          Axel Koeneke 1 Reply Last reply Reply Quote 0
          • Axel Koeneke
            Axel Koeneke @a1development last edited by
            Moin, ich habe den Adapter neu installiert nachdem ich von Pi4 auf Proxmox umgestiegen bin.
            Er hat auch schon mal gelaufen aber seit dem letzten reboot ist der Adapter nur noch rot.
            FYI: Es läuft ein Pihole auf einer anderen VM.
            Ich habe mal gelesen das es Probleme mit DNS gäbe, diese sollte aber doch inzwischen behoben sein, oder?
            radar2.0	2021-03-08 08:39:13.440	info	(18723) Adapter disconnected and stopped with dostop(null) and callback(true)
            radar2.0	2021-03-08 08:39:13.439	info	(18723) Unload adapter now with null
            radar2.0	2021-03-08 08:39:13.394	warn	(18723) Uncaught Exception: bind EACCES 0.0.0.0:67
            radar2.0	2021-03-08 08:39:13.390	error	(18723) Exception-Code: EACCES: bind EACCES 0.0.0.0:67
            radar2.0	2021-03-08 08:39:13.390	error	at processTicksAndRejections (internal/process/task_queues.js:85:21)
            radar2.0	2021-03-08 08:39:13.390	error	at dgram.js:338:20
            radar2.0	2021-03-08 08:39:13.390	error	(18723) Error: bind EACCES 0.0.0.0:67
            radar2.0	2021-03-08 08:39:13.388	error	(18723) uncaught exception: bind EACCES 0.0.0.0:67
            VG
            Axel
              crunchip Forum Testing Most Active @Axel Koeneke last edited by
              @axel-koeneke sagte in Test Adapter radar2 v1.2.x GitHub:
              Was war der Grund für einen reboot? Update?
              Dann wurde wahrscheinlich node oder bluetooth upgedatet, daher sind danach die setcup Befehle oder iobroker fix auszuführen.
              Axel Koeneke 2 Replies Last reply Reply Quote 0
              • Axel Koeneke
                Axel Koeneke @crunchip last edited by
                @crunchip Danke für die schnelle Antwort. Ich werde es heute Abend testen.
                VG
                Axel
                • Axel Koeneke
                  @crunchip sagte in Test Adapter radar2 v1.2.x GitHub:
                  Fix hat es gefixt !
                    Megawaldi last edited by
                    Hallo Leute,
                    der Adapter funktioniert soweit gut, aber ich habe noch das Problem das arp-scan nicht läuft.
                    Im log:
                    Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
                    Ich denke ich habe alle probiert:
                    sudors von iobroker passt,
                    iobroker fix gemacht,
                    als iobroker angemeldet -> arp-scan geht ohne passwort
                    Nur in iobroker kommt die warning von oben und doArp(false)...
                    Vielleicht fällt euch ja noch was ein, was ich probieren kann...
                    Megawaldi
                      Thomas Braun Most Active @Megawaldi last edited by
                      @megawaldi
                      apr-scan
                      sudo -u iobroker arp-scan
                      sudo arp-scan
                        Megawaldi @Thomas Braun last edited by
                        Hab ich schon probiert:
                        Auf alle drei Befehle kommt die normale help info von arp-scan.
                        Sollte also ansich laufen? Bin ein bischen ratlos...
                          @megawaldi
                          Bitte Ein- und Ausgaben vollständig posten und nicht nacherzählen.
                          Der Adapterstart sieht im log file genau wie aus?
                            [17:59][martin@xxx:~]$ arp-scan -interface=wlan0
                            Interface: wlan0, type: EN10MB, MAC: e4:5f:01:03:XX:XX, IPv4: 192.168.0.XXX
                            Usage: arp-scan [options] [hosts...]
                            Target hosts must be specified on the command line unless the --file option is
                            given, in which case the targets are read from the specified file instead, or
                            the --localnet option is used, in which case the targets are generated from
                            the network interface IP address and netmask.
                            You will need to be root, or arp-scan must be SUID root, in order to run
                            arp-scan, because the functions that it uses to read and write packets
                            require root privilege.
                            The target hosts can be specified as IP addresses or hostnames. You can also
                            specify the target as IPnetwork/bits (e.g. 192.168.1.0/24) to specify all hosts
                            in the given network (network and broadcast addresses included), or
                            IPstart-IPend (e.g. 192.168.1.3-192.168.1.27) to specify all hosts in the
                            inclusive range, or IPnetwork:NetMask (e.g. 192.168.1.0:255.255.255.0) to
                            specify all hosts in the given network and mask.
                            These different options for specifying target hosts may be used both on the
                            command line, and also in the file specified with the --file option.
                            use "arp-scan --help" for detailed information on the available options.
                            Report bugs or send suggestions at https://github.com/royhills/arp-scan
                            See the arp-scan homepage at https://github.com/royhills/arp-scan
                            [17:59][martin@xxx:~]$ sudo -u iobroker arp-scan -interface=wlan0
                            [sudo] password for martin:
                            [17:59][martin@xxx:~]$ sudo arp-scan -interface=wlan0
                            radar2.0	2021-03-12 16:34:33.724	warn	(2036) Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
                            radar2.0	2021-03-12 16:34:33.541	info	(2036) Connected with '0.0.0.0' for DHCP Scan
                            radar2.0	2021-03-12 16:34:33.043	info	(2036) Will run hcitool-mode and not noble on device [ [Object] ]!
                            radar2.0	2021-03-12 16:34:32.933	info	(2036) Will use l2Ping for BT scans.
                            radar2.0	2021-03-12 16:34:32.916	info	(2036) radar2 initialization started...
                            radar2.0	2021-03-12 16:34:32.494	info	(2036) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.21.0, js-controller: 3.2.16
                            Danach läuft er ohne Fehler und Warnungen bis zum:
                            radar2.0	2021-03-12 16:35:40.088	info	(2036) Adapter initialization finished!
                            Durch.
                            Ich denke das ich das dazwischen aus Datenschutzgründen hier nicht posten will. Ist aber nichts komisches dabei.
                            Danke dir für deine Hilfe Thomas
                              @megawaldi sagte in Test Adapter radar2 v1.2.x GitHub:
                              Auf was für Hardware und OS läuft die Geschichte?
                                Ist ein raspi 4 mit Ubuntu LTS
                                  Thomas Braun Most Active @Megawaldi last edited by Thomas Braun
                                  @megawaldi
                                  Mit Raspberry OS funktioniert das einwandfrei hier.
                                  Warum setzt man Ubuntu LTS (Welches Release?) ein und nicht das viel besser an den Pi 4 angepasste Raspberry OS? (Ich hoffe nicht wegen 'des schöneren Desktops')
                                    Das hat sich so ergeben. Nutze das ganze nur headless und bei raspian ist mir ehrlichgesagt zu viel "müll" dabei für ein server linux.
                                      @megawaldi
                                      Der Müll funktioniert aber.
                                        Wenn du mir dann bitte mal erzälen kannst, was für einen Einfluss jetzt nen xserver desktop oder nen office auf mein Problem mit arp-scan hat bin ich beeindruckt. Übrigens ist Ubuntu arm auch ein auf nen raspi optimiertes Linux. Das beide also Ubuntu und rasperian nen debian port sind muss ich dir ja ned erklären.
                                        crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                          crunchip Forum Testing Most Active @Megawaldi last edited by
                                          @megawaldi was passiert denn, wenn du setcap einzeln absetzt
                                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                                            Keinen. Weil ja keines von beidem auf einem Server läuft.
                                            Nee, brauchst du nicht. Das weiß ich. Trotzdem gibt es Unterschiede.
                                            radar2 adapter
                                            49
                                            244
                                            36971
