    4. Neuer Adapter: SMA Wechselrichter mit sbfspot
      Thomas Braun Most Active @Bastelritius last edited by
      @bastelritius
      Da muss noch mehr in der Zeile stehen. Am besten einen ganzen Block auch der davor oder danach stehenden Zeilen posten.
      Bastelritius 1 Reply Last reply Reply Quote 0
      • Bastelritius
        Bastelritius @Thomas Braun last edited by
        OK, dann jetzt noch mal alles ab Adapterneustart:
        host.iobroker2	2021-03-10 17:35:05.523	info	instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        sbfspot.0	2021-03-10 17:35:04.933	info	(1135) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        sbfspot.0	2021-03-10 17:35:04.931	debug	(1135) Plugin sentry destroyed
        sbfspot.0	2021-03-10 17:35:04.929	debug	(1135) timer killed
        sbfspot.0	2021-03-10 17:35:04.928	info	(1135) all done ...
        sbfspot.0	2021-03-10 17:35:04.927	debug	(1135) disconnect database
        sbfspot.0	2021-03-10 17:35:04.925	error	(1135) exception in DB_Connect [Error: /opt/iobroker/node_modules/better-sqlite3/build/Release/better_sqlite3.node: undefined symbol: _ZN7Stateme/tIteratorD1Ev]
        sbfspot.0	2021-03-10 17:35:04.903	debug	(1135) --- connecting to /home/pi/smadata/SBFspot.db
        sbfspot.0	2021-03-10 17:35:04.902	info	(1135) start with sqlite
        sbfspot.0	2021-03-10 17:35:04.900	debug	(1135) sunrise 06:37 sunset 18:09 true
        sbfspot.0	2021-03-10 17:35:04.896	debug	(1135) system longitude 12.044093013028032 latitude 48.815940688183474
        sbfspot.0	2021-03-10 17:35:04.852	debug	(1135) start
        sbfspot.0	2021-03-10 17:35:04.762	info	(1135) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v12.21.0, js-controller: 3.2.16
        sbfspot.0	2021-03-10 17:35:04.696	info	(1135) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        sbfspot.0	2021-03-10 17:35:04.666	debug	(1135) Plugin sentry Initialize Plugin (enabled=true)
        host.iobroker2	2021-03-10 17:35:00.050	info	instance system.adapter.sbfspot.0 started with pid 1135
        • wendy2702
          wendy2702 @Bastelritius last edited by wendy2702
          @bastelritius Bezüglich dem SQLite steht das hier eine Seite vorher:
          Im Verzeichnis /opt/iobroker/node_modules/iobroker.sbfspot musst du npm install aufrufen, um alle Abhängigkeiten zu installieren.
          • Bastelritius
            @wendy2702 said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
            Ok, jetzt scheint sich was zu tun. Brauchte allerdings zwei Anläufe da ich das npm install auf dem slave ausführen musste und nicht auf dem Master. 🙂
            • wendy2702
              @bastelritius Ja, das muss auf dem System ausgeführt werden auf dem die Instanz läuft.
              Sorry, für mich logisch deshalb nicht extra erwähnt.
              • Bastelritius
                Bastelritius @wendy2702 last edited by
                Ja, ist ja auch logisch. Ich war einfach zu schnell dabei 🙂
                Jetzt hab ich mich aber irgendwie zu früh gefreut. Irgendwie wurden nur ein paar Daten aus der Datenbank übernommen. Nun kommt folgende Meldung:
                sbfspot.0	2021-03-11 13:50:06.618	info	(11380) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                sbfspot.0	2021-03-11 13:50:06.617	debug	(11380) Plugin sentry destroyed
                sbfspot.0	2021-03-11 13:50:06.615	debug	(11380) timer killed
                sbfspot.0	2021-03-11 13:50:06.614	info	(11380) all done ...
                sbfspot.0	2021-03-11 13:50:06.613	debug	(11380) disconnect database
                sbfspot.0	2021-03-11 13:50:06.612	error	(11380) exception in DB_AddDummyData [SqliteError: attempt to write a readonly database]
                sbfspot.0	2021-03-11 13:50:06.611	debug	(11380) INSERT INTO`Inverters`(`Serial`, `Name`, `Type`, `SW_Version`, `TimeStamp`, `TotalPac`, `EToday`, `ETotal`, `OperatingTime`, `FeedInTime`, `Status`, `GridRelay`, `Temperature`) VALUES( 1234567
                sbfspot.0	2021-03-11 13:50:06.610	debug	(11380) add dummy data
                sbfspot.0	2021-03-11 13:50:06.609	error	(11380) no inverter data found, adding dummy data...
                sbfspot.0	2021-03-11 13:50:06.608	debug	(11380) rows undefined
                sbfspot.0	2021-03-11 13:50:06.607	error	(11380) exception in DB_GetInverters [SqliteError: attempt to write a readonly database]
                sbfspot.0	2021-03-11 13:50:06.604	debug	(11380) SELECT * from Inverters
                sbfspot.0	2021-03-11 13:50:06.603	debug	(11380) sqlite Database is connected ...
                sbfspot.0	2021-03-11 13:50:06.571	debug	(11380) --- connecting to /home/pi/smadata/SBFspot.db
                sbfspot.0	2021-03-11 13:50:06.570	info	(11380) start with sqlite
                sbfspot.0	2021-03-11 13:50:06.568	debug	(11380) sunrise 06:34 sunset 18:11 true
                sbfspot.0	2021-03-11 13:50:06.565	debug	(11380) system longitude 12.044093013028032 latitude 48.815940688183474
                sbfspot.0	2021-03-11 13:50:06.504	debug	(11380) start
                sbfspot.0	2021-03-11 13:50:06.396	info	(11380) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v12.21.0, js-controller: 3.2.16
                sbfspot.0	2021-03-11 13:50:06.309	info	(11380) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                sbfspot.0	2021-03-11 13:50:06.275	debug	(11380) Plugin sentry Initialize Plugin (enabled=true)
                Anscheinend hat er nun Zugriffsprobleme. Ich verstehe es aber nicht ganz. Der Adapter ruft doch die Daten nur ab. Wieso gibt es dann den Fehler
                Er will doch nur lesen, oder will der Adapter auch etwas schreiben?
                Die Berechtigungen der SBFspot.db habe ich auf iobroker und dialout geändert. Berechtigung sollte somit da sein, oder?
                  @bastelritius Der user iobroker darf erstmal nix im home-Verzeichnis des users pi.
                  Ich hätte die db in ~ von iobroker installiert oder dem iobroker (über eine gemeinsame Gruppe vielleicht) Rechte in einem Extra-Verzeichnis in /home/pi eingeräumt.
                  • Bastelritius
                    @thomas-braun said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                    OK, wieder was gelernt. Der Datebankdatei hatte ich schon die Gruppe Dialout gegeben. Dem Verzeichnis smadata aber nicht. Anscheinend war dass das Problem. Jetzt funktioniert es.
                    Vermutlich würde die DB Datei aber im iobroker Ordner mehr Sinn machen. Aber das kann ich mir ja noch überlegen. Momentan bin ich erst mal im Testbetrieb. Mal sehen was jetzt so für Daten auflaufen und wie man diese dann auch sinnvoll auswerten/ anzeigen kann.
                    • Bastelritius
                      So, Daten werden gesammelt 👏
                      Jetzt habe ich allerdings eine Frage zu den Historie Daten und dem Widget.
                      1. Kann man im Widget mehrere WR anzeigen lassen. Meine Anlage besteht nämlich aus 3 Stück, oder muss ich dann 3 Widgets benutzen?
                      2. Die Historie-daten füu "Today" enthalten nur einen Wert im Stundenabstand. Kann man das irgendwie ändern? Nur stündlich einen Wert zu bekommen ist mir irgendwie zu weing. Die Werte in die Datenbank werden alle 5min geschrieben. Die Aktuallisierung für den Adapter habe ich auch auf 5min gestellt.
                      [{"time":"06:03","value":36},{"time":"07:03","value":1085},{"time":"08:03","value":3091},{"time":"09:03","value":4666},{"time":"10:03","value":5873},{"time":"11:03","value":7241},{"time":"12:03","value":9372},{"time":"13:03","value":11600},{"time":"14:03","value":12966},{"time":"15:03","value":13746},{"time":"16:03","value":14259}]
                      • Rene_HM
                        Rene_HM Developer @Bastelritius last edited by
                        @bastelritius sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                        das widget ist für einen WR gedacht. Man kann nur eine Objekt-ID verwenden...
                        Das hängt davon ab, wie oft du den Adapter laufen lässt. Bei jedem Lauf das Adapters werden die Daten aus der DB geholt und in den history-json-string geschrieben. Das steuerst du über die s.g. Zeitplanung im admin von iobroker für den Adapter. Für einen Lauf alle 15 Minuten müsste dort */15 * * * * stehen...
                        • Bastelritius
                          Bastelritius @Rene_HM last edited by Bastelritius
                          @rene_hm :
                          Genau so hatte ich mir das gedacht. Daher habe ich den Adapter auf 5min gestellt. Die Daten im Datenpunkt "EToday" werden alle 5min aktualisiert und es kommen auch neue Werte an. Diesen Datenpunkt logge ich zusätzlich in einer InfluxDB seit Gestern als Kontrolle. Im history-json-string stehen aber wie oben schon gepostet nur die Stundenwerte.
                          • Rene_HM
                            @bastelritius schalte den Adapter mal auf debug und schaue was dort passiert. Mein Adapter läuft alle 15 Minuten und im history-json sind auch alle 15 Minuten Daten vorhanden. So wäre es auch implementiert. Ausnahme wäre, dass ein DB-Abruf vorher schief geht... das würden wir im log sehen...
                            was mir im obigen post auffältt ist die Zeit: immer 3 Minuten nach der vollen Stunde. Wenn dein Adapter alle 5 Minuten läuft, sollte immer die volle Stunde als Zeitstempel auftauchen.
                            Bei mir sieht das so aus:
                            [{"time":"06:45","value":0},{"time":"07:00","value":1},{"time":"07:15","value":13},{"time":"07:30","value":32},{"time":"07:45","value":64},{"time":"08:00","value":102}, ... ]
                            • Bastelritius
                              Bastelritius @wendy2702 last edited by Bastelritius
                              1. exception in DB_Connect [Error: /opt/iobroker/node_modules/better-sqlite3/build/Release/better_sqlite3.node: undefined symbol: _ZN7Stateme/tIteratorD1Ev]
                              Leider ist das Log etwas abgeschnitten so das mannschaftliche sagen kann das es wirklich von dem Adapter erzeugt wird.
                              @rene_hm said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                              Ja, komisch. Ich habe den Adapter mal komplett deinstalliert und neu installiert.
                              Den Log habe ich als Datei angehangen:iobroker.2021-03-14.log
                              • Bastelritius
                                Hat noch jemand eine Idee wieso die Werte bei mir immer nur 3min nach jeder vollen Stunde berechnet werden, obwohl ich den Adapter auf 5min Intervall eingestellt habe?
                                • Rene_HM
                                  @bastelritius laut log ist dein Problem nicht der Adapter sondern sbfspot.
                                  DB_CalcHistory_Today for 2100494098
                                  SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%m', datetime(TimeStamp, 'unixepoch'))
                                  rows [{"time":"04:03","ertrag":0},{"time":"05:03","ertrag":0}]
                                  Hier ist die Datenbankabfrage um 6:25Uhr. Da kommen die beiden Werte um 4:03 und 5:03. Ich denke, du hast den cron job auf dem Pi nicht richtig konfiguriert... siehe
                                  https://github.com/SBFspot/SBFspot/wiki/Installation-Linux-SQLite#️-automation
                                  • Bastelritius
                                    Danke. Aber ich habe es so konfiguriert wie unter dem Punkt Automation in Deinem Link.
                                    Irgendwie kommen ja auch alle 5min aktualisierte Werte. Zumindest wenn ich die Daten über die Historie auswerte.
                                    Ich habe hier mal die Tabelle SpotData ausgelesen und als txt angehangen.
                                    Kannst Du da mal reingucken ob das so stimmt. Ich denke die Daten sind da? SBFspot_SpotData.txt
                                    • Rene_HM
                                      @bastelritius und wenn du manuell o.g. SQL string mal in der Datenbank laufen lässt, was passiert dann? Wie das geht, wird ja unter
                                      https://github.com/SBFspot/SBFspot/wiki/Installation-Linux-SQLite#️-testing
                                      erklärt. nur dass du dort nicht
                                      select * from vwspotdata;
                                      sondern
                                      SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%m', datetime(TimeStamp, 'unixepoch'));
                                      verwendest.
                                      Welche Version von sqlite hast du auf dem PI?
                                      Was mir gerade auffällt:
                                      Versuche auch mal
                                      SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%M', datetime(TimeStamp, 'unixepoch'));
                                      • Bastelritius
                                        sondern
                                        verwendest.
                                        Hier bringt mir die Datenbank folgendes:
                                        sqlite> SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%m', datetime(TimeStamp, 'unixepoch'));
                                        04:03|0
                                        05:03|0
                                        Ich habe die Version SQLite version 3.27.2 2019-02-25 16:06:06
                                        Versuche auch mal
                                        Hier kommt das:
                                        04:03|0
                                        05:03|0
                                        05:03|0
                                        05:03|0
                                        sqlite>
                                        Was mir gerade komisch vorkommt ist der String für die Zeit.
                                        Du fragst mit der Abfrage einen String mit 3 Nachkommastellen ab 1615699506.314. In der Datenbank hat der String aber keine Nachkommastellen 1615915807. Kann das ein Grund sein?
                                        SBFspot version ist folgende:
                                        SBFspot V3.7.1
                                        Yet another tool to read power production of SMA solar inverters
                                        (c) 2012-2020, SBF (https://github.com/SBFspot/SBFspot)
                                        Compiled for Linux (LE) 32 bit with SQLite support
                                        Commandline Args: -v -ad1 -am0 -ae1 -cfg/usr/local/bin/sbfspot.3/SBFspot.cfg
                                        Ich habe das mit dem Configtool installiert
                                          Wene001 @Bastelritius last edited by
                                          Hi zusammen
                                          Versuch mich grad in die Materie des ioBroker einzuarbeiten. Da ich schon einige Jahre SBFspot nutze hab ich mir den tollen Adapter hier installiert.
                                          Super Sache...
                                          Leider funktioniert die Beschriftung der X-Achse nicht richtig in der heute Ansicht. Bei Jährlich, Monatlich und 30 Tage passts.
                                          Hat jemand Ideen ob ich das lösen kann, bzw ob das ein Bug ist ?
                                          LG Werner
                                          • Rene_HM
                                            Rene_HM Developer @Wene001 last edited by
                                            @wene001 was verwendest du denn als "Datumsformat" in den Einstellungen?
                                            248
                                            40936
