    4. Neuer Adapter: SMA Wechselrichter mit sbfspot
    • Bastelritius
      Bastelritius @Thomas Braun last edited by
      OK, dann jetzt noch mal alles ab Adapterneustart:
      host.iobroker2	2021-03-10 17:35:05.523	info	instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      sbfspot.0	2021-03-10 17:35:04.933	info	(1135) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      sbfspot.0	2021-03-10 17:35:04.931	debug	(1135) Plugin sentry destroyed
      sbfspot.0	2021-03-10 17:35:04.929	debug	(1135) timer killed
      sbfspot.0	2021-03-10 17:35:04.928	info	(1135) all done ...
      sbfspot.0	2021-03-10 17:35:04.927	debug	(1135) disconnect database
      sbfspot.0	2021-03-10 17:35:04.925	error	(1135) exception in DB_Connect [Error: /opt/iobroker/node_modules/better-sqlite3/build/Release/better_sqlite3.node: undefined symbol: _ZN7Stateme/tIteratorD1Ev]
      sbfspot.0	2021-03-10 17:35:04.903	debug	(1135) --- connecting to /home/pi/smadata/SBFspot.db
      sbfspot.0	2021-03-10 17:35:04.902	info	(1135) start with sqlite
      sbfspot.0	2021-03-10 17:35:04.900	debug	(1135) sunrise 06:37 sunset 18:09 true
      sbfspot.0	2021-03-10 17:35:04.896	debug	(1135) system longitude 12.044093013028032 latitude 48.815940688183474
      sbfspot.0	2021-03-10 17:35:04.852	debug	(1135) start
      sbfspot.0	2021-03-10 17:35:04.762	info	(1135) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v12.21.0, js-controller: 3.2.16
      sbfspot.0	2021-03-10 17:35:04.696	info	(1135) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      sbfspot.0	2021-03-10 17:35:04.666	debug	(1135) Plugin sentry Initialize Plugin (enabled=true)
      host.iobroker2	2021-03-10 17:35:00.050	info	instance system.adapter.sbfspot.0 started with pid 1135
      • wendy2702
        wendy2702 @Bastelritius last edited by wendy2702
        @bastelritius Bezüglich dem SQLite steht das hier eine Seite vorher:
        Im Verzeichnis /opt/iobroker/node_modules/iobroker.sbfspot musst du npm install aufrufen, um alle Abhängigkeiten zu installieren.
        • Bastelritius
          @wendy2702 said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
          Ok, jetzt scheint sich was zu tun. Brauchte allerdings zwei Anläufe da ich das npm install auf dem slave ausführen musste und nicht auf dem Master. 🙂
          • wendy2702
            @bastelritius Ja, das muss auf dem System ausgeführt werden auf dem die Instanz läuft.
            Sorry, für mich logisch deshalb nicht extra erwähnt.
            Bastelritius 1 Reply Last reply Reply Quote 0
            • Bastelritius
              Bastelritius @wendy2702 last edited by
              Ja, ist ja auch logisch. Ich war einfach zu schnell dabei 🙂
              Jetzt hab ich mich aber irgendwie zu früh gefreut. Irgendwie wurden nur ein paar Daten aus der Datenbank übernommen. Nun kommt folgende Meldung:
              sbfspot.0	2021-03-11 13:50:06.618	info	(11380) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              sbfspot.0	2021-03-11 13:50:06.617	debug	(11380) Plugin sentry destroyed
              sbfspot.0	2021-03-11 13:50:06.615	debug	(11380) timer killed
              sbfspot.0	2021-03-11 13:50:06.614	info	(11380) all done ...
              sbfspot.0	2021-03-11 13:50:06.613	debug	(11380) disconnect database
              sbfspot.0	2021-03-11 13:50:06.612	error	(11380) exception in DB_AddDummyData [SqliteError: attempt to write a readonly database]
              sbfspot.0	2021-03-11 13:50:06.611	debug	(11380) INSERT INTO`Inverters`(`Serial`, `Name`, `Type`, `SW_Version`, `TimeStamp`, `TotalPac`, `EToday`, `ETotal`, `OperatingTime`, `FeedInTime`, `Status`, `GridRelay`, `Temperature`) VALUES( 1234567
              sbfspot.0	2021-03-11 13:50:06.610	debug	(11380) add dummy data
              sbfspot.0	2021-03-11 13:50:06.609	error	(11380) no inverter data found, adding dummy data...
              sbfspot.0	2021-03-11 13:50:06.608	debug	(11380) rows undefined
              sbfspot.0	2021-03-11 13:50:06.607	error	(11380) exception in DB_GetInverters [SqliteError: attempt to write a readonly database]
              sbfspot.0	2021-03-11 13:50:06.604	debug	(11380) SELECT * from Inverters
              sbfspot.0	2021-03-11 13:50:06.603	debug	(11380) sqlite Database is connected ...
              sbfspot.0	2021-03-11 13:50:06.571	debug	(11380) --- connecting to /home/pi/smadata/SBFspot.db
              sbfspot.0	2021-03-11 13:50:06.570	info	(11380) start with sqlite
              sbfspot.0	2021-03-11 13:50:06.568	debug	(11380) sunrise 06:34 sunset 18:11 true
              sbfspot.0	2021-03-11 13:50:06.565	debug	(11380) system longitude 12.044093013028032 latitude 48.815940688183474
              sbfspot.0	2021-03-11 13:50:06.504	debug	(11380) start
              sbfspot.0	2021-03-11 13:50:06.396	info	(11380) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v12.21.0, js-controller: 3.2.16
              sbfspot.0	2021-03-11 13:50:06.309	info	(11380) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              sbfspot.0	2021-03-11 13:50:06.275	debug	(11380) Plugin sentry Initialize Plugin (enabled=true)
              Anscheinend hat er nun Zugriffsprobleme. Ich verstehe es aber nicht ganz. Der Adapter ruft doch die Daten nur ab. Wieso gibt es dann den Fehler
              Er will doch nur lesen, oder will der Adapter auch etwas schreiben?
              Die Berechtigungen der SBFspot.db habe ich auf iobroker und dialout geändert. Berechtigung sollte somit da sein, oder?
                Thomas Braun Most Active @Bastelritius last edited by
                @bastelritius Der user iobroker darf erstmal nix im home-Verzeichnis des users pi.
                Ich hätte die db in ~ von iobroker installiert oder dem iobroker (über eine gemeinsame Gruppe vielleicht) Rechte in einem Extra-Verzeichnis in /home/pi eingeräumt.
                • Bastelritius
                  @thomas-braun said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                  OK, wieder was gelernt. Der Datebankdatei hatte ich schon die Gruppe Dialout gegeben. Dem Verzeichnis smadata aber nicht. Anscheinend war dass das Problem. Jetzt funktioniert es.
                  Vermutlich würde die DB Datei aber im iobroker Ordner mehr Sinn machen. Aber das kann ich mir ja noch überlegen. Momentan bin ich erst mal im Testbetrieb. Mal sehen was jetzt so für Daten auflaufen und wie man diese dann auch sinnvoll auswerten/ anzeigen kann.
                  • Bastelritius
                    So, Daten werden gesammelt 👏
                    Jetzt habe ich allerdings eine Frage zu den Historie Daten und dem Widget.
                    1. Kann man im Widget mehrere WR anzeigen lassen. Meine Anlage besteht nämlich aus 3 Stück, oder muss ich dann 3 Widgets benutzen?
                    2. Die Historie-daten füu "Today" enthalten nur einen Wert im Stundenabstand. Kann man das irgendwie ändern? Nur stündlich einen Wert zu bekommen ist mir irgendwie zu weing. Die Werte in die Datenbank werden alle 5min geschrieben. Die Aktuallisierung für den Adapter habe ich auch auf 5min gestellt.
                    [{"time":"06:03","value":36},{"time":"07:03","value":1085},{"time":"08:03","value":3091},{"time":"09:03","value":4666},{"time":"10:03","value":5873},{"time":"11:03","value":7241},{"time":"12:03","value":9372},{"time":"13:03","value":11600},{"time":"14:03","value":12966},{"time":"15:03","value":13746},{"time":"16:03","value":14259}]
                    • Rene_HM
                      Rene_HM Developer @Bastelritius last edited by
                      @bastelritius sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                      das widget ist für einen WR gedacht. Man kann nur eine Objekt-ID verwenden...
                      Das hängt davon ab, wie oft du den Adapter laufen lässt. Bei jedem Lauf das Adapters werden die Daten aus der DB geholt und in den history-json-string geschrieben. Das steuerst du über die s.g. Zeitplanung im admin von iobroker für den Adapter. Für einen Lauf alle 15 Minuten müsste dort */15 * * * * stehen...
                      • Bastelritius
                        Bastelritius @Rene_HM last edited by Bastelritius
                        @rene_hm :
                        Genau so hatte ich mir das gedacht. Daher habe ich den Adapter auf 5min gestellt. Die Daten im Datenpunkt "EToday" werden alle 5min aktualisiert und es kommen auch neue Werte an. Diesen Datenpunkt logge ich zusätzlich in einer InfluxDB seit Gestern als Kontrolle. Im history-json-string stehen aber wie oben schon gepostet nur die Stundenwerte.
                        • Rene_HM
                          @bastelritius schalte den Adapter mal auf debug und schaue was dort passiert. Mein Adapter läuft alle 15 Minuten und im history-json sind auch alle 15 Minuten Daten vorhanden. So wäre es auch implementiert. Ausnahme wäre, dass ein DB-Abruf vorher schief geht... das würden wir im log sehen...
                          was mir im obigen post auffältt ist die Zeit: immer 3 Minuten nach der vollen Stunde. Wenn dein Adapter alle 5 Minuten läuft, sollte immer die volle Stunde als Zeitstempel auftauchen.
                          Bei mir sieht das so aus:
                          [{"time":"06:45","value":0},{"time":"07:00","value":1},{"time":"07:15","value":13},{"time":"07:30","value":32},{"time":"07:45","value":64},{"time":"08:00","value":102}, ... ]
                          • Bastelritius
                            Bastelritius @wendy2702 last edited by Bastelritius
                            1. exception in DB_Connect [Error: /opt/iobroker/node_modules/better-sqlite3/build/Release/better_sqlite3.node: undefined symbol: _ZN7Stateme/tIteratorD1Ev]
                            Leider ist das Log etwas abgeschnitten so das mannschaftliche sagen kann das es wirklich von dem Adapter erzeugt wird.
                            @rene_hm said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                            Ja, komisch. Ich habe den Adapter mal komplett deinstalliert und neu installiert.
                            Den Log habe ich als Datei angehangen:iobroker.2021-03-14.log
                            • Bastelritius
                              Hat noch jemand eine Idee wieso die Werte bei mir immer nur 3min nach jeder vollen Stunde berechnet werden, obwohl ich den Adapter auf 5min Intervall eingestellt habe?
                              • Rene_HM
                                @bastelritius laut log ist dein Problem nicht der Adapter sondern sbfspot.
                                DB_CalcHistory_Today for 2100494098
                                SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%m', datetime(TimeStamp, 'unixepoch'))
                                rows [{"time":"04:03","ertrag":0},{"time":"05:03","ertrag":0}]
                                Hier ist die Datenbankabfrage um 6:25Uhr. Da kommen die beiden Werte um 4:03 und 5:03. Ich denke, du hast den cron job auf dem Pi nicht richtig konfiguriert... siehe
                                https://github.com/SBFspot/SBFspot/wiki/Installation-Linux-SQLite#️-automation
                                • Bastelritius
                                  Danke. Aber ich habe es so konfiguriert wie unter dem Punkt Automation in Deinem Link.
                                  Irgendwie kommen ja auch alle 5min aktualisierte Werte. Zumindest wenn ich die Daten über die Historie auswerte.
                                  Ich habe hier mal die Tabelle SpotData ausgelesen und als txt angehangen.
                                  Kannst Du da mal reingucken ob das so stimmt. Ich denke die Daten sind da? SBFspot_SpotData.txt
                                  • Rene_HM
                                    @bastelritius und wenn du manuell o.g. SQL string mal in der Datenbank laufen lässt, was passiert dann? Wie das geht, wird ja unter
                                    https://github.com/SBFspot/SBFspot/wiki/Installation-Linux-SQLite#️-testing
                                    erklärt. nur dass du dort nicht
                                    select * from vwspotdata;
                                    sondern
                                    SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%m', datetime(TimeStamp, 'unixepoch'));
                                    verwendest.
                                    Welche Version von sqlite hast du auf dem PI?
                                    Was mir gerade auffällt:
                                    Versuche auch mal
                                    SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%M', datetime(TimeStamp, 'unixepoch'));
                                    • Bastelritius
                                      sondern
                                      verwendest.
                                      Hier bringt mir die Datenbank folgendes:
                                      sqlite> SELECT strftime('%H:%m', datetime(TimeStamp, 'unixepoch')) as time, Max(`EToday`) as ertrag FROM `SpotData` WHERE `Serial` = '2100494098' AND TimeStamp>= 1615676406.314 AND TimeStamp<= 1615699506.314 Group By strftime('%H-%m', datetime(TimeStamp, 'unixepoch'));
                                      04:03|0
                                      05:03|0
                                      Ich habe die Version SQLite version 3.27.2 2019-02-25 16:06:06
                                      Versuche auch mal
                                      Hier kommt das:
                                      04:03|0
                                      05:03|0
                                      05:03|0
                                      05:03|0
                                      sqlite>
                                      Was mir gerade komisch vorkommt ist der String für die Zeit.
                                      Du fragst mit der Abfrage einen String mit 3 Nachkommastellen ab 1615699506.314. In der Datenbank hat der String aber keine Nachkommastellen 1615915807. Kann das ein Grund sein?
                                      SBFspot version ist folgende:
                                      SBFspot V3.7.1
                                      Yet another tool to read power production of SMA solar inverters
                                      (c) 2012-2020, SBF (https://github.com/SBFspot/SBFspot)
                                      Compiled for Linux (LE) 32 bit with SQLite support
                                      Commandline Args: -v -ad1 -am0 -ae1 -cfg/usr/local/bin/sbfspot.3/SBFspot.cfg
                                      Ich habe das mit dem Configtool installiert
                                        Wene001 @Bastelritius last edited by
                                        Hi zusammen
                                        Versuch mich grad in die Materie des ioBroker einzuarbeiten. Da ich schon einige Jahre SBFspot nutze hab ich mir den tollen Adapter hier installiert.
                                        Super Sache...
                                        Leider funktioniert die Beschriftung der X-Achse nicht richtig in der heute Ansicht. Bei Jährlich, Monatlich und 30 Tage passts.
                                        Hat jemand Ideen ob ich das lösen kann, bzw ob das ein Bug ist ?
                                        LG Werner
                                        • Rene_HM
                                          Rene_HM Developer @Wene001 last edited by
                                          @wene001 was verwendest du denn als "Datumsformat" in den Einstellungen?
                                            Wene001 last edited by Wene001
                                            %H:%M
                                            Interessanterweise passte die Anzeige am Nachmittag (wenn 12:00 auch angeschrieben steht) Heut Früh ist es wieder abgeschnitten
                                            Bei mir war nur 6:00 und 12:00 auf der Skala angegeben.
                                            Leider ist dies auch eine Stunde verschoben. Wie kann ich das auf MEZ+1 umstellen am besten mit automatischer Sommerzeitumschaltung.
                                            Ich hab auch in meinem "today" json File nur Stundenwerte? sollten hier nicht 15min drin stehen...kann man das iwo einstellen?
                                            Der Adapter startet alle 5min im Iobroker und das Json File aktualisiert sich auch alle 5 min und der letzte Stundenwert steigt alle 5 min an.
                                            Ideen dazu?
                                            LG Werner
                                            248
                                            40931
