    4. Test Adapter Linux Control v1.x.x
      bishop @wendy2702 last edited by
      @wendy2702
      @Scrounger
      danke hat funktioniert.
      Ist etwas Offtopic aber ich wollte jetzt ein Js Controller update machen auf dem Raspberry pi2 und bekomme nun:
      pi@raspberrypi:~ $ iobroker upgrade self
      Update js-controller from @3.1.6 to @3.2.16
      NPM version: 6.14.11
      npm install iobroker.js-controller@3.2.16 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      /opt/iobroker/node_modules/at-least-node/index.js:5
          location?: LocationCode;
      SyntaxError: Unexpected token :
          at Module._compile (internal/modules/cjs/loader.js:723:23)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/mkdirs/make-dir.js:9:21)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2021-03-05T06_55_14_822Z-debug.log
      host.raspberrypi Cannot install iobroker.js-controller@3.2.16: 1
      pi@raspberrypi:~ $ npm -v
      6.14.11
      vorher habe ich eine apt-get update und upgrade gemacht.
      FredF Thomas Braun 2 Replies Last reply Reply Quote 0
      • FredF
        FredF Most Active Forum Testing @bishop last edited by
        @bishop
        iobroker stop
        iobroker update
        iobroker start
          Thomas Braun Most Active @bishop last edited by
          @bishop
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            bishop @FredF last edited by
            @fredf sagte in Test Adapter Linux Control v1.x.x:
            @bishop
            iobroker stop
            iobroker update
            iobroker start
            Das habe ich getan!
            @thomas-braun sagte in Test Adapter Linux Control v1.x.x:
            @bishop
            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v10.24.0
            /usr/bin/node
            v10.24.0
            /usr/bin/npm
            6.14.11
            nodejs:
              Installed: 10.24.0-1nodesource1
              Candidate: 10.24.0-1nodesource1
              Version table:
             *** 10.24.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
            pi@raspberrypi:~ $
              @bishop
              sudo apt update
              sudo apt dist-upgrade
              sudo reboot
                bishop @Thomas Braun last edited by
                @bishop
                sudo apt update
                sudo reboot
                pi@raspberrypi:~ $ sudo apt update
                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                Hit:3 http://packages.microsoft.com/repos/code stable InRelease
                Hit:4 https://www.pivccu.de/piVCCU stable InRelease
                Hit:5 https://deb.nodesource.com/node_10.x buster InRelease
                Reading package lists... Done
                Building dependency tree
                All packages are up to date.
                pi@raspberrypi:~ $ sudo apt dist-upgrade
                Calculating upgrade... Done
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                pi@raspberrypi:~ $
                  bishop @bishop last edited by bishop
                  @Scrounger
                  ist es möglich auch die synology nas zu integrieren?
                  Habe sie mal mit im Adapter konfiguriert aber leider bleibt nur ein INFO Datenpunkt mit der Ip und das sie Offline ist, ist aber natürlich online SSH ist dort auch konfiguriert ich bekomme eine Verbindung mit Putty hin.
                  Kann das sein weil es keine richtige Distribution ist?
                  linux-control.0	2021-03-13 21:27:33.633	error	at processTimers (internal/timers.js:497:7)
                  linux-control.0	2021-03-13 21:27:33.633	error	at listOnTimeout (internal/timers.js:554:17)
                  linux-control.0	2021-03-13 21:27:33.633	error	at Timeout._onTimeout (/opt/iobroker/node_modules/ssh2/lib/client.js:695:19)
                  linux-control.0	2021-03-13 21:27:33.633	error	(26597) [getConnection] error: Timed out while waiting for handshake, stack: Error: Timed out while waiting for handshake
                  linux-control.0	2021-03-13 21:27:33.631	error	(26597) [getConnection] Could not establish a connection to 'Diskstation218' (192.168.1.4:22)!
                  linux-control.0	2021-03-13 21:27:28.341	error	at processTimers (internal/timers.js:497:7)
                  linux-control.0	2021-03-13 21:27:28.341	error	at listOnTimeout (internal/timers.js:554:17)
                  linux-control.0	2021-03-13 21:27:28.341	error	at Timeout._onTimeout (/opt/iobroker/node_modules/ssh2/lib/client.js:695:19)
                  linux-control.0	2021-03-13 21:27:28.341	error	(26597) [getConnection] error: Timed out while waiting for handshake, stack: Error: Timed out while waiting for handshake
                  linux-control.0	2021-03-13 21:27:28.275	error	(26597) [getConnection] Could not establish a connection to 'Diskstation212' (192.168.1.104:22)!
                  • da_Woody
                    da_Woody last edited by
                    @bishop hmm, hab gerade meine 2 DS reingehängt, da kommt wirklich nicht viel rum. ausser bei der grossen mehr...
                    wenn du mehr infos brauchst, dann nimm den synology adapter...
                      bishop @da_Woody last edited by bishop
                      @da_woody
                      ja das habe ich auch schon probiert, wollte das ohne synology adapter versuchen 🙂
                      werde das ganze mit nem rsa schlüssel versuchen vielleicht geht es damit besser!
                      • da_Woody
                        da_Woody @bishop last edited by
                        @bishop tjo, schuss in den ofen... 🙂 komisch ja auch, daß bei der 218+ nichtmal control kommt...
                          @da_woody
                          liegt glaube ich am handshake.
                          • Scrounger
                            Scrounger Developer @bishop last edited by
                            @bishop sagte in Test Adapter Linux Control v1.x.x:
                            Hast du den timeout mal erhöht?
                              bishop @Scrounger last edited by
                              @scrounger
                              ja habe ich
                              linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
                              linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:82:5)
                              linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.servicesInfo (/opt/iobroker/node_modules/iobroker.linux-control/main.js:485:21)
                              linux-control.0	2021-03-14 13:25:03.940	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                              linux-control.0	2021-03-14 13:25:03.940	error	at runMicrotasks (<anonymous>)
                              linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
                              linux-control.0	2021-03-14 13:25:03.940	error	(23028) [servicesInfo] Diskstation218 (192.168.1.4:22): response error: sh: systemctl: command not found, stack: ResponseError: [servicesInfo] Diskstation218 (192.168.1.4:22): sh: systemctl: command
                              linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
                              linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:81:5)
                              linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.updateInfos (/opt/iobroker/node_modules/iobroker.linux-control/main.js:609:5)
                              linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.cmdAptUpdate (/opt/iobroker/node_modules/iobroker.linux-control/main.js:706:21)
                              linux-control.0	2021-03-14 13:25:03.551	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                              linux-control.0	2021-03-14 13:25:03.551	error	at runMicrotasks (<anonymous>)
                              linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
                              linux-control.0	2021-03-14 13:25:03.551	error	(23028) [cmdAptUpdate] Diskstation218 (192.168.1.4:22): response error: sh: apt-get: command not found, stack: ResponseError: [cmdAptUpdate] Diskstation218 (192.168.1.4:22): sh: apt-get: command not
                              linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
                              linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:80:5)
                              linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.distributionInfo (/opt/iobroker/node_modules/iobroker.linux-control/main.js:553:21)
                              linux-control.0	2021-03-14 13:25:03.533	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                              linux-control.0	2021-03-14 13:25:03.533	error	at runMicrotasks (<anonymous>)
                              linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
                              linux-control.0	2021-03-14 13:25:03.533	error	(23028) [distributionInfo] Diskstation218 (192.168.1.4:22): response error: cat: /etc/os-release: No such file or directory, stack: ResponseError: [distributionInfo] Diskstation218 (192.168.1.4:22):
                              host.iobroker	2021-03-14 13:24:27.723	info	instance system.adapter.linux-control.0 started with pid 23028
                              Der Synology Adapter ist im Prinzip möglich nur der stresst meine Nas ziemlich, wenn der Adapter läuft habe ich mindestens 30% mehr CPU auslastung!
                              ? Scrounger 2 Replies Last reply Reply Quote 0
                                A Former User @bishop last edited by
                                @bishop dann stimmt was nicht mit der config oder system, der Synology Adapter braucht nicht viel Ressourcen.
                                Welche Version hast du denn installiert?
                                • Scrounger
                                  Scrounger Developer @bishop last edited by Scrounger
                                  @bishop
                                  Jetzt klappt doch die Verbindung.
                                  Musst halt alle Datenpunkte wo er nix findet (Fehlemeldung im Log) auf die Blacklist schieben.
                                  Meine Befehle solltest du dann nutzen können.
                                    @scrounger
                                    Ok teste ich danke.
                                    @ilovegym
                                    Nicht das iobroker System sondern die Nas!
                                    • da_Woody
                                      @bishop hmm, mein privat-NAS dümpelt bei 6% rum, die grosse mit dem ftp-server, trotz 3 leutz aktiv drauf, bei 40%.
                                      wie sollte der adapter das NAS beanspruchen?
                                        @da_woody
                                        hm..
                                        hier mal ein Auszug aus meiner Ds218+ CPU Auslastung, Ram sind 8GB zusätzlich verbaut also insgesamt 10GB.
                                        IoBroker läuft im Docker.
                                        kein Plan warum das so eine Auswirkung auf meine DS hat... einfach zu schwach auf der Brust???
                                        • da_Woody
                                          @bishop die 218+ sollte das eigentlich schaffen. is ja meine private auch. wie sieht denn die benutzerauslastung aus, wenn adapter aus? die 67%...
                                          aber ok, bei mir lööpt da kein ioBroker oder sonstige Docker dingens...
                                            Master-Rudi @da_Woody last edited by
                                            Kann ich mit dem Adapter denn auch die GPIOs eines anderen Raspberry steuern?
                                            Ich habe an meinem Octoprint Raspberry ein Relais für das Licht, das würde ich gerne in meiner VIS ein und ausschalten wollen.
                                            Danke!
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            164013
