    4. Test Adapter enigma2 v1.2.x
    • Glasfaser
      Glasfaser @Termina last edited by
      @Termina sagte in Test Adapter enigma2 v1.2.x:
      auf das Picon verzichten kann!
      Eigentlich nicht ...
      Das Picon ist doch in sehr kurzer Zeit auf den neuen Namen geändert ...
      ist halt doppelt aber wehn Störts und du bist zufrieden .
        Termina @Glasfaser last edited by
        @Glasfaser
        Hast Du auch wieder recht! Gute Idee! 👍
          Jan1 last edited by Jan1
          Der Adapter läuft leider nicht mehr mit dem neuen JS-Controller 3.2.3 und bringt Fehler:
          2021-01-09 13:18:47.837 - info: host.Beelink "system.adapter.enigma2.0" disabled
          2021-01-09 13:19:03.296 - info: host.Beelink "system.adapter.enigma2.0" enabled
          2021-01-09 13:19:03.363 - info: host.Beelink instance system.adapter.enigma2.0 started with pid 1556694
          2021-01-09 13:19:05.000 - info: enigma2.0 (1556694) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.15.4, js-controller: 3.2.3
          2021-01-09 13:19:05.031 - info: enigma2.0 (1556694) starting Polling every 5000 ms
          2021-01-09 13:19:05.075 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-01-09 13:19:05.076 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
          2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Error: Not exists
          at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2270:17)
          at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3010:38)
          at processImmediate (internal/timers.js:463:21)
          2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Not exists
          2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
          2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Error: Not exists
          2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Not exists
          2021-01-09 13:19:05.104 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
          2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Error: Not exists
          2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Not exists
          2021-01-09 13:19:05.106 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
          2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) Error: Not exists
          2021-01-09 13:19:05.108 - error: enigma2.0 (1556694) Not exists
          2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
          2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Error: Not exists
          2021-01-09 13:19:05.110 - error: enigma2.0 (1556694) Not exists
          2021-01-09 13:19:05.619 - info: enigma2.0 (1556694) terminating
          2021-01-09 13:19:05.621 - warn: enigma2.0 (1556694) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2021-01-09 13:19:06.260 - error: host.Beelink instance system.adapter.enigma2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2021-01-09 13:19:06.262 - info: host.Beelink Restart adapter system.adapter.enigma2.0 because enabled
          Matten Matten 1 Reply Last reply Reply Quote 0
          • Matten Matten
            Matten Matten @Jan1 last edited by
            @Jan1 sagte in Test Adapter enigma2 v1.2.x:
            "fixed with js-controller 3.2.4" hat Apollon geantwortet.
            Matten Matten
              Jan1 @Matten Matten last edited by
              @Matten-Matten
              Ja läuft wieder 😉
                @Matten-Matten
                bleibt für Dich noch dieses kleine Problemchen 😉
                enigma2.0	2021-01-10 11:38:36.473	warn	(2002513) State "enigma2.0.Message.MESSAGE_ANSWER" has no existing object, this might lead to an error in future versions
                enigma2.0	2021-01-10 11:38:36.471	warn	(2002513) State "enigma2.0.enigma2.CHANNEL_PICON" has no existing object, this might lead to an error in future versions
                  Thema Videowiedergabe
                  Gibt es eine Möglichkeit Informationen zu erhalten, wenn die Box ein Video abspielt? Das normale TV-Programm kann man ja mittlerweile super auch in der VIS abbilden - wäre bei Filmen doch auch super, oder?
                  A SBorg 2 Replies Last reply Reply Quote 0
                    aleks-83 @Termina last edited by aleks-83
                    @termina
                    Geht das Ganze nicht über die "EVENT..." Datenpunkte? (EVENT_PROGRESS_PERCENT, EVENTREMAINING_MIN...)
                    Kann man mit dem Adapter eigentlich irgendwie das Display einer Enigma2 Box dimmen?
                    Speziell einer VU+ Duo2?
                    • SBorg
                      SBorg Forum Testing Most Active @Termina last edited by
                      @termina sagte in Test Adapter enigma2 v1.2.x:
                      Ja, ich finde nur gerade nicht wie ich es genau gelöst habe. Ich lasse mir aber in der VIS das Sender-Picon anzeigen. Wenn ich ein Video abspiele wird dies dann durch ein "Festplatten"-Picon ersetzt.
                      Soweit ich mich erinnere wird beim abspielen eines Videos die SID in etwa auf "0:0:0:0:0:0:0:0::" gesetzt, was ich mir dafür zu nutze mache, denn die wird nur da in der Art gesetzt.
                      @aleks-83 IMHO nein, denn mir wäre aktuell kein Web-IF Befehl (und die nutzt der Adapter per API) bekannt der die Helligkeit dimmen könnte. Außer es gäbe einen Konsolen-Befehl dafür, dann könnte man den per SSH absetzen.
                        EVOlutionIX last edited by
                        Hallo alle zusammen, ich bin jetzt wirklich 424 Beiträge durch gegangen aber ich kann kaum verstehen wie es funktioniert einfach auf einen bestimmten Kanal zu wechseln.
                        Ich konnte es mir solala zusammen reimen wie ich den Kanal Wechsel über den Befehl Servicereference (woher bekommt man sie Servicereference einfacher ohne den Umweg DreamboxEDIT) ? Allerdings schaffe ich es nicht auf den stream meiner IP Kamera umzuschalten, der in der Senderliste gespeichert ist, wenn ich auf die Servicereference umschalte bekomme ich nur einen schwarzen Bildschirm?
                        Schönen Sonntag noch Gruß Marcus
                        • Negalein
                          Negalein Global Moderator @EVOlutionIX last edited by
                          @evolutionix sagte in Test Adapter enigma2 v1.2.x:
                          http://IP-deiner-Box/web/getallservices
                          Jens Meyer 1 Reply Last reply Reply Quote 0
                          • Jens Meyer
                            Jens Meyer @Negalein last edited by Jens Meyer
                            Hallo an alle hier...
                            Der Adapter funktioniert und bin gerade am probieren,
                            Mit was kann ich den die movielist anzeigen lassen? Mit einfach html gehts nicht, json geht so auch nicht
                            Was nehmt ihr dafür und gibts ne Möglichkeit ne epg Vorschau für mehrere Tage anzuzeigen und dann was nehme ich dann auch dafür? Ne Tabelle?
                            Danke schon mal
                            Meister Mopper Negalein 2 Replies Last reply Reply Quote 0
                            • Meister Mopper
                              Meister Mopper @Jens Meyer last edited by
                              @jens-meyer Du kannst das webif in einem View in vis anzeigen lassen und dort auch bedienen.
                              • Jens Meyer
                                Jens Meyer @Meister Mopper last edited by
                                @meister-mopper ja, das wollte ich eigentlich nicht.. das webif kann ich auch so aufrufen..
                                ich dachte es muss doch ne andere Möglichkeit geben das darzustellen
                                Aber danke
                                • Meister Mopper
                                  @jens-meyer Dann musst Du ein eigenes webif bauen, das wäre mir zu viel 😧
                                  • Jens Meyer
                                    @meister-mopper
                                    Nein ich will das ja nur in der vis darstellen...
                                    Und der datenpunkt existiert ja
                                    • Negalein
                                      Negalein Global Moderator @Jens Meyer last edited by
                                      @jens-meyer sagte in Test Adapter enigma2 v1.2.x:
                                      schau mal hier
                                      • Jens Meyer
                                        @negalein
                                        Danke, schau ich mir mal genauer an...
                                          west last edited by west
                                          Ist das der https://github.com/Matten-Matten/ioBroker.enigma2 oder zum Testen steht oder ein anderen?
                                          Habe selber eine VU+ Solo4K mit OpenATV 6.4.20210409
                                          • Glasfaser
                                            Glasfaser @west last edited by
                                            @west
                                            Ist der richtige Link.
                                            adapter enigma2
                                            71
                                            640
                                            135585
