    4. JavaScript
    5. Energieanzeige (kWh) über HTML Tabelle - vis
      liv-in-sky @Idefix01 last edited by
      @idefix01 wenn's beim ersten klappt, dann hier das andere widget - auch im script ersetzen
      mysubText =     `<div>Strom: ${Number(vax3).toFixed(2)} A</div>
                        <div>Spannung: ${vax4} V</div>
                        <div>Leistung: ${vax5} W</div>
                        <div>&ensp; </div>
                        <div>Heute: ${Number(vax7).toFixed(2)} kWh</div>
                        <div>Monat: ${Number(vax8).toFixed(2)} kWh</div>
                        <div>Vormonat: ${vaxMBefore} kWh</div>
                        <div>&ensp; </div>
                        <div>Heute: ${vax9} €</div>
                        <div>Monat: ${vax10} €</div>
                        <div>Vormonat: ${vaxKostenBefore} €</div>
                        <div style="display: flex; flex: 1; text-align: left; align-items: center; position: relative;">
                        ${vax6}</font></div>`;
      } else {
      mysubText =     `     <div style="color: ${farbeMDEinspeisung};  ">EINSPEISUNG Leistung: ${vax5} W</div>
                          <div>&ensp; </div>
                          <div>&ensp; </div>
                          <div>Schalter: ${vax6}</font></div>`;
                          vaxBckGround="#8A4B08";
      //  // <div>Strom:${vax3}A Spannung: ${vax4}V Leistung: ${vax5}W</div>    //font-size: 80% ;
      if (vax1.indexOf("GESAMT VirtualPower")>-1) {
      mysubText =     ` <div>&ensp; </div>
                        <div>&ensp; </div>
                        <div>&ensp; </div>
                        <div>&ensp; </div>
                        <div>&ensp; </div>
                        <div>Heute: ${vax9} € </div>
                        <div>&ensp; </div>`;
      if (vax1.indexOf("GESAMT")>-1) {
                        <div>&ensp; </div>
                        <div>&ensp; </div>
                        <div>&ensp; </div>
                        <div>&ensp; </div>
      von hier:
      bis hier:
      • Holger Etzel
        Holger Etzel last edited by
        bekomme nach Start vom Script folgende Fehlermeldungen:
        javascript.0	2021-03-14 14:06:00.021	error	(2844967) at processTimers (internal/timers.js:497:7)
        javascript.0	2021-03-14 14:06:00.021	error	(2844967) at listOnTimeout (internal/timers.js:554:17)
        javascript.0	2021-03-14 14:06:00.021	error	(2844967) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
        javascript.0	2021-03-14 14:06:00.021	error	(2844967) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
        javascript.0	2021-03-14 14:06:00.021	error	(2844967) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
        javascript.0	2021-03-14 14:06:00.020	error	(2844967) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1296:34)
        javascript.0	2021-03-14 14:06:00.020	error	(2844967) at Object.<anonymous> (script.js.System.Status_Geräte_Stromverbrauch:1272:2)
        javascript.0	2021-03-14 14:06:00.014	error	(2844967) at writeHTML (script.js.System.Status_Geräte_Stromverbrauch:662:26)
        javascript.0	2021-03-14 14:06:00.013	error	(2844967) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:800:29)
        javascript.0	2021-03-14 14:06:00.013	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:678:77
        javascript.0	2021-03-14 14:06:00.012	error	(2844967) Error in callback: TypeError: Cannot read property 'toString' of null
        javascript.0	2021-03-14 14:05:20.390	error	(2844967) at Script.runInContext (vm.js:130:18)
        javascript.0	2021-03-14 14:05:20.390	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:1696:3
        javascript.0	2021-03-14 14:05:20.390	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:1275:2
        javascript.0	2021-03-14 14:05:20.390	error	(2844967) at writeHTML (script.js.System.Status_Geräte_Stromverbrauch:662:26)
        javascript.0	2021-03-14 14:05:20.390	error	(2844967) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:800:29)
        javascript.0	2021-03-14 14:05:20.390	error	(2844967) at script.js.System.Status_Geräte_Stromverbrauch:678:77
        javascript.0	2021-03-14 14:05:20.389	error	(2844967) script.js.System.Status_Geräte_Stromverbrauch: TypeError: Cannot read property 'toString' of null
        javascript.0	2021-03-14 14:05:20.388	info	(2844967) script.js.System.Status_Geräte_Stromverbrauch: registered 0 subscriptions and 1 schedule
        javascript.0	2021-03-14 14:05:20.365	info	(2844967) Start javascript script.js.System.Status_Geräte_Stromverbrauch
        Hat jemand eine Idee was das sein könnte?
        Danke schon mal im voraus.
        Holger
          liv-in-sky @Holger Etzel last edited by
          @holger-etzel
          es scheint mir auf den ersten blick, dass du geräte hast, die keinen state haben ( fritzdect und shelly)
          kann das sein
          beim shelly energy_current oder energy_voltage
          beim fritzdect entweder fehlt power oder voltage
          ich hoffe, du hast das script nicht mit firefox aus dem forum kopiert - den dann stimmen die zeilennummer nicht mehr - da muss man chrome nehmen
          Holger Etzel 1 Reply Last reply Reply Quote 0
          • Holger Etzel
            Holger Etzel @liv-in-sky last edited by
            @liv-in-sky
            ich habe nur shelly-Geräte:
            Plugs, shelly1PM, shelly 2.5 und shelly3EM.
            Wobei der 3EM nicht so wichtig für die Tabelle ist
            Habe das script gespeichert und mit editor geöffnet.
              @holger-etzel
              wieviele zeilen hat das script im javascript editor ?
              • Holger Etzel
                @liv-in-sky
                bei 1691 ist die letzte Klammer
                  @holger-etzel
                  das paßt
                  dann mußt du die shelly datenpunkte prüfen ob die states beschrieben sind - viellicht gibt es shelly's, die nicht mehr genutzt werden, oder unbenannt wurden ....
                    @holger-etzel
                    siehe chat nachricht
                    • Holger Etzel
                      @liv-in-sky
                      bin im Raum
                        @holger-etzel
                        kannst du mir bite den geänderten code im shelly block posten - hab vergessen zu koieren
                        • Holger Etzel
                          @liv-in-sky
                          $('shelly.*.*.*.Power').each(function(id, i) {
                                  if(existsState(id) && getState(id).val != null ) {
                                   anzahl++;
                                  var ida = id.split('.');
                                    counter++;
                                    val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ; // log(val0+"---" +lastID)
                                    if (val0 == lastID) {lastID=val0; shellyNumber++; val0=val0+"("+shellyNumber.toString()+")"} else{lastID=val0; shellyNumber=1}
                                    val1=getState(ida[0]+"."+ida[1]+"."+ida[2]+".online").val
                                    val2=" - "; val3=" - ";
                                    if(existsState(id.replace("Power","Energy_Current"))) {     val2=((getState(id.replace("Power","Energy_Current")).val)).toString()+ " A"; }
                                     if(existsState(id.replace("Power","Energy_Voltage"))) { val3=getState(id.replace("Power","Energy_Voltage")).val.toString()+" V"; }
                                    val4=getState(id).val.toString()+" W";
                                    var val5_1;
                                    if (existsState(id.replace("Power","Switch"))) {val5_1= getState(id.replace("Power","Switch")).val;  } else {val5_1= getState(ida[0]+"."+ida[1]+"."+ida[2]+".Relay0.Switch").val;  }
                                    val5_1 ? val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val5=(" <font color=\""+farbeSchalterON+"\"> ")+"OFF</font>";
                                     val6=" - "; val7=" - "; val8=" - "; val9=" - ";
                                     valMarkeDevice="shellyk"
                          sorry war gestern nicht im Forum.
                          Das sollte der code sein.
                          Nochmal vielen, vielen dank für die umfangreiche Hilfe.
                          Holger
                          tugsi 1 Reply Last reply Reply Quote 1
                          • tugsi
                            tugsi @Holger Etzel last edited by
                            @holger-etzel sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                            Es fehlt am Ende dann eine geschweifte Klammer durch :
                            Muss ganz am Ende des Shelly-Abschnittes (hast Du nicht mit angefügt) noch das Ende gesetzt werden:
                            } //ende fritzdect
                            Gesamter Shelly-Abschnitt also:
                             if (shelly){
                            counter=0
                                  counter++//=0;
                                  val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";val8="";val9="";
                                  tabelleBind();
                                  tabelleAusbessern();
                                  counter++//=0;
                                  val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Shelly</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                                  val5="<font color=\""+htmlColorDeviceUeberschrift+"\"></font>";
                                  val6="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Now<"+HTMLbrandSetting+"></font>";
                                  val7="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Monat<"+HTMLbrandSetting+"></font>";
                                  val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Now<"+HTMLbrandSetting+"></font>";
                                  val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Monat<"+HTMLbrandSetting+"></font>";
                                  tabelleBind();
                            lastID="";
                                     anzahl++;
                                      counter++;
                                       var val5_1;
                                      if (sourceAnalyShelly) {brechneEnergy(val0,getState(id).val)
                                         if (rootCounter){
                                             sammleDaten();
                                        berechneGesamt()
                                  zeigeVal1();
                                  if (!filterArrAusnahme.includes(val0)) {
                                     tabelleBind();
                                    } else{let help=[val0,val1,val2,val3,val4,val5,val6,val7,val8,val9]; filterArrAusnahmeHelp.push(help);}
                            } //ende fritzdect
                            Thomas
                              liv-in-sky @tugsi last edited by
                              @tugsi danke, da hast du recht - aber der codeausschnit war mehr für mich gedacht - zum einbinden ins script im ersten post
                              natrürlich kann man aber deinen "schnippsel" auch selbst ins eigene script kopieren
                              tugsi 1 Reply Last reply Reply Quote 0
                              • tugsi
                                tugsi @liv-in-sky last edited by
                                @liv-in-sky
                                ich war mir da etwas unsicher, da der Beitrag schon ein paar Tage alt war und ich gerade wegen den Shelly´s daran arbeitete und das in deinem Script noch nicht angepasst war.
                                Nicht bevor nachher den Schnipsel einfach nimmt und sich wundert, warum es nicht läuft 😉
                                  @tugsi
                                  mittlerweile ist es angepaßt - alles gut soweit 🙂
                                  • JB_Sullivan
                                    JB_Sullivan last edited by JB_Sullivan
                                    GOOD MORNING - ioBroker ( in Anlehnung an Vietnam ; ) )
                                    Ich wollte gerade Heute damit beginnen meine ganzen Energieströme mal ein bisschen zu sortieren. Gut das ich vorher (die nun besser funktionierende) Foren Suche benutzt habe.
                                    Da letztes Jahr, im Rahmen meiner PV Anlagen Installation, auch ein neuer Verteilerschrank (3-Reihig) montiert wurde, war ich die letzten Wochen damit beschäftigt diesen ein wenig mit Smart Home Komponenten zu bestücken.
                                    Damit bin ich jetzt soweit durch und habe .....
                                    • 4 x Shelly 3EM (Jeder Shelly detektiert eine Unterverteilung im Haus [Garten, Küche, Keller, Restliches Gebäude])
                                    • 6 x Sonoff POW für einzelne Geräte die über den Adapter Device-Reminder auch auf den Betriebszustand überwacht werden (Trockner, Waschmaschine, Geschirrspüler, 3 x TV Wände mit dem ganzen Multimedia Equipment & Beleuchtung)
                                    • Sowie die die üblichen Verdächtigen zur Erfassung der PV Daten (Fronius Adapter) und der Zähler Daten für`s EVU (Discovergy Adapter)
                                    • Demnächst wird noch openWB für die Erfassung der Energieströme zum e-Auto montiert.
                                    Natürlich ist auch Sourceanalytix im Einsatz.
                                    Lange Rede kurzer Sinn:
                                    Dieser Thread und alle Teil- und Vorgänger Threads sind ja nun doch sehr umfangreich und verschachtelt.
                                    Was ist denn jetzt der aktuelle Stand bezgl. Script und VIS Bild? Hier auf der Seite Beitrag #1?
                                    .... oder wie ist der Stand der Dinge?
                                    Freue mich schon darauf mit Eurer Vorlage loslegen zu können 😉
                                    So, habe mir mal das Script aus Beitrag #1 importiert. Allerdings unterstreicht der Script Editor jede Menge Zeilen und/oder Begriffe ROT, was ja meist der Hinweis auf ein Fehler ist.
                                    JavaScript Engine Adapter ist in der Version 5.1.3 installiert.
                                      liv-in-sky @JB_Sullivan last edited by
                                      @jb_sullivan
                                      auch dir ein good morning - seit der source-analy. adapter wieder gepflegt wird, mache ich eigentlich nix mehr an diesem script - ich bin davon ausgegangen, das der adapter das alles kann
                                      mein script wird deinen fall nicht abdecken - es wurde entwickelt um einzelne devices zu überwachen, den verbrauch zu notieren und anzuzeigen - bei deinem beispiel die sonoff pows - aber nur, wenn nicht die neue baumstriktur des sonoff adapters genutzt wird
                                      @jb_sullivan sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                                      sowie die die üblichen Verdächtigen zur Erfassung der PV Daten (Fronius Adapter) und der Zähler Daten für`s EVU (Discovergy Adapter)
                                      • damit kann das script nix anfangen
                                      • da bin ich mir garnicht mehr sicher - müßten mit aufgenommen werden können
                                      am besten, du installierst das script und setzt mal pow und shelly auf true und schaust dann mal in der vis, was alles angezeigt wird
                                      zur not können wir auch gerne eine anydesk session machen
                                      • JB_Sullivan
                                        JB_Sullivan @liv-in-sky last edited by
                                        @liv-in-sky sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                                        Ja, werde ich machen und mich mal ein bisschen durchwurschtel. Ich finde halt die ganze, daran hängende VIS Geschichte, mit der automatisch erzeugten Tabellen sehr Charmant.
                                        Ich muss das script nur mal irgendwie runter geladen bekommen. Trotz Chrome zerhackt der Browser mir die Ä,Ü usw. was dann im Script Editor für die roten Unterstreichungen sorgt.
                                          @jb_sullivan wart nen moment - meld mich
                                            @jb_sullivan
                                            probier es mal von hier - selbes script https://github.com/liv-in-sky/iobroker-energy-script/blob/main/Energy-script-22-1-21.txt
                                            javascript template
                                            37
                                            696
                                            130740
