    4. IOBroker nicht mehr erreichbar nach Routertausch
    • Matze Quin
      Matze Quin @Thomas Braun last edited by Matze Quin
      ja genau diese Meldung ist vorhanden.
      Normaler Weise werden automatisch über Backitup Backups erstellt. Habe eins vom 09.03. und 12.03. Warum dazwischen keine erstellt wurden entzieht sich meiner kenntnis. Ab dem 12.03. ist der neue Router da.
      cd /opt/iobroker
      iobroker stop
      sudo -H -u iobroker npm install iobroker.js-controller
      iobroker start
      läuft gerade
      Matze Quin 1 Reply Last reply Reply Quote 0
      • Matze Quin
        Matze Quin @Matze Quin last edited by
        @matze-quin
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ iobroker stop
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.10
        > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
         Cannot read system.config: null (OK when migrating or restoring)
         Cannot find view "system" for search "host"
        object 0_userdata.0.example_state created
        object 0_userdata.0 created
        object alias.0 created
        object system.certificates created
        object system.repositories created
        object system.config created
        object enum.functions created
        object enum.rooms created
        object system.group.user created
        object system.group.administrator created
        object _design/system created
        Renamed repository "default to "stable"
        Renamed repository "latest to "beta"
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + iobroker.js-controller@3.2.16
        removed 13 packages and updated 15 packages in 32.845s
        50 packages are looking for funding
          run `npm fund` for details
        pi@raspberrypi:/opt/iobroker $ iobroker start
        Leider immer noch nicht erreichbar über 192.168.0.178:8081
          Thomas Braun Most Active @Matze Quin last edited by
          @matze-quin
          Nochmal
          iobroker status
          iobroker list adapters
          iobroker list instances
          • Matze Quin
            @thomas-braun said in IOBroker nicht mehr erreichbar nach Routertausch:
            iobroker status
            iobroker status
            iobroker is not running on this host.
            Objects type: file
            States  type: file
            pi@raspberrypi:/opt/iobroker $ iobroker list adapters
            pi@raspberrypi:/opt/iobroker $ iobroker list instances
            + instance is alive
              Thomas Braun Most Active @Matze Quin last edited by Thomas Braun
              @matze-quin
              iobroker host this
              iobroker add admin
              • Matze Quin
                pi@raspberrypi:/opt/iobroker $ iobroker add admin
                host.raspberrypi install adapter admin
                npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.admin"
                upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                host.raspberrypi object system.adapter.admin created/updated
                host.raspberrypi create instance admin
                host.raspberrypi object admin.0.info.newsETag created
                host.raspberrypi object admin.0.info.newsfeed created
                host.raspberrypi object admin.0.connected created
                host.raspberrypi object admin.0 created
                host.raspberrypi object admin.0.info created
                host.raspberrypi object system.adapter.admin.upload created
                host.raspberrypi object system.adapter.admin.0.logLevel created
                host.raspberrypi object system.adapter.admin.0.sigKill created
                host.raspberrypi object system.adapter.admin.0.eventLoopLag created
                host.raspberrypi object system.adapter.admin.0.outputCount created
                host.raspberrypi object system.adapter.admin.0.inputCount created
                host.raspberrypi object system.adapter.admin.0.uptime created
                host.raspberrypi object system.adapter.admin.0.memRss created
                host.raspberrypi object system.adapter.admin.0.memHeapTotal created
                host.raspberrypi object system.adapter.admin.0.memHeapUsed created
                host.raspberrypi object system.adapter.admin.0.cputime created
                host.raspberrypi object system.adapter.admin.0.cpu created
                host.raspberrypi object system.adapter.admin.0.compactMode created
                host.raspberrypi object system.adapter.admin.0.connected created
                host.raspberrypi object system.adapter.admin.0.alive created
                host.raspberrypi object system.adapter.admin.0 created
                pi@raspberrypi:/opt/iobroker $ iobroker host this
                A host with the name "raspberrypi" already exists!
                host.raspberrypi object admin.1.info.newsETag created
                host.raspberrypi object admin.1.info.newsfeed created
                host.raspberrypi object admin.1.connected created
                host.raspberrypi object admin.1 created
                host.raspberrypi object admin.1.info created
                host.raspberrypi object system.adapter.admin.1.logLevel created
                host.raspberrypi object system.adapter.admin.1.sigKill created
                host.raspberrypi object system.adapter.admin.1.eventLoopLag created
                host.raspberrypi object system.adapter.admin.1.outputCount created
                host.raspberrypi object system.adapter.admin.1.inputCount created
                host.raspberrypi object system.adapter.admin.1.uptime created
                host.raspberrypi object system.adapter.admin.1.memRss created
                host.raspberrypi object system.adapter.admin.1.memHeapTotal created
                host.raspberrypi object system.adapter.admin.1.memHeapUsed created
                host.raspberrypi object system.adapter.admin.1.cputime created
                host.raspberrypi object system.adapter.admin.1.cpu created
                host.raspberrypi object system.adapter.admin.1.compactMode created
                host.raspberrypi object system.adapter.admin.1.connected created
                host.raspberrypi object system.adapter.admin.1.alive created
                host.raspberrypi object system.adapter.admin.1 created
                  @Matze-Quin
                  Da ist aber doch nicht nur der Router getauscht worden!
                  Was ist sonst noch "passiert"?
                  • Matze Quin
                    Matze Quin @Homoran last edited by Matze Quin
                    Der Pi war direkt an den Router angeschlossen.
                    Habe nen neuen Vodafone Vertrag.
                    An den Router waren auch 2 wlan router angeschlossen, allerdings haben die meines Wissens nichts mit dem PI zu tun?!
                    Der Router gehört mir, habe ihn Bei Vodafone angegeben, falls relevant.
                      Homoran Global Moderator Administrators @Matze Quin last edited by
                      @matze-quin sagte in IOBroker nicht mehr erreichbar nach Routertausch:
                      falls relevant.
                      Nee, isses nich!
                      Mich interessiert viel mehr, was am Pi sonst noch "gespielt" wurde
                      • an der selben Steckdose und diese wurde ausgeschaltet?
                      • Rettungsversuche irgendeiner Art?
                      • Installationen von irgendetwas?
                      • Matze Quin
                        Ja jetzt wo du es sagst habe ich letzte Tage einmal eine "Reparatur" von dem iobroker tool von elzershark ausgeführt.
                        Das habe ich allerdings schon öffter gemacht und noch nie war es bisher ein Problem. Sorry das hätte ich früher erwähnen sollen.
                        Dieses Tool ist gemeint:
                        https://www.elzershark.com/forum/index.php?thread/4-backup-reparatur-install-tool-iobroker/
                          Das ist leider kein gutes Tool 😢
                          Matze Quin 1 Reply Last reply Reply Quote 1
                          • Matze Quin
                            ohha das ist unschön zu lesen. Hast du da eine alternative für mich?
                            Meinst du das diese Tatsache mit meinem Problem im Zusammenhang steht?
                            Vorher war definitiv alles in Funktion.
                              sieh dir mal die Links in der Signatur von @Thomas-Braun an
                                Dann bin ich auch raus. Das Ding ist aus meiner Sicht so windig, da mach ich dann nix mehr.
                                • Matze Quin
                                  In welcher Form windig? Mir war nicht bewusst das dieses Tool nicht vernünftig funktioniert.
                                  • Matze Quin
                                    Danke das mache ich. Was ist nun geschehen nach der "Reparatur"?
                                    Bin mir unsicher wie ich nun vorgehen soll...
                                      @matze-quin
                                      Wenn ich mir so anschaue, was der 'Kollege' wiederholt für (mit Verlaub) Schwachsinn empfiehlt brauch ich gar nicht weiter zu schauen. Wenn der den selben Murks in seinem supermegadollen Tool verbricht wird das unwartbar.
                                      • Matze Quin
                                        Ok ich verstehe...
                                        wie kann ich nun am besten vorgehen? Bin echt aufgeschmissen, daher hoffe ich das ihr mir weiter helfen wollt.
                                          @matze-quin
                                          Hast du ein Backup?
                                          • backup extern sichern
                                          • ioBroker Neu installieren
                                          • backup zurückspielen
                                          • Matze Quin
                                            Ja habe ich. Ok wie führe ich die Neuinstalation am besten aus?
                                            1.0k
                                            22303
