    4. Test Adapter Linux Control v1.x.x
      bishop @Scrounger last edited by
      @scrounger
      ja habe ich
      linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
      linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:82:5)
      linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.servicesInfo (/opt/iobroker/node_modules/iobroker.linux-control/main.js:485:21)
      linux-control.0	2021-03-14 13:25:03.940	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      linux-control.0	2021-03-14 13:25:03.940	error	at runMicrotasks (<anonymous>)
      linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
      linux-control.0	2021-03-14 13:25:03.940	error	(23028) [servicesInfo] Diskstation218 (192.168.1.4:22): response error: sh: systemctl: command not found, stack: ResponseError: [servicesInfo] Diskstation218 (192.168.1.4:22): sh: systemctl: command
      linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
      linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:81:5)
      linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.updateInfos (/opt/iobroker/node_modules/iobroker.linux-control/main.js:609:5)
      linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.cmdAptUpdate (/opt/iobroker/node_modules/iobroker.linux-control/main.js:706:21)
      linux-control.0	2021-03-14 13:25:03.551	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      linux-control.0	2021-03-14 13:25:03.551	error	at runMicrotasks (<anonymous>)
      linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
      linux-control.0	2021-03-14 13:25:03.551	error	(23028) [cmdAptUpdate] Diskstation218 (192.168.1.4:22): response error: sh: apt-get: command not found, stack: ResponseError: [cmdAptUpdate] Diskstation218 (192.168.1.4:22): sh: apt-get: command not
      linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
      linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:80:5)
      linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.distributionInfo (/opt/iobroker/node_modules/iobroker.linux-control/main.js:553:21)
      linux-control.0	2021-03-14 13:25:03.533	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      linux-control.0	2021-03-14 13:25:03.533	error	at runMicrotasks (<anonymous>)
      linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
      linux-control.0	2021-03-14 13:25:03.533	error	(23028) [distributionInfo] Diskstation218 (192.168.1.4:22): response error: cat: /etc/os-release: No such file or directory, stack: ResponseError: [distributionInfo] Diskstation218 (192.168.1.4:22):
      host.iobroker	2021-03-14 13:24:27.723	info	instance system.adapter.linux-control.0 started with pid 23028
      Der Synology Adapter ist im Prinzip möglich nur der stresst meine Nas ziemlich, wenn der Adapter läuft habe ich mindestens 30% mehr CPU auslastung!
      ? Scrounger 2 Replies Last reply Reply Quote 0
        A Former User @bishop last edited by
        @bishop dann stimmt was nicht mit der config oder system, der Synology Adapter braucht nicht viel Ressourcen.
        Welche Version hast du denn installiert?
        • Scrounger
          Scrounger Developer @bishop last edited by Scrounger
          @bishop
          Jetzt klappt doch die Verbindung.
          Musst halt alle Datenpunkte wo er nix findet (Fehlemeldung im Log) auf die Blacklist schieben.
          Meine Befehle solltest du dann nutzen können.
            @scrounger
            Ok teste ich danke.
            @ilovegym
            Nicht das iobroker System sondern die Nas!
            • da_Woody
              da_Woody @bishop last edited by
              @bishop hmm, mein privat-NAS dümpelt bei 6% rum, die grosse mit dem ftp-server, trotz 3 leutz aktiv drauf, bei 40%.
              wie sollte der adapter das NAS beanspruchen?
                bishop @da_Woody last edited by bishop
                @da_woody
                hm..
                hier mal ein Auszug aus meiner Ds218+ CPU Auslastung, Ram sind 8GB zusätzlich verbaut also insgesamt 10GB.
                IoBroker läuft im Docker.
                kein Plan warum das so eine Auswirkung auf meine DS hat... einfach zu schwach auf der Brust???
                • da_Woody
                  @bishop die 218+ sollte das eigentlich schaffen. is ja meine private auch. wie sieht denn die benutzerauslastung aus, wenn adapter aus? die 67%...
                  aber ok, bei mir lööpt da kein ioBroker oder sonstige Docker dingens...
                    Master-Rudi @da_Woody last edited by
                    Kann ich mit dem Adapter denn auch die GPIOs eines anderen Raspberry steuern?
                    Ich habe an meinem Octoprint Raspberry ein Relais für das Licht, das würde ich gerne in meiner VIS ein und ausschalten wollen.
                    Danke!
                    • FredF
                      FredF Most Active Forum Testing @Master-Rudi last edited by
                      @master-rudi sagte in Test Adapter Linux Control v1.x.x:
                      Nein, dafür gibt es den RPI Adapter
                        Master-Rudi @FredF last edited by Master-Rudi
                        @fredf
                        Aber ich möchte die GPIOs von einem anderem Raspberry steuern auf dem kein ioBroker ist. Also ich habe einen Raspi mit iobroker als Zentrale und einen mit octoprint für den Drucker. Und ich würde gerne das Licht über die VIS einschalten.
                        Ich habe den octoprint nicht als Slave im Multihost, weil da eben nur octoprint drauf ist.
                        Wie kann ich denn mit dem RPI Adapter die Werte eines anderen Raspi auslesen bzw. dessen GPIOs steuern?? Seh da nur den auf den mein iobroker ist.
                        da_Woody FredF 2 Replies Last reply Reply Quote 0
                        • da_Woody
                          da_Woody @Master-Rudi last edited by
                          @master-rudi na dann häng dein licht an einen shelly1 z.b.
                            @da_woody :
                            Klar, sicher möglich. Hab einige Shellys verbaut und normale Sonoffs, aber naja, wieder ein Gerät mehr im WLAN, wieder ein Gerät mehr zu überwachen und am Strom verbrauchen... Da finde ich meine Lösungen mit Relais am RPI charmanter. Es funktioniert ja auch schon. Ich kann das Licht mit "GPIO Control" in Octoprint steuern und hab es auch schon angeklemmt.
                            Nur eben nicht "remote" über meine VIS.
                            geht das mit JS?
                            • FredF
                              @master-rudi Ok, verstehe. Deine Frage war ob es mit Linux control geht.
                              Was hält dich davon ab Multihost zu machen?
                              • da_Woody
                                @master-rudi sorry, aber da setzt bei mir die logik aus. wenn du mit octoprint druckst und schaltest, warum willst du dann über vis schalten?
                                  @da_woody
                                  Naja ich drucke meist nach dem slicen vom PC aus und nutze die Octopi Visualisierung meist nicht.
                                  Mit meiner ioBroker VIS überwachs ich alles, Temperaturen, Webcam, Einschalten und Ausschalten, Druckfortschritt usw... Da auch die Webcam eingebunden ist wollte ich eben auch in der VIS das Licht einschalten können.
                                  • da_Woody
                                    @master-rudi ah, ok. das versteh ich jetzt schon. naja, ich druck lieber direkt mit octoprint. die tabs sind bei mir eigentlich auf allen rechnern immer öffen wenn ich drucke...
                                    • Scrounger
                                      Scrounger Developer @da_Woody last edited by
                                      @da_woody, @Master-Rudi, @FredF, @bishop
                                      Leute hier geht es um den Linux Control Adapter, nicht um CPU Auslastung, Shelly, etc 😉
                                      Macht für sowas extra Themen auf, danke!
                                      M B 2 Replies Last reply Reply Quote 0
                                        Master-Rudi @Scrounger last edited by
                                        @scrounger
                                        Richtig 🙂 Meine ursprüngliche Frage bezog sich auch auf Linux Control und ob ich damit die GPIOs einen anderen RPI schalten kann. Aber ich habe verstanden, dass das nicht geht.
                                          bishop @Scrounger last edited by bishop
                                          @scrounger
                                          ich habe IoBroker im Container unter Proxmox am laufen.
                                          dort kann ich mich auch auf mein Raspberry pi der als Slave läuft verbinden.
                                          wenn ich nun aber den Slave in Linux-Control eintrage, bekomme ich ein.
                                          linux-control.0	2021-03-28 10:23:51.132	info	(31041) [getConnection] Host 'iobroker-slave' (192.168.1.44:22) seems not to be online
                                          linux-control.0	2021-03-28 10:23:51.127	info	(31041) getting data from iobroker-slave (192.168.1.44:22)
                                          linux-control.0	2021-03-28 10:18:51.038	info	(31041) [getConnection] Host 'iobroker-slave' (192.168.1.44:22) seems not to be online
                                          linux-control.0	2021-03-28 10:18:51.027	info	(31041) getting data from iobroker-slave (192.168.1.44:22, Adapter start)
                                          linux-control.0	2021-03-28 10:18:51.004	info	(31041) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.21.0, js-controller: 3.2.16
                                          liegt das an Proxmox?
                                            @bishop Hi, in den Screenshot bist du als root in dem iobroker lxc unterwegs, und der Adapter ruft das ssh ja vom iobroker-account aus auf..
                                            liegt dein RSA Schluessel überall da, wo er auch gebraucht wird?
                                            Ansonsten versuchs mal mit Passwort..
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            164068
