    4. [ESPHome] Beta release
      e-s @Dutchman last edited by
      @dutchman
      Habe auch mal getestet, dabei sind auch sehr viele Abbrüche zu sehen, 2 verschiedene errrors:
      esphome.0	2021-03-16 07:35:03.211	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
      esphome.0	2021-03-16 07:35:03.205	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:35:03.204	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:35:03.158	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:35:03.138	info	(14077) ESPHome Device info received for test
      esphome.0	2021-03-16 07:35:03.121	info	(14077) ESPHome client 192.168.2.117 connected
      esphome.0	2021-03-16 07:34:27.024	warn	(14077) ESPHome client 192.168.2.117 disconnected
      esphome.0	2021-03-16 07:34:27.024	error	(14077) ESPHome client 192.168.2.117 Error: read ECONNRESET
      esphome.0	2021-03-16 07:28:01.808	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
      esphome.0	2021-03-16 07:28:01.805	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:28:01.804	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:28:01.754	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:28:01.736	info	(14077) ESPHome Device info received for test
      esphome.0	2021-03-16 07:28:01.730	info	(14077) ESPHome client 192.168.2.117 connected
      esphome.0	2021-03-16 07:27:31.381	error	(14077) ESPHome client 192.168.2.117 Error: connect EISCONN 192.168.2.117:6053 - Local (192.168.2.222:57128)
      esphome.0	2021-03-16 07:27:01.379	warn	(14077) ESPHome client 192.168.2.117 disconnected
      esphome.0	2021-03-16 07:26:02.518	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
      esphome.0	2021-03-16 07:26:02.517	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:26:02.516	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:26:01.464	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:26:01.430	info	(14077) ESPHome Device info received for test
      esphome.0	2021-03-16 07:26:01.412	info	(14077) ESPHome client 192.168.2.117 connected
      esphome.0	2021-03-16 07:25:30.165	warn	(14077) ESPHome client 192.168.2.117 disconnected
      esphome.0	2021-03-16 07:20:53.467	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
      esphome.0	2021-03-16 07:20:53.449	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:20:53.442	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:20:53.441	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:20:53.389	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:20:53.358	info	(14077) ESPHome Device info received for test
      esphome.0	2021-03-16 07:20:52.697	info	(14077) ESPHome client 192.168.2.117 connected
      esphome.0	2021-03-16 07:20:21.735	error	(14077) ESPHome client 192.168.2.117 Error: read ECONNRESET
      esphome.0	2021-03-16 07:20:18.734	error	(14077) ESPHome client 192.168.2.117 Error: timeout
      esphome.0	2021-03-16 07:19:43.731	warn	(14077) ESPHome client 192.168.2.117 disconnected
      esphome.0	2021-03-16 07:17:28.950	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
      esphome.0	2021-03-16 07:17:28.900	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:17:28.898	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:17:28.897	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:17:28.850	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:17:28.816	info	(14077) ESPHome Device info received for test
      esphome.0	2021-03-16 07:17:28.798	info	(14077) ESPHome client 192.168.2.117 connected
      esphome.0	2021-03-16 07:16:43.311	error	(14077) ESPHome client 192.168.2.117 Error: read ECONNRESET
      esphome.0	2021-03-16 07:16:38.016	error	(14077) ESPHome client 192.168.2.117 Error: timeout
      esphome.0	2021-03-16 07:16:03.013	warn	(14077) ESPHome client 192.168.2.117 disconnected
      esphome.0	2021-03-16 07:12:47.395	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
      esphome.0	2021-03-16 07:12:47.391	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:12:47.389	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:12:47.388	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:12:47.345	info	(14077) Sensor found at test on ip 192.168.2.117
      esphome.0	2021-03-16 07:12:47.327	info	(14077) ESPHome Device info received for test
      esphome.0	2021-03-16 07:12:47.320	info	(14077) ESPHome client 192.168.2.117 connected
      • Dutchman
        Dutchman Developer Most Active Administrators @e-s last edited by
        @e-s sagte in [ESPHome] Beta release:
        @dutchman
        hmm dein ESP verabschiedet sich alle 6 Minuten, welche adapter version hast du drauf?
        Und könntest du die YAML bitte posten ich vermute overload der Sensor abfragen auf dem ESP
          @dutchman
          Per git aus dem ersten Post gestern Abend installiert.
          An die yaml komme ich erst heute Abend.
          • Dutchman
            @dutchman
            Check Dan warten wir darauf, trotzdem bitte welche Version ?
              @dutchman
              Version 0.1.4-3
              • Dutchman
                @dutchman
                Version 0.1.4-3
                Ok dan müssen wir uns die jammer anschauen, hast du 5ghz actief in deinem wlan ?
                • Johannes Bauerstatter
                  Johannes Bauerstatter @Dutchman last edited by
                  @dutchman läuft jetzt einwandfrei. Vielen Dank.
                  Dutchman 1 Reply Last reply Reply Quote 1
                    @dutchman
                    Habe 1x 5GHz WLAN und 1x 2,4GHz über Fritzbox Mash(7490 und 3x 1750 Repeater)
                    Zusätzlich ein einzelnes 2,4GHz WLAN mittig im Haus welches nur für meine Smarthome Geräte ist, bei allen Geräten ist das Fritz 2,4 Mash als backup mit drin.
                    Seit dem ich das so habe, habe ich mit shelly und tasmota keine WLAN Probleme.
                    Hatte in der YAML aber nur das Smarthome WLAN drin, die Fehler kamen nicht rythmisch, sondern immer mal wieder, manchmal auch erst nach 30min,
                    Habe jetzt auch hier beide eingetragen und lass es laufen. Melde mich wieder.
                    Aber trotzdem sollte man die errors lieber durch warns abfangen wenn neu verbunden werden muss, sieht das Optisch nicht besser aus?
                    • Dutchman
                      jup stimm thanks, werde ich aender
                      • Dutchman
                        Dutchman Developer Most Active Administrators @Johannes Bauerstatter last edited by
                        @johannes-bauerstatter sagte in [ESPHome] Beta release:
                        freut mich 🙂
                        • FredF
                          FredF Most Active Forum Testing last edited by
                          @Dutchman
                          Habe gerade den Namen einiger Sensoren geändert und dann den ESP geflasht. Den neuen Namen bekommt der Adapter zwar mit und behält aber schön die alten Datenpunkte...
                          Dew Point alt, Erdgeschoss Taupunkt neu
                          • Dutchman
                            Dutchman Developer Most Active Administrators @FredF last edited by Dutchman
                            @fredf sagte in [ESPHome] Beta release:
                            @Dutchman
                            Der Adapter löscht keine states, könnte man einbauen wen gewünscht habe dafür auch Code von anderen Adaptern
                            Wen gewollt bitte GIT issue Dan kan ich es Abarbeiten.
                            Vorschlag währe alle states löschen wen nicht mehr in der Device Angeboten
                            Edit: danke fürs issue erstellen !
                              @dutchman
                              der Grund warum ich überhaupt mit esphome angefangen habe ist, das ich 10 servos brauche.
                              Habe einen pca9685 angeschlossen, der wird soweit auch erkannt, aber jetzt ist ende bei mir:
                              pca9685 und servo habe ich in meiner yaml aktiviert, nur muss der Rest jetzt im Adapter geschehen.
                              Hast du demnächst Zeit das zu implementieren, oder kann ich dich irgendwie unterstützen?
                              Theoretisch ist das auch alles pwm, also auch für LEDs dimmen usw zu gebrauchen.
                              Das habe ich jetzt in der yaml´hinzugefügt:
                              api:
                                services:
                                  - service: control_servo
                                    variables:
                                      level: float
                                    then:
                                      - servo.write:
                                          level: !lambda 'return level / 100.0;'
                              i2c:
                                 - id: bus_a
                                   sda: 13
                                   scl: 12
                                   scan: True
                              pca9685:
                                frequency: 500
                                i2c_id: bus_a
                                address: 0x40
                              output:
                                - platform: pca9685
                                  pca9685_id: 'pca9685_1'
                                  channel: 0
                              servo:
                                - id: my_servo
                                  output: pca9685_output1
                              • Dutchman
                                post mal bitte dein log, da solle genau die info drin stehen die ich brauche 🙂
                                  e-s @Dutchman last edited by e-s
                                  @dutchman
                                  Esphome log oder log im iobroker?
                                  edit:
                                  INFO Reading configuration config/test.yaml...
                                  INFO Starting log output from test.local using esphome API
                                  INFO Connecting to test.local:6053 (192.168.2.117)
                                  INFO Successfully connected to test.local
                                  [22:00:02][I][app:105]: ESPHome version 1.16.2 compiled on Mar 17 2021, 21:16:36
                                  [22:00:02][C][wifi:443]: WiFi:
                                  [22:00:02][C][wifi:303]:   SSID:
                                  [redacted]
                                  [22:00:02][C][wifi:304]:   IP Address: 192.168.2.117
                                  [22:00:02][C][wifi:306]:   BSSID:
                                  [redacted]
                                  [22:00:02][C][wifi:307]:   Hostname: 'test'
                                  [22:00:02][C][wifi:311]:   Signal strength: -40 dB ▂▄▆█
                                  [22:00:02][C][wifi:315]:   Channel: 11
                                  [22:00:02][C][wifi:316]:   Subnet: 255.255.255.0
                                  [22:00:02][C][wifi:317]:   Gateway: 192.168.2.1
                                  [22:00:02][C][wifi:318]:   DNS1: 192.168.2.1
                                  [22:00:02][C][wifi:319]:   DNS2: 0.0.0.0
                                  [22:00:02][C][i2c:028]: I2C Bus:
                                  [22:00:02][C][i2c:029]:   SDA Pin: GPIO13
                                  [22:00:02][C][i2c:030]:   SCL Pin: GPIO12
                                  [22:00:02][C][i2c:031]:   Frequency: 50000 Hz
                                  [22:00:02][I][i2c:033]: Scanning i2c bus for active devices...
                                  [22:00:03][I][i2c:040]: Found i2c device at address 0x40
                                  [22:00:03][I][i2c:040]: Found i2c device at address 0x76
                                  [22:00:03][C][pca9685:078]: PCA9685:
                                  [22:00:03][C][pca9685:079]:   Mode: 0x0C
                                  [22:00:03][C][pca9685:080]:   Frequency: 500 Hz
                                  [22:00:03][C][output.switch:009]: Output Switch 'Relais 1'
                                  [22:00:03][C][output.switch:009]: Output Switch 'Relais 2'
                                  [22:00:03][C][gpio.output:010]: GPIO Binary Output:
                                  [22:00:03][C][gpio.output:011]:   Pin: GPIO26 (Mode: OUTPUT)
                                  [22:00:03][C][gpio.output:012]:   Inverted: YES
                                  [22:00:03][C][gpio.output:011]:   Pin: GPIO27 (Mode: OUTPUT)
                                  [22:00:03][C][logger:185]: Logger:
                                  [22:00:03][C][logger:186]:   Level: DEBUG
                                  [22:00:03][C][logger:187]:   Log Baud Rate: 115200
                                  [22:00:03][C][logger:188]:   Hardware UART: UART0
                                  [22:00:03][C][bme280.sensor:142]: BME280:
                                  [22:00:03][C][bme280.sensor:143]:   Address: 0x76
                                  [22:00:03][C][bme280.sensor:155]:   IIR Filter: OFF
                                  [22:00:03][C][bme280.sensor:156]:   Update Interval: 60.0s
                                  [22:00:03][C][bme280.sensor:158]:   Temperature 'BME280 Temperature'
                                  [22:00:03][C][bme280.sensor:158]:     Unit of Measurement: '°C'
                                  [22:00:03][C][bme280.sensor:158]:     Accuracy Decimals: 1
                                  [22:00:03][C][bme280.sensor:158]:     Icon: 'mdi:thermometer'
                                  [22:00:03][C][bme280.sensor:159]:     Oversampling: 16x
                                  [22:00:03][C][bme280.sensor:160]:   Pressure 'BME280 Pressure'
                                  [22:00:03][C][bme280.sensor:160]:     Unit of Measurement: 'hPa'
                                  [22:00:03][C][bme280.sensor:160]:     Accuracy Decimals: 1
                                  [22:00:03][C][bme280.sensor:160]:     Icon: 'mdi:gauge'
                                  [22:00:03][C][bme280.sensor:161]:     Oversampling: 16x
                                  [22:00:03][C][bme280.sensor:162]:   Humidity 'BME280 Humidity'
                                  [22:00:03][C][bme280.sensor:162]:     Unit of Measurement: '%'
                                  [22:00:03][C][bme280.sensor:162]:     Accuracy Decimals: 1
                                  [22:00:03][C][bme280.sensor:162]:     Icon: 'mdi:water-percent'
                                  [22:00:03][C][bme280.sensor:163]:     Oversampling: 16x
                                  [22:00:03][C][servo:012]: Servo:
                                  [22:00:03][C][servo:013]:   Idle Level: 7.5%
                                  [22:00:03][C][servo:014]:   Min Level: 3.0%
                                  [22:00:03][C][servo:015]:   Max Level: 12.0%
                                  [22:00:03][C][servo:016]:   auto detach time: 0 ms
                                  [22:00:03][C][servo:017]:   run duration: 0 ms
                                  [22:00:03][C][dallas.sensor:072]: DallasComponent:
                                  [22:00:03][C][dallas.sensor:073]:   Pin: GPIO14 (Mode: INPUT)
                                  [22:00:03][C][dallas.sensor:074]:   Update Interval: 60.0s
                                  [22:00:03][D][dallas.sensor:079]:   Found sensors:
                                  [22:00:03][D][dallas.sensor:082]:     0xCB00000C18274928
                                  [22:00:03][C][dallas.sensor:087]:   Device 'Living Room Temperature'
                                  [22:00:03][C][dallas.sensor:087]:     Unit of Measurement: '°C'
                                  [22:00:03][C][dallas.sensor:087]:     Accuracy Decimals: 1
                                  [22:00:03][C][dallas.sensor:087]:     Icon: 'mdi:thermometer'
                                  [22:00:03][C][dallas.sensor:095]:     Address: 0xCB00000C18274928
                                  [22:00:03][C][dallas.sensor:096]:     Resolution: 12
                                  [22:00:03][C][captive_portal:169]: Captive Portal:
                                  [22:00:03][C][web_server:132]: Web Server:
                                  [22:00:03][C][web_server:133]:   Address: test.local:80
                                  [22:00:03][C][ota:029]: Over-The-Air Updates:
                                  [22:00:03][C][ota:030]:   Address: test.local:3232
                                  [22:00:03][C][ota:032]:   Using Password.
                                  [22:00:03][C][api:095]: API Server:
                                  [22:00:03][C][api:096]:   Address: test.local:6053
                                  [22:00:05][D][dallas.sensor:153]: 'Living Room Temperature': Got Temperature=21.9°C
                                  [22:00:05][D][sensor:092]: 'Living Room Temperature': Sending state 21.87500 °C with 1 decimals of accuracy
                                  [22:00:23][D][bme280.sensor:197]: Got temperature=22.6°C pressure=1022.4hPa humidity=40.2%
                                  [22:00:23][D][sensor:092]: 'BME280 Temperature': Sending state 22.61000 °C with 1 decimals of accuracy
                                  [22:00:23][D][sensor:092]: 'BME280 Pressure': Sending state 1022.39722 hPa with 1 decimals of accuracy
                                  [22:00:23][D][sensor:092]: 'BME280 Humidity': Sending state 40.19141 % with 1 decimals of accuracy
                                  • Dutchman
                                    iobroker 🙂 da sollte stehen :
                                    DeviceType .... not yet supported
                                    Please submit git issue with all information from next line
                                    DeviceType ... State-Keys ... | [entityStateConfig] ...
                                      @dutchman
                                      hmmm, nichts zu finden. auch im debug nichts.
                                      wenn man hier schaut, muss irgendwas im hass.io eingestellt werden was sonst nicht da steht.
                                      Vielleicht muss ich auch die optionalen Sachen mal aktivieren, aber keine Ahnung welche.
                                      • Dutchman
                                        @dutchman
                                        hmmm kannste mir mal nen kompletten debug schicken vom hinzufügen der device bzw Adapter start ?
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators last edited by Dutchman
                                          hier
                                          ah habe es mir mal genauer angeschaut, da. musst du im ESPHome bissl mehr konfigurieren :
                                          # Home Assistant configuration
                                          input_number:
                                            servo_control:
                                              initial: 0
                                              min: -100
                                              max: 100
                                              step: 1
                                              mode: slider
                                          automation:
                                            - alias: Write Servo Value to ESP
                                              trigger:
                                                platform: state
                                                entity_id: input_number.servo_control
                                              action:
                                                # Replace livingroom with the name you gave the ESP
                                                - service: esphome.livingroom_control_servo
                                                  data_template:
                                                    level: '{{ trigger.to_state.state | int }}'
                                          # ESPHome configuration
                                          api:
                                            services:
                                                variables:
                                                  level: float
                                                then:
                                                  - servo.write:
                                          servo:
                                            - platform: ...
                                              # [...] servo config
                                          der input Service sollte dan nen state erstellen zum steuern, die automation reagiert darauf und steuert den servo
                                            @dutchman
                                            Dachte das was da unter home Assistent steht gehört nicht in die yaml sondern muss irgendwie von dir verarbeitet werden, sehe ich das richtig?
                                            1.0k
                                            591
                                            153228
