    3. Entwicklung
    4. [Neuer Adapter] Xiaomi Luftfilter
      @dontobi hab mal installiert
      debuglog
      miio.0	2021-01-24 20:07:47.018	debug	(17411) system.adapter.admin.0: logging true
      miio.0	2021-01-24 20:07:27.543	debug	(17411) system.adapter.admin.0: logging false
      miio.0	2021-01-24 20:06:55.318	info	(17411) 308331024 becomes unavailable.
      miio.0	2021-01-24 20:06:14.659	info	(17411) discover stoped after 10 seconds.
      miio.0	2021-01-24 20:06:06.275	debug	(17411) system.adapter.admin.0: logging true
      miio.0	2021-01-24 20:06:04.862	info	(17411) 84022681 token is hide
      miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.purifyVolume
      miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.usedTime
      miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.Temperature
      miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.humidity
      miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.averageAqi
      miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.motor1Speed
      miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.filterUsedTime
      miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.filterLife
      miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.aqi
      miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.learnSleepMode
      miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.favoriteLevel
      miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.ledBrightnessLevel
      miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.buzzer
      miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.childLock
      miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.led
      miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.mode
      miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.power
      miio.0	2021-01-24 20:06:04.686	info	(17411) Create state object devices.308331024.model
      miio.0	2021-01-24 20:06:04.686	info	(17411) Create state object devices.308331024.connected
      miio.0	2021-01-24 20:06:04.684	info	(17411) New device: zhimi.airpurifier.mb3. ID 308331024
      miio.0	2021-01-24 20:06:04.680	debug	(17411) Adapter init done!!!!!!
      miio.0	2021-01-24 20:06:04.669	info	(17411) new zhimi.airpurifier.mb device
      miio.0	2021-01-24 20:06:04.655	info	(17411) Start auto discover
      miio.0	2021-01-24 20:06:04.655	info	(17411) All defined devices are created
      miio.0	2021-01-24 20:06:04.653	info	(17411) 10.1.1.92 added.
      miio.0	2021-01-24 20:06:04.522	warn	(17411) 192.168.178.78 can not be connected.Error: Could not connect to device, handshake timeout
      miio.0	2021-01-24 20:06:02.207	info	(17411) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.miio, node: v12.20.1, js-controller: 3.2.10
      miio.0	2021-01-24 20:06:01.810	debug	(17411) statesDB connected
      miio.0	2021-01-24 20:06:01.809	debug	(17411) States connected to redis: 127.0.0.1:6379
      miio.0	2021-01-24 20:06:01.800	debug	(17411) States create User PubSub Client
      miio.0	2021-01-24 20:06:01.799	debug	(17411) States create System PubSub Client
      miio.0	2021-01-24 20:06:01.790	debug	(17411) Redis States: Use Redis connection: 127.0.0.1:6379
      miio.0	2021-01-24 20:06:01.788	debug	(17411) objectDB connected
      miio.0	2021-01-24 20:06:01.780	debug	(17411) Objects connected to redis: 127.0.0.1:9001
      miio.0	2021-01-24 20:06:01.736	debug	(17411) Objects client initialize lua scripts
      miio.0	2021-01-24 20:06:01.735	debug	(17411) Objects create User PubSub Client
      miio.0	2021-01-24 20:06:01.734	debug	(17411) Objects create System PubSub Client
      miio.0	2021-01-24 20:06:01.732	debug	(17411) Objects client ready ... initialize now
      miio.0	2021-01-24 20:06:01.682	debug	(17411) Redis Objects: Use Redis connection: 127.0.0.1:9001
      miio.0	2021-01-24 20:05:57.756	error	(17383) Network communication is unavailable, device might be destroyed
      miio.0	2021-01-24 20:05:57.756	error	at processTimers (internal/timers.js:497:7)
      miio.0	2021-01-24 20:05:57.756	error	at listOnTimeout (internal/timers.js:554:17)
      miio.0	2021-01-24 20:05:57.756	error	at Timeout._onTimeout (/opt/iobroker/node_modules/miio-lite/lib/network.js:52:9)
      miio.0	2021-01-24 20:05:57.756	error	at Network.get socket [as socket] (/opt/iobroker/node_modules/miio-lite/lib/network.js:229:10)
      miio.0	2021-01-24 20:05:57.756	error	(17383) Error: Network communication is unavailable, device might be destroyed
      miio.0	2021-01-24 20:05:57.755	error	(17383) uncaught exception: Network communication is unavailable, device might be destroyed
      miio.0	2021-01-24 20:05:57.325	info	(17383) 308331024 becomes unavailable.
      miio.0	2021-01-24 20:05:57.323	info	(17383) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      miio.0	2021-01-24 20:05:57.323	info	(17383) terminating
      miio.0	2021-01-24 20:05:57.322	info	(17383) cleaned everything up...
      miio.0	2021-01-24 20:05:57.321	info	(17383) Got terminate signal TERMINATE_YOURSELF
      miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.purifyVolume
      miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.usedTime
      miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.Temperature
      miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.humidity
      miio.0	2021-01-24 20:05:57.265	info	(17383) Create state object devices.308331024.averageAqi
      miio.0	2021-01-24 20:05:57.265	info	(17383) Create state object devices.308331024.motor1Speed
      miio.0	2021-01-24 20:05:57.265	info	(17383) Create state object devices.308331024.filterUsedTime
      miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.filterLife
      miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.aqi
      miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.learnSleepMode
      miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.favoriteLevel
      miio.0	2021-01-24 20:05:57.263	info	(17383) Create state object devices.308331024.ledBrightnessLevel
      miio.0	2021-01-24 20:05:57.263	info	(17383) Create state object devices.308331024.buzzer
      miio.0	2021-01-24 20:05:57.263	info	(17383) Create state object devices.308331024.childLock
      miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.led
      miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.mode
      miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.power
      miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.model
      miio.0	2021-01-24 20:05:57.261	info	(17383) Create state object devices.308331024.connected
      miio.0	2021-01-24 20:05:57.258	info	(17383) Update Device Purifier_H3's config: ip = 10.1.1.92, polling = 5000, id = 308331024
      miio.0	2021-01-24 20:05:57.257	info	(17383) New device: zhimi.airpurifier.mb3. ID 308331024
      miio.0	2021-01-24 20:05:57.250	debug	(17383) Adapter init done!!!!!!
      miio.0	2021-01-24 20:05:57.237	info	(17383) new zhimi.airpurifier.mb device
      miio.0	2021-01-24 20:05:57.218	info	(17383) Start auto discover
      miio.0	2021-01-24 20:05:57.218	info	(17383) All defined devices are created
      miio.0	2021-01-24 20:05:57.215	info	(17383) 10.1.1.92 added.
      miio.0	2021-01-24 20:05:57.075	warn	(17383) 192.168.178.78 can not be connected.Error: Could not connect to device, handshake timeout
      miio.0	2021-01-24 20:05:54.847	info	(17383) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.miio, node: v12.20.1, js-controller: 3.2.10
      miio.0	2021-01-24 20:05:54.457	debug	(17383) statesDB connected
      miio.0	2021-01-24 20:05:54.456	debug	(17383) States connected to redis: 127.0.0.1:6379
      miio.0	2021-01-24 20:05:54.451	debug	(17383) States create User PubSub Client
      miio.0	2021-01-24 20:05:54.450	debug	(17383) States create System PubSub Client
      miio.0	2021-01-24 20:05:54.445	debug	(17383) Redis States: Use Redis connection: 127.0.0.1:6379
      miio.0	2021-01-24 20:05:54.443	debug	(17383) objectDB connected
      miio.0	2021-01-24 20:05:54.437	debug	(17383) Objects connected to redis: 127.0.0.1:9001
      miio.0	2021-01-24 20:05:54.399	debug	(17383) Objects client initialize lua scripts
      miio.0	2021-01-24 20:05:54.398	debug	(17383) Objects create User PubSub Client
      miio.0	2021-01-24 20:05:54.397	debug	(17383) Objects create System PubSub Client
      miio.0	2021-01-24 20:05:54.396	debug	(17383) Objects client ready ... initialize now
      miio.0	2021-01-24 20:05:54.347	debug	(17383) Redis Objects: Use Redis connection: 127.0.0.1:9001
        Wildbill last edited by
        Wen es interessiert. Hier bei Github hab ich eine Version von Pittinis Script und die nötigen Dateien für Node-Mihome abgelegt, mit denen ich den 3C, 3H und Pro H problemlos steuern und auslesen kann. Ist halt als Script welches Datenpunkte füllt und kein Adapter, aber läuft problemlos.
        Gruß, Jürgen
        haselchen 1 Reply Last reply Reply Quote 1
        • haselchen
          haselchen Most Active @Wildbill last edited by
          @wildbill
          So problemlos ist das leider nicht.
          Hab auf Github und diversen anderen Seiten, pittinis und deine Beschreibungen durchgelesen. Geklappt hat davon leider nichts.
          Javascript ist die neueste Version.
          mi-home einzutragen hat nichts gebracht , ausser Fehlermeldungen.
          2021-03-16 19:33:19.851 - error: javascript.0 (517) script.js.Luftreiniger: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../node-mihome'
          2021-03-16 19:33:19.852 - error: javascript.0 (517) at script.js.Luftreiniger:3:16
          2021-03-16 19:33:19.852 - error: javascript.0 (517) at script.js.Luftreiniger:870:3
          2021-03-16 19:33:19.852 - error: javascript.0 (517) at Script.runInContext (vm.js:133:20)
          2021-03-16 19:33:19.852 - info: javascript.0 (517) script.js.Luftreiniger: Starting AllMyMi V.0.2.6
          2021-03-16 19:33:19.858 - info: javascript.0 (517) script.js.Luftreiniger: registered 0 subscriptions and 0 schedules
          2021-03-16 19:33:19.859 - error: javascript.0 (517) script.js.Luftreiniger: TypeError: Cannot read property 'miioProtocol' of undefined
          2021-03-16 19:33:19.859 - error: javascript.0 (517) at Init (script.js.Luftreiniger:599:12)
          2021-03-16 19:33:19.859 - error: javascript.0 (517) at script.js.Luftreiniger:67:1
          2021-03-16 19:33:19.860 - error: javascript.0 (517) at script.js.Luftreiniger:870:3
          2021-03-16 19:33:19.860 - error: javascript.0 (517) at Script.runInContext (vm.js:133:20)
          Auch die neueste Version von Pittini bringt die gleiche Fehlermeldung.
          node-mihome wird im Log installiert, wenn ich sie in der Javascript Instanz hinzufüge. dass kann ich sehen.
            SaiBot1981 last edited by
            @haselchen
            sorry aber das stimmt so nicht. das Script funktionier super. Habe selbst den H3 und kann damit wunderbar auslasen und die Steuerung der Modis übernehmen. Mehr braucht man ja auch nicht.
            • haselchen
              haselchen Most Active last edited by
              @saibot1981
              Das es super funktioniert will ich gar nicht absprechen.
              Aber anscheinend haben nicht alle die gleichen Voraussetzungen.
              Ich habe es 1:1 nach den Vorgaben gemacht und bekomme die Meldungen oben.
              Nun ist die Frage, was weicht ab, was der JS Ersteller nicht erwähnt.
              JS Controller Version?
              Nodejs Version?
                Wildbill @haselchen last edited by
                @haselchen Du musst, nachdem Du node-mihome im Javascript-Adapter eingetragen hast, diesen stoppen, Dich per SSH auf den iobroker einloggen und von Hand das passende device-file nach /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices kopieren. Anschliessend den javascript-adapter wieder starten und es läuft.
                Die devices sind leider noch nicht im offiziellen Github vom Entwickler von node-mihome drin und der ist, sagen wir es mal so, recht träge.
                Das ganze ist leider immer mal wieder nötig, z.B. nach iobroker-Neustart oder Update vom JS-Adapter. Erst, wenn die devices im offiziellen node-mihome drin sind kommen sie dann auch automatisch mit, wenn der JS-Adapter startet.
                Gruss, Jürgen
                • haselchen
                  @wildbill
                  Muss ich dafür zwingend die Version ab 4.8 des Javascript Adapters haben?
                  Muss ich per SSH kopieren? Hab nen Container im Docker auf ner Synology.
                    @haselchen Welche Version zwingend nötig ist, kann ich Dir nicht sagen. Der Adapter ist ja nicht von mir.
                    Und wo was in Docker hinkommt und wie man es dorthin kopiert weiß ich leider auch nicht. Docker war mir immer suspekt.
                    Gruß, Jürgen
                    • haselchen
                      @wildbill
                      Hab mir komplett alles zerschossen mit dem "Experiment".
                      Downgrade der Script Engine hat nur auf dem Papier geklappt.
                      Das Layout ist beim Upgrade geblieben.
                      Also deinstalliert, damit waren allerdings die Ordner auch weg vom Adapter.
                      Also Backup eingespielt.
                      Und die Erkenntnis, man muss nicht alles haben 🙂
                        @haselchen Naja, eigentlich sollte das Einrichten für die Xiaomi air purifier kein großer Act sein, und schon gar nicht irgendetwas, womit man sich sein System abschiesst. Im JS-Adapter node-mihome eintragen und danach stoppen, passende(s) device von hier als txt herunterladen und umbennen (.txt hinten weg), anschliessend das device in der passenden Ebene unter dem iobroker.javascript abspeichern (siehe oben /opt/...) evtl. Rechte anpassen (sollte iobroker:iobroker mit 644 sein), js-adapter wieder starten, das Script (auch direkt vom Link) Laden, anpassen an eigene Bedürfnisse und starten. Da kann man nicht viel falsch machen, das "schwierigste" ist wohl das Kopieren der device-files.
                        Ich bin bei der Script-engine auf 5.0.14, bin aber ziemlich sicher, dass es auch mit älteren und auch aktuelleren (beta) Versionen laufen müsste. Warum Du da ein downgrade machen wolltest, erschliesst sich mir da nicht. Aber, Du musst doch irgendwie auf die Files im Docker-Container zugreifen können. Muss ja nicht direkt per SSH sein, aber irgendwie muss das doch gehen?! Ohne die passenden device-files kann es nicht gehen, da der JS-Adapter dann die Geräte nicht kennt. Schau doch mal, in welchem Pfad iobroker im Docker-Container liegt und schlängel Dich da weiter durch.
                        Gruss, Jürgen
                        • haselchen
                          @wildbill
                          Ich hatte mich an Pittinis Anleitung gehalten, dass die Script Engine Version mindestens 4.8 sein muss. Also musste ich upgraden.
                          Dann begann aber schon der Stress mit meinen vorhandenen Scripten.
                          Viele kamen mit der 5.0.15 nicht zurecht.
                          Und deine und Pittinis Anleitung ergaben dauernd den mioo protocoll Fehler.
                          Also wieder downgrade auf 3.6.4
                          Und da ging es dann richtig in die Hose.
                          Nun läuft es wieder....Gott sei Dank.
                          Aber eben ohne Air Purifier.
                            Thomas Braun Most Active @haselchen last edited by
                            @haselchen sagte in [Neuer Adapter] Xiaomi Luftfilter:
                            Dann würde ich die skripte überarbeiten und an geänderte syntax anpassen.
                            • haselchen
                              haselchen Most Active @Thomas Braun last edited by haselchen
                              Das Themengebiet werde ich in nächster Zeit mal so überhaupt nicht anfassen.
                              Neue Versionen sind immer gewöhnungsbedürftig, aber das ich keine Texte mit der Maus (oder ich bin einfach zu blöd) kopieren und einfügen kann und stattdessen ein Script zippen soll zum Einfügen.....klar geht anscheinend die Tastenkombination zum kopieren und einfügen, aber ich bin nen Maustyp und werde es deswegen auch nicht ändern.
                              @Wildbill
                              javascript.0	2021-03-17 19:36:59.153	error	(29750) at require (internal/modules/cjs/helpers.js:25:18)
                              javascript.0	2021-03-17 19:36:59.153	error	(29750) at Module.require (internal/modules/cjs/loader.js:692:17)
                              javascript.0	2021-03-17 19:36:59.152	error	(29750) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                              javascript.0	2021-03-17 19:36:59.152	error	(29750) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                              javascript.0	2021-03-17 19:36:59.152	error	(29750) at Module.load (internal/modules/cjs/loader.js:653:32)
                              javascript.0	2021-03-17 19:36:59.152	error	(29750) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                              javascript.0	2021-03-17 19:36:59.152	error	(29750) at Module._compile (internal/modules/cjs/loader.js:778:30)
                              javascript.0	2021-03-17 19:36:59.152	error	(29750) at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/index.js:5:16)
                              javascript.0	2021-03-17 19:36:59.151	error	(29750) at require (internal/modules/cjs/helpers.js:25:18)
                              javascript.0	2021-03-17 19:36:59.151	error	(29750) at Module.require (internal/modules/cjs/loader.js:692:17)
                              javascript.0	2021-03-17 19:36:59.151	error	(29750) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                              javascript.0	2021-03-17 19:36:59.151	error	(29750) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                              javascript.0	2021-03-17 19:36:59.151	error	(29750) at Module.load (internal/modules/cjs/loader.js:653:32)
                              javascript.0	2021-03-17 19:36:59.151	error	(29750) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                              javascript.0	2021-03-17 19:36:59.150	error	(29750) at Module._compile (internal/modules/cjs/loader.js:778:30)
                              javascript.0	2021-03-17 19:36:59.150	error	(29750) at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/device.js:1:16)
                              javascript.0	2021-03-17 19:36:59.150	error	(29750) at require (internal/modules/cjs/helpers.js:25:18)
                              javascript.0	2021-03-17 19:36:59.150	error	(29750) at Module.require (internal/modules/cjs/loader.js:692:17)
                              javascript.0	2021-03-17 19:36:59.150	error	(29750) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                              javascript.0	2021-03-17 19:36:59.149	error	(29750) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                              javascript.0	2021-03-17 19:36:59.149	error	(29750) at Module.load (internal/modules/cjs/loader.js:653:32)
                              javascript.0	2021-03-17 19:36:59.149	error	(29750) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                              javascript.0	2021-03-17 19:36:59.149	error	(29750) at Module._compile (internal/modules/cjs/loader.js:778:30)
                              javascript.0	2021-03-17 19:36:59.149	error	(29750) at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/models.js:6:54)
                              javascript.0	2021-03-17 19:36:59.148	error	(29750) at Array.forEach (<anonymous>:null:null)
                              javascript.0	2021-03-17 19:36:59.148	error	(29750) at glob.sync.forEach.modelPath (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/models.js:9:23)
                              javascript.0	2021-03-17 19:36:59.148	error	(29750) at require (internal/modules/cjs/helpers.js:25:18)
                              javascript.0	2021-03-17 19:36:59.148	error	(29750) at Module.require (internal/modules/cjs/loader.js:692:17)
                              javascript.0	2021-03-17 19:36:59.148	error	(29750) at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                              javascript.0	2021-03-17 19:36:59.148	error	(29750) at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                              javascript.0	2021-03-17 19:36:59.147	error	(29750) at Module.load (internal/modules/cjs/loader.js:653:32)
                              javascript.0	2021-03-17 19:36:59.146	error	(29750) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                              javascript.0	2021-03-17 19:36:59.145	error	(29750) script.js.Luft: /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices/zhimi.airpurifier.mb3.js:5
                              Keine Chance. So easy ist es halt nicht 😉
                                @haselchen Soweit ich das sehe sind es zumindest nicht die typischen Fehlermeldungen, wenn ein device-file nicht gefunden wird. Vielleicht kann @Pittini dazu was sagen?
                                Entweder was Docker-typisches oder es liegt an Deiner veralteten Version des JS-Adapters?!
                                Gruss, Jürgen
                                • haselchen
                                  haselchen Most Active @Wildbill last edited by haselchen
                                  @wildbill
                                  Die kommen leider auch mit der neuesten Java Version.
                                  Es reizt ja schon das Ganze, weil ich 2 von den Dingern habe 🙂
                                  Die Erweiterung node-mihome, wo müsste ich die manuell installieren in welchen Ordner?
                                  • haselchen
                                    haselchen Most Active last edited by haselchen
                                    @Wildbill
                                    Oh man, welch eigentlich simples Problem.
                                    Ich denke, dass hilft viele Fragenden:
                                    Nodejs MUSS mindestens V12 sein
                                    Javascript KANN auch noch V3.6.4 sein
                                    Damit geht es jetzt.
                                    Hab Nodejs einfach nur aktualisiert.
                                    Das sollte @Pittini vielleicht noch irgendwo mit aufnehmen.
                                    Zeitgleich natürlich ein fettes Danke für das Script!
                                    @Thomas-Braun
                                    Edit:
                                    Stehe gerade mächtig wohl auf dem Schlauch.
                                    Werden die Werte nur ausgelesen oder kann ich das Gerät damit auch steuern?
                                    Sorry für die bescheuerte Frage, aber ich bin 48 Stunden auf den Beinen 🙂
                                    W tobasium 2 Replies Last reply Reply Quote 0
                                      @haselchen Klar kannst Du auch Steuern. Die Modes, Fanspeeds und Favorite-Level lassen sich steuern.
                                      Schön, wenn es jetzt läuft. Sagt uns aber auch, es geht nix über ein halbwegs aktuelles System... 😁
                                      Gruß, Jürgen
                                      haselchen Thomas Braun 2 Replies Last reply Reply Quote 1
                                      • haselchen
                                        @wildbill
                                        Wie gesagt, waren lange Tage 🙂
                                        Also ab in den IOT , Modes Datenpunkt nehmen und Alexa auf zum Beispiel Sleep schalten lassen?
                                        Oder wie löst du das?
                                          @haselchen Ich steuere einmal über die Visualisierung und habe Skripte laufen, die zum Beispiel auf Favorite stellen, wenn niemand zu Hause ist, den die Lüfter stören, um das Haus mal wieder durchzupusten.
                                          Mit Alexa müsste es aber bestimmt auch gehen, wenn man die Datenpunkte passend verknüpft.
                                          Gruß, Jürgen
                                            Thomas Braun Most Active @Wildbill last edited by Thomas Braun
                                            @wildbill sagte in [Neuer Adapter] Xiaomi Luftfilter:
                                            Mein Reden...
                                            Man könnte auch sagen:
                                            Patch your stuff!!!
                                            1.0k
                                            188
                                            34041
