    4. Mini-HowTo: Cannot find view "system" for search "host"
      RDZipZap @Thomas Braun last edited by
      @thomas-braun Übrigens: dieser Hotfix ist der Hit. Funktioniert in meinem Fall perfekt. Danke nochmal dafür 👍
        Thomas Braun Most Active @RDZipZap last edited by
        @rdzipzap Musst dich bei @wendy2702 bedanken, ich hab's nur nieder geschrieben.
          RDZipZap @wendy2702 last edited by
          @wendy2702 Sorry für den längeren Log-Ausschnitt. Aber mir ist was seltsames aufgefallen. Man beachte die Log-Zeiten:
          2021-03-17 21:22:11.297  - error: host.raspberrypi Caught by controller[0]:     |     property '_httpMessage' -> object with constructor 'ClientRequest'
          2021-03-17 21:22:11.298  - error: host.raspberrypi Caught by controller[0]:     --- property 'socket' closes the circle
          2021-03-17 21:22:11.298  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
          2021-03-17 21:22:11.298  - error: host.raspberrypi Caught by controller[0]:     at Object.log (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:893:28)
          2021-03-17 21:22:11.298  - error: host.raspberrypi Caught by controller[0]:     at Object.log (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2769:25)
          2021-03-17 21:22:11.298  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.<anonymous> (script.js.common.Dev_Autoload:20:21)
          2021-03-17 21:22:11.299  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.emit (events.js:326:22)
          2021-03-17 21:22:11.299  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.EventEmitter.emit (domain.js:483:12)
          2021-03-17 21:22:11.299  - error: host.raspberrypi Caught by controller[0]:     at endReadableNT (_stream_readable.js:1241:12)
          2021-03-17 21:22:11.299  - error: host.raspberrypi Caught by controller[0]:     at processTicksAndRejections (internal/process/task_queues.js:84:21)
          2021-03-17 21:22:11.300  - error: host.raspberrypi instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2021-03-17 21:22:11.300  - info: host.raspberrypi Restart adapter system.adapter.javascript.1 because enabled
          2021-03-17 21:22:17.017  - info: javascript.0 (1402) Stop script script.js.common.Dev_Autoload
          2021-03-17 21:22:23.505  - info: smartmeter.0 (1687) Received 13 values, 6 updated
          2021-03-17 21:17:20.810  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
          2021-03-17 21:17:20.816  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
          2021-03-17 21:17:20.817  - info: host.raspberrypi hostname: raspberrypi, node: v12.21.0
          2021-03-17 21:17:20.817  - info: host.raspberrypi ip addresses: 192.168.188.98 2003:e3:73d:ad00:ef25:7f56:ce67:5041 fe80::7dba:ddb4:2c5e:a655
          2021-03-17 21:17:20.867  - error: host.raspberrypi-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
          2021-03-17 21:17:21.307  - error: host.raspberrypi-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
          2021-03-17 21:17:21.465  - info: host.raspberrypi connected to Objects and States
          2021-03-17 21:17:21.551  - info: host.raspberrypi added notifications configuration of host
          2021-03-17 21:17:22.187  - info: host.raspberrypi 24 instances found
          2021-03-17 21:17:22.228  - info: host.raspberrypi starting 20 instances
          2021-03-17 21:17:22.345  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 704
          2021-03-17 21:17:24.149  - error: admin.0 (704) admin.0 already running
          2021-03-17 21:17:24.152  - warn: admin.0 (704) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:17:24.753  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:17:24.754  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
          2021-03-17 21:17:26.257  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 793
          2021-03-17 21:17:30.184  - error: backitup.0 (793) backitup.0 already running
          2021-03-17 21:17:30.187  - warn: backitup.0 (793) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:17:30.315  - info: host.raspberrypi instance system.adapter.fb-checkpresence.0 started with pid 805
          2021-03-17 21:17:30.778  - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:17:30.779  - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
          2021-03-17 21:17:31.553  - error: fb-checkpresence.0 (805) fb-checkpresence.0 already running
          2021-03-17 21:17:31.556  - warn: fb-checkpresence.0 (805) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:17:32.137  - error: host.raspberrypi instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:17:32.138  - info: host.raspberrypi Restart adapter system.adapter.fb-checkpresence.0 because enabled
          2021-03-17 21:17:34.267  - info: host.raspberrypi instance system.adapter.fronius.0 started with pid 816
          2021-03-17 21:23:37.303  - error: fronius.0 (816) fronius.0 already running
          2021-03-17 21:23:37.305  - warn: fronius.0 (816) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:23:37.941  - error: host.raspberrypi instance system.adapter.fronius.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:23:37.942  - info: host.raspberrypi Restart adapter system.adapter.fronius.0 because enabled
          2021-03-17 21:23:39.931  - info: host.raspberrypi instance system.adapter.harmony.0 started with pid 830
          2021-03-17 21:23:41.547  - error: harmony.0 (830) harmony.0 already running
          2021-03-17 21:23:41.550  - warn: harmony.0 (830) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:23:42.126  - error: host.raspberrypi instance system.adapter.harmony.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:23:42.127  - info: host.raspberrypi Restart adapter system.adapter.harmony.0 because enabled
          2021-03-17 21:23:43.980  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 841
          2021-03-17 21:23:45.372  - error: hm-rega.0 (841) hm-rega.0 already running
          2021-03-17 21:23:45.376  - warn: hm-rega.0 (841) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:23:46.014  - error: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:23:46.015  - info: host.raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
          2021-03-17 21:23:47.991  - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 855
          2021-03-17 21:23:49.038  - error: hm-rpc.0 (855) hm-rpc.0 already running
          2021-03-17 21:23:49.041  - warn: hm-rpc.0 (855) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:23:49.680  - error: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:23:49.681  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
          2021-03-17 21:23:51.962  - info: host.raspberrypi instance system.adapter.influxdb.0 started with pid 867
          2021-03-17 21:23:53.398  - error: influxdb.0 (867) influxdb.0 already running
          2021-03-17 21:23:53.401  - warn: influxdb.0 (867) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:23:54.024  - error: host.raspberrypi instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:23:54.025  - info: host.raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
          2021-03-17 21:23:55.994  - info: host.raspberrypi instance system.adapter.info.0 started with pid 878
          2021-03-17 21:23:56.430  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 885
          2021-03-17 21:23:58.462  - info: admin.0 (885) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.21.0, js-controller: 3.2.16
          2021-03-17 21:23:58.517  - info: admin.0 (885) requesting all states
          2021-03-17 21:23:58.518  - info: admin.0 (885) requesting all objects
          2021-03-17 21:23:59.240  - error: info.0 (878) info.0 already running
          2021-03-17 21:23:59.244  - warn: info.0 (878) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:23:59.533  - info: admin.0 (885) received all objects
          2021-03-17 21:23:59.710  - info: admin.0 (885) http server listening on port 8081
          2021-03-17 21:23:59.814  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:23:59.816  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
          2021-03-17 21:23:59.946  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 916
          2021-03-17 21:23:59.711  - info: admin.0 (885) Use link "http://localhost:8081" to configure.
          2021-03-17 21:24:02.456  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 923
          2021-03-17 21:24:03.015  - error: javascript.0 (916) javascript.0 already running
          2021-03-17 21:24:03.018  - warn: javascript.0 (916) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2021-03-17 21:24:03.655  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2021-03-17 21:24:03.656  - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
          2021-03-17 21:24:03.814  - info: host.raspberrypi instance system.adapter.fb-checkpresence.0 started with pid 934
          2021-03-17 21:24:03.976  - info: host.raspberrypi instance system.adapter.javascript.1 started with pid 941
          2021-03-17 21:24:05.376  - info: fb-checkpresence.0 (934) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
          2021-03-17 21:24:05.413  - info: fb-checkpresence.0 (934) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 2 Min. - interval members: 60 s
          2021-03-17 21:24:05.743  - info: fb-checkpresence.0 (934) service Hosts1-X_AVM-DE_GetHostListPath is supported
          Die Zeit springt um 5 Minuten zurück und der IOBroker startet. Aber anscheinend eine zweite Instanz - denn die Adapter meckern, dass schon ein Instanz von ihnen läuft. Oder interpretiere ich das falsch?
          Erschreckenderweise ergibt sich das gleiche Bild im syslog:
          Mar 17 21:22:11 raspberrypi bash[653]: TypeError: Converting circular structure to JSON
          Mar 17 21:22:11 raspberrypi bash[653]:     --> starting at object with constructor 'TLSSocket'
          Mar 17 21:22:11 raspberrypi bash[653]:     |     property '_httpMessage' -> object with constructor 'ClientRequest'
          Mar 17 21:22:11 raspberrypi bash[653]:     --- property 'socket' closes the circle
          Mar 17 21:22:11 raspberrypi bash[653]:     at JSON.stringify (<anonymous>)
          Mar 17 21:22:11 raspberrypi bash[653]:     at Object.log (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:893:28)
          Mar 17 21:22:11 raspberrypi bash[653]:     at Object.log (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2769:25)
          Mar 17 21:22:11 raspberrypi bash[653]:     at IncomingMessage.<anonymous> (script.js.common.Dev_Autoload:20:21)
          Mar 17 21:22:11 raspberrypi bash[653]:     at IncomingMessage.emit (events.js:326:22)
          Mar 17 21:22:11 raspberrypi bash[653]:     at IncomingMessage.EventEmitter.emit (domain.js:483:12)
          Mar 17 21:22:11 raspberrypi bash[653]:     at endReadableNT (_stream_readable.js:1241:12)
          Mar 17 21:22:11 raspberrypi bash[653]:     at processTicksAndRejections (internal/process/task_queues.js:84:21)
          Mar 17 21:22:11 raspberrypi bash[653]: ================================== > LOG REDIRECT system.adapter.javascript.1 => false [Process stopped]
          Mar 17 21:22:11 raspberrypi bash[653]: ================================== > LOG REDIRECT system.adapter.javascript.1 => false [system.adapter.javascript.1.logging]
          Mar 17 21:22:30 raspberrypi influxd[650]: [httpd] 127.0.0.1 - grafana [17/Mar/2021:21:22:30 +0000] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=grafana HTTP/1.1" 204 0 "-" "-" e13d9371-8766-11eb-9b16-dca63298e981 6774
          Mar 17 21:22:30 raspberrypi influxd[650]: [httpd] 127.0.0.1 - grafana [17/Mar/2021:21:22:30 +0000] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=grafana HTTP/1.1" 204 0 "-" "-" e13d7ad6-8766-11eb-9b15-dca63298e981 15034
          Mar 17 21:22:30 raspberrypi influxd[650]: [httpd] 127.0.0.1 - grafana [17/Mar/2021:21:22:30 +0000] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=grafana HTTP/1.1" 204 0 "-" "-" e13f93d1-8766-11eb-9b18-dca63298e981 7628
          Mar 17 21:22:30 raspberrypi influxd[650]: [httpd] 127.0.0.1 - grafana [17/Mar/2021:21:22:30 +0000] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=grafana HTTP/1.1" 204 0 "-" "-" e13f8501-8766-11eb-9b17-dca63298e981 13903
          Mar 17 21:17:05 raspberrypi fake-hwclock[109]: Wed 17 Mar 21:17:01 UTC 2021
          Mar 17 21:17:05 raspberrypi systemd-fsck[130]: e2fsck 1.44.5 (15-Dec-2018)
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
          Mar 17 21:17:05 raspberrypi systemd-fsck[130]: rootfs: clean, 125204/1910656 files, 986261/7725184 blocks
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] Linux version 5.4.83-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:11:54 GMT 2020
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
          Mar 17 21:17:05 raspberrypi systemd[1]: Started File System Check on Root Device.
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
          Mar 17 21:17:05 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000] On node 0 totalpages: 1012736
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000]   DMA zone: 2304 pages used for memmap
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000]   DMA zone: 0 pages reserved
          Mar 17 21:17:05 raspberrypi kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
          Mar 17 21:17:05 raspberrypi systemd[1]: Started udev Coldplug all Devices.
          Macht das Sinn?
          Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
            @rdzipzap
            Bring dein System auf Stand. Da dürfte mittlerweile ein Kernel 5.10 angeboten werden.
              apollon77 @RDZipZap last edited by
              @rdzipzap Also ja macht sinn. Dein Raspi Rebootet!!
              zu sehen an
              Und das ioBroker Log wäre cool mal vollständiger zu sehen, ebenso syslog. MEHR von "Vor" dem Fehler
              • N
                Night2k5 last edited by
                Moin Zusammen.
                Ich habe leider das selbe Problem wie @RDZipZap .
                Mittlerweile geht es so weit, dass es sogar bei Neuinstallationen vom ioBroker passiert.
                Ich verzweifle so langsam daran.
                Verbunden per ssh zeigt mir die Console die Fehler aus dem ersten Post an.
                Wenn ich jetzt die auch oben genannte Lösung anwende dann komme ich für ca. 5 Minuten auf den ioBroker, bzw. bis ich einige Adapter gestartet habe.
                Danach stürzt mein PI ab und der Fehler beginnt von vorne.
                Da dies ja keine Dauerlösung sein kann, habe ich den ioBroker neu aufgesetzt.
                Leider auch hier nicht die erhoffte Erlösung. Jetzt habe ich gerade zum dritten Mal die ganze Prozedur hinter mir und jetzt geht es schon direkt nach der Installation mit der im ersten Post genannten Fehlermeldung los.
                Was läuft denn im Moment schief?
                Ich dachte es liegt vielleicht an der NodeJS - Version und habe es diesmal mit der 10 probiert, allerdings auch leider erfolgslos.
                Ich nutze einen Raspberry Pi 4B - 4GB den ich mir extra zugelegt hatte, weil mein alter 3B nicht mehr zuverlässig genug war und wegen fehlender Leistung das Nutzererlebnis litt.
                Bei der Installation des ioBroker erscheinen schon einige Fehlermeldung in der Konsole.
                Ich habe vor der Installation mittels
                sudo apt-get update && sudo apt-get upgrade
                alles geupdated und danach neugestartet.
                Danach habe ich dann im raspi-config das Dateisystem angepasst
                Anschließend via
                curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                sudo apt-get install -y nodejs
                sudo reboot
                NodeJS installiert.
                Zu guter Letzt dann noch mit
                curl -sL https://iobroker.net/install.sh | bash -
                den ioBroker installiert, wo es dann während der Installation zu folgender Fehlermeldung kommt:
                    Installing ioBroker (3/4)
                In file included from ../../nan/nan.h:56,
                                 from ../src/main.cpp:3:
                /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                       (node::addon_register_func) (regfunc),                          \
                /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
                   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                 NODE_MODULE(diskusage, Init)
                                 from ../src/unix_dgram.cc:5:
                ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                 NODE_MODULE(unix_dgram, Initialize)
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                ../src/serialport.cpp: At global scope:
                ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                 SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                 SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                In file included from ../../../nan/nan.h:56,
                                 from ../src/./serialport.h:6,
                                 from ../src/serialport.cpp:1:
                /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                 NODE_MODULE(serialport, init);
                ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                ioBroker meldet danach dann eine erfolgreiche Installation
                    ioBroker was installed successfully
                    Open http://192.168.2.5:8081 in a browser and start configuring!
                Können die Abstürze an einer zu schlechten Spannungsversorgung liegen?
                Ich bin mit meinem Latein am Ende.
                wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                • wendy2702
                  wendy2702 @Night2k5 last edited by wendy2702
                  @night2k5 Das manuelle Installieren von Node ist nicht notwendig wenn man iobroker per Einzeiler installiert.
                  Spannungsprobleme könnten sich im Syslog finden lassen.
                  Was nutzt du denn für eine Spannungsversorgung?
                  Möglich aber auch das deine SD Karte einen Schaden hat.
                  N 2 Replies Last reply Reply Quote 1
                    Thomas Braun Most Active @Night2k5 last edited by
                    @night2k5 sagte in Mini-HowTo: Cannot find view "system" for search "host":
                    Da steht keine Fehlermeldung. Ganz normaler output vom kompilieren von serialport.
                    Durchaus möglich.
                    Poste mal die Ausgabe von
                    dmesg -T
                    Muss auch nicht auf Latein sein.
                    N 1 Reply Last reply Reply Quote 1
                    • N
                      Night2k5 @wendy2702 last edited by
                      @wendy2702 said in Mini-HowTo: Cannot find view "system" for search "host":
                      Die SD-Karte möchte ich nicht 100%ig ausschließen, ich habe diese allerdings schon gewechselt weil ich den Fehler auch hier vermutete.
                      Ich bin natürlich nicht sicher, ob die andere ( auch keine neue ) SD-Karte nicht vielleicht auch defekt ist.
                      Mit dem syslog mache ich mich mal schlau und schaue was ich dort finden kann.
                      • N
                        Night2k5 @Thomas Braun last edited by Night2k5
                        @thomas-braun said in Mini-HowTo: Cannot find view "system" for search "host":
                        dmesg -T
                        pi@raspberrypi:~ $ dmesg -T
                        [Mon Mar 22 21:24:44 2021] Booting Linux on physical CPU 0x0
                        [Mon Mar 22 21:24:44 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
                        [Mon Mar 22 21:24:44 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                        [Mon Mar 22 21:24:44 2021] CPU: div instructions available: patching division code
                        [Mon Mar 22 21:24:44 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                        [Mon Mar 22 21:24:44 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
                        [Mon Mar 22 21:24:44 2021] Memory policy: Data cache writealloc
                        [Mon Mar 22 21:24:44 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
                        [Mon Mar 22 21:24:44 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                        [Mon Mar 22 21:24:44 2021] Zone ranges:
                        [Mon Mar 22 21:24:44 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                        [Mon Mar 22 21:24:44 2021]   Normal   empty
                        [Mon Mar 22 21:24:44 2021]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
                        [Mon Mar 22 21:24:44 2021] Movable zone start for each node
                        [Mon Mar 22 21:24:44 2021] Early memory node ranges
                        [Mon Mar 22 21:24:44 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                        [Mon Mar 22 21:24:44 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                        [Mon Mar 22 21:24:44 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                        [Mon Mar 22 21:24:44 2021] On node 0 totalpages: 1012736
                        [Mon Mar 22 21:24:44 2021]   DMA zone: 2304 pages used for memmap
                        [Mon Mar 22 21:24:44 2021]   DMA zone: 0 pages reserved
                        [Mon Mar 22 21:24:44 2021]   DMA zone: 196608 pages, LIFO batch:63
                        [Mon Mar 22 21:24:44 2021]   HighMem zone: 816128 pages, LIFO batch:63
                        [Mon Mar 22 21:24:44 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
                        [Mon Mar 22 21:24:44 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                        [Mon Mar 22 21:24:44 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                        [Mon Mar 22 21:24:44 2021] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
                        [Mon Mar 22 21:24:44 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:F3:FA:A4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4adeac15-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                        [Mon Mar 22 21:24:44 2021] Kernel parameter elevator= does not have any effect anymore.
                                                   Please use sysfs to set IO scheduler for individual devices.
                        [Mon Mar 22 21:24:44 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                        [Mon Mar 22 21:24:44 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                        [Mon Mar 22 21:24:44 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
                        [Mon Mar 22 21:24:44 2021] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
                        [Mon Mar 22 21:24:44 2021] Memory: 3654940K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3264512K highmem)
                        [Mon Mar 22 21:24:44 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                        [Mon Mar 22 21:24:44 2021] ftrace: allocating 33942 entries in 67 pages
                        [Mon Mar 22 21:24:44 2021] ftrace: allocated 67 pages with 3 groups
                        [Mon Mar 22 21:24:44 2021] rcu: Hierarchical RCU implementation.
                        [Mon Mar 22 21:24:44 2021]      Rude variant of Tasks RCU enabled.
                        [Mon Mar 22 21:24:44 2021]      Tracing variant of Tasks RCU enabled.
                        [Mon Mar 22 21:24:44 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                        [Mon Mar 22 21:24:44 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                        [Mon Mar 22 21:24:44 2021] GIC: Using split EOI/Deactivate mode
                        [Mon Mar 22 21:24:44 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                        [Mon Mar 22 21:24:44 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                        [Mon Mar 22 21:24:44 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                        [Mon Mar 22 21:24:44 2021] bcm2835: system timer (irq = 25)
                        [Mon Mar 22 21:24:44 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                        [Mon Mar 22 21:24:44 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                        [Mon Mar 22 21:24:44 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                        [Mon Mar 22 21:24:44 2021] Switching to timer-based delay loop, resolution 18ns
                        [Mon Mar 22 21:24:44 2021] Console: colour dummy device 80x30
                        [Mon Mar 22 21:24:44 2021] printk: console [tty1] enabled
                        [Mon Mar 22 21:24:44 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                        [Mon Mar 22 21:24:44 2021] pid_max: default: 32768 minimum: 301
                        [Mon Mar 22 21:24:44 2021] LSM: Security Framework initializing
                        [Mon Mar 22 21:24:44 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                        [Mon Mar 22 21:24:44 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                        [Mon Mar 22 21:24:44 2021] Disabling memory control group subsystem
                        [Mon Mar 22 21:24:44 2021] CPU: Testing write buffer coherency: ok
                        [Mon Mar 22 21:24:44 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                        [Mon Mar 22 21:24:44 2021] Setting up static identity map for 0x200000 - 0x20003c
                        [Mon Mar 22 21:24:44 2021] rcu: Hierarchical SRCU implementation.
                        [Mon Mar 22 21:24:44 2021] smp: Bringing up secondary CPUs ...
                        [Mon Mar 22 21:24:44 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                        [Mon Mar 22 21:24:44 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                        [Mon Mar 22 21:24:44 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                        [Mon Mar 22 21:24:44 2021] smp: Brought up 1 node, 4 CPUs
                        [Mon Mar 22 21:24:44 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                        [Mon Mar 22 21:24:44 2021] CPU: All CPU(s) started in HYP mode.
                        [Mon Mar 22 21:24:44 2021] CPU: Virtualization extensions available.
                        [Mon Mar 22 21:24:44 2021] devtmpfs: initialized
                        [Mon Mar 22 21:24:44 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                        [Mon Mar 22 21:24:44 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                        [Mon Mar 22 21:24:44 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                        [Mon Mar 22 21:24:44 2021] pinctrl core: initialized pinctrl subsystem
                        [Mon Mar 22 21:24:44 2021] NET: Registered protocol family 16
                        [Mon Mar 22 21:24:44 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                        [Mon Mar 22 21:24:44 2021] audit: initializing netlink subsys (disabled)
                        [Mon Mar 22 21:24:44 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                        [Mon Mar 22 21:24:44 2021] thermal_sys: Registered thermal governor 'step_wise'
                        [Mon Mar 22 21:24:44 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                        [Mon Mar 22 21:24:44 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
                        [Mon Mar 22 21:24:44 2021] Serial: AMBA PL011 UART driver
                        [Mon Mar 22 21:24:44 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                        [Mon Mar 22 21:24:44 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
                        [Mon Mar 22 21:24:44 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
                        [Mon Mar 22 21:24:44 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                        [Mon Mar 22 21:24:44 2021] vgaarb: loaded
                        [Mon Mar 22 21:24:44 2021] SCSI subsystem initialized
                        [Mon Mar 22 21:24:44 2021] usbcore: registered new interface driver usbfs
                        [Mon Mar 22 21:24:44 2021] usbcore: registered new interface driver hub
                        [Mon Mar 22 21:24:44 2021] usbcore: registered new device driver usb
                        [Mon Mar 22 21:24:44 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
                        [Mon Mar 22 21:24:44 2021] clocksource: Switched to clocksource arch_sys_counter
                        [Mon Mar 22 21:24:45 2021] VFS: Disk quotas dquot_6.6.0
                        [Mon Mar 22 21:24:45 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                        [Mon Mar 22 21:24:45 2021] FS-Cache: Loaded
                        [Mon Mar 22 21:24:45 2021] CacheFiles: Loaded
                        [Mon Mar 22 21:24:45 2021] NET: Registered protocol family 2
                        [Mon Mar 22 21:24:45 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                        [Mon Mar 22 21:24:45 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                        [Mon Mar 22 21:24:45 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                        [Mon Mar 22 21:24:45 2021] TCP: Hash tables configured (established 8192 bind 8192)
                        [Mon Mar 22 21:24:45 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                        [Mon Mar 22 21:24:45 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                        [Mon Mar 22 21:24:45 2021] NET: Registered protocol family 1
                        [Mon Mar 22 21:24:45 2021] RPC: Registered named UNIX socket transport module.
                        [Mon Mar 22 21:24:45 2021] RPC: Registered udp transport module.
                        [Mon Mar 22 21:24:45 2021] RPC: Registered tcp transport module.
                        [Mon Mar 22 21:24:45 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
                        [Mon Mar 22 21:24:45 2021] PCI: CLS 0 bytes, default 64
                        [Mon Mar 22 21:24:45 2021] Initialise system trusted keyrings
                        [Mon Mar 22 21:24:45 2021] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                        [Mon Mar 22 21:24:45 2021] zbud: loaded
                        [Mon Mar 22 21:24:45 2021] FS-Cache: Netfs 'nfs' registered for caching
                        [Mon Mar 22 21:24:45 2021] NFS: Registering the id_resolver key type
                        [Mon Mar 22 21:24:45 2021] Key type id_resolver registered
                        [Mon Mar 22 21:24:45 2021] Key type id_legacy registered
                        [Mon Mar 22 21:24:45 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                        [Mon Mar 22 21:24:45 2021] Key type asymmetric registered
                        [Mon Mar 22 21:24:45 2021] Asymmetric key parser 'x509' registered
                        [Mon Mar 22 21:24:45 2021] bounce: pool size: 64 pages
                        [Mon Mar 22 21:24:45 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                        [Mon Mar 22 21:24:45 2021] io scheduler mq-deadline registered
                        [Mon Mar 22 21:24:45 2021] io scheduler kyber registered
                        [Mon Mar 22 21:24:45 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                        [Mon Mar 22 21:24:45 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                        [Mon Mar 22 21:24:45 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                        [Mon Mar 22 21:24:45 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                        [Mon Mar 22 21:24:45 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                        [Mon Mar 22 21:24:45 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                        [Mon Mar 22 21:24:45 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
                        [Mon Mar 22 21:24:45 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                        [Mon Mar 22 21:24:45 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                        [Mon Mar 22 21:24:45 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
                        [Mon Mar 22 21:24:45 2021] PCI: bus0: Fast back to back transfers disabled
                        [Mon Mar 22 21:24:45 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                        [Mon Mar 22 21:24:45 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                        [Mon Mar 22 21:24:45 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
                        [Mon Mar 22 21:24:45 2021] PCI: bus1: Fast back to back transfers disabled
                        [Mon Mar 22 21:24:45 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                        [Mon Mar 22 21:24:45 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                        [Mon Mar 22 21:24:45 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
                        [Mon Mar 22 21:24:45 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                        [Mon Mar 22 21:24:45 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                        [Mon Mar 22 21:24:45 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
                        [Mon Mar 22 21:24:45 2021] iproc-rng200 fe104000.rng: hwrng registered
                        [Mon Mar 22 21:24:45 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                        [Mon Mar 22 21:24:45 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                        [Mon Mar 22 21:24:45 2021] brd: module loaded
                        [Mon Mar 22 21:24:45 2021] loop: module loaded
                        [Mon Mar 22 21:24:45 2021] Loading iSCSI transport class v2.0-870.
                        [Mon Mar 22 21:24:45 2021] libphy: Fixed MDIO Bus: probed
                        [Mon Mar 22 21:24:45 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                        [Mon Mar 22 21:24:45 2021] libphy: bcmgenet MII bus: probed
                        [Mon Mar 22 21:24:45 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                        [Mon Mar 22 21:24:45 2021] usbcore: registered new interface driver r8152
                        [Mon Mar 22 21:24:45 2021] usbcore: registered new interface driver lan78xx
                        [Mon Mar 22 21:24:45 2021] usbcore: registered new interface driver smsc95xx
                        [Mon Mar 22 21:24:45 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                        [Mon Mar 22 21:24:45 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
                        [Mon Mar 22 21:24:45 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                        [Mon Mar 22 21:24:45 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                        [Mon Mar 22 21:24:45 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                        [Mon Mar 22 21:24:45 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        [Mon Mar 22 21:24:45 2021] usb usb1: Product: xHCI Host Controller
                        [Mon Mar 22 21:24:45 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                        [Mon Mar 22 21:24:45 2021] usb usb1: SerialNumber: 0000:01:00.0
                        [Mon Mar 22 21:24:45 2021] hub 1-0:1.0: USB hub found
                        [Mon Mar 22 21:24:45 2021] hub 1-0:1.0: 1 port detected
                        [Mon Mar 22 21:24:45 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                        [Mon Mar 22 21:24:45 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                        [Mon Mar 22 21:24:45 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                        [Mon Mar 22 21:24:45 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        [Mon Mar 22 21:24:45 2021] usb usb2: Product: xHCI Host Controller
                        [Mon Mar 22 21:24:45 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                        [Mon Mar 22 21:24:45 2021] usb usb2: SerialNumber: 0000:01:00.0
                        [Mon Mar 22 21:24:45 2021] hub 2-0:1.0: USB hub found
                        [Mon Mar 22 21:24:45 2021] hub 2-0:1.0: 4 ports detected
                        [Mon Mar 22 21:24:45 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                        [Mon Mar 22 21:24:45 2021] dwc_otg: FIQ enabled
                        [Mon Mar 22 21:24:45 2021] dwc_otg: NAK holdoff enabled
                        [Mon Mar 22 21:24:45 2021] dwc_otg: FIQ split-transaction FSM enabled
                        [Mon Mar 22 21:24:45 2021] Module dwc_common_port init
                        [Mon Mar 22 21:24:45 2021] usbcore: registered new interface driver uas
                        [Mon Mar 22 21:24:45 2021] usbcore: registered new interface driver usb-storage
                        [Mon Mar 22 21:24:45 2021] mousedev: PS/2 mouse device common for all mice
                        [Mon Mar 22 21:24:45 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                        [Mon Mar 22 21:24:45 2021] sdhci: Secure Digital Host Controller Interface driver
                        [Mon Mar 22 21:24:45 2021] sdhci: Copyright(c) Pierre Ossman
                        [Mon Mar 22 21:24:45 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                        [Mon Mar 22 21:24:45 2021] sdhci-pltfm: SDHCI platform and OF driver helper
                        [Mon Mar 22 21:24:45 2021] ledtrig-cpu: registered to indicate activity on CPUs
                        [Mon Mar 22 21:24:45 2021] hid: raw HID events driver (C) Jiri Kosina
                        [Mon Mar 22 21:24:45 2021] usbcore: registered new interface driver usbhid
                        [Mon Mar 22 21:24:45 2021] usbhid: USB HID core driver
                        [Mon Mar 22 21:24:45 2021] Initializing XFRM netlink socket
                        [Mon Mar 22 21:24:45 2021] NET: Registered protocol family 17
                        [Mon Mar 22 21:24:45 2021] Key type dns_resolver registered
                        [Mon Mar 22 21:24:45 2021] Registering SWP/SWPB emulation handler
                        [Mon Mar 22 21:24:45 2021] registered taskstats version 1
                        [Mon Mar 22 21:24:45 2021] Loading compiled-in X.509 certificates
                        [Mon Mar 22 21:24:45 2021] Key type ._fscrypt registered
                        [Mon Mar 22 21:24:45 2021] Key type .fscrypt registered
                        [Mon Mar 22 21:24:45 2021] Key type fscrypt-provisioning registered
                        [Mon Mar 22 21:24:45 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
                        [Mon Mar 22 21:24:45 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
                        [Mon Mar 22 21:24:45 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                        [Mon Mar 22 21:24:45 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                        [Mon Mar 22 21:24:45 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                        [Mon Mar 22 21:24:45 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                        [Mon Mar 22 21:24:45 2021] of_cfs_init
                        [Mon Mar 22 21:24:45 2021] of_cfs_init: OK
                        [Mon Mar 22 21:24:45 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                        [Mon Mar 22 21:24:45 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        [Mon Mar 22 21:24:45 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                        [Mon Mar 22 21:24:45 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                        [Mon Mar 22 21:24:45 2021] Waiting for root device PARTUUID=4adeac15-02...
                        [Mon Mar 22 21:24:45 2021] random: fast init done
                        [Mon Mar 22 21:24:45 2021] mmc1: new high speed SDIO card at address 0001
                        [Mon Mar 22 21:24:45 2021] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                        [Mon Mar 22 21:24:45 2021] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
                        [Mon Mar 22 21:24:45 2021]  mmcblk0: p1 p2
                        [Mon Mar 22 21:24:45 2021] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                        [Mon Mar 22 21:24:45 2021] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                        [Mon Mar 22 21:24:45 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                        [Mon Mar 22 21:24:45 2021] EXT4-fs (mmcblk0p2): recovery complete
                        [Mon Mar 22 21:24:45 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        [Mon Mar 22 21:24:45 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Mon Mar 22 21:24:45 2021] devtmpfs: mounted
                        [Mon Mar 22 21:24:45 2021] Freeing unused kernel memory: 2048K
                        [Mon Mar 22 21:24:45 2021] Run /sbin/init as init process
                        [Mon Mar 22 21:24:45 2021]   with arguments:
                        [Mon Mar 22 21:24:45 2021]     /sbin/init
                        [Mon Mar 22 21:24:45 2021]   with environment:
                        [Mon Mar 22 21:24:45 2021]     HOME=/
                        [Mon Mar 22 21:24:45 2021]     TERM=linux
                        [Mon Mar 22 21:24:45 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                        [Mon Mar 22 21:24:45 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                        [Mon Mar 22 21:24:45 2021] usb 1-1: Product: USB2.0 Hub
                        [Mon Mar 22 21:24:45 2021] hub 1-1:1.0: USB hub found
                        [Mon Mar 22 21:24:45 2021] hub 1-1:1.0: 4 ports detected
                        [Mon Mar 22 21:24:46 2021] systemd[1]: System time before build time, advancing clock.
                        [Mon Mar 22 21:24:46 2021] NET: Registered protocol family 10
                        [Mon Mar 22 21:24:46 2021] Segment Routing with IPv6
                        [Mon Mar 22 21:24:46 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                        [Mon Mar 22 21:24:46 2021] systemd[1]: Detected architecture arm.
                        [Mon Mar 22 21:24:46 2021] systemd[1]: Set hostname to <raspberrypi>.
                        [Mon Mar 22 21:24:47 2021] random: systemd: uninitialized urandom read (16 bytes read)
                        [Mon Mar 22 21:24:47 2021] systemd[1]: Listening on udev Control Socket.
                        [Mon Mar 22 21:24:47 2021] systemd[1]: Listening on initctl Compatibility Named Pipe.
                        [Mon Mar 22 21:24:47 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                        [Mon Mar 22 21:24:47 2021] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                        [Mon Mar 22 21:24:47 2021] systemd[1]: Reached target Local Encrypted Volumes.
                        [Mon Mar 22 21:24:47 2021] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                        [Mon Mar 22 21:24:47 2021] systemd[1]: Created slice system-getty.slice.
                        [Mon Mar 22 21:24:47 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        [Mon Mar 22 21:24:47 2021] systemd-journald[118]: Received request to flush runtime journal from PID 1
                        [Mon Mar 22 21:24:48 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                        [Mon Mar 22 21:24:48 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                        [Mon Mar 22 21:24:48 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                        [Mon Mar 22 21:24:48 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                        [Mon Mar 22 21:24:48 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                        [Mon Mar 22 21:24:48 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                        [Mon Mar 22 21:24:48 2021] [vc_sm_connected_init]: start
                        [Mon Mar 22 21:24:48 2021] [vc_sm_connected_init]: installed successfully
                        [Mon Mar 22 21:24:48 2021] mc: Linux media interface: v0.10
                        [Mon Mar 22 21:24:48 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                        [Mon Mar 22 21:24:48 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
                        [Mon Mar 22 21:24:48 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                        [Mon Mar 22 21:24:48 2021] videodev: Linux video capture interface: v2.00
                        [Mon Mar 22 21:24:48 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                        [Mon Mar 22 21:24:48 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                        [Mon Mar 22 21:24:48 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
                        [Mon Mar 22 21:24:48 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                        [Mon Mar 22 21:24:48 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                        [Mon Mar 22 21:24:48 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                        [Mon Mar 22 21:24:48 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                        [Mon Mar 22 21:24:48 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                        [Mon Mar 22 21:24:48 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                        [Mon Mar 22 21:24:48 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
                        [Mon Mar 22 21:24:48 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                        [Mon Mar 22 21:24:48 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                        [Mon Mar 22 21:24:48 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
                        [Mon Mar 22 21:24:48 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                        [Mon Mar 22 21:24:48 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                        [Mon Mar 22 21:24:48 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                        [Mon Mar 22 21:24:48 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                        [Mon Mar 22 21:24:48 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        [Mon Mar 22 21:24:48 2021] usbcore: registered new interface driver brcmfmac
                        [Mon Mar 22 21:24:48 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                        [Mon Mar 22 21:24:49 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        [Mon Mar 22 21:24:49 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                        [Mon Mar 22 21:24:51 2021] random: crng init done
                        [Mon Mar 22 21:24:51 2021] random: 7 urandom warning(s) missed due to ratelimiting
                        [Mon Mar 22 21:24:51 2021] uart-pl011 fe201000.serial: no DMA platform data
                        [Mon Mar 22 21:24:51 2021] 8021q: 802.1Q VLAN Support v1.8
                        [Mon Mar 22 21:24:51 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                        [Mon Mar 22 21:24:51 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                        [Mon Mar 22 21:24:51 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                        [Mon Mar 22 21:24:51 2021] bcmgenet fd580000.ethernet eth0: Link is Down
                        [Mon Mar 22 21:24:56 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                        [Mon Mar 22 21:24:58 2021] Bluetooth: Core ver 2.22
                        [Mon Mar 22 21:24:58 2021] NET: Registered protocol family 31
                        [Mon Mar 22 21:24:58 2021] Bluetooth: HCI device and connection manager initialized
                        [Mon Mar 22 21:24:58 2021] Bluetooth: HCI socket layer initialized
                        [Mon Mar 22 21:24:58 2021] Bluetooth: L2CAP socket layer initialized
                        [Mon Mar 22 21:24:58 2021] Bluetooth: SCO socket layer initialized
                        [Mon Mar 22 21:24:58 2021] Bluetooth: HCI UART driver ver 2.3
                        [Mon Mar 22 21:24:58 2021] Bluetooth: HCI UART protocol H4 registered
                        [Mon Mar 22 21:24:58 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
                        [Mon Mar 22 21:24:58 2021] Bluetooth: HCI UART protocol Broadcom registered
                        [Mon Mar 22 21:24:58 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                        [Mon Mar 22 21:24:58 2021] Bluetooth: BNEP filters: protocol multicast
                        [Mon Mar 22 21:24:58 2021] Bluetooth: BNEP socket layer initialized
                        [Mon Mar 22 21:25:46 2021] Under-voltage detected! (0x00050005)
                        [Mon Mar 22 21:25:53 2021] Voltage normalised (0x00000000)
                        Es scheint also anscheinend ein Fehler mit der Spannungsversorgung zu sein. Anscheinend ist der rPi4 da anfälliger als sein Vorgänger. Dann muss ich wohl doch nach einem passenden Netzteil + Kabel ausschau halten.
                        • wendy2702
                          @night2k5 Syslog liegt in
                          /var/log/
                          • wendy2702
                            So scheint es. Der PI3 war genau so empfindlich... kam nur wenn ich mich richtig erinnere mit weniger Leistung aus.
                              Thomas Braun Most Active @Night2k5 last edited by Thomas Braun
                              Besorg dir ein stabileres Netzteil. Was haste denn da jetzt dran?
                              • N
                                Im Moment nutze ich einfach den 5V Ausgang von meinem Tradfri-Ladestecker der bei dem Rollo von Ikea dabei war.
                                Dem 3er Pi hat das gereicht. Ich fahre gerade den Pi herunter und will es dann mal mit dem Netzteil von meinem Smartphone probieren, welches theoretisch mehr Leistung liefern sollte. Womöglich aber auch nur an das Smartphone dank der ganzen Elektronik und Absprachen zwischen Netzteil und Mobiltelefon.
                                wendy2702 Thomas Braun apollon77 3 Replies Last reply Reply Quote 0
                                • wendy2702
                                  @night2k5 Die beiden genannten Geräte sind “LADE” Geräte und keine stabile Spannungsversorgung für einen SBC.
                                    Da kannste ein Nachtlicht mit betreiben, aber keinen Pi4.
                                    • N
                                      @thomas-braun @wendy2702
                                      Könnt ihr mir ein konkretes Netzteil empfehlen?
                                      Bei dem Dschungel an Netzteilen und Informationen die so im Netz herumschwirren ist man leider auch mit ein wenig Vorkenntnissen schnell aufgeschmissen. Der eine sagt es muss auf jeden Fall mindestens 3A liefern. Dann wieder muss es ein bestimmtes Kabel sein was keine Datenleitungen enthält wegen eines Fehlers im Pi der dann den richtigen Strom nicht einstellt und so weiter.
                                      Leider nicht ganz einfach da noch zu filtern, was jetzt stimmt und was nur Marketing ist.
                                      • wendy2702
                                        @night2k5
                                        Zum Beispiel das originale:
                                        https://www.raspberrypi.org/products/type-c-power-supply/
                                        Oder eines aus der ELV Liste:
                                        https://de.elv.com/raspberry-pi-4-model-b-4gb-ram-250568?fs=2177327359
                                          @night2k5
                                          Ich habe bei meinem Pi4 das 'originale' für den Raspberry Pi laufen.
                                          Das hat zwar auch unterschiedliche Bewertungen bekommen, wenn ich mich recht entsinne, fällt aber bei mir nicht irgendwie negativ auf. Der Pi läuft inkl. einem Raspbee I - Modul.
                                          • N
                                            Besten Dank. Ich werde mir das bestellen und von nun an nutzen.
                                            Danke auch für eure schnelle Hilfe. Ohne euch hätte ich nie gewusst wo ich hätte nachschauen müssen wegen der Spannungsversorgungsprobleme.
                                            Bei Kodi war es immer leicht an dem Blitz im Fernseher zu erkennen. Hier in der Konsole ist es für einen Linux-Laien nicht ganz so einfach.
                                            302
                                            69438
