    4. Test Adapter mihome-vacuum v2.0.x
    • Z
      Zwer2k last edited by Zwer2k
      bekomme immer wieder folgenden Fehler. Hab Robororock S50.
      mihome-vacuum.0	2021-03-20 10:20:41.908	warn	(31187) Terminated (UNCAUGHT_EXCEPTION): Without reason
      mihome-vacuum.0	2021-03-20 10:20:41.907	info	(31187) terminating
      mihome-vacuum.0	2021-03-20 10:20:41.903	error	(31187) The id "32" has an invalid type! Expected "string" or "object", received "number".
      mihome-vacuum.0	2021-03-20 10:20:41.903	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      mihome-vacuum.0	2021-03-20 10:20:41.903	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1089:63
      mihome-vacuum.0	2021-03-20 10:20:41.903	error	at Object.callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:512:25)
      mihome-vacuum.0	2021-03-20 10:20:41.903	error	at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6223:17)
      mihome-vacuum.0	2021-03-20 10:20:41.903	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:505:19)
      mihome-vacuum.0	2021-03-20 10:20:41.903	error	(31187) Error: The id "32" has an invalid type! Expected "string" or "object", received "number".
      mihome-vacuum.0	2021-03-20 10:20:41.901	error	(31187) unhandled promise rejection: The id "32" has an invalid type! Expected "string" or "object", received "number".
      mihome-vacuum.0	2021-03-20 10:20:41.901	error	(31187) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mihome-vacuum.0	2021-03-20 10:20:41.900	info	(31187) send message: Method: app_zoned_clean Params: [[27900,26300,30200,28600,1],[23000,25700,27900,29100,1],[25800,21800,27900,25700,1],[23000,21800,25800,23200,1],[23000,21800,23700,25000,1]]
      oder
      mihome-vacuum.0	2021-03-20 10:42:31.830	warn	(3375) Terminated (UNCAUGHT_EXCEPTION): Without reason
      mihome-vacuum.0	2021-03-20 10:42:31.828	info	(3375) terminating
      mihome-vacuum.0	2021-03-20 10:42:31.824	error	(3375) The id "84" has an invalid type! Expected "string" or "object", received "number".
      mihome-vacuum.0	2021-03-20 10:42:31.824	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      mihome-vacuum.0	2021-03-20 10:42:31.824	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1089:63
      mihome-vacuum.0	2021-03-20 10:42:31.824	error	at Object.callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:512:25)
      mihome-vacuum.0	2021-03-20 10:42:31.824	error	at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6223:17)
      mihome-vacuum.0	2021-03-20 10:42:31.824	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:505:19)
      mihome-vacuum.0	2021-03-20 10:42:31.824	error	(3375) Error: The id "84" has an invalid type! Expected "string" or "object", received "number".
      mihome-vacuum.0	2021-03-20 10:42:31.822	error	(3375) unhandled promise rejection: The id "84" has an invalid type! Expected "string" or "object", received "number".
      mihome-vacuum.0	2021-03-20 10:42:31.822	error	(3375) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mihome-vacuum.0	2021-03-20 10:42:31.821	info	(3375) send message: Method: app_goto_target Params: [26400,25500]
      Nach dem Absturz bleibt der Adapter meistens ewig gelb bis er wieder online ist.
      (3375) connecting, this can take up to 10 minutes ...
        Schwabe last edited by
        Wenn ich mein Problem noch mal hervorholen darf.
        Ich habe 2 ioBroker System. Das "Alte" ist ein TinkerBoard S auf dem ich keinen mihome-vacuum Adpter neuer als 1.1.5 installiert bekomme. Updates brechen mit einer Fehlermeldung ab und ich muss danach den Adapter komplett deinstallieren und neu installieren, doch ansonsten läuft er einwandfrei. Da ich gerne auf mein "Neues" umsteigen möchte, würde ich hier nichts mehr dran ändern wollen.
        Das "Neue" ist ein Ubuntu unter Windows. Leider bleibt hier der Adapter bei "gelb" stehen er wird einfach nicht "grün". Ich kann die Serverdaten eintragen, bekomme meinen "Robbi" angezeigt und kann diesen auch übernehmen.
        Meine Node.js Version ist 12.21.0, die NPM 6.14.11 und der JS Controller ist auch aktuell.
        Ich habe den Adapter auf dem TinkerBoard längere Zeit deaktiviert.
        Ich habe den Adapter mehrfach neu installiert und eingerichtet.
        Ich habe den Sauger ausgeschaltet und wieder eingeschaltet.
        Ich habe den Sauger mehrfach laufen lassen, während der Adapter aktiv war.
        Der Adapter verursacht keine Fehlermeldungen im Log. Der angehängte Log ist von einem manuellen Neustart des Adapters im debug Modus.
        Hat vielleicht noch jemand einen Rat für mich? Vielen Dank im Vorraus.
        > mihome-vacuum.0	2021-03-14 21:05:56.355	debug	(26927) Xiaomi Cloud: Login successful
        > mihome-vacuum.0	2021-03-14 21:05:55.108	info	(26927) set nächster Timer: Nicht verfügbar
        > mihome-vacuum.0	2021-03-14 21:05:54.616	debug	(26927) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        > mihome-vacuum.0	2021-03-14 21:05:54.600	debug	(26927) server started on 0.0.0.0:53421
        > mihome-vacuum.0	2021-03-14 21:05:54.597	info	(26927) Cloud control disabled
        > mihome-vacuum.0	2021-03-14 21:05:54.597	info	(26927) Expert mode enabled, states created
        > mihome-vacuum.0	2021-03-14 21:05:54.595	debug	(26927) Xiaomi Cloud: Logging in
        > mihome-vacuum.0	2021-03-14 21:05:54.594	debug	(26927) load Map creator... false
        > mihome-vacuum.0	2021-03-14 21:05:54.556	info	(26927) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v15.11.0, js-controller: 3.2.16
        > mihome-vacuum.0	2021-03-14 21:05:54.437	debug	(26927) statesDB connected
        > mihome-vacuum.0	2021-03-14 21:05:54.437	debug	(26927) States connected to redis: 127.0.0.1:9000
        > mihome-vacuum.0	2021-03-14 21:05:54.431	debug	(26927) States create User PubSub Client
        > mihome-vacuum.0	2021-03-14 21:05:54.431	debug	(26927) States create System PubSub Client
        > mihome-vacuum.0	2021-03-14 21:05:54.428	debug	(26927) Redis States: Use Redis connection: 127.0.0.1:9000
        > mihome-vacuum.0	2021-03-14 21:05:54.427	debug	(26927) objectDB connected
        > mihome-vacuum.0	2021-03-14 21:05:54.425	debug	(26927) Objects connected to redis: 127.0.0.1:9001
        > mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects client initialize lua scripts
        > mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects create User PubSub Client
        > mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects create System PubSub Client
        > mihome-vacuum.0	2021-03-14 21:05:54.416	debug	(26927) Objects client ready ... initialize now
        > mihome-vacuum.0	2021-03-14 21:05:54.404	debug	(26927) Redis Objects: Use Redis connection: 127.0.0.1:9001
        > host.Server	2021-03-14 21:05:53.954	info	instance system.adapter.mihome-vacuum.0 started with pid 26927
        > host.Server	2021-03-14 21:05:51.499	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        > mihome-vacuum.0	2021-03-14 21:05:50.984	debug	(26912) system.adapter.admin.0: logging true
        > mihome-vacuum.0	2021-03-14 21:05:50.901	info	(26912) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        > mihome-vacuum.0	2021-03-14 21:05:50.900	info	(26912) terminating
        > host.Server	2021-03-14 21:05:50.900	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
        > mihome-vacuum.0	2021-03-14 21:05:50.900	info	(26912) Got terminate signal TERMINATE_YOURSELF
        Thomas Braun S 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Schwabe last edited by Thomas Braun
          @schwabe sagte in Test Adapter mihome-vacuum v2.0.x:
          Im Log steht was von node15. Schau dir das nochmal an. Siehe Link in meiner Signatur.
            Schwabe @Thomas Braun last edited by
            @thomas-braun Danke für Deinen Hinweis, da hast Du natürlich Recht. Der Log war noch von einem Start bevor ich den Node.js auf die aktuelle Stable zurückgesetzt hatte.
            Hier ein aktueller Log:
            mihome-vacuum.0	2021-03-20 14:27:13.704	info	(25385) set nächster Timer: Nicht verfügbar
            mihome-vacuum.0	2021-03-20 14:27:13.185	debug	(25385) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            mihome-vacuum.0	2021-03-20 14:27:13.178	debug	(25385) server started on 0.0.0.0:53421
            mihome-vacuum.0	2021-03-20 14:27:13.175	info	(25385) Cloud control disabled
            mihome-vacuum.0	2021-03-20 14:27:13.175	info	(25385) Expert mode disabled, states deleted
            mihome-vacuum.0	2021-03-20 14:27:13.154	info	(25385) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
            mihome-vacuum.0	2021-03-20 14:27:13.052	debug	(25385) statesDB connected
            mihome-vacuum.0	2021-03-20 14:27:13.052	debug	(25385) States connected to redis: 127.0.0.1:9000
            mihome-vacuum.0	2021-03-20 14:27:13.047	debug	(25385) States create User PubSub Client
            mihome-vacuum.0	2021-03-20 14:27:13.046	debug	(25385) States create System PubSub Client
            mihome-vacuum.0	2021-03-20 14:27:13.043	debug	(25385) Redis States: Use Redis connection: 127.0.0.1:9000
            mihome-vacuum.0	2021-03-20 14:27:13.042	debug	(25385) objectDB connected
            mihome-vacuum.0	2021-03-20 14:27:13.040	debug	(25385) Objects connected to redis: 127.0.0.1:9001
            mihome-vacuum.0	2021-03-20 14:27:13.032	debug	(25385) Objects client initialize lua scripts
            mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects create User PubSub Client
            mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects create System PubSub Client
            mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects client ready ... initialize now
            mihome-vacuum.0	2021-03-20 14:27:13.021	debug	(25385) Redis Objects: Use Redis connection: 127.0.0.1:9001
            host.Server	2021-03-20 14:27:12.721	info	instance system.adapter.mihome-vacuum.0 started with pid 25385
            host.Server	2021-03-20 14:27:12.699	info	"system.adapter.mihome-vacuum.0" enabled
              mech last edited by
              Moin, ich habe auch das Problem das "Get Devices" kein Ergebnis mehr liefert. Ich habe die Tage Node auf 12 geupgraded von 10. Ich vermute es liegt daran. Da ich noch einen Snapshot vom System hatte konnte ich IOBroker auf Node 10 zurücksetzen und der Adapter läuft wieder 1a.
              Irgendwas scheint nicht rund zu laufen 🙂
              Besten Gruß
                Thomas Braun Most Active @mech last edited by
                @mech sagte in Test Adapter mihome-vacuum v2.0.x:
                Kann ich nicht bestätigen. Hier läuft der Adapter ganz unauffällig mit node 12 und mit node14.
                Auf einen Debian-System? Das macht man nicht so grobschlächtig, man benutzt seinen Paketmanager und installiert das dann sauber darüber.
                  mech @Thomas Braun last edited by
                  @thomas-braun Bei einem Snapshot unter Proxmox sehe ich da kein Handlungsbedarf über den Paketmanager 😉
                    Thomas Braun Most Active @mech last edited by Thomas Braun
                    @mech
                    Dann wirst du nie 'elegant' mit dem System umgehen können.
                    Snapshot draufknallen ist keine Problemlösung, das ist nur stumpf drüberwalzen.
                    Beim Auto setzt du ja auch keinen Austauschmotor rein, wenn eigentlich nur die Zündkerzen erneuert werden sollen.
                      Spampunk last edited by
                      Hallo Freunde des gepflegten Staubsaugens,
                      ich gebe mal ein kurzes Feedback: Auch ich hatte ja lange Zeit keine Map, obwohl ich alle Einstellungen im Adapter und in der Mihome-App vorgenommen hatte. Vor ein paar Tagen dachte ich mir, ich könnte ja mal wieder auf den Schalter "Get Devices" im Mihome-Adapter klicken und -wupps- war der Token da und die Map in meiner VIS.
                      @Meistertr hatte den Verdacht, dass ich keine Verbindung zum Xiaomi-Server erhalte. Das kann ich bis heute nicht genau sagen. Das Einzige, was sich in dieser Zeit geändert hat, ist das Update der JS-Engine. Vielleicht hat das ja etwas bewirkt?
                      Jedenfalls bin ich jetzt glücklich und kann alles wie gewünscht nutzen!
                      Viele Grüße,
                      Spampunk
                      • da_Woody
                        da_Woody @Spampunk last edited by
                        @spampunk na das liest sich ja mal gut!
                        ohne das get devices gibts immer probleme. bei mir hats damls zum glück sofort funktioniert...
                          Coffeelover last edited by
                          ich habe gestern einen Roborock S7 in der App eingebunden.
                          Nachdem ich zunächst daran gescheitert war, weil ich für die Einrichtung die RoborockApp genutzt hatte und nicht die MiHome, ist er jetzt bei GetDevices aufgetaucht und verbunden.
                          Allerdings bleibt der Adapter gelb, obwohl die Zeitzone Roborock & Handy synchronisiert ist.
                          Meldung im Log:
                          (4734) Time difference between Mihome Vacuum and ioBroker: -1616765837 sec
                          Darauf folgt ein neuer Verbindungsversuch. Kennt jemand eine Lösung dazu?
                          VG
                            Thomas Braun Most Active @Coffeelover last edited by
                            @coffeelover sagte in Test Adapter mihome-vacuum v2.0.x:
                            1616765837 sec
                            Einer der beiden läuft auf Unix-Nullzeit. Das sind nämlich 51 Jahre umgerechnet = 01.01.1970
                              Coffeelover @Thomas Braun last edited by
                              @thomas-braun Danke. Die Frage ist eher: wie bekomme ich das auf heute synchronisiert?
                                @coffeelover
                                Welches System hat denn da keine aktuelle Zeit?
                                Auf dem Server:
                                date && date -u
                                prüfen.
                                  @thomas-braun iobroker läuft auf einem QNAP im Docker installiert.
                                  Die Abfrage oben liefert die aktuelle Zeit als CET. Eine zweite Xiaomi-Instanz meckert nicht - die Zeit in iobroker sollte also passen.
                                  im Roborock habe ich vorhin in den erweiterten Einstellungen noch eine Möglichkeit zum Setzen einer Zeitzone gefunden. Auch die habe ich auf MEZ gestellt - geändert hat sich wenig.
                                    Flauschi last edited by
                                    https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/228
                                    das Problem liegt am S7
                                    Black-Thunder created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                                    closed Roborock S7 not supported #228
                                    C 1 Reply Last reply Reply Quote 1
                                      Coffeelover @Flauschi last edited by
                                      @flauschi danke dir. Eine Info wie diese hatte ich gesucht. Mal abwarten, dafür gibt es sicher bald eine Lösung.
                                        mech @Thomas Braun last edited by mech
                                        @thomas-braun said in Test Adapter mihome-vacuum v2.0.x:
                                        @mech
                                        @thomas-braun Nein, ich würde mir direkt ein neues Auto kaufen.
                                          @mech Ja, das merke ich.
                                            Flauschi @Coffeelover last edited by
                                            @coffeelover wenn Du den angesprochenen Workaround machst, dann hast Du keine Fehler mehr.
                                            Die Zeitabweichung kam auch nur die ersten paar refreshes und dann nicht mehr.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            445836
