    4. [SourceAnalytix 0.4.8-Final] Released !
      Schwarzwälder @crunchip last edited by Negalein
      @crunchip
      Leider habe doch noch ein Problem mit den falschen historischen Werten, wie bekomme ich diese los?
      2021-03-21 14:00:42.296 - info: sourceanalytix.0 (1629) Welcome to SourceAnalytix, making things ready ...
      2021-03-21 14:00:42.395 - error: sourceanalytix.0 (1629) Check settings for smartmeter.0.1-0:2_8_0__255.value ! **Known valueAtDeviceReset : (904364.4407158422) > known cumulative value (18874.5548) cannot proceed**
      2021-03-21 14:00:42.395 - error: sourceanalytix.0 (1629) Troubleshoot Data smartmeter.0.1-0:2_8_0__255.value custom Data : {"type":"state","common":{"name":"1-0:2_8_0__255.value","type":"number","read":true,"unit":"kWh","role":"value","write":false,"custom":{"sourceanalytix.0":{"enabled":true,"alias":"Einspeisung","selectedPrice":"ElectricityDelivery","selectedUnit":"kWh","costs":false,"consumption":false,"meter_values":true,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":18065,"valueAtDeviceInit":18874.5548,"v**alueAtDeviceReset":904364.4407158422,"cumulativeValue":557092.3647416172}}**},"native":{"id":"1-0:2_8_0__255.value"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1616154824830,"_id":"smartmeter.0.1-0:2_8_0__255.value","acl":{"object":1636,"state":1636,"file":1636,"ownerGroup":"system.group.administrator"}}
      2021-03-21 14:00:42.402 - info: sourceanalytix.0 (1629) Initialising (1 of 2) state smartmeter.0.1-0:2_8_0__255.value
      2021-03-21 14:00:42.404 - error: sourceanalytix.0 (1629) Cannot handle initialisation for smartmeter.0.1-0:2_8_0__255.value
      2021-03-21 14:00:42.404 - info: sourceanalytix.0 (1629) Initialization (1 of 2) finished for : smartmeter.0.1-0:2_8_0__255.value
      Mod-Edit: Code in </> Code-Tag gepackt!
        crunchip Forum Testing Most Active @Schwarzwälder last edited by
        @schwarzwälder wie oben schon erwähnt, prüfe ob deine smartmeter Werte überhaupt richtig rein kommen
          Bloody @Dutchman last edited by
          @dutchman said in [SourceAnalytix 0.4.8-Final] Released !:
          @bloody sagte in [SourceAnalytix 0.4.8-Final] Released !:
          Er nimmt dann die kWh, die das Gerät ausspuckt und nicht was ich in SA eintrage. bekomme ich das wieder gerade gebogen?
          schau dir mal an was im rawdatan von deinem alten, und was im neuen stehen.
          Dan wirste sehen das dort ein startwert hinterlegt ist den du übernehmen musst (steht übrigens auch in der
          troubleshoot Sektion 🙂
          Irgendwie stehe ich auf dem Schlauch. Hab jetzt schon einiges probiert aber irgendwie will es nicht so, wie ich will.
          Das alte Gerät ging bis 48,194 kWh. Das neue fängt ab 7,94 an. Was muss ich genau wo einstellen? Habe schon mit den vier Werten gespielt aber nööö.
          "previousDeviceReset": 48.194,
          "previousInit": 48.194,
          "valueAtDeviceReset": 56,
          "valueAtDeviceInit": 7.94
               "sourceanalytix.0": {
                  "enabled": true,
                  "alias": "Aquarium Licht",
                  "selectedPrice": "ElectricityDay",
                  "selectedUnit": "kWh",
                  "costs": true,
                  "consumption": true,
                  "meter_values": true,
                  "start_day": 48.194,
                  "start_week": 48.194,
                  "start_month": 46.024,
                  "start_quarter": 37.291,
                  "start_year": 37.291,
            crunchip Forum Testing Most Active @Bloody last edited by
            @bloody was gibts denn für ein Problem?
              @crunchip said in [SourceAnalytix 0.4.8-Final] Released !:
              Ich habe das Gefühl, dass die Berechnungen nicht richtig sind. Hätte heute ja 4,62€ gekostet. Sonst um die 0,50€
                @bloody stimmt dein cumulativ Reading mit deinem eigentlichen Wert überein?
                • MassiveAttack
                  MassiveAttack last edited by
                  Durch ein Firmware Update habe ich einen Tag im März einen falschen (zu großen) Wert vom Wechselrichter bekommen, seit dem wird der Monatswert natürlich falsch dargestellt. Wie kann ich das wieder korrigieren?
                  • Werte überschreiben geht zwar, aber für den aktuellen Monat wird es wieder verworfen (geht anscheinend nur für vergangene Zeiträume)
                  • Zähler am DP zurücksetzen (korrigieren) geht, aber der errechnete Monatswert wird nicht aktualisiert. Es scheint als würde er beim "Zählerstand bei Tagesbeginn" die falschen Werte wieder dazu addieren.
                  Siehe Screenshot, der Tageswert ist viel zu hoch
                  K MassiveAttack 2 Replies Last reply Reply Quote 0
                    Kanumouse @MassiveAttack last edited by
                    @Dutchman,
                    Den Adapter finde ich toll bekomme ihn aber nicht richtig zum laufen.
                    Vielleicht kannst du mir helfen?
                    Im Log-File bekomme ich immer solche Fehlermeldungen und kann diese nicht einordnen.
                    2021-03-24 00:00:00.598  - error: sourceanalytix.0 (11067) [[resetStartValues] hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER] error: Cannot read property 'calcValues' of null, stack: TypeError: Cannot read property 'calcValues' of null
                        at CronJob.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:621:54)
                    2021-03-24 00:00:00.602  - error: sourceanalytix.0 (11067) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2021-03-24 00:00:00.603  - error: sourceanalytix.0 (11067) unhandled promise rejection: Cannot read property 'captureException' of undefined
                    2021-03-24 00:00:00.603  - error: sourceanalytix.0 (11067) TypeError: Cannot read property 'captureException' of undefined
                        at Sourceanalytix.errorHandling (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:1647:37)
                        at CronJob.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:849:12)
                    2021-03-24 00:00:00.604  - error: sourceanalytix.0 (11067) Cannot read property 'captureException' of undefined
                    2021-03-24 00:00:00.635  - info: sourceanalytix.0 (11067) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
                    2021-03-24 00:00:00.636  - info: sourceanalytix.0 (11067) terminating
                    2021-03-24 00:00:00.637  - warn: sourceanalytix.0 (11067) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    Gleichzeitig zählt er bei den Tages- und Wochenverbräuchen nur den aktuellen Zählerstand hoch, statt die Tages und Wochenverbräuche auszurechnen.
                    Wo liegt das Problem?
                    Ich hab die Adapter-Version 0.4.8 installiert.
                      Bloody @crunchip last edited by
                      Nein, der eigentliche Wert vom neuen "Messgerät" wäre eigentlich 8,22kWh.
                      Heute scheint die Berechnung allerdings wieder zu passen, bis auf den Wert von gestern halt.
                      • Dutchman
                        Dutchman Developer Most Active Administrators @Kanumouse last edited by
                        @kanumouse sagte in [SourceAnalytix 0.4.8-Final] Released !:
                        wie sieht das log beim starten des Adapter aus?
                        • MassiveAttack
                          MassiveAttack @MassiveAttack last edited by
                          @massiveattack said in [SourceAnalytix 0.4.8-Final] Released !:
                          Bitte um Hilfe...!!
                          Wie kann ich den Zähler (manuell) dauerhaft korrigieren, ohne dass er wieder zurückspringt?
                            crunchip Forum Testing Most Active @MassiveAttack last edited by
                            @massiveattack https://github.com/DrozmotiX/ioBroker.sourceanalytix#Troubleshooting
                            MassiveAttack 1 Reply Last reply Reply Quote 0
                              Kanumouse @Dutchman last edited by
                              @dutchman
                              folgend ein Log-Auszug beim Start von sourceanalytixs.
                              2021-03-24 17:50:37.376  - info: host.raspberrypi "system.adapter.sourceanalytix.0" enabled
                              2021-03-24 17:50:37.660  - info: host.raspberrypi instance system.adapter.sourceanalytix.0 started with pid 8419
                              2021-03-24 17:50:39.778  - info: sourceanalytix.0 (8419) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                              2021-03-24 17:50:39.795  - info: sourceanalytix.0 (8419) starting. Version 0.4.8 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.20.2, js-controller: 3.2.16
                              2021-03-24 17:50:39.834  - info: sourceanalytix.0 (8419) Welcome to SourceAnalytix, making things ready ...
                              2021-03-24 17:50:40.041  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (26.971700000000002) > known cumulative value (0) cannot proceed
                              2021-03-24 17:50:40.042  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"name":"Waschmaschine - Messwert.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","custom":{"sourceanalytix.0":{"enabled":true,"alias":"Waschmaschine","selectedPrice":"ElectricityDay","selectedUnit":"Wh","costs":true,"consumption":true,"meter_values":true,"start_day":26.9708,"start_week":26.9708,"start_month":26.9708,"start_quarter":26.9708,"start_year":26.9708,"valueAtDeviceReset":26.971700000000002,"valueAtDeviceInit":26.971699982}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1614760566301,"_id":"hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                              2021-03-24 17:50:40.104  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (19.559799994) > known cumulative value (0) cannot proceed
                              2021-03-24 17:50:40.105  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"name":"Schaltaktor_Kühlschrank:2.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","custom":{"sourceanalytix.0":{"enabled":true,"alias":"Kühlschrank","selectedPrice":"ElectricityDay","selectedUnit":"Wh","costs":false,"consumption":true,"meter_values":true,"start_day":15.3953,"start_week":15.3953,"start_month":15.3953,"start_quarter":15.3953,"start_year":15.3953,"valueAtDeviceReset":19.559799994,"valueAtDeviceInit":0}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1614866892101,"_id":"hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                              2021-03-24 17:50:40.136  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.REQ0777411.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (44.8956) > known cumulative value (0) cannot proceed
                              2021-03-24 17:50:40.137  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.REQ0777411.2.ENERGY_COUNTER custom Data : {"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1614760566236,"common":{"name":"Messung Solaranlage.ENERGY_COUNTER","type":"number","unit":"Wh","def":0,"min":0,"read":true,"write":false,"custom":{"history.0":{"enabled":true,"changesOnly":true,"debounce":"1000","maxLength":"960","retention":"31536000","changesRelogInterval":0,"changesMinDelta":0,"aliasId":""},"sourceanalytix.0":{"enabled":true,"alias":"","selectedPrice":"ElectricityDelivery","selectedUnit":"Wh","costs":false,"consumption":false,"meter_values":true,"start_day":44.5368,"start_week":44.5368,"start_month":44.5368,"start_quarter":44.5368,"start_year":44.5368,"valueAtDeviceReset":44.8956,"valueAtDeviceInit":44.895599976}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","ID":"ENERGY_COUNTER","TYPE":"FLOAT","UNIT":"Wh","DEFAULT":0,"FLAGS":1,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0},"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator","state":1636},"_id":"hm-rpc.1.REQ0777411.2.ENERGY_COUNTER","type":"state"}
                              2021-03-24 17:50:45.175  - info: sourceanalytix.0 (8419) Initialization (1 of 9) finished for : ebus.0.bai.messages.Yield.fields.energy.value
                              2021-03-24 17:50:45.176  - info: sourceanalytix.0 (8419) Initialising (2 of 9) state hm-rega.0.47153
                              2021-03-24 17:50:49.434  - info: sourceanalytix.0 (8419) Initialization (2 of 9) finished for : hm-rega.0.47153
                              2021-03-24 17:50:49.435  - info: sourceanalytix.0 (8419) Initialising (3 of 9) state hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.435  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.436  - info: sourceanalytix.0 (8419) Initialization (3 of 9) finished for : hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.436  - info: sourceanalytix.0 (8419) Initialising (4 of 9) state hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.436  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.437  - info: sourceanalytix.0 (8419) Initialization (4 of 9) finished for : hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.437  - info: sourceanalytix.0 (8419) Initialising (5 of 9) state hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.437  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.438  - info: sourceanalytix.0 (8419) Initialization (5 of 9) finished for : hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
                              2021-03-24 17:50:49.438  - info: sourceanalytix.0 (8419) Initialising (6 of 9) state hm-rpc.1.PEQ0543850.1.IEC_ENERGY_COUNTER
                              2021-03-24 17:50:51.593  - info: sourceanalytix.0 (8419) Initialization (6 of 9) finished for : hm-rpc.1.PEQ0543850.1.IEC_ENERGY_COUNTER
                              2021-03-24 17:50:51.593  - info: sourceanalytix.0 (8419) Initialising (7 of 9) state hm-rpc.1.PEQ0543850.1.IEC_POWER
                              2021-03-24 17:50:53.010  - info: sourceanalytix.0 (8419) Initialization (7 of 9) finished for : hm-rpc.1.PEQ0543850.1.IEC_POWER
                              2021-03-24 17:50:53.010  - info: sourceanalytix.0 (8419) Initialising (8 of 9) state hm-rpc.1.PEQ0543850.2.IEC_ENERGY_COUNTER
                              2021-03-24 17:50:55.401  - info: sourceanalytix.0 (8419) Initialization (8 of 9) finished for : hm-rpc.1.PEQ0543850.2.IEC_ENERGY_COUNTER
                              2021-03-24 17:50:55.402  - info: sourceanalytix.0 (8419) Initialising (9 of 9) state hm-rpc.1.PEQ0543850.2.IEC_POWER
                              2021-03-24 17:50:56.453  - info: sourceanalytix.0 (8419) Initialization (9 of 9) finished for : hm-rpc.1.PEQ0543850.2.IEC_POWER
                              2021-03-24 17:50:56.462  - info: sourceanalytix.0 (8419) SourceAnalytix initialisation finalized, will handle calculations ... for 9 states
                              • Dutchman
                                na dan behebe mal die 3 Fehler (Check settings for)
                                  @dutchman
                                  Das ist mir schon klar, dass da die Fehler liegen. Ich weß aber nicht, wie diese zustande kommen.
                                  Ich habe den Adapter auch schon gelöscht und wieder neu installiert und die Startwerte neu eingetragen, aber die Fehler bleiben.
                                  Was mich gewundert hat, dass nach der Neuinstallation immer noch die alten Datenpunkte bekannt waren, obwohl ich diese auch gelöscht hatte. Sind da vielleicht irgendwo (/opt/iobroker/iobroker-data) einige Dateien nicht gelöscht worden?
                                  • MassiveAttack
                                    MassiveAttack @crunchip last edited by
                                    Hat leider nicht funktioniert! Habe den cumulated value (=Gesamtwert) korrigiert, und die Startwerte ebenfalls. Beim Starten des Adapters wurde wieder alles überschrieben...
                                    Wie kann das Überschreiben verhindern?
                                      crunchip Forum Testing Most Active @Kanumouse last edited by
                                      So viel ich weiss, gibt es Probleme, wenn man bereits angelegte Datenpunkte löschen möchte, warum auch immer. Einen Workaround findest du hier
                                        crunchip Forum Testing Most Active @MassiveAttack last edited by crunchip
                                        @massiveattack hast du den Punkt Expertenmodus beachtet?
                                        Les mal hier nochmal
                                        • MassiveAttack
                                          ja, ich bin dem troubleshooting gefolgt ==> Issue 9 My calculations are incorrect
                                          Mein Szenario:
                                          Ich berechne vom Gesamtwert die "Tages/Monats/...-werte. "Cumulative reading" soll eben diesem Gesamtwert = Source gleich sein, richtig?
                                          Dann noch die Startwerte korrigiert. Nachdem der Adapter wieder neu gestartet hat, wurden die Werte wieder (falsch" überschrieben...
                                            @massiveattack wenn du es so machst, wie in meinem Link gerade eben, sollte es funktionieren
                                            Also ab ....danach im Reiter Objekte auf Experten Modus, schalten, deinen....
                                            2302
                                            1138280
