    4. [gelöst] BLE Adapter läuft nicht
    SOLVED [gelöst] BLE Adapter läuft nicht
    • AlCalzone
      AlCalzone Developer @rotamint last edited by
      @rotamint Das poweredOff ist das Problem.
      sudo hciconfig hci0 up
        Dragon last edited by
        curl -sL https://iobroker.net/fix.sh | bash -
        hilft bei mir immer wunder!
          rotamint @AlCalzone last edited by
          @AlCalzone said in [gelöst] BLE Adapter läuft nicht:
          Danke! 🙂
            rotamint last edited by rotamint
            @rotamint Hallo zusammen, ich bitte erneut um Hilfe zum BLE Adapter....
            code_tepi@raspberrypi:~ $ sudo hciconfig hci0 up
            Can't get device info: No such device
            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which n        pm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v14.16.0
            /usr/bin/node
            v14.16.0
            /usr/bin/npm
            6.14.11
            nodejs:
              Installed: 14.16.0-1nodesource1
              Candidate: 14.16.0-1nodesource1
              Version table:
             *** 14.16.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
            Der Adapter schreibt "connection = false, driverState = unknown"
            pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo systemctl status bluetooth.service
            -bash: pi@raspberrypi:~: command not found
               Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
               Active: inactive (dead)
                 Docs: man:bluetoothd(8)
            pi@raspberrypi:~ $ sudo systemctl enable bluetooth.service
            Synchronizing state of bluetooth.service with SysV service script with /lib/systemd/systemd-sysv-install.
            Executing: /lib/systemd/systemd-sysv-install enable bluetooth
            pi@raspberrypi:~ $ sudo systemctl start bluetooth.service
            ● bluetooth.service - Bluetooth service
               Active: active (running) since Wed 2021-03-24 17:47:46 CET; 15s ago
             Main PID: 27375 (bluetoothd)
               Status: "Running"
            pi@raspberrypi:~ $ ● bluetooth.service - Bluetooth service
                Tasks: 1 (limit: 3858)
               CGroup: /system.slice/bluetooth.service
                       └─27375 /usr/lib/bluetooth/bluetoothd
            Mar 24 17:47:46 raspberrypi systemd[1]: Starting Bluetooth service...
            Mar 24 17:47:46 raspberrypi bluetoothd[27375]: Bluetooth daemon 5.50
            Mar 24 17:47:46 raspberrypi systemd[1]: Started Bluetooth service.
            Mar 24 17:47:46 raspberrypi bluetoothd[27375]: Starting SDP server
            Mar 24 17:47:46 raspberrypi bluetoothd[27375]: Bluetooth management interface 1.18 initialized
            Danke für die Unterstützung!
            Stefan.
              Thomas Braun Most Active @rotamint last edited by Thomas Braun
              @rotamint
              Das ist das interne Bluetooth des Pi?
              Hau mal prophylaktisch den Fixer drüber:
              iobroker stop
              iobroker fix
              iobroker start
                rotamint @Thomas Braun last edited by
                @thomas-braun Hallo Thomas, danke für Deinen Hinweis. Hat aber nichts gebracht, den Fixer hatte ich schon ausgeführt.
                Mir scheint es eher so, als ob das on-board-bluetooth nicht aktiv ist ?!?
                pi@raspberrypi:~ $ hcitool dev
                Devices:
                pi@raspberrypi:~ $
                Jemand eine andere Idee? Dankeschön! Stefan.
                  crunchip Forum Testing Most Active @rotamint last edited by crunchip
                  @rotamint hab zwar keinen PI laufen, aber bei meinem Zotac kommt es hin und wieder vor, wenn ich meine VM(Proxmox) neu starte, das bluetooth nicht mehr läuft, abhilfe, das ich ihn kurz mal vom Strom nehmen muss.( Interne Spannungsprobleme mit dem Bluetoothboard.
                  Vllt bringt es etwas wenn du deinen Pi mal runter fährst und 20 sec vom Strom trennst.
                    rotamint @crunchip last edited by
                    @crunchip Danke. Hat nicht geholfen...
                    pi@raspberrypi:~ $ sudo hciconfig hci0 version
                    pi@raspberrypi:~ $
                      @rotamint
                      Ist Bluetooth aktiv in raspi-config? Ich meine mich erinnern zu können das es dazu einen Eintrag dort gibt.
                        @thomas-braun Hallo Thomas, ich denke / vermute der Bluetooth-Adapter ist nicht aktiviert. In der Raspi-config finde ich dazu nichts...
                          @rotamint
                          Hast recht, da hatte ich mich getäuscht.
                            Danke für Deine geduldige Hilfestellung, eine Neuinstallation hat's wieder fein gemacht 🙂
                            Frohe Ostertage.
                            Danke. Stefan.
                            ble bluetooth
                            2880
