    4. Test Adapter enigma2 v1.2.x
    • Matten Matten
      Matten Matten @Jan1 last edited by
      @Jan1 sagte in Test Adapter enigma2 v1.2.x:
      Der Adapter läuft leider nicht mehr mit dem neuen JS-Controller 3.2.3 und bringt Fehler:
      2021-01-09 13:18:47.837 - info: host.Beelink "system.adapter.enigma2.0" disabled
      2021-01-09 13:19:03.296 - info: host.Beelink "system.adapter.enigma2.0" enabled
      2021-01-09 13:19:03.363 - info: host.Beelink instance system.adapter.enigma2.0 started with pid 1556694
      2021-01-09 13:19:05.000 - info: enigma2.0 (1556694) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.15.4, js-controller: 3.2.3
      2021-01-09 13:19:05.031 - info: enigma2.0 (1556694) starting Polling every 5000 ms
      2021-01-09 13:19:05.075 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.076 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Error: Not exists
      at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2270:17)
      at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3010:38)
      at processImmediate (internal/timers.js:463:21)
      2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.104 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.106 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.108 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.110 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.619 - info: enigma2.0 (1556694) terminating
      2021-01-09 13:19:05.621 - warn: enigma2.0 (1556694) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-01-09 13:19:06.260 - error: host.Beelink instance system.adapter.enigma2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-01-09 13:19:06.262 - info: host.Beelink Restart adapter system.adapter.enigma2.0 because enabled
      "fixed with js-controller 3.2.4" hat Apollon geantwortet.
      Matten Matten
        Jan1 @Matten Matten last edited by
        @Matten-Matten
        Ja läuft wieder 😉
          @Matten-Matten
          bleibt für Dich noch dieses kleine Problemchen 😉
          enigma2.0	2021-01-10 11:38:36.473	warn	(2002513) State "enigma2.0.Message.MESSAGE_ANSWER" has no existing object, this might lead to an error in future versions
          enigma2.0	2021-01-10 11:38:36.471	warn	(2002513) State "enigma2.0.enigma2.CHANNEL_PICON" has no existing object, this might lead to an error in future versions
            Termina last edited by
            Thema Videowiedergabe
            Gibt es eine Möglichkeit Informationen zu erhalten, wenn die Box ein Video abspielt? Das normale TV-Programm kann man ja mittlerweile super auch in der VIS abbilden - wäre bei Filmen doch auch super, oder?
            A SBorg 2 Replies Last reply Reply Quote 0
              aleks-83 @Termina last edited by aleks-83
              @termina
              Geht das Ganze nicht über die "EVENT..." Datenpunkte? (EVENT_PROGRESS_PERCENT, EVENTREMAINING_MIN...)
              Kann man mit dem Adapter eigentlich irgendwie das Display einer Enigma2 Box dimmen?
              Speziell einer VU+ Duo2?
              • SBorg
                SBorg Forum Testing Most Active @Termina last edited by
                @termina sagte in Test Adapter enigma2 v1.2.x:
                Ja, ich finde nur gerade nicht wie ich es genau gelöst habe. Ich lasse mir aber in der VIS das Sender-Picon anzeigen. Wenn ich ein Video abspiele wird dies dann durch ein "Festplatten"-Picon ersetzt.
                Soweit ich mich erinnere wird beim abspielen eines Videos die SID in etwa auf "0:0:0:0:0:0:0:0::" gesetzt, was ich mir dafür zu nutze mache, denn die wird nur da in der Art gesetzt.
                @aleks-83 IMHO nein, denn mir wäre aktuell kein Web-IF Befehl (und die nutzt der Adapter per API) bekannt der die Helligkeit dimmen könnte. Außer es gäbe einen Konsolen-Befehl dafür, dann könnte man den per SSH absetzen.
                  EVOlutionIX last edited by
                  Hallo alle zusammen, ich bin jetzt wirklich 424 Beiträge durch gegangen aber ich kann kaum verstehen wie es funktioniert einfach auf einen bestimmten Kanal zu wechseln.
                  Ich konnte es mir solala zusammen reimen wie ich den Kanal Wechsel über den Befehl Servicereference (woher bekommt man sie Servicereference einfacher ohne den Umweg DreamboxEDIT) ? Allerdings schaffe ich es nicht auf den stream meiner IP Kamera umzuschalten, der in der Senderliste gespeichert ist, wenn ich auf die Servicereference umschalte bekomme ich nur einen schwarzen Bildschirm?
                  Schönen Sonntag noch Gruß Marcus
                  • Negalein
                    Negalein Global Moderator @EVOlutionIX last edited by
                    @evolutionix sagte in Test Adapter enigma2 v1.2.x:
                    http://IP-deiner-Box/web/getallservices
                    Jens Meyer 1 Reply Last reply Reply Quote 0
                    • Jens Meyer
                      Jens Meyer @Negalein last edited by Jens Meyer
                      Hallo an alle hier...
                      Der Adapter funktioniert und bin gerade am probieren,
                      Mit was kann ich den die movielist anzeigen lassen? Mit einfach html gehts nicht, json geht so auch nicht
                      Was nehmt ihr dafür und gibts ne Möglichkeit ne epg Vorschau für mehrere Tage anzuzeigen und dann was nehme ich dann auch dafür? Ne Tabelle?
                      Danke schon mal
                      Meister Mopper Negalein 2 Replies Last reply Reply Quote 0
                      • Meister Mopper
                        Meister Mopper @Jens Meyer last edited by
                        @jens-meyer Du kannst das webif in einem View in vis anzeigen lassen und dort auch bedienen.
                        • Jens Meyer
                          Jens Meyer @Meister Mopper last edited by
                          @meister-mopper ja, das wollte ich eigentlich nicht.. das webif kann ich auch so aufrufen..
                          ich dachte es muss doch ne andere Möglichkeit geben das darzustellen
                          Aber danke
                          • Meister Mopper
                            @jens-meyer Dann musst Du ein eigenes webif bauen, das wäre mir zu viel 😧
                            • Jens Meyer
                              @meister-mopper
                              Nein ich will das ja nur in der vis darstellen...
                              Und der datenpunkt existiert ja
                              • Negalein
                                Negalein Global Moderator @Jens Meyer last edited by
                                @jens-meyer sagte in Test Adapter enigma2 v1.2.x:
                                schau mal hier
                                • Jens Meyer
                                  @negalein
                                  Danke, schau ich mir mal genauer an...
                                    west last edited by west
                                    Ist das der https://github.com/Matten-Matten/ioBroker.enigma2 oder zum Testen steht oder ein anderen?
                                    Habe selber eine VU+ Solo4K mit OpenATV 6.4.20210409
                                    • Glasfaser
                                      Glasfaser @west last edited by
                                      @west
                                      Ist der richtige Link.
                                        west @Glasfaser last edited by
                                        @glasfaser Ok
                                        Die Command werden mir nicht angezeigt.
                                        • Glasfaser
                                          @west
                                          Was heißt " command " fehlt.
                                          Fehlt der Ordner ... fehlen Datenpunkte .
                                          ioBroker Seite mal aktualisiert !?
                                            @glasfaser Hast recht😉
                                            adapter enigma2
                                            71
                                            640
                                            141719
