    4. [SourceAnalytix 0.4.8-Final] Released !
      crunchip Forum Testing Most Active @MassiveAttack last edited by
      @massiveattack https://github.com/DrozmotiX/ioBroker.sourceanalytix#Troubleshooting
      MassiveAttack 1 Reply Last reply Reply Quote 0
        Kanumouse @Dutchman last edited by
        @dutchman
        folgend ein Log-Auszug beim Start von sourceanalytixs.
        2021-03-24 17:50:37.376  - info: host.raspberrypi "system.adapter.sourceanalytix.0" enabled
        2021-03-24 17:50:37.660  - info: host.raspberrypi instance system.adapter.sourceanalytix.0 started with pid 8419
        2021-03-24 17:50:39.778  - info: sourceanalytix.0 (8419) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2021-03-24 17:50:39.795  - info: sourceanalytix.0 (8419) starting. Version 0.4.8 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.20.2, js-controller: 3.2.16
        2021-03-24 17:50:39.834  - info: sourceanalytix.0 (8419) Welcome to SourceAnalytix, making things ready ...
        2021-03-24 17:50:40.041  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (26.971700000000002) > known cumulative value (0) cannot proceed
        2021-03-24 17:50:40.042  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"name":"Waschmaschine - Messwert.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","custom":{"sourceanalytix.0":{"enabled":true,"alias":"Waschmaschine","selectedPrice":"ElectricityDay","selectedUnit":"Wh","costs":true,"consumption":true,"meter_values":true,"start_day":26.9708,"start_week":26.9708,"start_month":26.9708,"start_quarter":26.9708,"start_year":26.9708,"valueAtDeviceReset":26.971700000000002,"valueAtDeviceInit":26.971699982}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1614760566301,"_id":"hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2021-03-24 17:50:40.104  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (19.559799994) > known cumulative value (0) cannot proceed
        2021-03-24 17:50:40.105  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"name":"Schaltaktor_Kühlschrank:2.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","custom":{"sourceanalytix.0":{"enabled":true,"alias":"Kühlschrank","selectedPrice":"ElectricityDay","selectedUnit":"Wh","costs":false,"consumption":true,"meter_values":true,"start_day":15.3953,"start_week":15.3953,"start_month":15.3953,"start_quarter":15.3953,"start_year":15.3953,"valueAtDeviceReset":19.559799994,"valueAtDeviceInit":0}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1614866892101,"_id":"hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2021-03-24 17:50:40.136  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.REQ0777411.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (44.8956) > known cumulative value (0) cannot proceed
        2021-03-24 17:50:40.137  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.REQ0777411.2.ENERGY_COUNTER custom Data : {"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1614760566236,"common":{"name":"Messung Solaranlage.ENERGY_COUNTER","type":"number","unit":"Wh","def":0,"min":0,"read":true,"write":false,"custom":{"history.0":{"enabled":true,"changesOnly":true,"debounce":"1000","maxLength":"960","retention":"31536000","changesRelogInterval":0,"changesMinDelta":0,"aliasId":""},"sourceanalytix.0":{"enabled":true,"alias":"","selectedPrice":"ElectricityDelivery","selectedUnit":"Wh","costs":false,"consumption":false,"meter_values":true,"start_day":44.5368,"start_week":44.5368,"start_month":44.5368,"start_quarter":44.5368,"start_year":44.5368,"valueAtDeviceReset":44.8956,"valueAtDeviceInit":44.895599976}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","ID":"ENERGY_COUNTER","TYPE":"FLOAT","UNIT":"Wh","DEFAULT":0,"FLAGS":1,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0},"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator","state":1636},"_id":"hm-rpc.1.REQ0777411.2.ENERGY_COUNTER","type":"state"}
        2021-03-24 17:50:45.175  - info: sourceanalytix.0 (8419) Initialization (1 of 9) finished for : ebus.0.bai.messages.Yield.fields.energy.value
        2021-03-24 17:50:45.176  - info: sourceanalytix.0 (8419) Initialising (2 of 9) state hm-rega.0.47153
        2021-03-24 17:50:49.434  - info: sourceanalytix.0 (8419) Initialization (2 of 9) finished for : hm-rega.0.47153
        2021-03-24 17:50:49.435  - info: sourceanalytix.0 (8419) Initialising (3 of 9) state hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
        2021-03-24 17:50:49.435  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
        2021-03-24 17:50:49.436  - info: sourceanalytix.0 (8419) Initialization (3 of 9) finished for : hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
        2021-03-24 17:50:49.436  - info: sourceanalytix.0 (8419) Initialising (4 of 9) state hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
        2021-03-24 17:50:49.436  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
        2021-03-24 17:50:49.437  - info: sourceanalytix.0 (8419) Initialization (4 of 9) finished for : hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
        2021-03-24 17:50:49.437  - info: sourceanalytix.0 (8419) Initialising (5 of 9) state hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
        2021-03-24 17:50:49.437  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
        2021-03-24 17:50:49.438  - info: sourceanalytix.0 (8419) Initialization (5 of 9) finished for : hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
        2021-03-24 17:50:49.438  - info: sourceanalytix.0 (8419) Initialising (6 of 9) state hm-rpc.1.PEQ0543850.1.IEC_ENERGY_COUNTER
        2021-03-24 17:50:51.593  - info: sourceanalytix.0 (8419) Initialization (6 of 9) finished for : hm-rpc.1.PEQ0543850.1.IEC_ENERGY_COUNTER
        2021-03-24 17:50:51.593  - info: sourceanalytix.0 (8419) Initialising (7 of 9) state hm-rpc.1.PEQ0543850.1.IEC_POWER
        2021-03-24 17:50:53.010  - info: sourceanalytix.0 (8419) Initialization (7 of 9) finished for : hm-rpc.1.PEQ0543850.1.IEC_POWER
        2021-03-24 17:50:53.010  - info: sourceanalytix.0 (8419) Initialising (8 of 9) state hm-rpc.1.PEQ0543850.2.IEC_ENERGY_COUNTER
        2021-03-24 17:50:55.401  - info: sourceanalytix.0 (8419) Initialization (8 of 9) finished for : hm-rpc.1.PEQ0543850.2.IEC_ENERGY_COUNTER
        2021-03-24 17:50:55.402  - info: sourceanalytix.0 (8419) Initialising (9 of 9) state hm-rpc.1.PEQ0543850.2.IEC_POWER
        2021-03-24 17:50:56.453  - info: sourceanalytix.0 (8419) Initialization (9 of 9) finished for : hm-rpc.1.PEQ0543850.2.IEC_POWER
        2021-03-24 17:50:56.462  - info: sourceanalytix.0 (8419) SourceAnalytix initialisation finalized, will handle calculations ... for 9 states
        • Dutchman
          Dutchman Developer Most Active Administrators @Kanumouse last edited by
          @kanumouse sagte in [SourceAnalytix 0.4.8-Final] Released !:
          na dan behebe mal die 3 Fehler (Check settings for)
            @dutchman
            Das ist mir schon klar, dass da die Fehler liegen. Ich weß aber nicht, wie diese zustande kommen.
            Ich habe den Adapter auch schon gelöscht und wieder neu installiert und die Startwerte neu eingetragen, aber die Fehler bleiben.
            Was mich gewundert hat, dass nach der Neuinstallation immer noch die alten Datenpunkte bekannt waren, obwohl ich diese auch gelöscht hatte. Sind da vielleicht irgendwo (/opt/iobroker/iobroker-data) einige Dateien nicht gelöscht worden?
            • MassiveAttack
              MassiveAttack @crunchip last edited by
              @crunchip said in [SourceAnalytix 0.4.8-Final] Released !:
              Hat leider nicht funktioniert! Habe den cumulated value (=Gesamtwert) korrigiert, und die Startwerte ebenfalls. Beim Starten des Adapters wurde wieder alles überschrieben...
              Wie kann das Überschreiben verhindern?
                crunchip Forum Testing Most Active @Kanumouse last edited by
                So viel ich weiss, gibt es Probleme, wenn man bereits angelegte Datenpunkte löschen möchte, warum auch immer. Einen Workaround findest du hier
                  crunchip Forum Testing Most Active @MassiveAttack last edited by crunchip
                  @massiveattack hast du den Punkt Expertenmodus beachtet?
                  Les mal hier nochmal
                  • MassiveAttack
                    ja, ich bin dem troubleshooting gefolgt ==> Issue 9 My calculations are incorrect
                    Mein Szenario:
                    Ich berechne vom Gesamtwert die "Tages/Monats/...-werte. "Cumulative reading" soll eben diesem Gesamtwert = Source gleich sein, richtig?
                    Dann noch die Startwerte korrigiert. Nachdem der Adapter wieder neu gestartet hat, wurden die Werte wieder (falsch" überschrieben...
                      @massiveattack wenn du es so machst, wie in meinem Link gerade eben, sollte es funktionieren
                      Also ab ....danach im Reiter Objekte auf Experten Modus, schalten, deinen....
                      • MassiveAttack
                        Danke, das hat tatsächlich funktioniert 👏 😊
                          Kanumouse @crunchip last edited by
                          @crunchip
                          Vielen Dank für den Hinweis, der zur Lösung geführt hat. Nach dem Löschen und Neuanlegen der Datenpunkte in der beschriebenen Art und Weise habe ich keine Fehlermeldungen mehr.
                          • hg6806
                            hg6806 Most Active last edited by
                            So, bei mir läuft es jetzt auch relativ stabil.
                            Das kurze Rückwärtszählen der Solarthermie-Werte habe ich mit einem Blockly abgefangen.
                            Gelegentlich muss ich noch bei einem Datenpunkt die Werte korrigieren. Das kommt, glaube ich, von einem Neustart ohne Sourceanalytix vorher zu stoppen, da kann es sein, dass mal "komische" Werte geschrieben werden. Das kann aber mit dem hier beschriebenen Workaround gefixt werden.
                            Wird das in dem Adapter eigentlich noch verbessert? Vor der Neustrukturierung hatte ich nie Probleme damit.
                            Dann warte ich noch sehnsüchtig nach der geplanten Funktion "add object states for previous [x]day, [x]week, [x]month, [x]quarter, [x]year configurable in adapter settings".
                            Ich muss hier immer wöchentlich und monatlich die Werte für VIS umorganisieren.
                            • qqolli
                              qqolli @Dutchman last edited by
                              @dutchman
                              ich habe gerade Deinen Adapter installiert. Er wird auch grün, aber ich habe das Problem, das er nicht viel anzeigt womit man etwas anfangen kann:
                              Mehr kann ich da nicht einstellen und außerdem taucht er nicht in den Objekten auf.
                              Frage: Was ist noch zu tun, damit er "richtig" funktioniert?
                              Frage: Was bedeutet in den "Price definitions" "Preis/Monat"? Abschlag pro Monat bei z. B. Wasser und Strom?
                                crunchip Forum Testing Most Active @qqolli last edited by
                                @qqolli sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                das sind auch nur die Grundeinstellungen, der Rest wird beim entsprechenden Datenpunkt(dein gesamtZähler rechts auf den Schraubenschlüssel, SA auswählen), angelegt.
                                das ist für deinen Grundpreis/Gebühr gedacht, ist glaub ich, noch nicht aktiv
                                qqolli 1 Reply Last reply Reply Quote 1
                                • qqolli
                                  qqolli @crunchip last edited by
                                  @crunchip
                                  Danke für die schnelle Antwort. Dann kann ich ja endlich loslegen 🙂
                                  • Xsev
                                    Xsev last edited by
                                    Moing,
                                    ich hab heute morgen den JS Adapter aktualisiert (5.1.3) jetzt hab ich plötzlich -2800kwh für heute, dadurch stimmen natürlich die restlichen Werte (Woche, Monat) auch nicht mehr. Ich hab schon versucht in den Objekten die negativen Werte zu entfernen aber leider werden die sofort wieder zurück gesetzt. Was kann ich da machen?
                                      crunchip Forum Testing Most Active @Xsev last edited by
                                      @xsev https://forum.iobroker.net/post/575930
                                      Xsev 1 Reply Last reply Reply Quote 0
                                      • Xsev
                                        Xsev @crunchip last edited by
                                        @crunchip Danke habs über Git drüber installiert und den Wert auf 0 gesetzt im Expertenmodus allerdings fehlen mir jetzt die 3 Zeilen im Datenpunkt, bzw. 2 Zeilen siehe hier (valueAtDeviceReset": 0 gibts)
                                          "type": "state",
                                          "common": {
                                            "name": "Total Instantaneous power",
                                            "type": "number",
                                            "role": "value.power",
                                            "read": true,
                                            "write": false,
                                            "def": 0,
                                            "unit": "W",
                                            "custom": {
                                              "sql.0": {
                                                "enabled": true,
                                                "changesOnly": true,
                                                "debounce": "1000",
                                                "retention": "31536000",
                                                "changesRelogInterval": 0,
                                                "changesMinDelta": 0,
                                                "storageType": "",
                                                "aliasId": "",
                                                "counter": false
                                              "sourceanalytix.0": {
                                                "enabled": true,
                                                "alias": "",
                                                "selectedPrice": "ElectricityDay",
                                                "selectedUnit": "automatisch",
                                                "costs": true,
                                                "consumption": true,
                                                "meter_values": true,
                                                "start_day": 3278,
                                                "start_week": 3278,
                                                "start_month": 2883,
                                                "start_quarter": 2883,
                                                "start_year": 1281,
                                                "currentValue": 3277.9090823635834,
                                                "valueAtDeviceReset": 0
                                          "native": {},
                                          "from": "system.adapter.shelly.0",
                                          "user": "system.user.admin",
                                          "ts": 1619415910906,
                                          "_id": "shelly.0.SHEM-3#D8BFC01A81E4#1.Total.InstantPower",
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                            "owner": "system.user.admin",
                                          crunchip Forum Testing Most Active @Xsev last edited by crunchip
                                          @xsev instllieren wäre nicht nötig gewesen, nur das darunter, wie man die Werte wieder auf Stand bringt.
                                          Die Werte werden automatisch wieder angelegt.
                                          kannst auch HIER schauen, da ist es mit screens erklärt
                                          Xsev 1 Reply Last reply Reply Quote 1
                                          • Xsev
                                            Xsev @crunchip last edited by Xsev
                                            @crunchip Danke habs hin bekommen!!
                                            2302
                                            1138226
