    4. Iobroker backitup error.. Wo liegt das problem
    • Fred Freund
      Fred Freund @Thomas Braun last edited by
      pi@broker1:~ $ cat /etc/passwd | grep iobroker
      iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
      Raspi! Aber am Nas gibt's den smb User für den share!
        Thomas Braun Most Active @Fred Freund last edited by
        @fred-freund Aber der hat da eine andere UID.
        Fred Freund 1 Reply Last reply Reply Quote 0
        • Fred Freund
          Fred Freund @Thomas Braun last edited by Fred Freund
          Auszug ist oben!
          Nein abgeschossen hab ich den Vorgang nicht..
          Werd mal Nas wegnehmen und schauen was er lokal macht... Oder macht er das trotzdem?
          Braucht man das Javascript bkup?
          Auch Ohne Javascript..
          DEBUG] [iobroker] - host.broker1 1570 objects saved
          [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_23-23_09_27_backupiobroker.tar.gz'
          [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
          [DEBUG] [iobroker] - done
          [DEBUG] [influxDB] - Start InfluxDB Backup ...
          [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
          [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
          [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_03_23-23_09_32_backupiobroker"
          backup: open temp file: open /opt/iobroker/backups/influxDB_2021_03_23-23_09_32_backupiobroker/meta.00.pending: permission denied
          • simatec
            simatec Developer Most Active @Fred Freund last edited by
            @fred-freund Versuche mal bitte die Version 2.1.0
            Fred Freund 1 Reply Last reply Reply Quote 1
            • Fred Freund
              Fred Freund @simatec last edited by
              @simatec
              DEBUG] [iobroker] - host.broker1 1195 states saved
              [DEBUG] [iobroker] - host.broker1 1570 objects saved
              [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz'
              [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1,zigbee.2
              [DEBUG] [zigbee] - done
              [ERROR] [zigbee] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz'
              [DEBUG] [cifs] - Copy iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz...
              [DEBUG] [cifs] - Copy zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz...
              [DEBUG] [cifs] - Copy zigbee.1_2021_03_24-22_46_03_backupiobroker.tar.gz...
              [DEBUG] [cifs] - Copy zigbee.2_2021_03_24-22_46_03_backupiobroker.tar.gz...
              [DEBUG] [cifs] - done
              [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/home/iobroker","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
              [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
              [DEBUG] [clean] - done
              [DEBUG] [historyHTML] - new history html values created
              [DEBUG] [historyHTML] - done
              [DEBUG] [historyJSON] - new history json values created
              [DEBUG] [historyJSON] - done
              [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,
              Das Backup hat wieder Größe 0
              Der Ordner am smb share
              drwxrwxrwx  3 1000 1000      4096 Mär 24 22:46 iobroker
              rw-r--r--  1 1000 1000       0 Mär 24 22:39 zigbee.1_2021_03_24-22_39_23_backupiobroker.tar.gz
              • simatec
                @fred-freund
                Dann hast du ein Rechteproblem.
                Hast du iobroker fix bereits ausgeführt?
                • Fred Freund
                  Fred Freund @simatec last edited by Fred Freund
                  @simatec
                  Ja gestern 2x
                  Mach ich jetzt auch nochmal... Je nachdem welche smb Version ich verwende ändert sich auch die Error Meldung..
                  2021-03-24 23:00:26.538  - error: backitup.0 (27502) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                  Smb 3.1.1
                  Fix hat nix gebracht... 😞
                  • simatec
                    @fred-freund
                    Bitte vollständigen Log posten
                    • Fred Freund
                      @simatec
                      2021-03-25 20:58:44.655  - warn: backitup.0 (29557) backup error: TypeError: Converting circular structure to JSON
                         --> starting at object with constructor 'DerivedLogger'
                         |     property '_readableState' -> object with constructor 'ReadableState'
                         |     property 'pipes' -> object with constructor 'Array'    |     index 0 -> object with constructor 'DailyRotateFile'
                         --- property 'parent' closes the circle ... please check your config and try again!!
                      2021-03-25 20:58:50.903  - warn: zigbee.0 (29458) Device '0x5c0272fffe895fc7' announced itself
                      2021-03-25 21:00:15.356  - warn: backitup.0 (29557) backup error: TypeError: Converting circular structure to JSON
                      2021-03-25 21:01:50.628  - info: host.broker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                      2021-03-25 21:01:50.640  - info: backitup.0 (29557) Got terminate signal TERMINATE_YOURSELF
                      2021-03-25 21:01:50.645  - info: host.broker1 stopInstance system.adapter.backitup.0 send kill signal
                      2021-03-25 21:01:50.642  - info: backitup.0 (29557) cleaned everything up...
                      2021-03-25 21:01:50.643  - info: backitup.0 (29557) terminating
                      2021-03-25 21:01:50.645  - info: backitup.0 (29557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2021-03-25 21:01:51.256  - info: host.broker1 instance system.adapter.backitup.0 terminated with cpi@broker1:~ $ cat /opt/iobroker/log/iobroker.current.log
                         --> starting at object with constructor 'DerivedLogger'                                           |     property '_readableState' -> object with constructor 'ReadableState'
                      2021-03-25 21:01:51.256  - info: host.broker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2021-03-25 21:01:53.710  - info: host.broker1 instance system.adapter.backitup.0 started with pid 8864
                      2021-03-25 21:01:57.240  - info: backitup.0 (8864) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
                      2021-03-25 21:01:57.340  - info: backitup.0 (8864) [iobroker] backup was activated at 02:40 every 1 day(s)
                      pi@broker1:~ $
                      Smb 1.0
                      • simatec
                        @fred-freund
                        Dein System scheint mächtig in Schieflage zu sein.
                        Was passiert denn, wenn du iobroker backup über die Konsole ausführst?
                        Hast du Backitup mal komplett deinstalliert (Instanz und Adapter)? Wenn nicht, mach das mal bitte und installiere in Anschluss neu.
                        Hoffe du hast npm nirgends mit sudo ausgeführt.
                        Dein System wirft sehr komische Dinge im Log
                        • Fred Freund
                          @simatec said in Iobroker backitup error.. Wo liegt das problem:
                          pi@broker1:~ $ iobroker stop && iobroker backup && iobroker start
                          Backup created: /opt/iobroker/backups/2021_03_26-20_53_35_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001 3540091 Mar 26 20:53 2021_03_26-20_53_35_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001   87112 Mar 26 02:00 zigbee.0_2021_03_26-02_00_27_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001    1655 Mar 26 02:00 zigbee.1_2021_03_26-02_00_27_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001      87 Mar 26 02:00 zigbee.2_2021_03_26-02_00_27_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001 3540945 Mar 26 02:00 iobroker_2021_03_26-02_00_20_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001 3539146 Mar 25 21:23 2021_03_25-21_23_06_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001   86633 Mar 25 02:40 zigbee.0_2021_03_25-02_40_27_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001    1655 Mar 25 02:40 zigbee.1_2021_03_25-02_40_27_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001      87 Mar 25 02:40 zigbee.2_2021_03_25-02_40_27_backupiobroker.tar.gz
                          -rw-rw-r--+ 1 1001 1001 3524666 Mar 25 02:40 iobroker_2021_03_25-02_40_20_backupiobroker.tar.gz
                          ich suchte mal ob ich mit sudo was installierte, nix gefunden...
                          pi@broker1:~ $ history | grep npm
                            234  npm install node-red-contrib-schedex
                          history | grep curl
                             78  curl -slf https://deb.nodesource.com/setup_12.x | sudo -E bash -
                             80  curl -slf https://deb.nodesource.com/setup_14.x | sudo -E bash -
                             82  curl -sLF https://ipbroker.net/install.sh | bash -
                             83  curl -sLf https://ipbroker.net/install.sh | bash -
                             84  curl -sLf https://iobroker.net/install.sh | bash -
                          clean from the history
                             79  sudo apt-get install -y node.js
                             81  sudo apt-get install -y node.js
                             85  iobroker plugin disable sentry
                          Die um 02:40 sind die automatischen...ob die gehen? das share
                          Die manuell aus dem adapter gestarteten haben andere Rechte..ausserdem sieht es fuer mich so aus als wuerde das Backup gleich einige male gestartet!! siehe 23:07???
                          -rw-rwxr--+ 1 1001 1001 3519796 Mar 24 23:07 2021_03_24-20_46_07_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_24-20_33_43_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_24-20_34_57_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3519979 Mar 24 23:07 iobroker_2021_03_24-20_33_36_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3520465 Mar 24 23:07 iobroker_2021_03_24-20_34_50_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001   85264 Mar 24 23:07 zigbee.0_2021_03_24-20_34_58_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001    1667 Mar 24 23:07 zigbee.1_2021_03_24-20_34_58_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3339610 Mar 24 23:07 2021_03_09-21_18_54_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_23-19_58_42_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_23-20_04_52_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001     990 Mar 24 23:07 influxDB_2021_03_23-20_06_27_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001     989 Mar 24 23:07 influxDB_2021_03_23-20_31_52_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001     990 Mar 24 23:07 influxDB_2021_03_23-20_32_46_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3516990 Mar 24 23:07 iobroker_2021_03_23-19_58_36_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3517122 Mar 24 23:07 iobroker_2021_03_23-20_04_46_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3517072 Mar 24 23:07 iobroker_2021_03_23-20_06_20_Iobroker1_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3517129 Mar 24 23:07 iobroker_2021_03_23-20_31_45_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001 3517069 Mar 24 23:07 iobroker_2021_03_23-20_32_40_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001   83731 Mar 24 23:07 zigbee.0_2021_03_23-19_58_43_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001   83731 Mar 24 23:07 zigbee.0_2021_03_23-20_04_53_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001   83731 Mar 24 23:07 zigbee.0_2021_03_23-20_06_28_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001   83736 Mar 24 23:07 zigbee.0_2021_03_23-20_31_53_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001   83736 Mar 24 23:07 zigbee.0_2021_03_23-20_32_47_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-19_58_43_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_04_53_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_06_28_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_31_53_backupiobroker.tar.gz
                          -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_32_47_backupiobroker.tar.gz
                          Hier das share, dies sind alle leer
                          eigentlich kann ich ja ein script schreiben der das gemachte consolen backup dann auf den share kopiert...bzw dieses mit cron startet.
                          Sind die node red flows jetzt auch gebackupt?
                          • simatec
                            @fred-freund
                            Ehrlich gesagt, weiß ich nicht was du da genau machst. Irgendwas ist an deiner Config schief und die Rechte vom NAS sind auch wohl ein Problem. Des Weiteren sind deine Logs vom 24.3. und nicht die aktuellen. Du solltest die Rechte wie in meinem letzten Post mal anpassen und mal nur lokal das Backup fahren.
                            Sonst bekommen wir deine Probleme nicht eingedämmt. Dafür ist dein Input zu mau und die Fehler zu viel
                            • Fred Freund
                              Ich habe jetzt zum Backup folder einen direkten share erstellt im smb.
                              Jetzt funktioniert es! Bekomme ein Backup und keine Fehlermeldung mehr.
                              Warum bekomme ich zigbee. 0.. 1...2 backups obwohl ich nur zigbee.0 instance habe.
                              Und Node red ist das jetzt auch im Backup?
                              Danke!
                              • simatec
                                @fred-freund
                                Dann existieren bei dir diese 3 zigbee Unterordner
                                Auf meine Fragen habe ich noch immer keine Antwort bekommen.
                                Dementsprechend kann ich hier auch nicht weiterhelfen
                                • Fred Freund
                                  @simatec. Alles Gut!
                                  Started iobroker ...
                                  [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"}
                                  [DEBUG] [mount] - mount successfully completed
                                  [DEBUG] [mount] - done
                                  [DEBUG] [iobroker] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"backupDir":"/opt/iobroker/backups"}
                                  [DEBUG] [iobroker] - host.broker1 1195 states saved
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz
                                  [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz
                                  [DEBUG] [influxDB] - done
                                  [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                                  [DEBUG] [historyHTML] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.1_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.2_2021_03_27-07_24_52_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"],"types":["iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en","time":"27. March 2021 at 07:24 Hours"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"backupDir":"/opt/iobroker/backups"}
                                  [DEBUG] [umount] - mount activ, umount is started ...
                                  [DEBUG] [historyJSON] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.1_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.2_2021_03_27-07_24_52_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"],"types":["iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en","time":"27. March 2021 at 07:24 Hours"},"backupDir":"/opt/iobroker/backups"}
                                  [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups"}
                                  [DEBUG] [umount] - umount successfully completed
                                  [DEBUG] [umount] - done
                                  [EXIT] 0
                                  2021-03-27 07:24:31.466  - error: backitup.0 (746) umount: /opt/iobroker/backups: not mounted.
                                  Wo finde ich die zigbee Ordner?
                                  Und herzlichen Dank für deine Geduld.
                                  Humidor 1 Reply Last reply Reply Quote 0
                                  • Humidor
                                    Humidor @Fred Freund last edited by
                                    @fred-freund hi, hab auch das Thema gerade, nach Update geht er nicht mehr
                                    siehe meinen https://forum.iobroker.net/topic/43664/iobackup-log-meldung-und-fehler/4?_=1616921423478
                                    hab auf 2.0.4 downgegrades und es läuft wieder einwandfrei.
                                    wenn ich das richtig verfolgen kann dann startet er den mount nicht
                                    • simatec
                                      simatec Developer Most Active @Humidor last edited by
                                      @humidor
                                      Was genau geht denn nicht bei dir? Etwas mehr Input außer einen Schnipsel aus dem Log wäre gut
                                      • Humidor
                                        Humidor @simatec last edited by
                                        @simatec wo soll ich jetzt antworten, hier oder in meinem Thread 🤔
                                        • simatec
                                          @humidor Eigentlich gibt es einen Thread für Backitup
                                          Versuche mal die aktuelle Version 2.1.0 zu installieren und poste damit mal den Log
                                          • Humidor
                                            Humidor @simatec last edited by Humidor
                                            @simatec hab einen aus 2019 gefunden, das wirds wohl nich sein ?
                                            2.1.0
                                            manuelles Backup
                                            [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"}
                                            [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                            [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                            mount error(16): Device or resource busy
                                            Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                            [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                            [DEBUG] [iobroker] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                            [DEBUG] [iobroker] - host.raspi4iobrokerpv 2093 states saved
                                            [DEBUG] [iobroker] - host.raspi4iobrokerpv 2538 objects saved
                                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
                                            [DEBUG] [historyDB] - compress from historyDB started ...
                                            [DEBUG] [historyDB] - Packed 9MB so far...
                                            [DEBUG] [historyDB] - Packed 19MB so far...
                                            [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
                                            [DEBUG] [historyDB] - done
                                            [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                                            [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
                                            [DEBUG] [telegram] - done
                                            [DEBUG] [telegram] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                            [DEBUG] [historyHTML] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                            [DEBUG] [historyJSON] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                            [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups"}
                                            log
                                            backitup.0	2021-03-28 18:03:24.952	debug	(14449) system.adapter.admin.0: logging true
                                            backitup.0	2021-03-28 18:02:39.560	debug	(14449) [iobroker/historyJSON] done
                                            backitup.0	2021-03-28 18:02:39.559	debug	(14449) [iobroker/historyJSON] new history json values created
                                            backitup.0	2021-03-28 18:02:39.394	debug	(14449) [iobroker/historyHTML] done
                                            backitup.0	2021-03-28 18:02:39.392	debug	(14449) [iobroker/historyHTML] new history html values created
                                            backitup.0	2021-03-28 18:02:39.081	debug	(14449) [iobroker/telegram] done
                                            backitup.0	2021-03-28 18:02:39.079	debug	(14449) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                                            backitup.0	2021-03-28 18:02:39.065	debug	(14449) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                                            backitup.0	2021-03-28 18:02:38.602	debug	(14449) [iobroker/clean] done
                                            backitup.0	2021-03-28 18:02:38.600	debug	(14449) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                            backitup.0	2021-03-28 18:02:37.995	debug	(14449) [iobroker/cifs] done
                                            backitup.0	2021-03-28 18:02:36.935	debug	(14449) [iobroker/historyDB] done
                                            backitup.0	2021-03-28 18:02:36.909	debug	(14449) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:02:27.441	debug	(14449) [iobroker/historyDB] Packed 19MB so far...
                                            backitup.0	2021-03-28 18:02:17.442	debug	(14449) [iobroker/historyDB] Packed 9MB so far...
                                            backitup.0	2021-03-28 18:02:07.439	debug	(14449) [iobroker/historyDB] compress from historyDB started ...
                                            backitup.0	2021-03-28 18:02:06.682	debug	(14449) [iobroker/iobroker] done
                                            backitup.0	2021-03-28 18:02:05.589	debug	(14449) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:02:02.046	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2538 objects saved
                                            backitup.0	2021-03-28 18:02:02.019	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2093 states saved
                                            backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                            backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
                                            backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker
                                            backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                            backitup.0	2021-03-28 18:01:59.326	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
                                            backitup.0	2021-03-28 18:01:59.325	debug	(14449) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroke
                                            backitup.0	2021-03-28 18:01:59.238	debug	(14449) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                                            backitup.0	2021-03-28 18:01:55.647	debug	(14449) system.adapter.admin.0: logging false
                                            backitup.0	2021-03-28 18:01:49.159	debug	(14449) Backup has started ...
                                            backitup.0	2021-03-28 18:01:49.156	error	(14449) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                                            backitup.0	2021-03-28 18:01:47.336	debug	(14449) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
                                            backitup.0	2021-03-28 18:01:47.333	debug	(14449) telegram-instance: telegram.0
                                            backitup.0	2021-03-28 18:01:24.555	debug	(14449) Start all Adapter after Restore enabled
                                            backitup.0	2021-03-28 18:01:16.924	debug	(14449) detect last backup file: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.921	debug	(14449) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.920	debug	(14449) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.919	debug	(14449) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.918	debug	(14449) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.917	debug	(14449) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.916	debug	(14449) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.915	debug	(14449) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.913	debug	(14449) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
                                            backitup.0	2021-03-28 18:01:16.192	debug	(14449) system.adapter.admin.0: logging true
                                            backitup.0	2021-03-28 18:01:14.902	error	Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                            backitup.0	2021-03-28 18:01:14.902	error	mount error(16): Device or resource busy
                                            backitup.0	2021-03-28 18:01:14.902	error	(14449) Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                            backitup.0	2021-03-28 18:01:14.854	debug	(14449) first mount attempt with smb option failed. try next mount attempt without smb option ...
                                            backitup.0	2021-03-28 18:01:14.722	debug	(14449) [iobroker] 10 15 06 */1 * *
                                            backitup.0	2021-03-28 18:01:14.676	info	(14449) [iobroker] backup was activated at 06:15 every 1 day(s)
                                            backitup.0	2021-03-28 18:01:14.346	info	(14449) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
                                            wendy2702 crunchip simatec 3 Replies Last reply Reply Quote 0
                                            156
                                            19313
