    3. Entwicklung
    4. [Neuer Adapter] MeteoSchweiz
    • ice987
      ice987 @deMynchi last edited by
      @demynchi
      Vielen Dank für deine Mühe, einen neuen Wetter-Adapter für die Schweiz zu erstellen. Ich habe soeben versucht, diesen Adapter zu Installieren. Nun erhalte ich folgende Fehlermeldungen, starten der Instanz ist nicht möglich:
      host.iobroker-v510-testsystem	2021-03-22 15:53:30.877	info	"system.adapter.meteoswiss.0" disabled
      host.iobroker-v510-testsystem	2021-03-22 15:53:25.408	info	Restart adapter system.adapter.meteoswiss.0 because enabled
      host.iobroker-v510-testsystem	2021-03-22 15:53:25.407	error	instance system.adapter.meteoswiss.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      meteoswiss.0	2021-03-22 15:53:24.839	error	(3133) Exception-Code: SQLITE_MISUSE: SQLITE_MISUSE: Database is closed
      meteoswiss.0	2021-03-22 15:53:24.838	error	(3133) Error: SQLITE_MISUSE: Database is closed at /opt/iobroker/node_modules/sqlite/build/Database.js:64:21 at new Promise (<anonymous>) at Database.close (/opt/iobroker/node_modules/sqli
      meteoswiss.0	2021-03-22 15:53:24.835	error	(3133) unhandled promise rejection: SQLITE_MISUSE: Database is closed
      meteoswiss.0	2021-03-22 15:53:24.835	error	(3133) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      meteoswiss.0	2021-03-22 15:53:24.834	warn	(3133) Terminated (UNCAUGHT_EXCEPTION): Without reason
      meteoswiss.0	2021-03-22 15:53:24.833	info	(3133) terminating
      meteoswiss.0	2021-03-22 15:53:24.821	error	(3133) Exception-Code: ECONNREFUSED: connect ECONNREFUSED 127.0.0.1:80
      meteoswiss.0	2021-03-22 15:53:24.821	error	(3133) Error: connect ECONNREFUSED 127.0.0.1:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
      meteoswiss.0	2021-03-22 15:53:24.820	error	(3133) unhandled promise rejection: connect ECONNREFUSED 127.0.0.1:80
      meteoswiss.0	2021-03-22 15:53:24.819	error	(3133) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      meteoswiss.0	2021-03-22 15:53:24.515	info	(3133) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.meteoswiss, node: v12.21.0, js-controller: 3.2.16
      host.iobroker-v510-testsystem	2021-03-22 15:53:22.294	info	instance system.adapter.meteoswiss.0 started with pid 3133
      host.iobroker-v510-testsystem	2021-03-22 15:52:52.212	info	Restart adapter system.adapter.meteoswiss.0 because enabled
      host.iobroker-v510-testsystem	2021-03-22 15:52:52.211	error	instance system.adapter.meteoswiss.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      meteoswiss.0	2021-03-22 15:52:51.591	error	(3092) Exception-Code: SQLITE_MISUSE: SQLITE_MISUSE: Database is closed
      meteoswiss.0	2021-03-22 15:52:51.590	error	(3092) Error: SQLITE_MISUSE: Database is closed at /opt/iobroker/node_modules/sqlite/build/Database.js:64:21 at new Promise (<anonymous>) at Database.close (/opt/iobroker/node_modules/sqli
      meteoswiss.0	2021-03-22 15:52:51.588	error	(3092) unhandled promise rejection: SQLITE_MISUSE: Database is closed
      meteoswiss.0	2021-03-22 15:52:51.587	error	(3092) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      meteoswiss.0	2021-03-22 15:52:51.586	warn	(3092) Terminated (UNCAUGHT_EXCEPTION): Without reason
      meteoswiss.0	2021-03-22 15:52:51.585	info	(3092) terminating
      meteoswiss.0	2021-03-22 15:52:51.548	error	(3092) Exception-Code: ECONNREFUSED: connect ECONNREFUSED 127.0.0.1:80
      meteoswiss.0	2021-03-22 15:52:51.548	error	(3092) Error: connect ECONNREFUSED 127.0.0.1:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
      meteoswiss.0	2021-03-22 15:52:51.547	error	(3092) unhandled promise rejection: connect ECONNREFUSED 127.0.0.1:80
      meteoswiss.0	2021-03-22 15:52:51.547	error	(3092) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      meteoswiss.0	2021-03-22 15:52:51.195	info	(3092) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.meteoswiss, node: v12.21.0, js-controller: 3.2.16
      host.iobroker-v510-testsystem	2021-03-22 15:52:49.035	info	instance system.adapter.meteoswiss.0 started with pid 3092
      host.iobroker-v510-testsystem	2021-03-22 15:52:48.977	info	"system.adapter.meteoswiss.0" enabled
      konfigurieren ist ebenfalls nicht möglich. Es erscheint der folgende Fehler:
      Adapter must be running to configure it.
      System:
      Plattform: linux
      Node.js: v12.21.0
      NPM: 6.14.11
      js-controller: v3.2.16
      deMynchi 1 Reply Last reply Reply Quote 0
      • deMynchi
        deMynchi @ice987 last edited by
        @ice987 In der Version 0.1.2 ist das Problem behoben.
        Dann sollte der Adapter starten und sobald der läuft, funktioniert auch die Konfiguration.
        ice987 1 Reply Last reply Reply Quote 0
        • ice987
          @demynchi
          Installieren funktioniert 👍 ich lass alles nun mal etwas laufen 😳
            Andre R. last edited by
            Erstmal danke für den Adapter. Wäre es auch möglich die Gefahrenmeldungen und das Satellitenbild zu integrieren?
            Grüße Obi
              M240-Swiss @deMynchi last edited by
              @demynchi Ich werde den Adapter in den nächsten Tagen auch installieren 👍🏻
              • deMynchi
                deMynchi @Andre R. last edited by
                @andre-r said in [Neuer Adapter] MeteoSchweiz:
                Zu den Gefahrenmeldungen habe ich mir auch schon Gedanken gemacht. Ich weiss leider nicht recht, wie ich die aufbereiten soll. Ich kann nicht pro Gefahrenmeldung einen Datenpunkt machen, sonst muss ich ständig Datenpunkte löschen und neue erstellen und für eine vis wäre das auch nicht praktisch. Wie würdest du die Gefahrenmeldungen denn verwenden? Wenn wir eine gute Lösung finden, setze ich die gerne um.
                Was meinst du mit Satellitenbild? Meinst du das Niederschlagsradar oder gibt es in der App noch irgendwo ein Satellitenbild (habe ich noch nie gesehen)?
                Wenn du das Niederschlagsradar meinst, dann kannst du einfach alle 10 Minuten folgende URL herunterladen: https://s3-eu-central-1.amazonaws.com/app-prod-static-fra.meteoswiss-app.ch/v1/currentPrecipitationHomescreen.png. Das Bild sieht komisch aus, da es wirklich nur einen "Overlay" des Niederschlages zeigt. Darunter musst du eine Karte setzen - die von MeteoSchweiz ist leider nicht per URL verfügbar, aber swisstopo hat vor kurzem alle Daten veröffentlicht. Zudem musst du alles was Rot ist, ausblenden, denn das sind die Regionen, die vom Radar nicht abgedeckt werden.
                Ich werde im Adapter wohl keine Bild-Manipulationen machen, das ist mir zu kompliziert.
                • ice987
                  @demynchi
                  ich hab' den jetzt noch einmal installiert. Nun erhalte ich folgenden Fehler, direkt im Installationsfenster:
                  $ ./iobroker url "https://github.com/deMynchi/ioBroker.meteoswiss.git"
                  install deMynchi/ioBroker.meteoswiss#2baf382a6350311cff2367e6b67ba2a2471388a7
                  NPM version: 6.14.11
                  npm install deMynchi/ioBroker.meteoswiss#2baf382a6350311cff2367e6b67ba2a2471388a7 --loglevel error --prefix "/opt/iobroker" (System call)
                  sh: 1: node-pre-gyp: not found
                  npm ERR! code ELIFECYCLEnpm ERR! syscall spawnnpm ERR! file shnpm ERR! errno ENOENT
                  npm ERR! sqlite3@5.0.2 install: `node-pre-gyp install --fallback-to-build`npm ERR! spawn ENOENTnpm ERR! npm ERR! Failed at the sqlite3@5.0.2 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR! A complete log of this run can be found in:npm ERR!     /opt/iobroker/.npm/_logs/2021-03-23T14_36_54_238Z-debug.log
                  ERROR: host.iobroker-v510 Cannot install deMynchi/ioBroker.meteoswiss#2baf382a6350311cff2367e6b67ba2a2471388a7: 1
                  ERROR: process exited with code 25
                  UncleSam 1 Reply Last reply Reply Quote 0
                    @demynchi Adapter installiert, kann ihn jedoch nicht starten (fällt immer auf rot) und erhalte folgendes Log
                      Andre R. @deMynchi last edited by
                      @demynchi Ja ich meinte das Regenradar. Mit den Warnungen weiss ich auch nicht wie man das machen kann, die Seite stellt ja leider keinen RSS Feed zur Verfügung.
                      • UncleSam
                        UncleSam Developer @ice987 last edited by UncleSam
                        @ice987 Was für ein System hast du? Wie hast du Nodejs installieren? Welche Version hast du?
                        • UncleSam
                          UncleSam Developer @M240-Swiss last edited by UncleSam
                          @m240-swiss Kannst du aus deinem Netzwerk auf Meteo Schweiz oder den von @deMynchi angegebenen Link zugreifen?
                          • ice987
                            ice987 @UncleSam last edited by
                            @unclesam sagte in [Neuer Adapter] MeteoSchweiz:
                            interessanterweise ist es 2x das gleiche System, einmal "nackt" (da funktioniert es) und einmal mit verschiedenen installierten Adapter.
                            System (docker):
                            Plattform: linux
                            Node.js: v12.21.0
                            NPM: 6.14.11
                            • UncleSam
                              @ice987 Es scheint, dass dir gyp fehlt. Hast du ein aktuelles Docker Image von ioBroker oder buanet?
                              Zudem: ich würde dir empfehlen, von NPM zu installieren und nicht von GitHub, ich weiss nicht was der @deMynchi dort bastelt 😉
                                M240-Swiss @UncleSam last edited by M240-Swiss
                                @unclesam : nach dem ich deinen Link nicht öffnen konnte hat es „Klick“ gemacht 😊
                                Mein PiHole hat diese Adresse blockiert. PiHole angepasst und der Adapter ist grün.
                                Ich werde das ganze nun etwas beobachten und gerne dann Feedback geben.
                                • ice987
                                  ice987 @UncleSam last edited by ice987
                                  @unclesam
                                  Ich hab die Version v5.1.0 von Buanet. Ich erstell mal einen neuen Container...
                                  Edit:
                                  den Container habe ich neu aufgesetzt. Das Problem bleibt das gleiche. Ich denke, dies liegt aber nicht am Adapter, eher an meiner Installation...
                                  UncleSam ice987 2 Replies Last reply Reply Quote 0
                                  • UncleSam
                                    @ice987 Das klingt nach einem sehr Docker spezifischen Problem. Ich habe es bei mir auch in Docker am laufen und habe das nicht gesehen. Vielleicht kann @andre helfen?
                                    • andre
                                      andre Developer @UncleSam last edited by
                                      @unclesam Habe zufällig gerade einen frischen test container laufen. Github URL rein und installiert. Instanz angelegt. Läuft nicht, Konfiguration nicht möglich, konfig Seite lädt und lädt und lädt, Adapter gelb.
                                      Neustart der Instanz, Adapter wird grün, konfig möglich.
                                      Adapter konfiguriert PLZ 3000 / Wetterstation Bern, speichern, Daten werden gefüllt.
                                      In Bern scheint die Sonne und es sind 13,8 Grad...
                                      Soweit sehe ich erstmal kein generelles Problem im Docker Container (v5.1.0)...
                                      MfG,
                                      André
                                      • UncleSam
                                        UncleSam Developer @andre last edited by
                                        @andre Danke. Ja, bei mir ist es dasselbe (der Adapter muss scheinbar laufen, damit man ihn konfigurieren kann). Aber hast du den Fehler bezüglich node-pre-gyp bei der Installation eventuell schon einmal gesehen oder davon gehört? Siehe hier: https://forum.iobroker.net/post/603599
                                        • andre
                                          @unclesam Gesehen ja, aber ich bin leider kein Adapter Entwickler der sich mit NPM & co auskennt. 🙂
                                          Falls mir mal jemand erklären mag wie das mit npm, der Installation der npm-pakete und dem Einsatz von node-gyp bzw. node-pre-gyp funktioniert bin ich gerne bereit die Schulbank zu drücken...
                                          Seltsam ist allerdings, dass es bei mir im frischen Container keine Probleme diesbezüglich gibt. Frisch gestartete Container sollten ja eigentlich alle gleich sein...
                                          MfG,
                                          André
                                            @demynchi Habe den Adapter nun einige Tage in Betrieb. Soweit keine Fehler.
                                            Was mir aufgefallen ist:
                                            • ich habe zu Testzwecken zwei Orte in den Einstellungen eingetragen, auch wenn ich einen Ort wieder entfernt habe bleibt er in den Objekten weiterhin bestehen.
                                            • die Daten werden gemäss Log alle 3-10min aktualisiert. Kann dies so angepasst werden das man dies Zeit manuell eintragen kann?
                                            Gruss aus dem Wallis
                                            44
                                            4788
