    4. Test Adapter Somfy Tahoma v0.3.x GitHub
      pfahlenbauer @blackeagle998 last edited by
      @blackeagle998
      Ich habe nur Copy/Paste gemacht und die Einstellungen im Log Perser so gemacht wie in Deiner Anleitung:
      on({id:'logparser.0.filters.tahoma.jsonCount', change:'ne'}, function (dp) {
      if (dp.state.val >= 10){
      setState('logparser.0.filters.tahoma.emptyJson', true);
      restartTahomaAdapter();
      function restartTahomaAdapter(){
      let adapter_id = 'system.adapter.tahoma.0';
      var obj = getObject(adapter_id);
      if (obj.common.enabled){
          obj.common.enabled = false;  // Adapter ausschalten
           setObject(adapter_id, obj);
           log('Tahoma Instanz ausgeschaltet.', 'info');
       setTimeout(function(){
           obj.common.enabled = true;  // Adapter einschalten
           log('Tahoma Instanz wieder eingeschaltet.', 'info');
       },10000);
        blackeagle998 @pfahlenbauer last edited by
        @pfahlenbauer
        Hmm ich sehe da erstmal nichts problematisches.
        Kannst du noch die kompletten Log Fehler (alle und in code tags) posten?
          @blackeagle998
          Das sieht so aus:
          avascript.0	2021-03-25 23:12:18.353	error	(30416) at process.topLevelDomainCallback (domain.js:126:23)
          javascript.0	2021-03-25 23:12:18.353	error	(30416) at processImmediate (timers.js:658:5)
          javascript.0	2021-03-25 23:12:18.353	error	(30416) at tryOnImmediate (timers.js:676:5)
          javascript.0	2021-03-25 23:12:18.353	error	(30416) at runCallback (timers.js:706:11)
          javascript.0	2021-03-25 23:12:18.353	error	(30416) at Immediate.adapter.getForeignState [as _onImmediate] (/opt/iobroker/node_modules/iobroker.javascript/main.js:1281:17)
          javascript.0	2021-03-25 23:12:18.352	error	(30416) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1791:17)
          javascript.0	2021-03-25 23:12:18.352	error	(30416) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1690:37)
          javascript.0	2021-03-25 23:12:18.352	error	(30416) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1443:28)
          javascript.0	2021-03-25 23:12:18.352	error	(30416) at Object.createScript (vm.js:277:10)
          javascript.0	2021-03-25 23:12:18.352	error	(30416) at new Script (vm.js:83:7)
          javascript.0	2021-03-25 23:12:18.352	error	(30416) SyntaxError: missing ) after argument list
          javascript.0	2021-03-25 23:12:18.351	error	(30416) ^
          javascript.0	2021-03-25 23:12:18.351	error	(30416) }
          javascript.0	2021-03-25 23:12:18.351	error	at script.js.TaHoMa_Log_Perser_Skript:7
          javascript.0	2021-03-25 23:12:18.351	error	(30416) script.js.TaHoMa_Log_Perser_Skript compile failed:
            @pfahlenbauer
            Da war ich wohl zu doof beim kopieren, Klammer vergessen, habe es oben korrigiert und hier auch nochmal (die Funktion danach muss natürlich bleiben) :
              @blackeagle998
              Super, danke - läuft!
              MichaelSc 1 Reply Last reply Reply Quote 1
              • MichaelSc
                MichaelSc @pfahlenbauer last edited by
                Hi, ab und an habe ich auch genau diese Probleme.
                Zitat: "Stehe derzeit vor dem gleichen Problem. Die Steuerung per App funktioniert 1a, nur das Modul hier wirft ständig Fehler bzgl. des Logins." - leider muss ich mich dem anschließen.
                tahomalink.com lässt mein Login dann auch nicht mehr zu, falsches PW, also eher: Ausgesperrt.
                Ein Anruf letztens bei der Somfy-Hotline ergab: Zuviele Abrufe, setzen Sie mal den Polling-Wert höher. Dabei steht der bei mir schon auf "2400000".
                Bedienung der Geräte über die Tahoma-App funktioniert natürlich, denn ich vermute mal, diese App spricht mit der Tahoma-Zentrale und geht nicht übers Internet.
                Aber der Adapter kann sich nun dann nicht mehr verbinden.
                Jetzt muss ich mich wohl wieder um eine telefonische Entsperrung kümmern (heute geht keiner ans Telefon wegen einer internen Veranstaltung dort).
                Was ist denn nun der Königsweg hier: Nachts den Adapter abschalten? Per Script überwachen und bei Fehlern im Bereich 400 neu starten? Das sind doch eigentlich alles nur Workarounds.
                Übrigens: Im AppleHome(Kit) sind die Tahoma-Jalousien alle enthalten und dort funktionieren sie auch. Nachdem Somfy sich wohl Apple gegenüber geöffnet hat, hat man die Geräte in AppleHome auch zur Verfügung und da besteht das Login-Problem nicht. Vermutlich, weil AppleHome direkt auf die Tahoma-Zentrale hier zugreift?!? Wenn ich jetzt den AppleHome-Tahoma-Button aus IOBroker betätigen könnte, dann hätte ich auch keine Probleme mehr.
                Aber...
                Was hilft wirklich gegen dies:
                tahoma.0 2021-03-26 08:35:59.081 info (29905) Login failed three times, waiting 2 minutes before retrying.
                tahoma.0 2021-03-26 08:35:59.080 warn (29905) error during tahomalink request: undefined ->401 retry login
                (=ausgesperrt)
                LG
                M
                  SaschaS @blackeagle998 last edited by
                  @blackeagle998
                  Ich habe noch Anlaufschwierigkeiten mit dem setObject(). Wo muss ich denn die Rechte(?) dafür vergeben?
                  javascript.0	2021-03-26 14:17:52.194	info	(2198) script.js.Tahoma.Restart_Tahoma: Tahoma Instanz wieder eingeschaltet.
                  javascript.0	2021-03-26 14:17:52.194	error	(2198) Function "setObject" is not allowed. Use adapter settings to allow it.
                  javascript.0	2021-03-26 14:17:42.191	info	(2198) script.js.Tahoma.Restart_Tahoma: Tahoma Instanz ausgeschaltet.
                  javascript.0	2021-03-26 14:17:42.191	error	(2198) Function "setObject" is not allowed. Use adapter settings to allow it.
                    blackeagle998 @SaschaS last edited by
                    @saschas
                    Das musst du in den Einstellungen der Javascript Instanz aktivieren, ich meine es ist direkt auf der ersten Seite unten.
                      @blackeagle998 Du warst du schnell - oder ich zu langsam. Wollte beim Post schon löschen...
                      Hab im Tahoma und Logparser Adapter gesucht. Muss aber natürlich beim Javascript-Adapter schauen.
                      Gefunden. 🙂
                        SaschaS @SaschaS last edited by
                        @blackeagle998 Vielleicht kannst du aber in deinem Post für die Nachwelt noch aufnehmen, dass es der Haken bei "Merge" nicht unbedingt gesetzt werden sollte.
                        Für den nachstehende Fall erhöht sich nämlich sonst der Counter nie.
                        tahoma.0	2021-03-26 14:38:13.208	info	(18402) Login failed three times, waiting 2 minutes before retrying.
                        tahoma.0	2021-03-26 14:38:13.208	warn	(18402) error during tahomalink request: undefined ->401 retry login
                        tahoma.0	2021-03-26 14:36:13.093	info	(18402) Login failed three times, waiting 2 minutes before retrying.
                        tahoma.0	2021-03-26 14:36:13.091	warn	(18402) error during tahomalink request: undefined ->401 retry login
                        tahoma.0	2021-03-26 14:34:12.940	info	(18402) Login failed three times, waiting 2 minutes before retrying.
                        tahoma.0	2021-03-26 14:34:12.939	warn	(18402) error during tahomalink request: undefined ->401 retry login
                        tahoma.0	2021-03-26 14:34:12.800	warn	(18402) error during tahomalink request: undefined ->401 retry login
                        tahoma.0	2021-03-26 14:34:12.651	warn	(18402) error during tahomalink request: undefined ->401 retry login
                        tahoma.0	2021-03-26 14:34:12.509	warn	(18402) error during tahomalink request: undefined ->401 retry login
                        tahoma.0	2021-03-26 14:34:12.383	warn	(18402) error during tahomalink request: undefined ->401 retry login
                        tahoma.0	2021-03-26 14:34:12.010	info	(18402) [INFO] Configured polling interval: 10000
                        tahoma.0	2021-03-26 14:34:12.006	info	(18402) [START] Starting adapter tahoma v0.3.3.3
                        tahoma.0	2021-03-26 14:34:11.906	info	(18402) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.16.3, js-controller: 3.1.4
                        @blackeagle998 said in Test Adapter Somfy Tahoma v0.3.x GitHub:
                        @saschas
                        Der aus meiner Sicht einfachste Weg:
                        1. LOG Parser Adapter installieren und im Reiter Parser-Regeln einen Eintrag "Tahoma" hinzufügen, siehe Screenshot letzte Zeile (WARN anhaken, bei Bedarf auch ERROR):
                        2. In der Objektansicht erhält man dann folgende Struktur:
                        3. Auf Änderungen des Datenpunktes 'logparser.0.filters.tahoma.jsonCount' subscriben. Wenn Anzahl größer x (hier 10), dann clear das JSON und führe die Funktion "restartTahomaAdapter" aus:
                            },10000);
                        Das lässt sich beliebig ausbauen, bspw. kann man pro Fehler genau eine LOG-Parser Regel anlegen und somit pro Fehler ein JSON erhalten.
                        Mehr kann ich nicht liefern, meine Inhalte sind speziell auf meine Steuerung zugeschnitten, das würde hier nicht passen.
                          @saschas
                          Erledigt, danke für den Hinweis.
                            Hat schon jemand eine Idee zu der neuen warn Meldung seit dem letzten Box Update?
                            tahoma.0	2021-03-27 13:40:11.362	warn	(2032) State "tahoma.0.devices.Laura_rechts.states.io:PriorityLockLevelState" has no existing object, this might lead to an error in future versions
                            tahoma.0	2021-03-27 13:40:11.362	warn	(2032) State "tahoma.0.devices.Laura_rechts.states.io:PriorityLockOriginatorState" has no existing object, this might lead to an error in future versions
                            Jetzt habe ich zwar blackeagle998's Skript erfolgreich aktiviert, aber mit dieser neuen Meldung, die alle 2 Minuten kommt, würde der Adapter ja alle 10 Minuten neu gestartet werden...
                              blackeagle998 @pfahlenbauer last edited by blackeagle998
                              @pfahlenbauer
                              Dann setz doch diese Meldung auf die Blacklist in der Logparser Config. Somit erscheint die nicht mehr im JSON.
                                @blackeagle998
                                Danke, gute Idee.
                                  SaschaS @derdominik last edited by
                                  @derdominik said in Test Adapter Somfy Tahoma v0.3.x GitHub:
                                  Hallo, ich habe heute den jscontroller aktualisiert und seit dem kommt bei jedem Status-Refresh folgende WARN-Meldungen:
                                  State "tahoma.0.devices.Studio_1.states.io:PriorityLockLevelState" has no existing object, this might lead to an error in future versions
                                  State "tahoma.0.devices.Studio_1.states.io:PriorityLockOriginatorState" has no existing object, this might lead to an error in future versions
                                  Hat jemand eine Idee wie ich die Meldungen wegbekomme?
                                  Gibt es dazu schon etwas neues? Habt ihr die Objekte von Hand angelegt, damit die Warnmeldungen verschwinden?
                                  Alexandre Mariet 1 Reply Last reply Reply Quote 0
                                  • Alexandre Mariet
                                    Alexandre Mariet @SaschaS last edited by
                                    @saschas
                                    Du kannst direkt im Code selber korrigieren : https://github.com/StrathCole/ioBroker.tahoma/issues/17
                                    Hat bei mir geklappt.
                                      grooovie @integer63 last edited by grooovie
                                      hallo.
                                      der Adapter ist prima und funktioniert bei mir gut.
                                      Jetzt habe ich allerdings im log eine ständige Warnmeldung alle paar Sekunden entdeckt. Weiter unten ein Ausschnitte, das geht ständig so weiter...
                                      Damit kann ich leider nichts anfangen. Muss ich da was anders einstellen irgendwo?
                                      danke im Voraus für die Hilfe
                                      PID
                                      Zeit
                                      warn
                                      Nachricht
                                      tahoma.0
                                      542	2021-07-24 22:20:06.921	warn	refresh device state failed
                                      tahoma.0
                                      542	2021-07-24 22:20:06.921	warn	Body: {"errorCode":"TOO_MANY_OPERATIONS_IN_PROGRESS","error":"Too many asynchronous jobs, try again later (job was Full refresh all states)"}
                                      tahoma.0
                                      542	2021-07-24 22:20:06.920	warn	Response: {"statusCode":400,"body":{"errorCode":"TOO_MANY_OPERATIONS_IN_PROGRESS","error":"Too many asynchronous jobs, try again later (job was Full refresh all states)"},"headers":{"date":"Sat, 24 Jul 2021 20:20:06 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI//setup/devices/states/refresh","path":"/enduser-mobile-web/enduserAPI//setup/devices/states/refresh","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI//setup/devices/states/refresh"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.112 Safari/537.36","cookie":"JSESSIONID=B1CFD773A8FA9F4D9DE26963E15B7FEE","accept":"application/json","content-type":"application/json","content-length":2}}}
                                      tahoma.0
                                      542	2021-07-24 22:20:06.920	warn	error during tahomalink request: null, request path: /setup/devices/states/refresh with payload:{}
                                      tahoma.0
                                      542	2021-07-24 22:20:06.920	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"}
                                      tahoma.0
                                      542	2021-07-24 22:20:06.920	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"},"headers":{"date":"Sat, 24 Jul 2021 20:20:06 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI/events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch","path":"/enduser-mobile-web/enduserAPI/events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI/events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.112 Safari/537.36","cookie":"JSESSIONID=B1CFD773A8FA9F4D9DE26963E15B7FEE","accept":"application/json","content-type":"application/json","content-length":2}}}
                                      tahoma.0
                                      542	2021-07-24 22:20:06.919	warn	error during tahomalink request: null, request path: events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch with payload:{}
                                      tahoma.0
                                      542	2021-07-24 22:19:46.925	warn	refresh device state failed
                                      tahoma.0
                                      542	2021-07-24 22:19:46.925	warn	Body: {"errorCode":"TOO_MANY_OPERATIONS_IN_PROGRESS","error":"Too many asynchronous jobs, try again later (job was Full refresh all states)"}
                                      tahoma.0
                                      542	2021-07-24 22:19:46.925	warn	Response: {"statusCode":400,"body":{"errorCode":"TOO_MANY_OPERATIONS_IN_PROGRESS","error":"Too many asynchronous jobs, try again later (job was Full refresh all states)"},"headers":{"date":"Sat, 24 Jul 2021 20:19:46 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI//setup/devices/states/refresh","path":"/enduser-mobile-web/enduserAPI//setup/devices/states/refresh","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI//setup/devices/states/refresh"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.112 Safari/537.36","cookie":"JSESSIONID=B1CFD773A8FA9F4D9DE26963E15B7FEE","accept":"application/json","content-type":"application/json","content-length":2}}}
                                      tahoma.0
                                      542	2021-07-24 22:19:46.925	warn	error during tahomalink request: null, request path: /setup/devices/states/refresh with payload:{}
                                      tahoma.0
                                      542	2021-07-24 22:19:46.921	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"}
                                      tahoma.0
                                      542	2021-07-24 22:19:46.921	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"},"headers":{"date":"Sat, 24 Jul 2021 20:19:46 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI/events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch","path":"/enduser-mobile-web/enduserAPI/events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI/events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.112 Safari/537.36","cookie":"JSESSIONID=B1CFD773A8FA9F4D9DE26963E15B7FEE","accept":"application/json","content-type":"application/json","content-length":2}}}
                                      tahoma.0
                                      542	2021-07-24 22:19:46.920	warn	error during tahomalink request: null, request path: events/8604aac4-98e4-e192-30fa-1977c4b80e7f/fetch with payload:{}
                                        maodch @StrathCole last edited by maodch
                                        sorry, falscher Post
                                          Jautze last edited by
                                          was ich nirgends gefunden habe, ist welche Hardware ich brauche bzw. unterstützt wird.
                                          Ich habe 3 Somfy J406 io und möchte diese über IOBroker steuern.
                                          Was brauche ich noch? Reicht das Connectivity Kit oder brauche ich den Tahoma Switch?
                                          Danke und viele Grüße
                                          Marcel
                                          31.7k
                                          79.8k
                                          rollladensteuerung somfy tahoma
                                          34
                                          294
                                          36368
