    4. Test Adapter mihome-vacuum v2.0.x
      Schwabe @Thomas Braun last edited by
      @thomas-braun Danke für Deinen Hinweis, da hast Du natürlich Recht. Der Log war noch von einem Start bevor ich den Node.js auf die aktuelle Stable zurückgesetzt hatte.
      Hier ein aktueller Log:
      mihome-vacuum.0	2021-03-20 14:27:13.704	info	(25385) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2021-03-20 14:27:13.185	debug	(25385) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      mihome-vacuum.0	2021-03-20 14:27:13.178	debug	(25385) server started on 0.0.0.0:53421
      mihome-vacuum.0	2021-03-20 14:27:13.175	info	(25385) Cloud control disabled
      mihome-vacuum.0	2021-03-20 14:27:13.175	info	(25385) Expert mode disabled, states deleted
      mihome-vacuum.0	2021-03-20 14:27:13.154	info	(25385) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
      mihome-vacuum.0	2021-03-20 14:27:13.052	debug	(25385) statesDB connected
      mihome-vacuum.0	2021-03-20 14:27:13.052	debug	(25385) States connected to redis: 127.0.0.1:9000
      mihome-vacuum.0	2021-03-20 14:27:13.047	debug	(25385) States create User PubSub Client
      mihome-vacuum.0	2021-03-20 14:27:13.046	debug	(25385) States create System PubSub Client
      mihome-vacuum.0	2021-03-20 14:27:13.043	debug	(25385) Redis States: Use Redis connection: 127.0.0.1:9000
      mihome-vacuum.0	2021-03-20 14:27:13.042	debug	(25385) objectDB connected
      mihome-vacuum.0	2021-03-20 14:27:13.040	debug	(25385) Objects connected to redis: 127.0.0.1:9001
      mihome-vacuum.0	2021-03-20 14:27:13.032	debug	(25385) Objects client initialize lua scripts
      mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects create User PubSub Client
      mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects create System PubSub Client
      mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects client ready ... initialize now
      mihome-vacuum.0	2021-03-20 14:27:13.021	debug	(25385) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.Server	2021-03-20 14:27:12.721	info	instance system.adapter.mihome-vacuum.0 started with pid 25385
      host.Server	2021-03-20 14:27:12.699	info	"system.adapter.mihome-vacuum.0" enabled
        mech last edited by
        Moin, ich habe auch das Problem das "Get Devices" kein Ergebnis mehr liefert. Ich habe die Tage Node auf 12 geupgraded von 10. Ich vermute es liegt daran. Da ich noch einen Snapshot vom System hatte konnte ich IOBroker auf Node 10 zurücksetzen und der Adapter läuft wieder 1a.
        Irgendwas scheint nicht rund zu laufen 🙂
        Besten Gruß
          Thomas Braun Most Active @mech last edited by
          @mech sagte in Test Adapter mihome-vacuum v2.0.x:
          Kann ich nicht bestätigen. Hier läuft der Adapter ganz unauffällig mit node 12 und mit node14.
          Auf einen Debian-System? Das macht man nicht so grobschlächtig, man benutzt seinen Paketmanager und installiert das dann sauber darüber.
            mech @Thomas Braun last edited by
            @thomas-braun Bei einem Snapshot unter Proxmox sehe ich da kein Handlungsbedarf über den Paketmanager 😉
              Thomas Braun Most Active @mech last edited by Thomas Braun
              @mech
              Dann wirst du nie 'elegant' mit dem System umgehen können.
              Snapshot draufknallen ist keine Problemlösung, das ist nur stumpf drüberwalzen.
              Beim Auto setzt du ja auch keinen Austauschmotor rein, wenn eigentlich nur die Zündkerzen erneuert werden sollen.
                Spampunk last edited by
                Hallo Freunde des gepflegten Staubsaugens,
                ich gebe mal ein kurzes Feedback: Auch ich hatte ja lange Zeit keine Map, obwohl ich alle Einstellungen im Adapter und in der Mihome-App vorgenommen hatte. Vor ein paar Tagen dachte ich mir, ich könnte ja mal wieder auf den Schalter "Get Devices" im Mihome-Adapter klicken und -wupps- war der Token da und die Map in meiner VIS.
                @Meistertr hatte den Verdacht, dass ich keine Verbindung zum Xiaomi-Server erhalte. Das kann ich bis heute nicht genau sagen. Das Einzige, was sich in dieser Zeit geändert hat, ist das Update der JS-Engine. Vielleicht hat das ja etwas bewirkt?
                Jedenfalls bin ich jetzt glücklich und kann alles wie gewünscht nutzen!
                Viele Grüße,
                Spampunk
                • da_Woody
                  da_Woody @Spampunk last edited by
                  @spampunk na das liest sich ja mal gut!
                  ohne das get devices gibts immer probleme. bei mir hats damls zum glück sofort funktioniert...
                    Coffeelover last edited by
                    ich habe gestern einen Roborock S7 in der App eingebunden.
                    Nachdem ich zunächst daran gescheitert war, weil ich für die Einrichtung die RoborockApp genutzt hatte und nicht die MiHome, ist er jetzt bei GetDevices aufgetaucht und verbunden.
                    Allerdings bleibt der Adapter gelb, obwohl die Zeitzone Roborock & Handy synchronisiert ist.
                    Meldung im Log:
                    (4734) Time difference between Mihome Vacuum and ioBroker: -1616765837 sec
                    Darauf folgt ein neuer Verbindungsversuch. Kennt jemand eine Lösung dazu?
                    VG
                      Thomas Braun Most Active @Coffeelover last edited by
                      @coffeelover sagte in Test Adapter mihome-vacuum v2.0.x:
                      1616765837 sec
                      Einer der beiden läuft auf Unix-Nullzeit. Das sind nämlich 51 Jahre umgerechnet = 01.01.1970
                        Coffeelover @Thomas Braun last edited by
                        @thomas-braun Danke. Die Frage ist eher: wie bekomme ich das auf heute synchronisiert?
                          @coffeelover
                          Welches System hat denn da keine aktuelle Zeit?
                          Auf dem Server:
                          date && date -u
                          prüfen.
                            @thomas-braun iobroker läuft auf einem QNAP im Docker installiert.
                            Die Abfrage oben liefert die aktuelle Zeit als CET. Eine zweite Xiaomi-Instanz meckert nicht - die Zeit in iobroker sollte also passen.
                            im Roborock habe ich vorhin in den erweiterten Einstellungen noch eine Möglichkeit zum Setzen einer Zeitzone gefunden. Auch die habe ich auf MEZ gestellt - geändert hat sich wenig.
                              Flauschi last edited by
                              https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/228
                              das Problem liegt am S7
                              Black-Thunder created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                              closed Roborock S7 not supported #228
                              C 1 Reply Last reply Reply Quote 1
                                Coffeelover @Flauschi last edited by
                                @flauschi danke dir. Eine Info wie diese hatte ich gesucht. Mal abwarten, dafür gibt es sicher bald eine Lösung.
                                  mech @Thomas Braun last edited by mech
                                  @thomas-braun said in Test Adapter mihome-vacuum v2.0.x:
                                  @mech
                                  @thomas-braun Nein, ich würde mir direkt ein neues Auto kaufen.
                                    @mech Ja, das merke ich.
                                      Flauschi @Coffeelover last edited by
                                      @coffeelover wenn Du den angesprochenen Workaround machst, dann hast Du keine Fehler mehr.
                                      Die Zeitabweichung kam auch nur die ersten paar refreshes und dann nicht mehr.
                                        Schwabe @Schwabe last edited by
                                        Wenn ich mein Problem noch mal hervorholen darf? Ich habe zwischenzeitlich natürlich versucht eine Lösung zu finden, bisher aber noch immer ohne Erfolg.
                                        Ich habe 2 ioBroker System. Das "Alte" ist ein TinkerBoard S auf dem ich keinen mihome-vacuum Adpter neuer als 1.1.5 installiert bekomme. Updates brechen mit einer Fehlermeldung ab und ich muss danach den Adapter komplett deinstallieren und neu installieren, doch ansonsten läuft er einwandfrei. Da ich gerne auf mein "Neues" umsteigen möchte, würde ich hier nichts mehr dran ändern wollen.
                                        Das "Neue" ist ein Ubuntu unter Windows. Leider bleibt hier der Adapter bei "gelb" stehen er wird einfach nicht "grün". Ich kann die Serverdaten eintragen, bekomme meinen "Robbi" angezeigt und kann diesen auch übernehmen.
                                        Meine Node.js Version ist 12.21.0, die NPM 6.14.11 und der JS Controller ist auch aktuell.
                                        Ich habe den Adapter auf dem TinkerBoard längere Zeit deaktiviert.
                                        Ich habe den Adapter mehrfach neu installiert und eingerichtet.
                                        Ich habe den Sauger ausgeschaltet und wieder eingeschaltet.
                                        Ich habe den Sauger mehrfach laufen lassen, während der Adapter aktiv war.
                                        Der Adapter verursacht keine Fehlermeldungen im Log. Der angehängte Log ist von einem manuellen Neustart des Adapters im debug Modus.
                                        Hat vielleicht noch jemand einen Rat für mich? Vielen Dank im Voraus für jeden Tipp.
                                          @flauschi Danke, aber ich bin gerade noch zu doof, den Code einzufügen bzw. die js in einem Editor zu öffnen.
                                            Ich habe mittlerweile Canvas wie in der Beschreibung über die Konsole installiert, ohne weiteren Erfolg. Der Adapter lässt sich auch nicht auf eine niedrigere Version downgraden.
                                            Mir fällt langsam nichts mehr ein und ich bin für jeden Tipp dankbar.
                                            Das ist der Log von einem solchen Versuch.
                                            $ ./iobroker upgrade mihome-vacuum@2.0.8
                                            Update mihome-vacuum from @2.1.1 to @2.0.8
                                            NPM version: 6.14.11
                                            npm install iobroker.mihome-vacuum@2.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
                                            npm ERR! code ETARGET
                                            npm ERR! notarget No matching version found for iobroker.mihome-vacuum@2.0.8.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
                                            npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-03-30T21_37_39_770Z-debug.log
                                            upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                            Update "system.adapter.mihome-vacuum.0"
                                            upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                                            upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                                            upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                                            upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                                            upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
                                            upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                                            upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                                            upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                            upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                            upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                            upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                            Adapter "mihome-vacuum" updated
                                            process exited with code 0
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            445845
