    4. Material Design Widgets: Value Widget
    • ub.privat
      ub.privat last edited by
      @liv-in-sky
      Der Hinweis mit GoogleChrome ist gar nicht so schlecht. Ein paar Fehler - SCHREIBFEHLER! - konnte ich bereits beseitigen. DANKE.
      Nun habe ich noch folgenden Fehler, dazu der ERROR-Text aus der Console:
      promisebuffer.ts:24 Error in eval[value]     : {val:homeconnect.0.SIEMENS-SX858D06PE-68A40E064ECA.programs.active.BSH_Common_Root_ActiveProgram; val== "Dishcare.Dishwasher.Program.Intensiv70" ? "Intensiv 70°C" : val== "Dishcare.Dishwasher.Program.Auto2" ? "Auto 45-65°C" : val== "Dishcare.Dishwasher.Program.Eco50" ? "Eco 50°C : val== "Dishcare.Dishwasher.Program.NightWash" ? "Leise" : val== "Dishcare.Dishwasher.Program.Quick65" ? "Schnell 65°C" : val== "Dishcare.Dishwasher.Program.Quick45" ? "Schnell 45°C" : val== "Dishcare.Dishwasher.Program.MachineCare" ? "Maschinenpflege" : "no-no" }
      (anonymous) @ promisebuffer.ts:24
      (anonymous) @ captureconsole.ts:16
      formatBinding @ vis.js:2498
      createIds @ vis.js:3312
      (anonymous) @ vis.js:3330
      sentryWrapped @ helpers.ts:124
      setTimeout (async)
      (anonymous) @ trycatch.ts:197
      createIds @ vis.js:3329
      (anonymous) @ vis.js:3461
      (anonymous) @ conn.js:801
      r.onack @ socket.io.js:8
      r.onpacket @ socket.io.js:8
      (anonymous) @ socket.io.js:8
      r.emit @ socket.io.js:6
      r.ondecoded @ socket.io.js:6
      a.add @ socket.io.js:6
      r.ondata @ socket.io.js:6
      r.onPacket @ socket.io.js:6
      (anonymous) @ socket.io.js:6
      r.onPacket @ socket.io.js:7
      r.onData @ socket.io.js:7
      ws.onmessage @ socket.io.js:8
      promisebuffer.ts:24 Error in eval[script]: var val = "undefined";return  val== "Dishcare.Dishwasher.Program.Intensiv70" ? "Intensiv 70°C" : val== "Dishcare.Dishwasher.Program.Auto2" ? "Auto 45-65°C" : val== "Dishcare.Dishwasher.Program.Eco50" ? "Eco 50°C : val== "Dishcare.Dishwasher.Program.NightWash" ? "Leise" : val== "Dishcare.Dishwasher.Program.Quick65" ? "Schnell 65°C" : val== "Dishcare.Dishwasher.Program.Quick45" ? "Schnell 45°C" : val== "Dishcare.Dishwasher.Program.MachineCare" ? "Maschinenpflege" : "no-no" ;
      formatBinding @ vis.js:2499
      setTimeout (async)
      promisebuffer.ts:24 Error in eval[error] : SyntaxError: Unexpected identifier
      Das ist mein Binding:
      Wie muss ich den Fehlertext lesen? Ist dies die Fehlerquelle: Error in eval[script]: var val = "undefined";return ?
        liv-in-sky @ub.privat last edited by liv-in-sky
        @ub-privat
        anführungszeichen fehlt
        nach 50°C
        ub.privat 1 Reply Last reply Reply Quote 1
        • ub.privat
          ub.privat @liv-in-sky last edited by
          @liv-in-sky
          JUPP, das wars. Ich glaube, das Programmieren wird nicht mein Spezialgebiet. Diese Syntax nervt einen die Sicht...
          Aber deine Empfehlung ist Gold-Wert.
          Wie hast du so schnell die fehlenden " gefunden?
            @ub-privat
            intuition - keine ahnung - habe in letzter zeit viel mit code gemacht - irgendwann sieht man das - nachdem man natütlich die selben fehler 100 mal selber gemacht hat
            ub.privat 1 Reply Last reply Reply Quote 0
            • ub.privat
              @liv-in-sky
              na dann bin ich beruhigt, vllt. wird's ja noch! DANKE nochmals!
                Marcel85 last edited by
                Hallo.
                Ist stehe gerade vor dem selben Problem.
                Ich habe schon die letzten Bindings mit meinem verglichen und nach meinem Verständnis sollte es bei mir so funktionieren.
                Allerdings zeigt er mir im Widget nur 0 an.
                Der Datenpunkt gibt die Werte 1, 2 und 3 aus. Daraus soll er offen, verriegelt und entriegelt machen.
                Vielleicht könnte mir dabei jemand auf die Sprünge helfen.
                Mein Binding:
                {val:vw-connect.0.TMB**************.status.data_0x030104FFFF.field_0x0301040001.value; val== "2" ? "offen"}
                Vielen Dank schon mal!
                Gruß Marcel
                  liv-in-sky @Marcel85 last edited by liv-in-sky
                  @marcel85
                  ist ne zahl - daher bei der neusten vis version:
                  {val:controll-own.0.AAATEST.TestHTMLAuswahlDelete; val==1 ? "ist eins" : val==2 ? "ist zwei" : val==3 ? "ist drei" : "sonst"}
                  • Scrounger
                    Scrounger Developer @liv-in-sky last edited by
                    @liv-in-sky sagte in Material Design Widgets: Value Widget:
                    @Marcel85
                    Und wenn du den Vorteil des Value Wigdet nutzen möchtest - auf Binding verzichten - dann musst du das ganze wie folgt einstellen:
                    liv-in-sky M 2 Replies Last reply Reply Quote 1
                      liv-in-sky @Scrounger last edited by liv-in-sky
                      @scrounger theoretisch: kann man auch einen zweiten datenpunkt zur berechnung miteinbeziehen ?
                      • Scrounger
                        @liv-in-sky
                        Nein das geht noch nicht, hab ich aber schon auf dem Schirm.
                        Wird die Möglichkeit geben mehere Ids im Widget zu hinterlegen und dann mit #value1, #value2, etc die mit einzubeziehen.
                          Marcel85 @Scrounger last edited by
                          @scrounger
                          funktioniert.
                          #value==1 ? "ist eins" : #value==2 ? "ist zwei" : #value==3 ? "ist drei" : "sonst"
                          unter Berechnung funktioniert scheinbar nicht.
                          Da zeigt er weiterhin nur die Zahl an.
                          Habe ich irgendwo noch einen Fehler?
                          • Scrounger
                            Scrounger Developer @Marcel85 last edited by
                            @marcel85
                            Objekt ID hast du gesetzt?
                            Welche Version hast du 0.5.2-beta?
                              @scrounger
                              Objekt ID ist weiterhin gesetzt, er zeigt die Zahl ja auch an.
                              Aktuell noch die 0.5.1-beta
                              • Scrounger
                                @marcel85 sagte in Material Design Widgets: Value Widget:
                                Ok dann liegt es wohl daran, zieh dir mal die aktuelle version von github
                                  @scrounger
                                  Leider keine Besserung nach dem Update auf 0.5.2-beta.
                                    @marcel85 bei dir ist da noch der "wurm" drin - bei mir geht's mit dem neuen widget (unter berechnung) und der formel von @Scrounger
                                      Marcel85 @liv-in-sky last edited by
                                      @liv-in-sky @Scrounger
                                      Macht es Sinn ein Upload beim Adapter (VIS oder Material Design Widgets) durchzuführen?
                                      Eventuell hat er irgendwas beim Update nicht mit übernommen?
                                      Gruß Marcel
                                        @marcel85 macht meist sinn und anschliessend auch die vis instanz selbst
                                          @marcel85 und zeig mal, was du eingetragen hast
                                            @liv-in-sky
                                            Wenn der Wert eine Zahl ist, funktioniert es.
                                            Ist es z.B. "off", dann funktioniert es nicht.
                                            vis
                                            16
                                            76
                                            10146
