    2. English
    3. Scripting / Logic
    4. JSON - Reading a datapoint with a . in the name? - Solved
      erwinberlin last edited by erwinberlin
      Hi, I am having trouble reading a data point from a JSON message in blockly. The script works, however there is 1 datapoint with a . in it. Is there a trick to get it done? I tried various solutions I found online, however to no avail. See the JSON message below.
      {"Time":"2021-03-28T11:31:08","BMP180":{"Temperature":11.4,"Pressure":1022.7},"SHT3X-0x45":{"Temperature":11.2,"Humidity":45.3,"DewPoint":-0.3},"SDS0X1":{"PM2.5":3.6,"PM10":7.0},"PressureUnit":"hPa","TempUnit":"C"}
        paul53 @erwinberlin last edited by paul53
        @erwinberlin
        obj.SDS0X1['PM2.5']
        Blockly:
          erwinberlin @paul53 last edited by erwinberlin
          This is my code, however the PM2.5 still does not work in this script. I used the code in blockly and that works fine! Now I can see the differences, but I still would like to understand why the script does not work?
          Probably obvious to experienced Java programmers, however not for a newbie like me. Any help appreciated!
          var AQ;
          on({id: "mqtt.0.tele.tasmota_sensors_7E466A.SENSOR", change: "any"}, async function (obj) {
            var value = obj.state.val;
            AQ = (function () { try {return JSON.parse(getState("mqtt.0.tele.tasmota_sensors_7E466A.SENSOR").val);} catch(e) {return {};}})();
            console.log('PM10 & PM2.5');
            console.log(parseFloat(getAttr(AQ, 'SDS0X1.PM10')));
            console.log(parseFloat(getAttr(AQ, 'SDS0X1['PM2.5']')));
            if (parseFloat(getAttr(AQ, 'SDS0X1.PM10')) != 0) {
              setState("javascript.0.Air-quality.10um", parseFloat(getAttr(AQ, 'SDS0X1.PM10')), true);
            if (parseFloat(getAttr (AQ, 'SDS0X1['PM2.5']') != 0) {
              setState("javascript.0.Air-quality.2_5um", parseFloat(getAttr(AQ, 'SDS0X1['PM2.5']')), true);
            @erwinberlin sagte): 'SDS0X1['PM2.5']'
            Try this:
            PM10 and PM2.5 values are numbers.
            let x = getAttr(json, 'SDS0X1['PM2.5']'); // designed for Blockly
            // is not
            let x = JSON.parse(json).SDS0X1['PM2.5']; // Javascript
            because the 2. parameter of getAttr() must be a string or an array with one string element.
            P.S. Spricht ErwinBerlin kein deutsch?
              @erwinberlin
              Javascript-Version:
              on('mqtt.0.tele.tasmota_sensors_7E466A.SENSOR', function (dp) {
                let sensor = JSON.parse(dp.state.val);
                let pm10 = sensor.SDS0X1.PM10;
                let pm2_5 = sensor.SDS0X1['PM2.5'];
                log('PM10: ' + pm10);
                log('PM2.5: ' + pm2_5);
                if (pm10) setState("javascript.0.Air-quality.10um", pm10, true);
                if (pm2_5) setState("javascript.0.Air-quality.2_5um", pm2_5, true);
                @paul53 Super, vielen Dank! Das hat mich sehr geholfen.
                Übrigens spreche ich Deutsch, aber schreiben ist jedoch etwas ganz anderes...
                blockly javascript
