    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      mmemme @mmemme last edited by
      @mmemme @Newan der "batteryStatus" Wert stimmt überein mit der UVO-App Ladestandsanzeige.
      Newan 1 Reply Last reply Reply Quote 0
      • Newan
        Newan @mmemme last edited by
        @mmemme AHHHH du hast einen PHEV 🙂
        Na dann muss ich ja noch Reichweite Gas und Reichweite EV einbauen ^^
        • Newan
          @mmemme Version 1.0.3 bitte testen!
            Michaelnorge last edited by Michaelnorge
            Ich bekomme häufig diese Fehlermeldung vom Adapter:
            2021-03-31 06:19:58.967 - info: bluelink.0 (2926) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.bluelink, node: v10.24.0, js-controller: 3.2.16
            2021-03-31 06:19:59.002 - info: bluelink.0 (2926) Login to api
            2021-03-31 06:20:03.277 - info: bluelink.0 (2926) Vehicles found
            2021-03-31 06:20:03.339 - info: bluelink.0 (2926) Read new status from api
            2021-03-31 06:20:04.259 - error: bluelink.0 (2926) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2021-03-31 06:20:04.261 - error: bluelink.0 (2926) unhandled promise rejection: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"26876f26-xxxx-xxxx-xxxx-e75b566a2483"}
            2021-03-31 06:20:04.263 - error: bluelink.0 (2926) ManagedBluelinkyError: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"26876f26-xxxx-xxxx-xxxx-e75b566a2483"}
            at T (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:144032)
            at b. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:152142)
            at Generator.throw ()
            at P (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
            at process._tickCallback (internal/process/next_tick.js:68:7)
            2021-03-31 06:20:04.264 - error: bluelink.0 (2926) @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"26876f26-xxxx-xxxx-xxxx-e75b566a2483"}
            2021-03-31 06:20:04.290 - info: bluelink.0 (2926) Adapter bluelink cleaned up everything...
            2021-03-31 06:20:04.292 - info: bluelink.0 (2926) terminating
            Das deckt sich glaube ich mit der Aussage in meiner Bluelink-App:
            "Remote Service in process..
            Please try again later (4004)"
            Die Fehlermeldungen kommen ohne mein Zutun.
            Ich habe ioBroker neu gestartet, als die Logeinträge aufkamen.
            EDIT: Diese Fehlermeldung kam tatsächlich von einer leeren 12v-Bordbatterie!!
            Noch etwas: Komischer Weise ist meine App am Handy jetzt auf englisch, ich finde keine Möglichkeit mehr, sie auf Deutsch umzustellen.
            Kann das von jemandem bestätigt werden?
              Hab den Adapter jetzt erstmal pausiert, der gibt nur noch Fehlermeldungen aus...
              EDIT: Ich wollte gerade losfahren, da war die 12v-Batterie schon wieder leer.
              Vielleicht ist das der Grund der Fehlermeldungen??
              Zieht die App irgendwie an der Batterie bei 100 Abfragen täglich?
              Ich werd das mal überprüfen und melde mich....
                Aiouh @Michaelnorge last edited by Aiouh
                @michaelnorge said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                Normalerweise geht das Fahrzeug und alle seine Systeme nach Abstellen und Abschliessen in den Ruhezustand um den Stromverbrauch zu minimieren. Wenn wir ständig Abfragen schicken wecken wir die Systeme wieder auf und sie verbrauchen wieder Strom. Irgendwann ist die 12V Batterie leer. Das Nachladen erfolgt nach meinen Erfahrungen nur wenn das Fahrzeug fährt oder zumindest im Fahrmodus ist. Ich stecke meinen e-soull sicherheitshalber immer an das 12V Ladegerät wenn ich rumspiele, oder "rumspielen lasse" 😉 .
                @Newan Sind die eingetragenen "100" die Anzahl von automatisch zyklischen Abfragen oder ist das ein Limit das uns daran hindern soll die 200er Grenze nicht zu überschreiten?
                  Ich werde aus den Werten nicht schlau.
                  Soc-12v:
                  Zeigt bei mir immer 255 an, meine Batterie war heute morgen tot, jetzt lädt sie, aber der Wert ändert sich nicht.
                  state-12v:
                  Der Wert ist 1 und ändert sich nie.
                    @Newan Ist der Wert "Abfrage pro Tag" bezogen auf 24h ?
                    Wenn ich also den Wert 24 angebe, so wird stündlich eine Abfrage gesendet?
                      Michaelnorge @Aiouh last edited by
                      @aiouh said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                      Hatte ich schon gedacht, daß es daran liegen könnte.
                      Man, meine Frau war vielleicht sauer heute morgen 😇
                      Ich stelle den Abfragewert mal lieber runter :-)))
                      • Newan
                        Newan @Michaelnorge last edited by
                        @michaelnorge die Formel ist 24*60=1440 Minuten/ Anzahl request. Bei hundert ist es dann fast jede Viertelstunde...
                          mmemme @Newan last edited by
                          @newan Guten morgen,
                          jetzt sieht es deutlich besser aus und fast alle Daten sind zugeordnet und es sind keine Fehler mehr im LOG zu sehen. Die folgenden Werte sehe ich im Debug log werden aber nicht übernommen:
                          Odometer value
                          Vehicle position latitude
                          Diese Werte werden ebenfalls nicht gesetzt, kommen aber auch nicht zurück von der API, ich denke einfach das dort ein Unterschied zwischen voll E und PHEV ist:
                          Vehicle charge limit for fast charging
                          Vehicle charge limit for slow charging
                          Vehicle 12v battery state of charge
                          Vehicle 12v battery State
                            Soc-12v:
                            Siehe mein Kommentar weiter oben. der 12V Soc scheint sich erst zu aktualisieren wenn Du fährst.
                              Kenne ich
                              Da hilft auch https://dadslife.at/mobilitaet/starthilfe-powerbank/ 🙂
                                Aiouh @Aiouh last edited by
                                @newan, weiss nicht ob Dir das weiter hilft, aber Hier gibts viele Details zu den CAN messages.
                                  O ja danke, hatte es übersehen 😉
                                  • Newan
                                    Bitte mal testen ob der Adapter mit Version 1.0.3 auch abschmiert oder ob die Api Fehler nun gefangen werden. Kann ich ja schlecht testen
                                      Aiouh @Newan last edited by Aiouh
                                      @newan bei mir ist er gleich am Anfang abgeschmiert. Ich habe Ihn disabled, ne Weile gewartet und wieder gestartet, seit 10:00 läuft er jetzt fehlerfrei. Abfrage ist gesetzt auf 8 x am Tag, das reicht mir, ansonsten forciere ich eben mal die Abfrage manuell.
                                      Vehicles found
                                      2021-03-31 09:57:08.302  - info: bluelink.0 (25796) Read new status from api
                                      2021-03-31 09:57:08.743  - error: bluelink.0 (25796) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2021-03-31 09:57:08.744  - error: bluelink.0 (25796) unhandled promise rejection: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/0a0518ab-e661-4474-b6a2-fa9d56455a3a/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"7b80db0d-e8df-4221-9603-127dd376ed70"}
                                      2021-03-31 09:57:08.745  - error: bluelink.0 (25796) ManagedBluelinkyError: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/0a0518ab-e661-4474-b6a2-fa9d56455a3a/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"7b80db0d-e8df-4221-9603-127dd376ed70"}
                                          at b.<anonymous> (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:152142)
                                      2021-03-31 09:57:08.745  - error: bluelink.0 (25796) @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/0a0518ab-e661-4474-b6a2-fa9d56455a3a/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"7b80db0d-e8df-4221-9603-127dd376ed70"}
                                      2021-03-31 09:57:08.762  - info: bluelink.0 (25796) Adapter bluelink cleaned up everything...
                                      2021-03-31 09:57:08.763  - info: bluelink.0 (25796) terminating
                                      2021-03-31 09:57:08.763  - warn: bluelink.0 (25796) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2021-03-31 09:57:09.577  - error: host.iobroker-vm instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      2021-03-31 09:57:09.578  - info: host.iobroker-vm Restart adapter system.adapter.bluelink.0 because enabled
                                      2021-03-31 09:57:09.578  - warn: host.iobroker-vm Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                                      2021-03-31 09:57:21.268  - info: host.iobroker-vm "system.adapter.bluelink.0" disabled
                                        Definitiv nicht.
                                        Das Auto wurde soeben 40km gefahren, aber der Soc-12V Wert steht immer noch auf 255.
                                          Ich habe es nun so laufen daß bluelink nur dann updated, wenn ich aktiv auf die entsprechende VIS-Seite schalte oder wenn ein bestimmtes Ereignis startet (Stecker ins Auto gesteckt/Auto vollgeladen u.s.w.) . Das verringert die Anzahl Syncs extrem.
                                          In der Instanz-Einstellung habe ich 4 Anfragen pro Tag eingestellt.
                                          So gibt´s auch keine Probleme mehr mit Hyundai und eventuellem Blocken 🙂
                                            Definitiv nicht.
                                            Wenn die Batterie ganz leer war vermute ich, dass er erst mal wieder lernen muss was "voll" bedeutet. Gib doch mal Bescheid wenn sich bei dem SoC wieder was tut.
                                            2288
                                            856054
