    4. Test Adapter pegelalarm v0.0.1-x
    • Negalein
      Negalein Global Moderator @simatec last edited by
      @simatec sagte in Test Adapter pegelalarm v0.0.1-x:
      So mal wieder was zum testen ...
      Auswahl passt sehr gut!
      Was mir aufgefallen ist:
      Ich hab nur folgendes konfiguriert.
      Land: Deutschland
      Region: Bayern
      Wasser: Inn
      Stationsname: Passau Ingling
      Bei Stationsname gäb es noch Passau Ingling KW, Passau Ingling OW, Passau Ingling Q
      In den Objekten werden alle 4 Passau Ingling ... angelegt und abgefragt.
      • simatec
        simatec Developer Most Active @Negalein last edited by simatec
        @negalein Da muss ich mir die API nochmal anschauen.
        Die Ausgabe sieht wie folgt aus wenn Passau Ingling gewählt wird
        {"status":{"code":200},"payload":{"stations":[{"name":"Inn / Passau Ingling Ow / de","commonid":"18007798-de","country":"Deutschland","stationName":"Passau Ingling Ow","water":"Inn","region":"Bayern","latitude":48.554052327939,"longitude":13.432204664619,"positionKm":0.0,"altitudeM":0.0,"data":[{"type":"height in cm","value":303.0,"requestDate":"03.08.2016T15:46:12+0200","sourceDate":"03.08.2016T15:30:00+0200"}],"trend":100,"situation":100,"visibility":"PUBLIC"},{"name":"Inn / Passau Ingling / de","commonid":"18008008-de","country":"Deutschland","stationName":"Passau Ingling","water":"Inn","region":"Bayern","latitude":48.561454544109,"longitude":13.444192030337,"positionKm":3.1,"altitudeM":289.19,"defaultWarnValueCm":670.0,"defaultWarnValueM3s":3000.0,"defaultAlarmValueCm":1159.0,"defaultAlarmValueM3s":6820.0,"data":[{"type":"height in cm","value":245.0,"requestDate":"31.03.2021T16:44:50+0200","sourceDate":"31.03.2021T16:30:00+0200"},{"type":"flow in m3s","value":630.0,"requestDate":"31.03.2021T16:44:50+0200","sourceDate":"31.03.2021T16:30:00+0200"}],"trend":10,"situation":10,"visibility":"PUBLIC"},{"name":"Inn / Passau Ingling Kw / de","commonid":"18007800-de","country":"Deutschland","stationName":"Passau Ingling Kw","water":"Inn","region":"Bayern","latitude":48.554052327939,"longitude":13.432204664619,"positionKm":4.2,"defaultWarnValueM3s":1200.0,"data":[{"type":"flow in m3s","value":642.0,"requestDate":"31.03.2021T16:29:08+0200","sourceDate":"31.03.2021T16:15:00+0200"}],"trend":10,"situation":10,"visibility":"PUBLIC"},{"name":"Inn / Passau Ingling Q / de","commonid":"18008019-de","country":"Deutschland","stationName":"Passau Ingling Q","water":"Inn","region":"Bayern, Passau","latitude":48.561466508438,"longitude":13.444119928175,"positionKm":3.1,"altitudeM":289.19,"data":[{"type":"flow in m3s","value":0.0,"requestDate":"25.07.2018T14:57:29+0200","sourceDate":"25.07.2018T14:45:00+0200"}],"trend":0,"situation":100,"visibility":"PUBLIC"}]}}
        • Negalein
          Da sind leider alle 4 enthalten.
          Habe es gerade mit denn Daten auf der Website verglichen.
          Zumindest weiß ich nun, welchen DP ich loggen kann.
          • simatec
            @negalein Versuche bitte nochmal ... habe da noch einen Filter eingebaut, um die API Ausgaben gerade zu biegen
            Gleiche Version vom Github
            • Negalein
              Merci
              Nun kommt nur die gewünschte Messstelle! 👍
              • simatec
                @negalein Die API gibt da teilweise mehr raus, als gewollt.
                Man filtert auf eine Messstelle und es kommen 4 Stück an.
                Habe dadurch nun nochmal einen weiteren Filter nach dem Abruf der API gesetzt
                • Negalein
                  Ja, ist mir auch aufgefallen.
                  Hab ein paar getestet. Bei 10 waren es bestimmt 4 mit mehr Messstellen.
                  Hast du gut gemacht! 🤘
                  simatec 2 Replies Last reply Reply Quote 0
                  • simatec
                    @negalein Dann Happy Testing 👍🏻
                    • simatec
                      @negalein Konntest du das Problem lösen? Was war der Grund für "terminated with code 15"?
                      • Negalein
                        war ein Irrtum. War ein anderer Adapter.
                        • simatec
                          simatec Developer Most Active last edited by simatec
                          So hier die nächste Version zum testen ...
                          Version 1.1.4 liegt auf Github.
                          Github: https://github.com/simatec/ioBroker.pegelalarm.git
                          Changelog
                          1.1.4 (2021-04-02)
                          • (simatec) Improved code for request from measuring stations
                          • Negalein
                            Installation lief 1A durch.
                            Bis jetzt keine Auffälligkeiten. 🙂
                              sigi234 Forum Testing Most Active @Negalein last edited by
                              @negalein sagte in Test Adapter pegelalarm v0.0.1-x:
                              Dito 👍
                              • simatec
                                simatec Developer Most Active @sigi234 last edited by
                                @sigi234 @Negalein
                                Stellt den Log mal bitte auch auf debug und beobachtet, ob alle Request richtig durchlaufen.
                                Debug gibt da einige Infos raus.
                                Negalein sigi234 2 Replies Last reply Reply Quote 0
                                • Negalein
                                  2021-04-02 14:52:00.098  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 15862
                                  2021-04-02 14:52:01.006  - debug: pegelalarm.1 (15862) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  2021-04-02 14:52:01.116  - debug: pegelalarm.1 (15862) Objects client ready ... initialize now
                                  2021-04-02 14:52:01.150  - debug: pegelalarm.1 (15862) Objects create System PubSub Client
                                  2021-04-02 14:52:01.155  - debug: pegelalarm.1 (15862) Objects create User PubSub Client
                                  2021-04-02 14:52:01.157  - debug: pegelalarm.1 (15862) Objects client initialize lua scripts
                                  2021-04-02 14:52:01.228  - debug: pegelalarm.1 (15862) Objects connected to redis: 0.0.0.0:9001
                                  2021-04-02 14:52:01.243  - debug: pegelalarm.1 (15862) objectDB connected
                                  2021-04-02 14:52:01.246  - debug: pegelalarm.1 (15862) Redis States: Use Redis connection: 0.0.0.0:9000
                                  2021-04-02 14:52:01.283  - debug: pegelalarm.1 (15862) States create User PubSub Client
                                  2021-04-02 14:52:01.298  - debug: pegelalarm.1 (15862) States create System PubSub Client
                                  2021-04-02 14:52:01.690  - debug: pegelalarm.1 (15862) States connected to redis: 0.0.0.0:9000
                                  2021-04-02 14:52:01.691  - debug: pegelalarm.1 (15862) statesDB connected
                                  2021-04-02 14:52:03.625  - info: pegelalarm.1 (15862) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
                                  2021-04-02 14:52:03.655  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is started ...
                                  2021-04-02 14:52:03.658  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
                                  2021-04-02 14:52:03.904  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
                                  2021-04-02 14:52:06.046  - debug: pegelalarm.1 (15862) Pegelalarm request done
                                  2021-04-02 14:52:06.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is finish ...
                                  2021-04-02 14:52:07.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is started ...
                                  2021-04-02 14:52:07.048  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
                                  2021-04-02 14:52:07.396  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
                                  2021-04-02 14:52:09.532  - debug: pegelalarm.1 (15862) Pegelalarm request done
                                  2021-04-02 14:52:09.533  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is finish ...
                                  2021-04-02 14:52:12.536  - debug: pegelalarm.1 (15862) Pegelalarm Request is completed
                                  2021-04-02 14:52:17.538  - debug: pegelalarm.1 (15862) Check for deleting old objects is started
                                  2021-04-02 14:52:37.542  - debug: pegelalarm.1 (15862) cleaned everything up...
                                  2021-04-02 14:52:37.681  - info: pegelalarm.1 (15862) Terminated (NO_ERROR): Without reason
                                  2021-04-02 14:52:38.191  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
                                  2021-04-02 15:00:08.440  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 27391
                                  2021-04-02 15:00:09.420  - debug: pegelalarm.1 (27391) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  2021-04-02 15:00:09.547  - debug: pegelalarm.1 (27391) Objects client ready ... initialize now
                                  2021-04-02 15:00:09.558  - debug: pegelalarm.1 (27391) Objects create System PubSub Client
                                  2021-04-02 15:00:09.561  - debug: pegelalarm.1 (27391) Objects create User PubSub Client
                                  2021-04-02 15:00:09.562  - debug: pegelalarm.1 (27391) Objects client initialize lua scripts
                                  2021-04-02 15:00:09.624  - debug: pegelalarm.1 (27391) Objects connected to redis: 0.0.0.0:9001
                                  2021-04-02 15:00:09.681  - debug: pegelalarm.1 (27391) objectDB connected
                                  2021-04-02 15:00:09.683  - debug: pegelalarm.1 (27391) Redis States: Use Redis connection: 0.0.0.0:9000
                                  2021-04-02 15:00:09.709  - debug: pegelalarm.1 (27391) States create User PubSub Client
                                  2021-04-02 15:00:09.717  - debug: pegelalarm.1 (27391) States create System PubSub Client
                                  2021-04-02 15:00:09.809  - debug: pegelalarm.1 (27391) States connected to redis: 0.0.0.0:9000
                                  2021-04-02 15:00:09.811  - debug: pegelalarm.1 (27391) statesDB connected
                                  2021-04-02 15:00:11.230  - info: pegelalarm.1 (27391) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
                                  2021-04-02 15:00:11.290  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is started ...
                                  2021-04-02 15:00:11.295  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
                                  2021-04-02 15:00:11.521  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
                                  2021-04-02 15:00:12.526  - info: host.iobroker instance system.adapter.pegelalarm.0 started with pid 27460
                                  2021-04-02 15:00:13.387  - debug: pegelalarm.0 (27460) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  2021-04-02 15:00:13.437  - debug: pegelalarm.0 (27460) Objects client ready ... initialize now
                                  2021-04-02 15:00:13.484  - debug: pegelalarm.0 (27460) Objects create System PubSub Client
                                  2021-04-02 15:00:13.486  - debug: pegelalarm.0 (27460) Objects create User PubSub Client
                                  2021-04-02 15:00:13.489  - debug: pegelalarm.0 (27460) Objects client initialize lua scripts
                                  2021-04-02 15:00:13.571  - debug: pegelalarm.0 (27460) Objects connected to redis: 0.0.0.0:9001
                                  2021-04-02 15:00:13.591  - debug: pegelalarm.0 (27460) objectDB connected
                                  2021-04-02 15:00:13.593  - debug: pegelalarm.0 (27460) Redis States: Use Redis connection: 0.0.0.0:9000
                                  2021-04-02 15:00:13.618  - debug: pegelalarm.0 (27460) States create User PubSub Client
                                  2021-04-02 15:00:13.621  - debug: pegelalarm.0 (27460) States create System PubSub Client
                                  2021-04-02 15:00:13.671  - debug: pegelalarm.0 (27460) States connected to redis: 0.0.0.0:9000
                                  2021-04-02 15:00:13.674  - debug: pegelalarm.0 (27460) statesDB connected
                                  2021-04-02 15:00:13.682  - debug: pegelalarm.1 (27391) Pegelalarm request done
                                  2021-04-02 15:00:13.683  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is finish ...
                                  2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is started ...
                                  2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
                                  2021-04-02 15:00:14.912  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
                                  2021-04-02 15:00:15.946  - info: pegelalarm.0 (27460) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
                                  2021-04-02 15:00:15.966  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is started ...
                                  2021-04-02 15:00:15.968  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Inn&qStationName=Sch%C3%A4rding
                                  2021-04-02 15:00:16.261  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
                                  2021-04-02 15:00:17.098  - debug: pegelalarm.1 (27391) Pegelalarm request done
                                  2021-04-02 15:00:17.099  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is finish ...
                                  2021-04-02 15:00:18.420  - debug: pegelalarm.0 (27460) Pegelalarm request done
                                  2021-04-02 15:00:18.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is finish ...
                                  2021-04-02 15:00:19.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is started ...
                                  2021-04-02 15:00:19.422  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Pram&qStationName=Pramerdorf
                                  2021-04-02 15:00:19.627  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
                                  2021-04-02 15:00:20.102  - debug: pegelalarm.1 (27391) Pegelalarm Request is completed
                                  2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request done
                                  2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is finish ...
                                  2021-04-02 15:00:24.764  - debug: pegelalarm.0 (27460) Pegelalarm Request is completed
                                  2021-04-02 15:00:25.104  - debug: pegelalarm.1 (27391) Check for deleting old objects is started
                                  2021-04-02 15:00:29.765  - debug: pegelalarm.0 (27460) Check for deleting old objects is started
                                  2021-04-02 15:00:45.109  - debug: pegelalarm.1 (27391) cleaned everything up...
                                  2021-04-02 15:00:45.167  - info: pegelalarm.1 (27391) Terminated (NO_ERROR): Without reason
                                  2021-04-02 15:00:45.679  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
                                  2021-04-02 15:00:49.771  - debug: pegelalarm.0 (27460) cleaned everything up...
                                  2021-04-02 15:00:49.797  - info: pegelalarm.0 (27460) Terminated (NO_ERROR): Without reason
                                  2021-04-02 15:00:50.307  - info: host.iobroker instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
                                    sigi234 Forum Testing Most Active @simatec last edited by
                                    @simatec
                                    pegelalarm.0	2021-04-02 15:18:13.280	info	(2420) Terminated (NO_ERROR): Without reason
                                    pegelalarm.0	2021-04-02 15:18:13.277	debug	(2420) cleaned everything up...
                                    pegelalarm.0	2021-04-02 15:17:53.261	debug	(2420) Check for deleting old objects is started
                                    pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm Request is completed
                                    pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request for measuring station 5 is finish ...
                                    pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request done
                                    pegelalarm.0	2021-04-02 15:17:48.135	debug	(2420) Pegelalarm API is available ... Status: 200
                                    pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems&qStationName=Kematen%20An%20Der%20Krems
                                    pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) Pegelalarm request for measuring station 5 is started ...
                                    pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request for measuring station 4 is finish ...
                                    pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request done
                                    pegelalarm.0	2021-04-02 15:17:30.363	debug	(2420) Pegelalarm API is available ... Status: 200
                                    pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Traun
                                    pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) Pegelalarm request for measuring station 4 is started ...
                                    pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request for measuring station 3 is finish ...
                                    pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request done
                                    pegelalarm.0	2021-04-02 15:17:18.896	debug	(2420) Pegelalarm API is available ... Status: 200
                                    pegelalarm.0	2021-04-02 15:17:18.781	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Steyr
                                    pegelalarm.0	2021-04-02 15:17:18.780	debug	(2420) Pegelalarm request for measuring station 3 is started ...
                                    pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request for measuring station 2 is finish ...
                                    pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request done
                                    pegelalarm.0	2021-04-02 15:17:05.406	debug	(2420) Pegelalarm API is available ... Status: 200
                                    pegelalarm.0	2021-04-02 15:17:05.283	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Donau
                                    pegelalarm.0	2021-04-02 15:17:05.282	debug	(2420) Pegelalarm request for measuring station 2 is started ...
                                    pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request for measuring station 1 is finish ...
                                    pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request done
                                    pegelalarm.0	2021-04-02 15:16:57.927	debug	(2420) Pegelalarm API is available ... Status: 200
                                    pegelalarm.0	2021-04-02 15:16:57.765	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems
                                    pegelalarm.0	2021-04-02 15:16:57.764	debug	(2420) Pegelalarm request for measuring station 1 is started ...
                                    pegelalarm.0	2021-04-02 15:16:57.757	info	(2420) starting. Version 1.1.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.pegelalarm, node: v12.21.0, js-controller: 3.2.16
                                    • simatec
                                      @sigi234 @Negalein
                                      Sieht gut aus ...
                                      @Negalein
                                      Ich würde die Instanzen etwas zeitversetzt fahren, damit es nicht zu eventuellen Request Fehlern kommt.
                                      • Negalein
                                        mach ich bereits seit Anfang an 🙂
                                          Ich denke man brauch die API nicht alle 15 Min. abrufen, eigentlich nur wenn eine Warnung gibt. Was denk Ihr?
                                          simatec Negalein 2 Replies Last reply Reply Quote 0
                                          • simatec
                                            @sigi234
                                            Ich denke auch, dass einmal die Stunde reichen sollte
                                            adapter fluss gewässer hochwasser hochwasser adapter pegelalarm
                                            10
                                            95
                                            7536
