    4. Test Adapter pegelalarm v0.0.1-x
    • simatec
      simatec Developer Most Active @Negalein last edited by simatec
      @negalein Da muss ich mir die API nochmal anschauen.
      Die Ausgabe sieht wie folgt aus wenn Passau Ingling gewählt wird
      {"status":{"code":200},"payload":{"stations":[{"name":"Inn / Passau Ingling Ow / de","commonid":"18007798-de","country":"Deutschland","stationName":"Passau Ingling Ow","water":"Inn","region":"Bayern","latitude":48.554052327939,"longitude":13.432204664619,"positionKm":0.0,"altitudeM":0.0,"data":[{"type":"height in cm","value":303.0,"requestDate":"03.08.2016T15:46:12+0200","sourceDate":"03.08.2016T15:30:00+0200"}],"trend":100,"situation":100,"visibility":"PUBLIC"},{"name":"Inn / Passau Ingling / de","commonid":"18008008-de","country":"Deutschland","stationName":"Passau Ingling","water":"Inn","region":"Bayern","latitude":48.561454544109,"longitude":13.444192030337,"positionKm":3.1,"altitudeM":289.19,"defaultWarnValueCm":670.0,"defaultWarnValueM3s":3000.0,"defaultAlarmValueCm":1159.0,"defaultAlarmValueM3s":6820.0,"data":[{"type":"height in cm","value":245.0,"requestDate":"31.03.2021T16:44:50+0200","sourceDate":"31.03.2021T16:30:00+0200"},{"type":"flow in m3s","value":630.0,"requestDate":"31.03.2021T16:44:50+0200","sourceDate":"31.03.2021T16:30:00+0200"}],"trend":10,"situation":10,"visibility":"PUBLIC"},{"name":"Inn / Passau Ingling Kw / de","commonid":"18007800-de","country":"Deutschland","stationName":"Passau Ingling Kw","water":"Inn","region":"Bayern","latitude":48.554052327939,"longitude":13.432204664619,"positionKm":4.2,"defaultWarnValueM3s":1200.0,"data":[{"type":"flow in m3s","value":642.0,"requestDate":"31.03.2021T16:29:08+0200","sourceDate":"31.03.2021T16:15:00+0200"}],"trend":10,"situation":10,"visibility":"PUBLIC"},{"name":"Inn / Passau Ingling Q / de","commonid":"18008019-de","country":"Deutschland","stationName":"Passau Ingling Q","water":"Inn","region":"Bayern, Passau","latitude":48.561466508438,"longitude":13.444119928175,"positionKm":3.1,"altitudeM":289.19,"data":[{"type":"flow in m3s","value":0.0,"requestDate":"25.07.2018T14:57:29+0200","sourceDate":"25.07.2018T14:45:00+0200"}],"trend":0,"situation":100,"visibility":"PUBLIC"}]}}
      • Negalein
        Negalein Global Moderator @simatec last edited by
        @simatec sagte in Test Adapter pegelalarm v0.0.1-x:
        Da sind leider alle 4 enthalten.
        Habe es gerade mit denn Daten auf der Website verglichen.
        Zumindest weiß ich nun, welchen DP ich loggen kann.
        • simatec
          @negalein Versuche bitte nochmal ... habe da noch einen Filter eingebaut, um die API Ausgaben gerade zu biegen
          Gleiche Version vom Github
          • Negalein
            Merci
            Nun kommt nur die gewünschte Messstelle! 👍
            • simatec
              @negalein Die API gibt da teilweise mehr raus, als gewollt.
              Man filtert auf eine Messstelle und es kommen 4 Stück an.
              Habe dadurch nun nochmal einen weiteren Filter nach dem Abruf der API gesetzt
              • Negalein
                Ja, ist mir auch aufgefallen.
                Hab ein paar getestet. Bei 10 waren es bestimmt 4 mit mehr Messstellen.
                Hast du gut gemacht! 🤘
                simatec 2 Replies Last reply Reply Quote 0
                • simatec
                  @negalein Dann Happy Testing 👍🏻
                  • simatec
                    @negalein Konntest du das Problem lösen? Was war der Grund für "terminated with code 15"?
                    • Negalein
                      war ein Irrtum. War ein anderer Adapter.
                      • simatec
                        simatec Developer Most Active last edited by simatec
                        So hier die nächste Version zum testen ...
                        Version 1.1.4 liegt auf Github.
                        Github: https://github.com/simatec/ioBroker.pegelalarm.git
                        Changelog
                        1.1.4 (2021-04-02)
                        • (simatec) Improved code for request from measuring stations
                        • Negalein
                          Installation lief 1A durch.
                          Bis jetzt keine Auffälligkeiten. 🙂
                            sigi234 Forum Testing Most Active @Negalein last edited by
                            @negalein sagte in Test Adapter pegelalarm v0.0.1-x:
                            Dito 👍
                            • simatec
                              simatec Developer Most Active @sigi234 last edited by
                              @sigi234 @Negalein
                              Stellt den Log mal bitte auch auf debug und beobachtet, ob alle Request richtig durchlaufen.
                              Debug gibt da einige Infos raus.
                              Negalein sigi234 2 Replies Last reply Reply Quote 0
                              • Negalein
                                2021-04-02 14:52:00.098  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 15862
                                2021-04-02 14:52:01.006  - debug: pegelalarm.1 (15862) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                2021-04-02 14:52:01.116  - debug: pegelalarm.1 (15862) Objects client ready ... initialize now
                                2021-04-02 14:52:01.150  - debug: pegelalarm.1 (15862) Objects create System PubSub Client
                                2021-04-02 14:52:01.155  - debug: pegelalarm.1 (15862) Objects create User PubSub Client
                                2021-04-02 14:52:01.157  - debug: pegelalarm.1 (15862) Objects client initialize lua scripts
                                2021-04-02 14:52:01.228  - debug: pegelalarm.1 (15862) Objects connected to redis: 0.0.0.0:9001
                                2021-04-02 14:52:01.243  - debug: pegelalarm.1 (15862) objectDB connected
                                2021-04-02 14:52:01.246  - debug: pegelalarm.1 (15862) Redis States: Use Redis connection: 0.0.0.0:9000
                                2021-04-02 14:52:01.283  - debug: pegelalarm.1 (15862) States create User PubSub Client
                                2021-04-02 14:52:01.298  - debug: pegelalarm.1 (15862) States create System PubSub Client
                                2021-04-02 14:52:01.690  - debug: pegelalarm.1 (15862) States connected to redis: 0.0.0.0:9000
                                2021-04-02 14:52:01.691  - debug: pegelalarm.1 (15862) statesDB connected
                                2021-04-02 14:52:03.625  - info: pegelalarm.1 (15862) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
                                2021-04-02 14:52:03.655  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is started ...
                                2021-04-02 14:52:03.658  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
                                2021-04-02 14:52:03.904  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
                                2021-04-02 14:52:06.046  - debug: pegelalarm.1 (15862) Pegelalarm request done
                                2021-04-02 14:52:06.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is finish ...
                                2021-04-02 14:52:07.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is started ...
                                2021-04-02 14:52:07.048  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
                                2021-04-02 14:52:07.396  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
                                2021-04-02 14:52:09.532  - debug: pegelalarm.1 (15862) Pegelalarm request done
                                2021-04-02 14:52:09.533  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is finish ...
                                2021-04-02 14:52:12.536  - debug: pegelalarm.1 (15862) Pegelalarm Request is completed
                                2021-04-02 14:52:17.538  - debug: pegelalarm.1 (15862) Check for deleting old objects is started
                                2021-04-02 14:52:37.542  - debug: pegelalarm.1 (15862) cleaned everything up...
                                2021-04-02 14:52:37.681  - info: pegelalarm.1 (15862) Terminated (NO_ERROR): Without reason
                                2021-04-02 14:52:38.191  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
                                2021-04-02 15:00:08.440  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 27391
                                2021-04-02 15:00:09.420  - debug: pegelalarm.1 (27391) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                2021-04-02 15:00:09.547  - debug: pegelalarm.1 (27391) Objects client ready ... initialize now
                                2021-04-02 15:00:09.558  - debug: pegelalarm.1 (27391) Objects create System PubSub Client
                                2021-04-02 15:00:09.561  - debug: pegelalarm.1 (27391) Objects create User PubSub Client
                                2021-04-02 15:00:09.562  - debug: pegelalarm.1 (27391) Objects client initialize lua scripts
                                2021-04-02 15:00:09.624  - debug: pegelalarm.1 (27391) Objects connected to redis: 0.0.0.0:9001
                                2021-04-02 15:00:09.681  - debug: pegelalarm.1 (27391) objectDB connected
                                2021-04-02 15:00:09.683  - debug: pegelalarm.1 (27391) Redis States: Use Redis connection: 0.0.0.0:9000
                                2021-04-02 15:00:09.709  - debug: pegelalarm.1 (27391) States create User PubSub Client
                                2021-04-02 15:00:09.717  - debug: pegelalarm.1 (27391) States create System PubSub Client
                                2021-04-02 15:00:09.809  - debug: pegelalarm.1 (27391) States connected to redis: 0.0.0.0:9000
                                2021-04-02 15:00:09.811  - debug: pegelalarm.1 (27391) statesDB connected
                                2021-04-02 15:00:11.230  - info: pegelalarm.1 (27391) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
                                2021-04-02 15:00:11.290  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is started ...
                                2021-04-02 15:00:11.295  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
                                2021-04-02 15:00:11.521  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
                                2021-04-02 15:00:12.526  - info: host.iobroker instance system.adapter.pegelalarm.0 started with pid 27460
                                2021-04-02 15:00:13.387  - debug: pegelalarm.0 (27460) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                2021-04-02 15:00:13.437  - debug: pegelalarm.0 (27460) Objects client ready ... initialize now
                                2021-04-02 15:00:13.484  - debug: pegelalarm.0 (27460) Objects create System PubSub Client
                                2021-04-02 15:00:13.486  - debug: pegelalarm.0 (27460) Objects create User PubSub Client
                                2021-04-02 15:00:13.489  - debug: pegelalarm.0 (27460) Objects client initialize lua scripts
                                2021-04-02 15:00:13.571  - debug: pegelalarm.0 (27460) Objects connected to redis: 0.0.0.0:9001
                                2021-04-02 15:00:13.591  - debug: pegelalarm.0 (27460) objectDB connected
                                2021-04-02 15:00:13.593  - debug: pegelalarm.0 (27460) Redis States: Use Redis connection: 0.0.0.0:9000
                                2021-04-02 15:00:13.618  - debug: pegelalarm.0 (27460) States create User PubSub Client
                                2021-04-02 15:00:13.621  - debug: pegelalarm.0 (27460) States create System PubSub Client
                                2021-04-02 15:00:13.671  - debug: pegelalarm.0 (27460) States connected to redis: 0.0.0.0:9000
                                2021-04-02 15:00:13.674  - debug: pegelalarm.0 (27460) statesDB connected
                                2021-04-02 15:00:13.682  - debug: pegelalarm.1 (27391) Pegelalarm request done
                                2021-04-02 15:00:13.683  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is finish ...
                                2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is started ...
                                2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
                                2021-04-02 15:00:14.912  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
                                2021-04-02 15:00:15.946  - info: pegelalarm.0 (27460) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
                                2021-04-02 15:00:15.966  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is started ...
                                2021-04-02 15:00:15.968  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Inn&qStationName=Sch%C3%A4rding
                                2021-04-02 15:00:16.261  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
                                2021-04-02 15:00:17.098  - debug: pegelalarm.1 (27391) Pegelalarm request done
                                2021-04-02 15:00:17.099  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is finish ...
                                2021-04-02 15:00:18.420  - debug: pegelalarm.0 (27460) Pegelalarm request done
                                2021-04-02 15:00:18.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is finish ...
                                2021-04-02 15:00:19.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is started ...
                                2021-04-02 15:00:19.422  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Pram&qStationName=Pramerdorf
                                2021-04-02 15:00:19.627  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
                                2021-04-02 15:00:20.102  - debug: pegelalarm.1 (27391) Pegelalarm Request is completed
                                2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request done
                                2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is finish ...
                                2021-04-02 15:00:24.764  - debug: pegelalarm.0 (27460) Pegelalarm Request is completed
                                2021-04-02 15:00:25.104  - debug: pegelalarm.1 (27391) Check for deleting old objects is started
                                2021-04-02 15:00:29.765  - debug: pegelalarm.0 (27460) Check for deleting old objects is started
                                2021-04-02 15:00:45.109  - debug: pegelalarm.1 (27391) cleaned everything up...
                                2021-04-02 15:00:45.167  - info: pegelalarm.1 (27391) Terminated (NO_ERROR): Without reason
                                2021-04-02 15:00:45.679  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
                                2021-04-02 15:00:49.771  - debug: pegelalarm.0 (27460) cleaned everything up...
                                2021-04-02 15:00:49.797  - info: pegelalarm.0 (27460) Terminated (NO_ERROR): Without reason
                                2021-04-02 15:00:50.307  - info: host.iobroker instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
                                  sigi234 Forum Testing Most Active @simatec last edited by
                                  @simatec
                                  pegelalarm.0	2021-04-02 15:18:13.280	info	(2420) Terminated (NO_ERROR): Without reason
                                  pegelalarm.0	2021-04-02 15:18:13.277	debug	(2420) cleaned everything up...
                                  pegelalarm.0	2021-04-02 15:17:53.261	debug	(2420) Check for deleting old objects is started
                                  pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm Request is completed
                                  pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request for measuring station 5 is finish ...
                                  pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request done
                                  pegelalarm.0	2021-04-02 15:17:48.135	debug	(2420) Pegelalarm API is available ... Status: 200
                                  pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems&qStationName=Kematen%20An%20Der%20Krems
                                  pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) Pegelalarm request for measuring station 5 is started ...
                                  pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request for measuring station 4 is finish ...
                                  pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request done
                                  pegelalarm.0	2021-04-02 15:17:30.363	debug	(2420) Pegelalarm API is available ... Status: 200
                                  pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Traun
                                  pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) Pegelalarm request for measuring station 4 is started ...
                                  pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request for measuring station 3 is finish ...
                                  pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request done
                                  pegelalarm.0	2021-04-02 15:17:18.896	debug	(2420) Pegelalarm API is available ... Status: 200
                                  pegelalarm.0	2021-04-02 15:17:18.781	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Steyr
                                  pegelalarm.0	2021-04-02 15:17:18.780	debug	(2420) Pegelalarm request for measuring station 3 is started ...
                                  pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request for measuring station 2 is finish ...
                                  pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request done
                                  pegelalarm.0	2021-04-02 15:17:05.406	debug	(2420) Pegelalarm API is available ... Status: 200
                                  pegelalarm.0	2021-04-02 15:17:05.283	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Donau
                                  pegelalarm.0	2021-04-02 15:17:05.282	debug	(2420) Pegelalarm request for measuring station 2 is started ...
                                  pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request for measuring station 1 is finish ...
                                  pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request done
                                  pegelalarm.0	2021-04-02 15:16:57.927	debug	(2420) Pegelalarm API is available ... Status: 200
                                  pegelalarm.0	2021-04-02 15:16:57.765	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems
                                  pegelalarm.0	2021-04-02 15:16:57.764	debug	(2420) Pegelalarm request for measuring station 1 is started ...
                                  pegelalarm.0	2021-04-02 15:16:57.757	info	(2420) starting. Version 1.1.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.pegelalarm, node: v12.21.0, js-controller: 3.2.16
                                  • simatec
                                    @sigi234 @Negalein
                                    Sieht gut aus ...
                                    @Negalein
                                    Ich würde die Instanzen etwas zeitversetzt fahren, damit es nicht zu eventuellen Request Fehlern kommt.
                                    • Negalein
                                      mach ich bereits seit Anfang an 🙂
                                        Ich denke man brauch die API nicht alle 15 Min. abrufen, eigentlich nur wenn eine Warnung gibt. Was denk Ihr?
                                        simatec Negalein 2 Replies Last reply Reply Quote 0
                                        • simatec
                                          @sigi234
                                          Ich denke auch, dass einmal die Stunde reichen sollte
                                          • Negalein
                                            Negalein Global Moderator @sigi234 last edited by
                                            @sigi234 sagte in Test Adapter pegelalarm v0.0.1-x:
                                            Was denk Ihr?
                                            Ja, das würde sicher reichen.
                                            Cool wäre es, wenn der Adapter erkennt das eine Warnung da ist und dann selbsständig den Cron auf zB 15 Min. verändert. Wenn Warnung wieder weg, dann Cron wieder auf 60 Min.!
                                            Aber ob das vom Adapter möglich ist?
                                            31.7k
                                            79.8k
                                            adapter fluss gewässer hochwasser hochwasser adapter pegelalarm
                                            10
                                            95
                                            7020
