    • pfried
      pfried @pfried last edited by pfried
      @jomjol
      @pfried said in Wasserzähler - Version 2 - all-in-device:
      @jomjol Guten Morgen, ich habe jetzt dauernd im IOBroker MQTT Adapter folgende Fehlermeldung seit einiger Zeit:
      mqtt.0	2021-04-01 09:40:46.771	info	(29466) Client [gaszaehler] reconnected. Old secret 1617262821326_2128. New secret 1617262846770_6566
      mqtt.0	2021-04-01 09:40:21.335	info	(29466) Client [gaszaehler] reconnected. Old secret 1617261963053_8627. New secret 1617262821326_2128
      mqtt.0	2021-04-01 09:39:50.196	info	(29466) Client [wasserzaehler] connected with secret 1617262790195_3666
      mqtt.0	2021-04-01 09:39:35.145	info	(29466) Client [wasserzaehler] connection closed: closed
      mqtt.0	2021-04-01 09:38:12.057	warn	(29466) Client [wasserzaehler] Message 38530 deleted after 11 retries
      mqtt.0	2021-04-01 09:37:48.070	warn	(29466) Client [wasserzaehler] Cannot publish message: TypeError [ERR_INVALID_ARG_TYPE]: The "string" argument must be of type string or an instance of Buffer or ArrayBuffer. Received type number (182
      fb-checkpresence.0	2021-04-01 09:35:48.273	info	(2689) newActive Regina false
      mqtt.0	2021-04-01 09:33:59.541	info	(29466) Client [wasserzaehler] reconnected. Old secret 1617262390637_1786. New secret 1617262439540_1195
      mqtt.0	2021-04-01 09:33:10.638	info	(29466) Client [wasserzaehler] connected with secret 1617262390637_1786
      mqtt.0	2021-04-01 09:32:55.162	info	(29466) Client [wasserzaehler] connection closed: closed
      mqtt.0	2021-04-01 09:31:32.004	warn	(29466) Client [wasserzaehler] Message 10577 deleted after 11 retries
      mqtt.0	2021-04-01 09:31:08.010	warn	(29466) Client [wasserzaehler] Cannot publish message: TypeError [ERR_INVALID_ARG_TYPE]: The "string" argument must be of type string or an instance of Buffer or ArrayBuffer. Received type number (182
      Hängt das nun mit dem IOBroker, oder doch mit dem AID (All-in-Device) zusammen?
      Habe den Fehler gefunden: Im IOBroker war unter Dezimaltrennzeichen das Komma eingestellt, du schickst aber die Zahl mit einem Punkt. Kann man das in der Config.ini einstellbar machen? Wenn nein, sollte man das in die Doku irgendwie aufnehmen....
        Homoran Global Moderator Administrators @pfried last edited by
        @pfried sagte in Wasserzähler - Version 2 - all-in-device:
        einfach im Suchfeld "ESP32" eingeben
        kommt nix (=0) 😉
        pfried 1 Reply Last reply Reply Quote 0
          jomjol @pfried last edited by
          @pfried Ist momentan nicht konfigurierbar - ich nehme es mal als Idee in den Speicher mit auf. Bevor jetzt der Artikel kommt, will ich keine Änderungen mehr einspielen - typischerweise geht dann irgendwas nicht auf Anhieb 🙂
          • pfried
            pfried @Homoran last edited by
            @homoran Sorry, ich meinte "Board Manager" ... mein Fehler
            • BananaJoe
              BananaJoe Most Active last edited by
              Ich hatte beim Flashen unter Windows auch zunächst Probleme. Im Windows-Flash-Tool sah alles gut aus und die Dateien waren ausgewählt.
              In der dazu gehörigen Eingabeaufforderungsfenster wo man die Ausgabe der vom GUI Tool ausgeführten Kommandozeilenbefehle sah jedoch nicht.
              Gründe waren bei mir folgende:
              • Pfad zu lang / Leerzeichen enthalten /Sonderzeichen
              • Tool nicht per Rechtsklick => Als Administrator ausführen gestartet
              Also sowohl das Tool als auch die Firmware-Dateien mal in kurzen Pfaden ohne Leerzeichen und ohne äöü+- etc. hinterlegen.
              • BananaJoe
                Und einen habe ich noch:
                Es gibt auf Github den Master-Branch und den Rolling-Branch.
                Bei zweiteren hat er das Ansteuern der SD-Karten wieder zurückgeändert (wieder auf 4Bit statt 1Bit)
                Das.scheint die Kompatibilität zu vielen SD-Karten stark erhöht zu haben. Nachzulesen in den Posts weiter oben
                  ich auch!
                  den esp32 hab ich da nicht drin.
                    jomjol @BananaJoe last edited by
                    @bananajoe sagte in Wasserzähler - Version 2 - all-in-device:
                    Da muss ich leider korrigieren - es ist jetzt überall wieder 1-line. Aber mit einem upgedaten Modul. Ich habe das bei mir auf SD-Karten von 6 Herstellern getestet - 5 laufen und 1 mit 64 GB nicht und zwar im 1-line code und nach dem Update der Bibliothek.
                    • BananaJoe
                      BananaJoe Most Active @jomjol last edited by
                      @jomjol sagte in Wasserzähler - Version 2 - all-in-device:
                      Ah, die Änderung habe ich verpasst.
                      Aber die nachbestellten ESP32 für Strom- und Gas-Zähler sind gestern gekommen, da kann ich das dann auch austesten.
                      Mein erster Versuch mit dem Wasserzähler war zufällig mit der 4-Bit Variante
                        Homoran Global Moderator Administrators @BananaJoe last edited by
                        Habe jetzt mal einen fliegenden Aufbau versucht, klappte natürlich auf Anhieb besser als bei jeder Optimierung danach.
                        Da ich nicht weiß ob ich die Röhre überhaupt dorthin bekomme, bzw. ziemlich sicher bin dass es nicht geht, da direkt darüber der Absperrhahn für das Gas liegt, wollte ich die Mindesthöhe ausloten.
                        Wie gesagt, der erste Anlauf war der Beste:
                        im Moment bekomme ich nur verzerrte Bilder und viele NaN
                        Die Erkennung war eigentlich super, aber die KleinBilder passen nicht dazu 😉
                        • pfried
                          @homoran DIe Lichtreflexion auf dem linken 2er ist zu groß. Aufbau drehen und dann mit der Rotate Einstellung zurückdrehen. Die Ziffernfelder dürfen keine überlagerten "Blitzeffekte" aufweisen.
                            Homoran Global Moderator Administrators @pfried last edited by Homoran
                            dachte ich auch, aber damals hat er alles erkannt.
                            Im Moment ändere ich seit heute morgen nahezu kontinuierlich den Aufbau und schaffe es nicht mal mehr in diese Qualität:
                            Das sieht IMHO "mit den Augen eines Automaten gesehen" besser aus - klappt aber nicht
                            Diese Verzerrungen sind im Original Foto (ungedreht) nicht vorhanden
                            EDIT:
                            was ich mit dem vorherigen Bild zeigen wollte ist, dass die Zahlen zwar korrekt erkannt werden, die dazugehörigen Bildchen aber nicht passen.
                            So wie jetzt auch:
                            Trotz deutlicher Reflektionen gute Erkennung, aber die kleinen Bilder stammen von anderen Stellen
                            pfried Knallochse 2 Replies Last reply Reply Quote 0
                            • pfried
                              pfried @Homoran last edited by pfried
                              @homoran Auf was steht denn Dein DecimalShift in der Config.ini?
                              Nachtrag: sollte -3 sein
                                das hatte ich auf 0 gestellt, damit ich Liter herausbekomme
                                EDIT:
                                habe jetzt auf 3 gestellt und bekomme 73053200 statt 73053,200
                                • Knallochse
                                  Knallochse @Homoran last edited by
                                  @homoran sagte in Wasserzähler - Version 2 - all-in-device
                                  So wie jetzt auch:
                                  Kontrolliere nochmal deine ROI (digital) Reihenfolge.
                                  Kann mich nicht erinnern, dass dieses Problem hier schon mal aufgetreten war
                                    Homoran Global Moderator Administrators @Knallochse last edited by
                                    @knallochse sagte in Wasserzähler - Version 2 - all-in-device:
                                    hab ich bereits mehrfach 😉
                                    allerdings gehen die Namen durcheinander, weil ich nachträglich einen eingefügt und verschoben hatte
                                    Knallochse 1 Reply Last reply Reply Quote 0
                                    • Knallochse
                                      @homoran sagte in Wasserzähler - Version 2 - all-in-device:
                                      Ich vermute, dass da der Hase im Pfeffer liegt.
                                      In die Config.ini werden die Daten eingetragen. Da muß die Reihenfolge stimmen
                                        Homoran Global Moderator Administrators @Knallochse last edited by Homoran
                                        hab ich das denn falsch verstanden? Oder durch Try and Error falsch interpretiert?
                                        Neu hinzugefügt wird immer hinten, dann kann man doch mit move previous den in der Reihenfolge nach vorne schieben
                                        zumindest sind sie im Pulldown in der richtigen Reihenfolge
                                        • pfried
                                          @homoran Soweit ich auf Deinem Bild erkennen kann hast du 5 Stellen vor dem Komma und 4 nach dem Komma, davon ist die letzte Stelle der Nachkomma Sektion eine Analoge (also ein Zeiger). D.h. die Analoge Auswertung liefert 1 Digit und die Digitale Auswertung 8 Stellen. Solltest Du nun den DecimalShift auf Null gesetzt haben, sollte in dem Bild "00023042" und Analog "7" rauskommen. Der DecimaleShift funktioniert in beiden Richtungen, nur als Hinweis.
                                          Jetzt zu Deinem Bild (letztes Bild in Deinem Post): der große Bildausschnitt zeigt den gesamten Zähler: Digital: 00023042 die kleinen Bilder sind die extrahierten Bilder dazu, diese zeigen aber 00024242 ?? Entweder wartest Du zuwenig lang mit dem Screenshot bis der ESP32 die Bilder extrahiert hat, oder etwas anderes funktioniert nicht. Zuerst einmal muss Du die Bilder hinbekommen. Ich tippe darauf, dass du beim Kunfigurieren eine Stelle zweimal nimmst. Gehe nochmals die Regions of Interests (ROI) durch, der Fehler liegt sicher bei den Digital ROIs.
                                          Die schwarzen Zahlen neben den kleinen Bildern sind die Interpretation des ESPs zu den Zahlen in den kleinen Bildern. Das kann man noch später dem System anlernen diese richtig zu lesen....
                                            Habe ich jetzt nochmals gemacht 😉 nachdem ich das heute bereits bestimmt 10x machen musste weil ich das Referenzbild neu justiert hatte.
                                            beim Durchklicken der digitalen im Pulldown von 1-8 wandern die Rahmen ordnungsgemäß von links nach rechts.
                                            nein, sind sie ja eben nicht.
                                            Bei mir sind es die (mehr oder weniger) korrekten Interpretationen der Positionen des Rollenzählers im großen Bild, bei den kleinen Bildern zeigen aber zwei die Ausschnitte von anderen Positionen an
                                            238
                                            3411
                                            2021275
