    4. Test Adapter pegelalarm v0.0.1-x
    • Negalein
      Negalein Global Moderator @simatec last edited by
      @simatec sagte in Test Adapter pegelalarm v0.0.1-x:
      So hier die nächste Version zum testen ...
      Installation lief 1A durch.
      Bis jetzt keine Auffälligkeiten. 🙂
        sigi234 Forum Testing Most Active @Negalein last edited by
        @negalein sagte in Test Adapter pegelalarm v0.0.1-x:
        Dito 👍
        • simatec
          simatec Developer Most Active @sigi234 last edited by
          @sigi234 @Negalein
          Stellt den Log mal bitte auch auf debug und beobachtet, ob alle Request richtig durchlaufen.
          Debug gibt da einige Infos raus.
          Negalein sigi234 2 Replies Last reply Reply Quote 0
          • Negalein
            2021-04-02 14:52:00.098  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 15862
            2021-04-02 14:52:01.006  - debug: pegelalarm.1 (15862) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2021-04-02 14:52:01.116  - debug: pegelalarm.1 (15862) Objects client ready ... initialize now
            2021-04-02 14:52:01.150  - debug: pegelalarm.1 (15862) Objects create System PubSub Client
            2021-04-02 14:52:01.155  - debug: pegelalarm.1 (15862) Objects create User PubSub Client
            2021-04-02 14:52:01.157  - debug: pegelalarm.1 (15862) Objects client initialize lua scripts
            2021-04-02 14:52:01.228  - debug: pegelalarm.1 (15862) Objects connected to redis: 0.0.0.0:9001
            2021-04-02 14:52:01.243  - debug: pegelalarm.1 (15862) objectDB connected
            2021-04-02 14:52:01.246  - debug: pegelalarm.1 (15862) Redis States: Use Redis connection: 0.0.0.0:9000
            2021-04-02 14:52:01.283  - debug: pegelalarm.1 (15862) States create User PubSub Client
            2021-04-02 14:52:01.298  - debug: pegelalarm.1 (15862) States create System PubSub Client
            2021-04-02 14:52:01.690  - debug: pegelalarm.1 (15862) States connected to redis: 0.0.0.0:9000
            2021-04-02 14:52:01.691  - debug: pegelalarm.1 (15862) statesDB connected
            2021-04-02 14:52:03.625  - info: pegelalarm.1 (15862) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
            2021-04-02 14:52:03.655  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is started ...
            2021-04-02 14:52:03.658  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
            2021-04-02 14:52:03.904  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
            2021-04-02 14:52:06.046  - debug: pegelalarm.1 (15862) Pegelalarm request done
            2021-04-02 14:52:06.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 1 is finish ...
            2021-04-02 14:52:07.047  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is started ...
            2021-04-02 14:52:07.048  - debug: pegelalarm.1 (15862) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
            2021-04-02 14:52:07.396  - debug: pegelalarm.1 (15862) Pegelalarm API is available ... Status: 200
            2021-04-02 14:52:09.532  - debug: pegelalarm.1 (15862) Pegelalarm request done
            2021-04-02 14:52:09.533  - debug: pegelalarm.1 (15862) Pegelalarm request for measuring station 2 is finish ...
            2021-04-02 14:52:12.536  - debug: pegelalarm.1 (15862) Pegelalarm Request is completed
            2021-04-02 14:52:17.538  - debug: pegelalarm.1 (15862) Check for deleting old objects is started
            2021-04-02 14:52:37.542  - debug: pegelalarm.1 (15862) cleaned everything up...
            2021-04-02 14:52:37.681  - info: pegelalarm.1 (15862) Terminated (NO_ERROR): Without reason
            2021-04-02 14:52:38.191  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
            2021-04-02 15:00:08.440  - info: host.iobroker instance system.adapter.pegelalarm.1 started with pid 27391
            2021-04-02 15:00:09.420  - debug: pegelalarm.1 (27391) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2021-04-02 15:00:09.547  - debug: pegelalarm.1 (27391) Objects client ready ... initialize now
            2021-04-02 15:00:09.558  - debug: pegelalarm.1 (27391) Objects create System PubSub Client
            2021-04-02 15:00:09.561  - debug: pegelalarm.1 (27391) Objects create User PubSub Client
            2021-04-02 15:00:09.562  - debug: pegelalarm.1 (27391) Objects client initialize lua scripts
            2021-04-02 15:00:09.624  - debug: pegelalarm.1 (27391) Objects connected to redis: 0.0.0.0:9001
            2021-04-02 15:00:09.681  - debug: pegelalarm.1 (27391) objectDB connected
            2021-04-02 15:00:09.683  - debug: pegelalarm.1 (27391) Redis States: Use Redis connection: 0.0.0.0:9000
            2021-04-02 15:00:09.709  - debug: pegelalarm.1 (27391) States create User PubSub Client
            2021-04-02 15:00:09.717  - debug: pegelalarm.1 (27391) States create System PubSub Client
            2021-04-02 15:00:09.809  - debug: pegelalarm.1 (27391) States connected to redis: 0.0.0.0:9000
            2021-04-02 15:00:09.811  - debug: pegelalarm.1 (27391) statesDB connected
            2021-04-02 15:00:11.230  - info: pegelalarm.1 (27391) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
            2021-04-02 15:00:11.290  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is started ...
            2021-04-02 15:00:11.295  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Ingling
            2021-04-02 15:00:11.521  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
            2021-04-02 15:00:12.526  - info: host.iobroker instance system.adapter.pegelalarm.0 started with pid 27460
            2021-04-02 15:00:13.387  - debug: pegelalarm.0 (27460) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2021-04-02 15:00:13.437  - debug: pegelalarm.0 (27460) Objects client ready ... initialize now
            2021-04-02 15:00:13.484  - debug: pegelalarm.0 (27460) Objects create System PubSub Client
            2021-04-02 15:00:13.486  - debug: pegelalarm.0 (27460) Objects create User PubSub Client
            2021-04-02 15:00:13.489  - debug: pegelalarm.0 (27460) Objects client initialize lua scripts
            2021-04-02 15:00:13.571  - debug: pegelalarm.0 (27460) Objects connected to redis: 0.0.0.0:9001
            2021-04-02 15:00:13.591  - debug: pegelalarm.0 (27460) objectDB connected
            2021-04-02 15:00:13.593  - debug: pegelalarm.0 (27460) Redis States: Use Redis connection: 0.0.0.0:9000
            2021-04-02 15:00:13.618  - debug: pegelalarm.0 (27460) States create User PubSub Client
            2021-04-02 15:00:13.621  - debug: pegelalarm.0 (27460) States create System PubSub Client
            2021-04-02 15:00:13.671  - debug: pegelalarm.0 (27460) States connected to redis: 0.0.0.0:9000
            2021-04-02 15:00:13.674  - debug: pegelalarm.0 (27460) statesDB connected
            2021-04-02 15:00:13.682  - debug: pegelalarm.1 (27391) Pegelalarm request done
            2021-04-02 15:00:13.683  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 1 is finish ...
            2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is started ...
            2021-04-02 15:00:14.685  - debug: pegelalarm.1 (27391) https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Bayern&qWater=Inn&qStationName=Passau%20Marienbr%C3%BCcke
            2021-04-02 15:00:14.912  - debug: pegelalarm.1 (27391) Pegelalarm API is available ... Status: 200
            2021-04-02 15:00:15.946  - info: pegelalarm.0 (27460) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v12.18.3, js-controller: 3.1.6
            2021-04-02 15:00:15.966  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is started ...
            2021-04-02 15:00:15.968  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Inn&qStationName=Sch%C3%A4rding
            2021-04-02 15:00:16.261  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
            2021-04-02 15:00:17.098  - debug: pegelalarm.1 (27391) Pegelalarm request done
            2021-04-02 15:00:17.099  - debug: pegelalarm.1 (27391) Pegelalarm request for measuring station 2 is finish ...
            2021-04-02 15:00:18.420  - debug: pegelalarm.0 (27460) Pegelalarm request done
            2021-04-02 15:00:18.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 1 is finish ...
            2021-04-02 15:00:19.421  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is started ...
            2021-04-02 15:00:19.422  - debug: pegelalarm.0 (27460) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Pram&qStationName=Pramerdorf
            2021-04-02 15:00:19.627  - debug: pegelalarm.0 (27460) Pegelalarm API is available ... Status: 200
            2021-04-02 15:00:20.102  - debug: pegelalarm.1 (27391) Pegelalarm Request is completed
            2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request done
            2021-04-02 15:00:21.760  - debug: pegelalarm.0 (27460) Pegelalarm request for measuring station 2 is finish ...
            2021-04-02 15:00:24.764  - debug: pegelalarm.0 (27460) Pegelalarm Request is completed
            2021-04-02 15:00:25.104  - debug: pegelalarm.1 (27391) Check for deleting old objects is started
            2021-04-02 15:00:29.765  - debug: pegelalarm.0 (27460) Check for deleting old objects is started
            2021-04-02 15:00:45.109  - debug: pegelalarm.1 (27391) cleaned everything up...
            2021-04-02 15:00:45.167  - info: pegelalarm.1 (27391) Terminated (NO_ERROR): Without reason
            2021-04-02 15:00:45.679  - info: host.iobroker instance system.adapter.pegelalarm.1 terminated with code 0 (NO_ERROR)
            2021-04-02 15:00:49.771  - debug: pegelalarm.0 (27460) cleaned everything up...
            2021-04-02 15:00:49.797  - info: pegelalarm.0 (27460) Terminated (NO_ERROR): Without reason
            2021-04-02 15:00:50.307  - info: host.iobroker instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
              sigi234 Forum Testing Most Active @simatec last edited by
              @simatec
              pegelalarm.0	2021-04-02 15:18:13.280	info	(2420) Terminated (NO_ERROR): Without reason
              pegelalarm.0	2021-04-02 15:18:13.277	debug	(2420) cleaned everything up...
              pegelalarm.0	2021-04-02 15:17:53.261	debug	(2420) Check for deleting old objects is started
              pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm Request is completed
              pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request for measuring station 5 is finish ...
              pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request done
              pegelalarm.0	2021-04-02 15:17:48.135	debug	(2420) Pegelalarm API is available ... Status: 200
              pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems&qStationName=Kematen%20An%20Der%20Krems
              pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) Pegelalarm request for measuring station 5 is started ...
              pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request for measuring station 4 is finish ...
              pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request done
              pegelalarm.0	2021-04-02 15:17:30.363	debug	(2420) Pegelalarm API is available ... Status: 200
              pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Traun
              pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) Pegelalarm request for measuring station 4 is started ...
              pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request for measuring station 3 is finish ...
              pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request done
              pegelalarm.0	2021-04-02 15:17:18.896	debug	(2420) Pegelalarm API is available ... Status: 200
              pegelalarm.0	2021-04-02 15:17:18.781	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Steyr
              pegelalarm.0	2021-04-02 15:17:18.780	debug	(2420) Pegelalarm request for measuring station 3 is started ...
              pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request for measuring station 2 is finish ...
              pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request done
              pegelalarm.0	2021-04-02 15:17:05.406	debug	(2420) Pegelalarm API is available ... Status: 200
              pegelalarm.0	2021-04-02 15:17:05.283	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Donau
              pegelalarm.0	2021-04-02 15:17:05.282	debug	(2420) Pegelalarm request for measuring station 2 is started ...
              pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request for measuring station 1 is finish ...
              pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request done
              pegelalarm.0	2021-04-02 15:16:57.927	debug	(2420) Pegelalarm API is available ... Status: 200
              pegelalarm.0	2021-04-02 15:16:57.765	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems
              pegelalarm.0	2021-04-02 15:16:57.764	debug	(2420) Pegelalarm request for measuring station 1 is started ...
              pegelalarm.0	2021-04-02 15:16:57.757	info	(2420) starting. Version 1.1.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.pegelalarm, node: v12.21.0, js-controller: 3.2.16
              • simatec
                @sigi234 @Negalein
                Sieht gut aus ...
                @Negalein
                Ich würde die Instanzen etwas zeitversetzt fahren, damit es nicht zu eventuellen Request Fehlern kommt.
                • Negalein
                  mach ich bereits seit Anfang an 🙂
                    Ich denke man brauch die API nicht alle 15 Min. abrufen, eigentlich nur wenn eine Warnung gibt. Was denk Ihr?
                    simatec Negalein 2 Replies Last reply Reply Quote 0
                    • simatec
                      @sigi234
                      Ich denke auch, dass einmal die Stunde reichen sollte
                      • Negalein
                        Negalein Global Moderator @sigi234 last edited by
                        @sigi234 sagte in Test Adapter pegelalarm v0.0.1-x:
                        Was denk Ihr?
                        Ja, das würde sicher reichen.
                        Cool wäre es, wenn der Adapter erkennt das eine Warnung da ist und dann selbsständig den Cron auf zB 15 Min. verändert. Wenn Warnung wieder weg, dann Cron wieder auf 60 Min.!
                        Aber ob das vom Adapter möglich ist?
                        • simatec
                          Hier die Version 1.1.5 zum testen auf Github
                          Github: https://github.com/simatec/ioBroker.pegelalarm.git
                          Changelog
                          1.1.5 (2021-04-07)
                          • (simatec) fetch added
                          • (simatec) sentry added
                          Latzi Negalein 2 Replies Last reply Reply Quote 0
                          • Latzi
                            Latzi @simatec last edited by
                            @simatec
                            👍 läuft!
                            • Negalein
                              • simatec
                                So die Version 1.1.7 ist nun im latest ..
                                Hier gehts weiter 😉
                                31.7k
                                79.8k
                                adapter fluss gewässer hochwasser hochwasser adapter pegelalarm
                                10
                                95
                                7020
