    5. Mit Werten aus SQL-Adapter rechnen/abfragen
      liv-in-sky @David G. last edited by
      @david-g kannst du machen - aber wenn du alle 30 oder 60 min die daten holst, kann das script kurz duchlaufen
      aber hier mal eine blockly version mit allem drin
       <variables>
         <variable id="YlMXv/1bH+LS:H24mJ6h">x</variable>
       </variables>
       <block type="on" id="pa9(FWtZ;Q44*O_x,:?^" disabled="true" x="563" y="37">
         <field name="OID">iot.0.services.custom_tanken</field>
       <block type="logic_operation" id="ORfdCv^0fjBcwU%Am1-/" inline="false" disabled="true" x="763" y="38">
         <field name="OP">AND</field>
           <block type="logic_compare" id="4uWKQ6wB2^|5Mw]bJDF@">
             <field name="OP">NEQ</field>
               <block type="get_value" id="pC=zB]ulq]*e-3OTWMgr">
                 <field name="OID">0_userdata.0.Tanken.Diesel_3_Tage</field>
               <block type="math_number" id=":XN:N~H%oh2TZF_TU,tn">
                 <field name="NUM">0</field>
       <block type="procedures_callcustomnoreturn" id=";`4Mx]ofsd^0/uZ}GGmL" x="413" y="137">
         <mutation name="etwas tun"></mutation>
       <block type="procedures_defnoreturn" id="fh|Pq_xhE`]~vQy:9[VQ" x="88" y="187">
         <mutation>
           <arg name="x" varid="YlMXv/1bH+LS:H24mJ6h"></arg>
         </mutation>
         <field name="NAME">benachrichtigung</field>
         <statement name="STACK">
           <block type="controls_if" id="?-:g4ZtCBqJr+Z26C5};">
               <block type="logic_operation" id="PiYCCyZ@WrZYAbDnJB^H" inline="false">
                   <block type="time_compare_ex" id="32?TD_h,_n,w47NwOH-`">
                     <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="false" actual_time="true"></mutation>
                     <field name="OPTION">&gt;</field>
                     <value name="START_TIME">
                       <shadow type="text" id="$T?X^6vkibPk*L[]Wnk{">
                         <field name="TEXT">12:00</field>
                   <block type="time_compare_ex" id="l^Ik)t?;|6DWeLLsb$Iz">
                     <field name="OPTION">&lt;</field>
                       <shadow type="text" id="$eT_MD3kTs-~7LE7;^yE">
                         <field name="TEXT">21:00</field>
               <block type="debug" id="tGD.?r}T(]ZfEN6]-G9p">
                 <value name="TEXT">
                   <shadow type="text" id="s3SkWTbDZxvuh;6}8OCY">
                   <block type="variables_get" id="bN{[bO-I)DU+xuX6-PR%">
                     <field name="VAR" id="YlMXv/1bH+LS:H24mJ6h">x</field>
                   <block type="pushover" id="N}lEukazHnEzXzFrwoqe">
                     <field name="INSTANCE">.0</field>
                     <field name="SOUND"></field>
                     <field name="PRIORITY">0</field>
                     <field name="LOG"></field>
                     <value name="MESSAGE">
                       <shadow type="text" id="|krAJI9FJSf$rX0$FEmd">
                       <block type="text_join" id="k$f1SSAE7JJ2ZTi%CJ#Q">
                         <value name="ADD0">
                           <block type="text" id="M)fQF]*^`:t}nqJfO}/8">
                             <field name="TEXT">kannst gerne tanken -  </field>
                         <value name="ADD1">
                           <block type="variables_get" id=":N*AJdJsZj!TD%k/qI;y">
                         <value name="ADD2">
                           <block type="text" id="rEHYB*7kf!2hH7MmL=i9">
                             <field name="TEXT"> €</field>
                       <block type="telegram" id="e6![_6kpAfd$|U(sWw9p">
                         <field name="INSTANCE">.1</field>
                           <shadow type="text" id="A):~:`@vIDjsi_/G%4cN">
                           <block type="text_join" id="|owomGsGAydyRq9jLq}/">
                             <value name="ADD0">
                               <block type="text" id="f|GB6z5,::,M)lWHD^bv">
                             <value name="ADD1">
                               <block type="variables_get" id="Ky3PG-rc1ez~FmEc8lgr">
                             <value name="ADD2">
                               <block type="text" id="9C+xGMuXmKmNcwdqr%x5">
       <block type="procedures_defcustomnoreturn" id="Ouc{(T_hKwe,rf1l(}vU" x="863" y="287">
         <mutation statements="false"></mutation>
         <field name="NAME">etwas tun</field>
         <field name="SCRIPT">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</field>
        @david-g du mußt im scriptteil den datenpunkt für deinen service noch eintragen
          @david-g
          ach -sorry und das musst du auch ändern - brauchte ich für test
          • David G.
            David G. @liv-in-sky last edited by
            @liv-in-sky
            Den ganzen else Block oder das orangene?
              @david-g was meinst du mit orange ?
              einmal geht es um den datenpunkt - zeile 3
              beim zweiten mal in zeile37 das benachrichtigung(helper) auskommentieren -
                @david-g oder meinst du was anderes
                • David G.
                  @liv-in-sky
                  Meine das grüne 🤣
                  Beim Grillen sind die Gedanken und Augen woanders.....
                    @david-g
                    aoooch - jetzt hab ich appetit auf ein stück grill-fleisch
                    David G. 2 Replies Last reply Reply Quote 0
                    • David G.
                      @liv-in-sky
                      Genau eins ist übrig......
                      Verdient hättest du es.
                      • David G.
                        @liv-in-sky
                        Hab das Blockly grad importiert.
                        Einige Blöcke waren deaktiviert.
                        Hab es mal zusammengesetzt wie ich denke.
                        Passt das so?
                          liv-in-sky @David G. last edited by liv-in-sky
                          @david-g genau so wie es war, sollte es sein
                          Die waren mit Absicht deaktiviert
                          Was zu ändern ist, habe ich anschließend beschrieben
                          Der Trigger für den tasker dp ist im Javascriptteil
                          Im blockly selbst , braucht es keinen Trigger mehr
                          • David G.
                            David G. @liv-in-sky last edited by David G.
                            @liv-in-sky
                            Ah, der Trigger ist im JS Teil.
                            Dieser startet dann auch die Funktion und übergibt die Variable an Blockly?
                            Verstanden.
                            Wäre was mehr in Blockly anstatt im JS, (Trigger, die einzelne Variable mit dem Preisstatus), könnte man was leichter noch andere Dinge mit den Werten machen.
                            Zb was für die Visu oder eine manuelle Abfrage anstoßen.
                              @david-g
                              von hand anzusteuern geht ja in der vis - du brauchst ja nur den iot datenpunkt in der vis haben und diesen schalten
                              der vorteil bei dieser vorgehensweise ist: man braucht keine zeitverzögerung einbauen und die error-verwaltung ist auch drin
                              der durchschnittswert wird ja eh in einem dp gespeichert und der aktuelle wert ist auch unter tankerkönig.0 lesbar - damit sind alle daten vorhanden, die du auch noch anders be/verarbeiten kannst.
                              man hätte natürlich in der vis den aktuellen durchschnitt anzeigen können - dauerhaft - aber das wolltest du ja nicht. du wolltest das script ja nur am laufen haben, wenn du selbst triggerst. du kannst aber im blockly einen weiteren trigger einbauen - dieser muss dann dann den iot dp ansprehen und somit kannst du auch automatisch den durchschnittswert aktuell halten
                              damit du später mal weißt, was in dem script getriggert wird, kannst du dir unter system ein kommentar-blockly holen und dir dort notieren, dass der haupttrigger im js-teil ist
                              • David G.
                                @liv-in-sky
                                Klingt alles plausibel was du schreibst.
                                Muss vermutlich langsam mal was aus meiner Blockly Konfortzone raus. Aber ob ich JS irgendwann man kann 😅
                                @liv-in-sky said in Mit Werten aus SQL-Adapter rechnen/abfragen:
                                der durchschnittswert wird ja eh in einem dp gespeichert und......
                                Du meinst den Min-Wert aus dem angegebenen Zeitraum?
                                  @david-g
                                  ja - ist ja kein durchschnitt - sondern min wert
                                  eigentlich brauchen wir bei dem script die zeitabfrage nicht mehr - die würde ja evtl verhindern, dass du in der vis eine anfrage starten kannst - könntest du löschen
                                    @david-g sagte in Mit Werten aus SQL-Adapter rechnen/abfragen:
                                    um kleiner änderungen zu machen: man kann ja über
                                    ansehen, wie der code hinter blockly eigenlich generiert wird. wenn du also in blockly weißt, was du programmieren willst, kannst du dir über den blau-gelben button den code ansehen - kopieren - und in ein js einfügen - mach ich auch bei manchen befehlen.
                                      @david-g
                                      tasker ist cool 🙂
                                      ändert die farbe, wenn günstig tanken möglich
                                      David G. 1 Reply Last reply Reply Quote 1
                                      • David G.
                                        @liv-in-sky
                                        Sehr cool.
                                        Hab seit eben auch alles am laufen.
                                        Zum testen von 3 Tagen auf 1h gestellt.
                                        Hab im Auto auch schön meine Nachricht bekommen. Schon was unheimlich 😅
                                        Hast du dein Script angepasst, dass es noch einen Wert für nicht tanken ausgibt?
                                        Kann man über iot also auch Datenpunkte abfragen? Machst du ja scheinbar für das Tasker Widget.
                                        Tasker ist wirklich fein. Hab auch neulich ein HowTo geschrieben wie automatisch das vpn gestartet und getrennt wird für die Visu (ein paar Wochen später hab ich dann gesehen, dass du das auch schonmal gemacht hast, wobei ich es teilweise ein wenig anders gelöst hab).
                                          @david-g
                                          https://forum.iobroker.net/topic/22341/avm-tasker-vpncilla-iqontrol-sichere-hausteuerung-von-unterwegs/11 🙂
                                          nee - die daten von iobroker zum handy funktioniert über pushover. tasker liest die benachrichtigungen und filtert dann aus. über iot kann man keine daten empfangen (denke ich)
                                          ja - ich habe dafür auch eine nachricht, wenn man "nicht tanken" soll - ich habe auch zusätzlich ein schedule - alle halbe stunde, in dem das script getriggert wird - das mache ich, weil sonst das icon auf dem handy immer auf dem alten stand bleibt und ich dort immer die aktuelle situation haben möchte - zusätzlich kann man das icon drücken und die aktuelle info holen.
                                          • David G.
                                            @liv-in-sky
                                            Das klingt interessant.
                                            Hab mir gtad auch mit Tasker und Zoom schon ein Widget zum Garage öffnen erstellt.
                                            Kannst du mir das Skript mit der zusätzlichen Ausgabe nicht tanken zukommen lassen?
                                            Würde die Info dann in meiner Visu anzeigen und wenn ich manuell nach dem Preis frage.
                                            5183
