    4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
      kakacs last edited by
      @Meistertr @da_Woody
      hab es gerade noch mal versucht den adptar manuel installiert
      das gibt er mir raus bei installieren ist dieses loglevel error normal ?
      $ ./iobroker url "https://github.com/MeisterTR/ioBroker.mihome-vacuum" --debug
      install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee
      NPM version: 6.14.11
      npm install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee --loglevel error --prefix "/opt/iobroker" (System call)
      canvas@2.7.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
      COPY Release/canvas-postbuild.node
      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
      ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
      ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
      CXX(target) Release/obj.target/canvas/src/Backends.o
      CXX(target) Release/obj.target/canvas/src/Canvas.o
      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
      CXX(target) Release/obj.target/canvas/src/closure.o
      CXX(target) Release/obj.target/canvas/src/color.o
      CXX(target) Release/obj.target/canvas/src/Image.o
      CXX(target) Release/obj.target/canvas/src/ImageData.o
      CXX(target) Release/obj.target/canvas/src/init.o
      CXX(target) Release/obj.target/canvas/src/register_font.o
      SOLINK_MODULE(target) Release/obj.target/canvas.node
      COPY Release/canvas.node
      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
      • iobroker.mihome-vacuum@3.0.2added 22 packages from 16 contributors in 72.94s
        46 packages are looking for funding run npm fund for details
        upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
        upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
        upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
        upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
        upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
        upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
        upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
        upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
        upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
        upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
        upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
        upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
        process exited with code 0
        GoodOld @Meistertr last edited by GoodOld
        @meistertr Moin, ich teste gerade den neuen (noch nicht auf dem Markt) den Dreame L10 Pro.
        Adapter ist grün, aber leider werden nur die Üblichen Datenpunkte erzeugt wie "device Info" & "info".
        Falls ich irgendwie helfen kann, einfach melden.
        PS: Aktuell lässte er sich nur über den China Server einbinden.
        mihome-vacuum.0	2021-04-02 18:57:10.832	warn	(1526) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
        mihome-vacuum.0	2021-04-02 18:57:10.832	debug	(1526) DeviceModel selected to: dreame.vacuum.p2029
        mihome-vacuum.0	2021-04-02 18:57:10.830	debug	(1526) Get Device data from robot..
        mihome-vacuum.0	2021-04-02 18:57:10.829	debug	(1526) Get Device data..1
        mihome-vacuum.0	2021-04-02 18:57:10.828	debug	(1526) GETMODELFROMAPI:Data: {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1038","ap":{"ssid":"Hust24","bssid":"xxxxxxx","rssi":-43},"netif":{"l
        mihome-vacuum.0	2021-04-02 18:57:10.821	debug	(1526) Get Device data..0
        mihome-vacuum.0	2021-04-02 18:57:08.812	debug	(1526) GETMODELFROMAPI: objModel: {"val":"dreame.vacuum.p2029","ack":true,"ts":1617xxxxx189,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":161xxxxx60}
        mihome-vacuum.0	2021-04-02 18:57:08.803	debug	(1526) MAIN: Connected to device, try to get model..
        mihome-vacuum.0	2021-04-02 18:57:08.794	debug	(1526) server started on 0.0.0.0:53421
        mihome-vacuum.0	2021-04-02 18:57:08.779	debug	(1526) MIIO: Config: ip:192.168.178.249 token: 737xxxxxxxxxxxxxxxxx4
        mihome-vacuum.0	2021-04-02 18:57:08.777	debug	(1526) load Map creator... true
        mihome-vacuum.0	2021-04-02 18:57:08.656	info	(1526) check group user admin group admin: false
        mihome-vacuum.0	2021-04-02 18:57:08.638	info	(1526) check user admin pw iobroker: false
        mihome-vacuum.0	2021-04-02 18:57:08.340	info	(1526) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
        mihome-vacuum.0	2021-04-02 18:57:07.541	debug	(1526) statesDB connected
        mihome-vacuum.0	2021-04-02 18:57:07.536	debug	(1526) States connected to redis: 127.0.0.1:9010
        mihome-vacuum.0	2021-04-02 18:57:07.489	debug	(1526) States create User PubSub Client
        mihome-vacuum.0	2021-04-02 18:57:07.488	debug	(1526) States create System PubSub Client
        mihome-vacuum.0	2021-04-02 18:57:07.464	debug	(1526) Redis States: Use Redis connection: 127.0.0.1:9010
        mihome-vacuum.0	2021-04-02 18:57:07.459	debug	(1526) objectDB connected
        mihome-vacuum.0	2021-04-02 18:57:07.436	debug	(1526) Objects connected to redis: 127.0.0.1:9011
        mihome-vacuum.0	2021-04-02 18:57:07.386	debug	(1526) Objects client initialize lua scripts
        mihome-vacuum.0	2021-04-02 18:57:07.385	debug	(1526) Objects create User PubSub Client
        mihome-vacuum.0	2021-04-02 18:57:07.383	debug	(1526) Objects create System PubSub Client
        mihome-vacuum.0	2021-04-02 18:57:07.377	debug	(1526) Objects client ready ... initialize now
        mihome-vacuum.0	2021-04-02 18:57:06.864	debug	(1526) Redis Objects: Use Redis connection: 127.0.0.1:9011
        mihome-vacuum.0	2021-04-02 18:57:01.857	info	(1122) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mihome-vacuum.0	2021-04-02 18:57:01.855	info	(1122) terminating
        mihome-vacuum.0	2021-04-02 18:57:01.853	info	(1122) Got terminate signal TERMINATE_YOURSELF
        mihome-vacuum.0	2021-04-02 18:56:07.176	warn	(1122) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
        mihome-vacuum.0	2021-04-02 18:56:07.065	info	(1122) check group user admin group admin: false
        mihome-vacuum.0	2021-04-02 18:56:07.056	info	(1122) check user admin pw iobroker: false
        mihome-vacuum.0	2021-04-02 18:56:06.715	info	(1122) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
        mihome-vacuum.0	2021-04-02 18:55:59.896	info	(632) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mihome-vacuum.0	2021-04-02 18:55:59.894	info	(632) terminating
        mihome-vacuum.0	2021-04-02 18:55:59.891	info	(632) Got terminate signal TERMINATE_YOURSELF
        mihome-vacuum.0	2021-04-02 18:55:09.233	warn	(632) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
        mihome-vacuum.0	2021-04-02 18:55:05.102	info	(632) check group user admin group admin: false
        mihome-vacuum.0	2021-04-02 18:55:05.093	info	(632) check user admin pw iobroker: false
        mihome-vacuum.0	2021-04-02 18:55:04.753	info	(632) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
        mihome-vacuum.0	2021-04-02 18:54:57.748	info	(32156) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mihome-vacuum.0	2021-04-02 18:54:57.746	info	(32156) terminating
        mihome-vacuum.0	2021-04-02 18:54:57.743	info	(32156) Got terminate signal TERMINATE_YOURSEL
        Meistertr 1 Reply Last reply Reply Quote 0
        • Meistertr
          Meistertr Developer @GoodOld last edited by
          @goodold die Dream Modelle kommunizieren anders als die anderen nicht über miio sondern über miot das ist das neue Standartprotokoll von xiaomi mit DID (DeviceID kein Problem kommt mit über die cloud) SID (ServiceID) und PID (ParameterID) wie meine Nachforschungen ergeben haben geht diese Kommunikation auch verschlüsselt über udp wie beim miio (Schonmal gut somit kann man das alte nutzen) Ich bin gerade wieder mal an dem Adapter rewrite und baue es so, dass es Modular aufgebaut ist und schnell und einfach neue Geräte hinzugefügt werden können.
          Jetzt Kommt aber das ABER Das Testen der Nachrichten ist sehr zeitaufwendig. Hilfe bietet jeder an (das aber auch nur, wenn es um bugreport und testen geht) für miot gibt es eine webapi wo alle komandos beschrieben sind (Reschere über git adresse ist mi.spect....) Der Adapter bieten in allen Versionen die Möglichkeit eigene Komandos zu schicken. also eigentlich nichts weltbewegendes, was auch jeder Beginner kann.
          Ablauf:
          1: Komandos SID und PID aus der mi.spect suchen (da gibs für jedes device einen apiurl)
          2: config aus admin herunterladen und mit dem Texteditor öffen (unter devices müsste in einer json die DID stehen)
          3: am besten in einen Texteditor die Messages zusammenbauen und abschicken und sehen was zurückkommt.
          4: das ganze dokumentieren und mir zukommen lassen. dann ist der Roboter im nu eingebunden
          da fällt mir gerade ein dass es so mit dem adapter noch nciht geht weil die Nachricht auf miio standard geprüft wird. Wenn Interesse besteht mach ich eine Version fertig in der man raw daten senden kann.
            @Meistertr gild das auch für den xiaomi viomi se ??? ich bekomme denn nicht verbunden mit dem adapter ??
            • Meistertr
              Meistertr Developer @kakacs last edited by
              @kakacs gibt es da etwas nähere ausführungen? debuglog? wie ist die Modellbezeichnung also viomi.vacuum.xxx
                @meistertr das model ist viomi.vacuum.v19
                wenn ich den andapter von dir installiere kommt das bei der installation raus .
                ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
                • iobroker.mihome-vacuum@3.0.2added 23 packages from 15 contributors in 68.776s
                52 packages are looking for funding run npm fund for details
                und das kommt beim log raus :
                mihome-vacuum.0 2021-04-04 10:59:11.969 warn (19248) Terminated (UNCAUGHT_EXCEPTION): Without reason
                mihome-vacuum.0 2021-04-04 10:59:11.967 info (19248) terminating
                mihome-vacuum.0 2021-04-04 10:59:11.942 error (19248) Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 10:59:11.941 error (19248) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                mihome-vacuum.0 2021-04-04 10:59:11.939 error (19248) unhandled promise rejection: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 10:59:11.937 error (19248) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                mihome-vacuum.0 2021-04-04 10:59:01.898 info (19248) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 10:59:01.893 info (19248) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 10:59:01.687 info (19248) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                mihome-vacuum.0 2021-04-04 10:58:29.564 warn (19214) Terminated (UNCAUGHT_EXCEPTION): Without reason
                mihome-vacuum.0 2021-04-04 10:58:29.562 info (19214) terminating
                mihome-vacuum.0 2021-04-04 10:58:29.542 error (19214) Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 10:58:29.541 error (19214) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                mihome-vacuum.0 2021-04-04 10:58:29.539 error (19214) unhandled promise rejection: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 10:58:29.538 error (19214) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                mihome-vacuum.0 2021-04-04 10:58:19.440 info (19214) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 10:58:19.435 info (19214) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 10:58:19.235 info (19214) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                mihome-vacuum.0 2021-04-04 10:57:47.070 warn (19187) Terminated (UNCAUGHT_EXCEPTION): Without reason
                mihome-vacuum.0 2021-04-04 10:57:47.068 info (19187) terminating
                mihome-vacuum.0 2021-04-04 10:57:47.044 error (19187) Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 10:57:47.043 error (19187) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                mihome-vacuum.0 2021-04-04 10:57:47.040 error (19187) unhandled promise rejection: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 10:57:47.039 error (19187) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                mihome-vacuum.0 2021-04-04 09:57:36.943 info (19187) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 09:57:36.938 info (19187) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 09:57:36.729 info (19187) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                mihome-vacuum.0 2021-04-04 09:56:28.779 warn (19145) Terminated (UNCAUGHT_EXCEPTION): Without reason
                mihome-vacuum.0 2021-04-04 09:56:28.776 info (19145) terminating
                mihome-vacuum.0 2021-04-04 09:56:28.752 error (19145) Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:56:28.751 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                mihome-vacuum.0 2021-04-04 09:56:28.751 error (19145) TypeError: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:56:28.748 error (19145) unhandled promise rejection: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:56:28.747 error (19145) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                mihome-vacuum.0 2021-04-04 09:56:18.711 info (19145) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 09:56:18.707 info (19145) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 09:56:18.498 info (19145) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                mihome-vacuum.0 2021-04-04 09:55:46.333 warn (19125) Terminated (UNCAUGHT_EXCEPTION): Without reason
                mihome-vacuum.0 2021-04-04 09:55:46.330 info (19125) terminating
                mihome-vacuum.0 2021-04-04 09:55:46.302 error (19125) Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:55:46.301 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                mihome-vacuum.0 2021-04-04 09:55:46.301 error (19125) TypeError: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:55:46.299 error (19125) unhandled promise rejection: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:55:46.297 error (19125) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                mihome-vacuum.0 2021-04-04 09:55:36.204 info (19125) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 09:55:36.199 info (19125) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 09:55:35.993 info (19125) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                mihome-vacuum.0 2021-04-04 09:55:03.867 warn (19100) Terminated (UNCAUGHT_EXCEPTION): Without reason
                mihome-vacuum.0 2021-04-04 09:55:03.864 info (19100) terminating
                mihome-vacuum.0 2021-04-04 09:55:03.840 error (19100) Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:55:03.838 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                mihome-vacuum.0 2021-04-04 09:55:03.838 error (19100) TypeError: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:55:03.836 error (19100) unhandled promise rejection: Cannot read property 'val' of null
                mihome-vacuum.0 2021-04-04 09:55:03.835 error (19100) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                mihome-vacuum.0 2021-04-04 09:54:53.734 info (19100) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 09:54:53.729 info (19100) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 09:54:53.507 info (19100) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                mihome-vacuum.0 2021-04-04 09:54:48.899 info (19033) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                mihome-vacuum.0 2021-04-04 09:54:48.897 info (19033) terminating
                mihome-vacuum.0 2021-04-04 09:54:48.894 info (19033) Got terminate signal TERMINATE_YOURSELF
                mihome-vacuum.0 2021-04-04 09:52:32.454 info (19033) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 09:52:32.449 info (19033) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 09:52:32.235 info (19033) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                aber was mir auffällt ist das ein ganz andere token angezeigt wird als ich von der app ausgelesen habe.
                • Meistertr
                  @kakacs sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                  viomi.vacuum.v19
                  installiere mal über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3
                  K A 2 Replies Last reply Reply Quote 0
                    kakacs @Meistertr last edited by
                    @meistertr super mit dem wird die instanz grün und unter objekten steht schon mal was Screenshot_2021-04-04 objects - ioBroker.png
                    aber es ändert sich nichts an wenn ich den staubsauger starte im log habe ich das jetzt
                    mihome-vacuum.0 2021-04-04 14:22:50.827 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                    mihome-vacuum.0 2021-04-04 13:21:50.822 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                    mihome-vacuum.0 2021-04-04 13:20:50.934 warn (23416) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                    mihome-vacuum.0 2021-04-04 13:20:50.718 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                    mihome-vacuum.0 2021-04-04 13:20:50.639 info (23416) check group user admin group admin: false
                    mihome-vacuum.0 2021-04-04 13:20:50.633 info (23416) check user admin pw iobroker: true
                    mihome-vacuum.0 2021-04-04 13:20:50.408 info (23416) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                    mihome-vacuum.0 2021-04-04 13:20:45.741 info (23341) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    mihome-vacuum.0 2021-04-04 13:20:45.739 info (23341) terminating
                    mihome-vacuum.0 2021-04-04 13:20:45.736 info (23341) Got terminate signal TERMINATE_YOURSELF
                    mihome-vacuum.0 2021-04-04 13:20:28.689 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                    mihome-vacuum.0 2021-04-04 13:19:28.676 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                    mihome-vacuum.0 2021-04-04 13:18:28.669 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                    mihome-vacuum.0 2021-04-04 13:17:30.856 warn (23341) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                    mihome-vacuum.0 2021-04-04 13:17:28.662 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                    • Meistertr
                      @kakacs bitte mal auf debug stellen und den log posten
                        @meistertr jetzt musst du mir helfen wie stell ich denn auf debug??
                        • Meistertr
                          @kakacs https://www.google.com/search?q=wie+stelle+ich+iobroker+auf+debug&ie=utf-8&oe=utf-8&aq=t
                          K 2 Replies Last reply Reply Quote 0
                            @meistertr danke
                            mihome-vacuum.0 2021-04-04 14:47:43.491 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                            mihome-vacuum.0 2021-04-04 14:47:43.488 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f1d1ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0 2021-04-04 14:46:43.720 warn (25026) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                            mihome-vacuum.0 2021-04-04 14:46:43.720 debug (25026) DeviceModel selected to: viomi.vacuum.v19
                            mihome-vacuum.0 2021-04-04 14:46:43.719 debug (25026) Get Device data from robot..
                            mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) Get Device data..0
                            mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) GETMODELFROMAPI:Data: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:C
                            mihome-vacuum.0 2021-04-04 14:46:43.717 debug (25026) MIIO RECIVE: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw
                            mihome-vacuum.0 2021-04-04 14:46:43.511 debug (25026) Message= {"id":1,"method":"miIO.info"}
                            mihome-vacuum.0 2021-04-04 14:46:43.509 debug (25026) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617543894399,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
                            mihome-vacuum.0 2021-04-04 14:46:43.396 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                            mihome-vacuum.0 2021-04-04 14:46:43.393 debug (25026) MAIN: Connected to device, try to get model..
                            mihome-vacuum.0 2021-04-04 14:46:43.392 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f195ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0 2021-04-04 14:46:43.306 debug (25026) server started on 0.0.0.0:53421
                            mihome-vacuum.0 2021-04-04 14:46:43.298 debug (25026) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
                            mihome-vacuum.0 2021-04-04 14:46:43.296 info (25026) check group user admin group admin: false
                            mihome-vacuum.0 2021-04-04 14:46:43.291 info (25026) check user admin pw iobroker: true
                            mihome-vacuum.0 2021-04-04 14:46:43.078 info (25026) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                            mihome-vacuum.0 2021-04-04 14:46:42.875 debug (25026) statesDB connected
                            mihome-vacuum.0 2021-04-04 14:46:42.874 debug (25026) States connected to redis: 127.0.0.1:9000
                            mihome-vacuum.0 2021-04-04 14:46:42.862 debug (25026) States create User PubSub Client
                            mihome-vacuum.0 2021-04-04 14:46:42.861 debug (25026) States create System PubSub Client
                            mihome-vacuum.0 2021-04-04 14:46:42.849 debug (25026) Redis States: Use Redis connection: 127.0.0.1:9000
                            mihome-vacuum.0 2021-04-04 14:46:42.847 debug (25026) objectDB connected
                            mihome-vacuum.0 2021-04-04 14:46:42.837 debug (25026) Objects connected to redis: 127.0.0.1:9001
                            mihome-vacuum.0 2021-04-04 14:46:42.819 debug (25026) Objects client initialize lua scripts
                            mihome-vacuum.0 2021-04-04 14:46:42.818 debug (25026) Objects create User PubSub Client
                            mihome-vacuum.0 2021-04-04 14:46:42.816 debug (25026) Objects create System PubSub Client
                            mihome-vacuum.0 2021-04-04 14:46:42.805 debug (25026) Objects client ready ... initialize now
                            mihome-vacuum.0 2021-04-04 14:46:42.764 debug (25026) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            mihome-vacuum.0 2021-04-04 14:46:38.420 info (24980) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            mihome-vacuum.0 2021-04-04 14:46:38.417 info (24980) terminating
                            mihome-vacuum.0 2021-04-04 14:46:38.414 info (24980) Got terminate signal TERMINATE_YOURSELF
                              @meistertr
                              mihome-vacuum.0 2021-04-04 15:58:57.637 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                              mihome-vacuum.0 2021-04-04 15:58:57.635 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f474ffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 15:58:56.681 debug (1208) system.adapter.admin.0: logging true
                              mihome-vacuum.0 2021-04-04 14:58:22.365 debug (1208) sendTo "discovery" to system.adapter.admin.0 from system.adapter.mihome-vacuum.0
                              mihome-vacuum.0 2021-04-04 14:58:22.364 debug (1208) discover__[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":"192.168.178.75","mac":"5C:6B:D7
                              mihome-vacuum.0 2021-04-04 14:58:22.362 debug (1208) {"code":0,"message":"ok","result":{"list":[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":
                              mihome-vacuum.0 2021-04-04 14:58:22.231 debug (1208) GET devices from:https://de.api.io.mi.com/app/home/device_list
                              mihome-vacuum.0 2021-04-04 14:58:22.223 debug (1208) Xiaomi Cloud: Login successful
                              mihome-vacuum.0 2021-04-04 14:58:22.222 debug (1208) Login step3: [{"key":"userId","value":"6432461162","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-04-04T13:58:22.179Z","lastAccessed":"2021-04-04T13:58:22.220Z"},{"k
                              mihome-vacuum.0 2021-04-04 14:58:21.945 debug (1208) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"XXyyLiOls5U1ionL2h/ygw==","code":0,"passToken":"V1:bOtEAOudpqEL/PTNVjfNjI1KRycqTK7DU62Fk/J18icmBS60DBX3c+rn/eV5WKs
                              mihome-vacuum.0 2021-04-04 14:58:21.340 debug (1208) Login step1: &&&START&&&{"serviceParam":"{"checkSafePhone":false,"checkSafeAddress":false,"lsrp_score":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callb
                              mihome-vacuum.0 2021-04-04 14:58:20.465 debug (1208) Xiaomi Cloud: Logging in
                              mihome-vacuum.0 2021-04-04 14:57:57.631 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                              mihome-vacuum.0 2021-04-04 14:57:57.629 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f438ffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 14:57:53.101 debug (1208) system.adapter.admin.0: logging false
                              mihome-vacuum.0 2021-04-04 14:56:57.590 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                              mihome-vacuum.0 2021-04-04 14:56:57.589 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3fcffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 14:55:57.559 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                              mihome-vacuum.0 2021-04-04 14:55:57.558 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3bfffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 14:54:57.502 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                              mihome-vacuum.0 2021-04-04 14:54:57.500 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f383ffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 14:53:57.741 warn (1208) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                              mihome-vacuum.0 2021-04-04 14:53:57.740 debug (1208) DeviceModel selected to: viomi.vacuum.v19
                              mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data from robot..
                              mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data..0
                              mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) GETMODELFROMAPI:Data: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA
                              mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) MIIO RECIVE: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw_
                              mihome-vacuum.0 2021-04-04 14:53:57.442 debug (1208) Message= {"id":1,"method":"miIO.info"}
                              mihome-vacuum.0 2021-04-04 14:53:57.440 debug (1208) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617544003728,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
                              mihome-vacuum.0 2021-04-04 14:53:57.436 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                              mihome-vacuum.0 2021-04-04 14:53:57.433 debug (1208) MAIN: Connected to device, try to get model..
                              mihome-vacuum.0 2021-04-04 14:53:57.432 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f347ffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 14:53:57.340 debug (1208) server started on 0.0.0.0:53421
                              mihome-vacuum.0 2021-04-04 14:53:57.332 debug (1208) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
                              mihome-vacuum.0 2021-04-04 14:53:57.330 info (1208) check group user admin group admin: false
                              mihome-vacuum.0 2021-04-04 14:53:57.325 info (1208) check user admin pw iobroker: true
                              mihome-vacuum.0 2021-04-04 14:53:57.113 info (1208) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.0, js-controller: 3.2.16
                              mihome-vacuum.0 2021-04-04 14:53:56.874 debug (1208) statesDB connected
                              mihome-vacuum.0 2021-04-04 14:53:56.873 debug (1208) States connected to redis: 127.0.0.1:9000
                              mihome-vacuum.0 2021-04-04 14:53:56.866 debug (1208) States create User PubSub Client
                              mihome-vacuum.0 2021-04-04 14:53:56.864 debug (1208) States create System PubSub Client
                              mihome-vacuum.0 2021-04-04 14:53:56.857 debug (1208) Redis States: Use Redis connection: 127.0.0.1:9000
                              mihome-vacuum.0 2021-04-04 14:53:56.854 debug (1208) objectDB connected
                              mihome-vacuum.0 2021-04-04 14:53:56.845 debug (1208) Objects connected to redis: 127.0.0.1:9001
                              mihome-vacuum.0 2021-04-04 14:53:56.822 debug (1208) Objects client initialize lua scripts
                              mihome-vacuum.0 2021-04-04 14:53:56.821 debug (1208) Objects create User PubSub Client
                              mihome-vacuum.0 2021-04-04 14:53:56.819 debug (1208) Objects create System PubSub Client
                              mihome-vacuum.0 2021-04-04 14:53:56.816 debug (1208) Objects client ready ... initialize now
                              mihome-vacuum.0 2021-04-04 14:53:56.753 debug (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              • Meistertr
                                viomi.vacuum.v19
                                bitte nochmal von git installieren und debug posten (bitte log in codetags)
                                  @meistertr @meistertr said in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                                  log in codetags
                                  ok mache ich wie geht das mit log in code tags ??? bin noch nicht so fit mit iobroker sorry.
                                  hast du geshen in dem log was ich gepostet habe ws bedeutet das
                                  Time difference between Mihome Vacuum and ioBroker ich installier den adapter noch mal neu den du mir empfohlen hast richtig?? und soll ich erst wieder löschen ??
                                    @meistertr hab den gelöscht und will den noch mal installieren und dann kommt das
                                    $ ./iobroker url " https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
                                    install "
                                    npm install " --loglevel error --prefix "/opt/iobroker" (System call)
                                    /bin/sh: 1: Syntax error: Unterminated quoted string
                                    ERROR: host.raspberrypi Cannot install ": 2
                                    ERROR: process exited with code 25
                                    • Meistertr
                                      leerzeichen davor
                                      • Meistertr
                                        @kakacs löschen brachst du ihn vor dem drüber installieren nicht. das sind nur kleine Änderungen die ich vornehme. Die Timedifference ist nebensächlich, das bedeutet nur dass der roboter und der adapter unterschiedliche uhrzeiten haben und die Nachrichten daran angepasst werden
                                          @meistertr ok ich hab denn jetzt schon gelöscht wie meinst du leerzeichen davor
                                            audi1503 @kakacs last edited by
                                            @kakacs Du hattest vor dem Link nen Leerzeichen
                                            viomi xiaomi
                                            19
                                            108
                                            11047
