Bose sprach ausgabe
Hier ist der Export.
Mein Appkey habe ich mit xxxxxx ersetzt.<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable type="timeout" id="timeout">timeout</variable> <variable type="timeout" id="timeout2">timeout2</variable> </variables> <block type="on" id="P)MbE7-)CU,Ie~9{Mg.#" x="-762" y="63"> <field name="OID">0_userdata.0.Sprachausgabe.Zu_sprechender_Text</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="sayit" id="Xc~;GZD?XGl9=L{x?qN="> <field name="INSTANCE">all</field> <field name="LANGUAGE">de</field> <field name="LOG"></field> <value name="MESSAGE"> <shadow type="text" id="K_Jt7a[/u7gsA:[dZ;/o"> <field name="TEXT">gggg</field> </shadow> <block type="on_source" id="9mr8aFJ;V)R,jrmmDO1v"> <field name="ATTR">state.val</field> </block> </value> <next> <block type="timeouts_settimeout" id="9Cj1NeWGz_KD5dc9}11]"> <field name="NAME">timeout</field> <field name="DELAY">1</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="exec" id="-Hs@I63![jqDc)(?R6o)"> <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation> <field name="WITH_STATEMENT">FALSE</field> <field name="LOG"></field> <value name="COMMAND"> <shadow type="text" id="Eu*kfUv}Z3$L%i2S|+uk"> <field name="TEXT">mv /opt/iobroker/iobroker-data/sayit/sayit.0.say.mp3 /var/www/html</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="c0kX0%rr)ee7)r%K=nBj"> <field name="NAME">timeout2</field> <field name="DELAY">1</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="exec" id="=(Uxiu)4n@vAW4~8yM:c"> <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation> <field name="WITH_STATEMENT">FALSE</field> <field name="LOG"></field> <value name="COMMAND"> <shadow type="text" id="1I$^f/Qa*aeoQjfCa`O;"> <field name="TEXT">curl -d \ "<play_info><app_key>xxxxxxxxxxxxx;/app_key><url>http://192.168.99.33/sayit.0.say.mp3</url><service>service text</service><reason>reason text</reason><message>message text</message><volume>10</volume></play_info>" http://192.168.99.24:8090/speaker</field> </shadow> <block type="text_join" id="37M^HRW9i67*5:1tD-4g"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="THF9pN,zFaoAxP9kIl(4"> <field name="TEXT">curl -d \ "<play_info><app_key>xxxxxxxxx</app_key><url>http://192.168.99.33/sayit.0.say.mp3</url><service>service text</service><reason>reason text</reason><message>message text</message><volume></field> </block> </value> <value name="ADD1"> <block type="get_value" id="+#ZjSj~6;Ti*1boSEaJF"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.Sprachausgabe.Lautsaerke</field> </block> </value> <value name="ADD2"> <block type="text" id="iK2UbN]TyKAs#i*1qhoC"> <field name="TEXT"></volume></play_info>" http://192.168.99.24:8090/speaker</field> </block> </value> </block> </value> </block> </statement> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </xml>
@david-g @david-g @david-g danke, ich habe es aus probiert. es funktioniert bis auf die ton ausgabe. da komt immer der log error datei ist zu kurtz. ist ich habe die mp3 datein auf meiner fritznas gespeichert. ich habe dein skript 1 zu 1 übernommen nur der trigger habe ich entfernt. weil ich nicht genau begriffen habe wofür der ist.
Der Trigger überwacht einen Datenpunkt in den der Text für die Sprachausgabe geschrieben wird.
Wenn dort zb "Waschmaschine fertig" eingetragen wird, wird das Script gestartet.
Erst wird mit sayit die mp3 (Waschmaschine fertig) geschrieben, verschoben und dann abgespielt.
Kann die Fritzbox die Daten per http bereitstellen? Dachte nur ftp. Dachte, dass mag die Bose nicht.
Welcher Adapter meldet, dass die mp3 zu kurz ist?
Den eigenen Appkey hast du?
@david-g einen Appkey habbe ich. und es funktioniert auch alles nur halt kein ton.
ich habe grade mahl versucht eine Datei von meinem Server abzuspielen genau das gleiche problem, kein ton.
so wol als link per fritz.box und per Freigabe von meinem synology nas kein ton.habe es jetzt so modifieziert
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable type="timeout" id="timeout">timeout</variable> <variable type="timeout" id="timeout2">timeout2</variable> </variables> <block type="sayit" id="Xc~;GZD?XGl9=L{x?qN=" x="-412" y="113"> <field name="INSTANCE">all</field> <field name="LANGUAGE">de</field> <field name="LOG"></field> <value name="MESSAGE"> <shadow type="text" id="K_Jt7a[/u7gsA:[dZ;/o"> <field name="TEXT">Post ist da</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="9Cj1NeWGz_KD5dc9}11]"> <field name="NAME">timeout</field> <field name="DELAY">1</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="exec" id="-Hs@I63![jqDc)(?R6o)"> <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation> <field name="WITH_STATEMENT">FALSE</field> <field name="LOG"></field> <value name="COMMAND"> <shadow type="text" id="Eu*kfUv}Z3$L%i2S|+uk"> <field name="TEXT">mv /opt/iobroker/iobroker-data/sayit/sayit.0.say.mp3 /var/www/html</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="c0kX0%rr)ee7)r%K=nBj"> <field name="NAME">timeout2</field> <field name="DELAY">1</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="exec" id="=(Uxiu)4n@vAW4~8yM:c"> <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation> <field name="WITH_STATEMENT">FALSE</field> <field name="LOG"></field> <value name="COMMAND"> <shadow type="text" id="1I$^f/Qa*aeoQjfCa`O;"> <field name="TEXT">curl -d \ "<play_info><app_key>xxxxxxxxxxxxx;/app_key><url>http://192.168.99.33/sayit.0.say.mp3</url><service>service text</service><reason>reason text</reason><message>message text</message><volume>10</volume></play_info>" http://192.168.99.24:8090/speaker</field> </shadow> <block type="text_join" id="_*1t)3F`,vxAU0?!apgg"> <mutation items="3"></mutation> <value name="ADD0"> <block type="text" id="Q(h5wpOs0a9XMcteFZ7E"> <field name="TEXT">curl -d \ "<play_info><app_key>xxxxxxxx</app_key><url>http://192.168.178.29/sayit.0.say.mp3</url><service>post ist da</service><reason>es ligt ein paket in der postbox </reason><message>post ist da</message><volume></field> </block> </value> <value name="ADD1"> <block type="text" id=";);mx97{rVisnx7tz}ww"> <field name="TEXT">30</field> </block> </value> <value name="ADD2"> <block type="text" id="9cKsZZsE/wFhWlC0Z{Mg"> <field name="TEXT"></volume></play_info>" http://192.168.178.12:8090/speaker</field> </block> </value> </block> </value> </block> </statement> </block> </next> </block> </statement> </block> </next> </block> </xml>
vielleicht kannst du mahl kucken (wen du ziet und lust hast) wo möglicher weise ein Fehler liegen könnte.
Edit:
es funktioniert so wie ich das jetzt modifiziert habe bis auf die ton aus Gabe
Hast du mal eine xbelibige Datei aus dem internet probiert?
Wo man so einfach drauf kommt.So hatte ich anfangs alles erst ans laufen gebracht. Dann hab ich eigene mp3s getestet.
Welche Box hast du?
Was mir grad noch einfällt, was für eine Lautstärke ist eingestellt?
MUSS zwischen 10 und 70 sein. -
@david-g erstmal vrohe Ostern. Die Lautstärke beträgt 30. Ich habe es mahl mit einem yt link probiert. Hat trotzdem kein Ton abgespielt.
Ich habe die soundtouch 20 v3Edit
habe grade noch ein error gefunden im log. Mit nem mplayer
Wird die mp3 denn erzeugt?
Das macht der bei mir nicht bei jeder Einstellung.So hab ich es:
Kannst du über die entsprechende URL aus deinem Skript eine funktionierende mp3 runterladen?
EDIT:
Hab grad mal oben deinen Code überflogen. Kann sein, dass beim Befehl für die Bose noch die IP meiner Box steht? -
@david-g nein kann nicht sein. meine box reagiert drauf kommt aber nur kein ton. aber ich kucke noch mahl Sicherheits halber mahl.
Edit. Der Fehler den ich beim letzten post hatte ist weg. Aber das Problem ist trotzdem noch da
@johny2410
Kannst mir ja mal. Deine mp3 senden.
Dann schaue ich mal was meine Box macht. -
@johny2410 said in Bose sprach ausgabe:
Meinst du Youtube? Klappt das?
Teste mal mit https://www.soundjay.com/transportation/train-crossing-bell-01.mp3Evtl kommt die Box ja nicht mit dem Server von deiner Fritte zurecht (wie hast du den überhaupt eingerichtet, kenne ich gar nicht?).
@johny2410
Hab jetzt auch die to short Meldung bekommen.
Allerdings bei einem sehr langen Text.
Hast du mal was kurzes probiert, falls dein Text lang ist?Oder die timeouts was verlängert? Evtl ist die Übertragung noch nicht fertig.
@david-g ich habe das alles schon mahl durch getestet, habe den fehler noch nicht gefunden. Ich glaube das ich das erstmal ruhen lasse. Und es noch mahl zu einem anderem Zeitpunkt wieder aufgreifen werde. Erst mahl danke für deine Hilfe und deinem Support. Und die Zeit die du dir genommen hast.
Glaube hab die Lösung von deinem Problem gefunden.
Hat der Server von deiner mp3 ein gültiges Ssl Zertifikat?
Hab grad gesehen, dass es bei den Objekten von sayit schon einen link zur mp3 gibt.
Diesen konnte ich im Browser auch öffnen. Die Bose hat ihn allerdings nicht genommen. Laufende Musik wurde abgesenkt, kam aber keine Meldung.Hab dann noch eine weitere Instanz vom Web-Adapter installiert, dort die Verschlüsselung abgeschaltet und einen anderen Port (bei mir 8083 anstatt 8082) wie in Instanz 1 angegeben. Dann bei Sayit diese Instanz angegeben.
Nun erscheint in den Sayit nach einem Neustart und dem ersten generieren einer mp3 ein neuer Link.
Dieser klappt wieder in der Box.
Und im Skript auf jeden Fall den Timeout einbauen. Sonst wird die mp3 nicht fertig. -
@david-g
ich habe mahl die timer auf 1-5 minuten gestelt. und habe meine http verschluselung von der web instans deaktiviert. habe noch nicht weiter angekuckt. aber beim spontanen versuch hat es erst mahl nicht geklapt -
Dann hab ich erstmal auch keine Idee mehr....
ich bin auf der Suche nach einer Möglichkeit zur Sprachausgabe über meine Bose-Boxen auf diesen Beitrag gestoßen und wollte den Ansatz ebenfalls versuchen.Leider bekomme ich auf der Bose Webseite die Mittelung, dass das Developer Portal geschlossen wurde. Somit kann ich keinen Consumer Key erstellen.
Funktioniert die Sprachausgabe bei euch noch oder ist der Ansatz mit dem schließen des Developer Portal hinfällig?
Falls es noch funktioniert, kann mir jemand sagen, wie man an Consumer Key herankommt? Meine Recherchen haben da leider nichts ergeben...
Bei mir klappt es noch.
Grad getestet. Läuft nicht so oft. -
Danke für die Antwort. Ich habe mich mal an den Bose Support gewandt, aber der konnte mir bisher nicht weiterhelfen. Wie immer kommt man nur beim low-level Support raus und hat keine Möglichkeit, mit jemandem zu reden, der sich mit den Sachen auskennt.
Ich werde noch weiter versuchen, an den Consumer Key zu kommen. Falls ich Erfolg damit haben sollte, werde ich die Infos hier teilen.
