    4. [solved] MQTT adapter update problems V2.1.14->2.3.4->2.3.5
      Thomas Braun Most Active @WillyIobrok last edited by Thomas Braun
      @willyiobrok
      Gerade mal in meinem System probiert.
      Läuft:
      pi@raspberrypi:/opt/iobroker $ iobroker update
      pi@raspberrypi:/opt/iobroker $ iobroker add mqtt
      NPM version: 6.14.12
      npm install iobroker.mqtt@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
      host.raspberrypi install adapter mqtt
      upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
      upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
      upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
      upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
      host.raspberrypi object system.adapter.mqtt created/updated
      host.raspberrypi create instance mqtt
      host.raspberrypi object mqtt.0.info created
      host.raspberrypi object system.adapter.mqtt.0.logLevel created
      host.raspberrypi object system.adapter.mqtt.0.sigKill created
      host.raspberrypi object system.adapter.mqtt.0.eventLoopLag created
      host.raspberrypi object system.adapter.mqtt.0.outputCount created
      host.raspberrypi object system.adapter.mqtt.0.inputCount created
      host.raspberrypi object system.adapter.mqtt.0.uptime created
      host.raspberrypi object system.adapter.mqtt.0.memRss created
      host.raspberrypi object system.adapter.mqtt.0.memHeapTotal created
      host.raspberrypi object system.adapter.mqtt.0.memHeapUsed created
      host.raspberrypi object system.adapter.mqtt.0.cputime created
      host.raspberrypi object system.adapter.mqtt.0.cpu created
      host.raspberrypi object system.adapter.mqtt.0.compactMode created
      host.raspberrypi object system.adapter.mqtt.0.connected created
      host.raspberrypi object system.adapter.mqtt.0.alive created
      host.raspberrypi object system.adapter.mqtt.0 created
        WillyIobrok @Thomas Braun last edited by
        Oh - vielen Dank für's ausprobieren !
        Der Unterschied zwischen beiden Tests ist : Bei mir ist's ein update von der Version 2.3.4 ( die schon beim Update von 2.1.14 Schwierigkeiten gemacht hat) auf 2.3.5 - bei Dir war's eine Neu-Installation der 2.3.5, wenn ich das log richtig lese ...
        Wie kriege ich jetzt die installierte Version 2.3.4 aus meinem System so komplett raus, daß es auch bei mir eine Neu-Installation wird?
        Die Instanz löschen reicht wohl nicht ... habe ich ausprobiert ... glaube ich ? ...
        Könnte es sein, daß ein Fehler im Filesystem meiner SD-card irgendetwas "corrupted" hat, das ich später zumindest im Filesystem wieder repariert habe?
          @willyiobrok
          Integrity verification failed for sha512
          deutet eigentlich darauf hin, dass dein Download des Updates nicht i. O. war/ist.
          Normalerweise leert man dann den cache und lädt nochmal. Wie oben schon mal gemacht.
            moin moin. Habe gestern noch ein issue bei mqtt gesetzt und auch prompt (wie erwartet) die Antwort bekommen, daß das nichts mit dem Adapter zu tun hat.
            Ich soll das Cache leeren oder warten bis sich das Problem einfach von selbst löst...
            Deshalb habe ich das jetzt nochmal probiert und prompt unerwartete Fehlermeldungen bekommen:
            pi@ioBroker-4:/opt/iobroker $ iobroker stop
            pi@ioBroker-4:/opt/iobroker $ npm cache clear --force
            npm WARN using --force I sure hope you know what you are doing. (weiss ich leider nicht so genau hihihi)
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rmdir
            npm ERR! path /home/iobroker/.npm/_cacache/index-v5/14/72
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache/index-v5/14/72'
            npm ERR!     /home/iobroker/.npm/_logs/2021-04-03T07_07_40_405Z-debug.log
            vielleicht hilft das ein wenig weiter? Ich schau mir jetzt mal das nicht leere cache-dir an...
            Muß man das cache leeren eigentlich bei aktivem oder bei gestoppten ioBroker ausführen ? Ich habe beide Fälle probiert - mit dem gleichen Resultat ...
              WillyIobrok @WillyIobrok last edited by
              @willyiobrok
              so, habe in dem o.g. Directory eine Datei mit dem Namen '018e044851804'$'\261''c89a4f39fb29f<592695e73668ea09e1b3f2a10v74d1'$'\341''7'
              gefunden und das Ding - was auch immer es ist - mit sudo-Berechtigung gelöscht (durfte ich das? -> auf eigenes Risiko!)
              Nachfolgende Installation des mqtt Adapters hat zwar einige Fehlermeldungen geworfen (siehe unten), aber die Installation der mqtt-Version 2.3.5 scheint geklappt zu haben (?). Auf jeden Fall funktioniert der mqtt Adapter V2.3.5 - zmindest auf den ersten Blick. Irgendwelche Kollateralschäden habe ich auch (noch) nicht beobachtet. 😊
              Vielen Dank für die Hilfe !
              Frohe Ostern,
              WillyIoBrok
              mqtt.0	2021-04-03 09:49:43.181	info	(8886) Starting MQTT server on 192.168.27.147:1883
              mqtt.0	2021-04-03 09:49:41.651	info	(8886) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.mqtt, node: v14.16.0, js-controller: 3.1.6
              host.ioBroker-4	2021-04-03 09:49:38.972	info	instance system.adapter.mqtt.0 started with pid 8886
              host.ioBroker-4	2021-04-03 09:49:37.583	info	iobroker exit 0
              host.ioBroker-4	2021-04-03 09:49:36.970	info	instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.ioBroker-4	2021-04-03 09:49:36.933	info	stopInstance system.adapter.mqtt.0 killing pid 8824
              host.ioBroker-4	2021-04-03 09:49:36.562	info	iobroker Adapter "mqtt" updated
              mqtt.0	2021-04-03 09:49:36.439	info	(8824) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              mqtt.0	2021-04-03 09:49:36.437	info	(8824) terminating
              host.ioBroker-4	2021-04-03 09:49:36.360	info	iobroker upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
              host.ioBroker-4	2021-04-03 09:49:36.215	info	iobroker upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
              host.ioBroker-4	2021-04-03 09:49:36.035	info	iobroker upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
              mqtt.0	2021-04-03 09:49:35.935	info	(8824) Got terminate signal TERMINATE_YOURSELF
              host.ioBroker-4	2021-04-03 09:49:35.929	info	stopInstance system.adapter.mqtt.0 send kill signal
              host.ioBroker-4	2021-04-03 09:49:35.848	info	stopInstance system.adapter.mqtt.0 (force=false, process=true)
              host.ioBroker-4	2021-04-03 09:49:35.798	info	iobroker Update "system.adapter.mqtt.0"
              host.ioBroker-4	2021-04-03 09:49:35.676	info	iobroker upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
              host.ioBroker-4	2021-04-03 09:49:31.386	info	iobroker Please submit a full bug report,with preprocessed source if appropriate.See <file:///usr/share/doc/gcc-8/README.Bugs> for instructions.make: *** [bindings.target.mk:112: Release/obj.target/b
              host.ioBroker-4	2021-04-03 09:49:31.376	info	iobroker g++: internal compiler error: Speicherzugriffsfehler signal terminated program cc1plus
                @willyiobrok
                Hätte ich wohl auch so gemacht. Aber beim kompilieren ist der Compiler ausgestiegen. Musst du Mal beobachten was bei anderen Updates passiert
                  nun habe ich heute wieder ein adapter - update gemacht - diesmal der backitup-adapter.
                  Vordergründig sieht alles i.O. aus, aber ich habe natürlich genau hingeschaut : der Compiler ist jetzt auch hier ausgestiegen.
                  Ich bin leider vom Know-How her nicht in der Lage, den gewünschten "full bug report, with preprocessed source" zur Verfügung zu stellen.
                  Aber vielleicht hilft die Veröffentlichung des logs ...
                  WillyIoBrok
                  2021-04-05 23:25:32.731	info	iobroker gyp ERR! node -v v14.16.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                  2021-04-05 23:25:32.729	info	iobroker at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/u
                  2021-04-05 23:25:32.728	info	iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack
                  2021-04-05 23:25:32.726	info	iobroker ERR! build error
                  2021-04-05 23:25:32.725	info	iobroker gyp
                  2021-04-05 23:25:32.722	info	iobroker Please submit a full bug report,with preprocessed source if appropriate.See <file:///usr/share/doc/gcc-8/README.Bugs> for instructions.make: *** [bindings.target.mk:112: Release/obj.target/b
                  2021-04-05 23:25:32.720	info	iobroker g++: internal compiler error: Speicherzugriffsfehler signal terminated program cc1plus
                  2021-04-05 23:24:58.459	info	iobroker npm install iobroker.backitup@2.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
                  2021-04-05 23:24:58.456	info	iobroker NPM version: 6.14.11
                  vollständig:
                  backitup.0	2021-04-05 23:25:42.908	info	(19509) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.16.0, js-controller: 3.1.6
                  host.ioBroker-4	2021-04-05 23:25:38.310	info	iobroker exit 0
                  host.ioBroker-4	2021-04-05 23:25:37.351	info	instance system.adapter.backitup.0 started with pid 19509
                  host.ioBroker-4	2021-04-05 23:25:37.297	info	"system.adapter.backitup.0" enabled
                  host.ioBroker-4	2021-04-05 23:25:37.200	info	iobroker Adapter "backitup" updatedhost.ioBroker-4 Adapter "system.adapter.backitup.0" is started
                  host.ioBroker-4	2021-04-05 23:25:37.138	info	iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  host.ioBroker-4	2021-04-05 23:25:37.080	info	iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  host.ioBroker-4	2021-04-05 23:25:37.023	info	iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  host.ioBroker-4	2021-04-05 23:25:36.964	info	iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  host.ioBroker-4	2021-04-05 23:25:36.897	info	iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  host.ioBroker-4	2021-04-05 23:25:36.839	info	iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  host.ioBroker-4	2021-04-05 23:25:36.783	info	iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  host.ioBroker-4	2021-04-05 23:25:36.726	info	iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  host.ioBroker-4	2021-04-05 23:25:36.667	info	iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  host.ioBroker-4	2021-04-05 23:25:36.467	info	iobroker Update "system.adapter.backitup.0"
                  host.ioBroker-4	2021-04-05 23:25:36.356	info	iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  host.ioBroker-4	2021-04-05 23:25:32.731	info	iobroker gyp ERR! node -v v14.16.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                  host.ioBroker-4	2021-04-05 23:25:32.729	info	iobroker at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/u
                  host.ioBroker-4	2021-04-05 23:25:32.728	info	iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack
                  host.ioBroker-4	2021-04-05 23:25:32.726	info	iobroker ERR! build error
                  host.ioBroker-4	2021-04-05 23:25:32.725	info	iobroker gyp
                  host.ioBroker-4	2021-04-05 23:25:32.722	info	iobroker Please submit a full bug report,with preprocessed source if appropriate.See <file:///usr/share/doc/gcc-8/README.Bugs> for instructions.make: *** [bindings.target.mk:112: Release/obj.target/b
                  host.ioBroker-4	2021-04-05 23:25:32.720	info	iobroker g++: internal compiler error: Speicherzugriffsfehler signal terminated program cc1plus
                  host.ioBroker-4	2021-04-05 23:24:58.459	info	iobroker npm install iobroker.backitup@2.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
                  host.ioBroker-4	2021-04-05 23:24:58.456	info	iobroker NPM version: 6.14.11
                  host.ioBroker-4	2021-04-05 23:24:56.638	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  backitup.0	2021-04-05 23:24:56.104	info	(607) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  backitup.0	2021-04-05 23:24:56.101	info	(607) terminating
                  backitup.0	2021-04-05 23:24:56.100	info	(607) cleaned everything up...
                  backitup.0	2021-04-05 23:24:56.071	info	(607) Got terminate signal TERMINATE_YOURSELF
                  host.ioBroker-4	2021-04-05 23:24:56.066	info	stopInstance system.adapter.backitup.0 send kill signal
                  host.ioBroker-4	2021-04-05 23:24:56.063	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
                  host.ioBroker-4	2021-04-05 23:24:56.061	info	"system.adapter.backitup.0" disabled
                  host.ioBroker-4	2021-04-05 23:24:55.886	info	iobroker host.ioBroker-4 Adapter "system.adapter.backitup.0" is stopped.
                  host.ioBroker-4	2021-04-05 23:24:55.862	info	iobroker Update backitup from @2.0.5 to @2.1.0
                  host.ioBroker-4	2021-04-05 23:24:53.521	info	iobroker upgrade backitup
                    @willyiobrok Steinalter Kernel. Bring dein System mal in die Jetzt-Zeit.
                      OK, mach ich morgen (jetzt wär's zu gefährlich 😁 )
                      so - oder ?
                      sudo apt update && sudo apt upgrade
                      sudo rpi-update
                        @willyiobrok Nie rpi-update verwenden!
                        Immer per apt!
                        Ich bevorzuge auch
                        sudo apt update
                        sudo apt dist-upgrade
                        Auf jedenfall reboot nicht vergessen!
                          @thomas-braun ok, danke!
                            WillyIobrok @WillyIobrok last edited by WillyIobrok
                            so, habe jetzt
                            sudo apt update
                            durchgeführt.
                            Oberflächlich scheint alles gut zu sein, Iobroker mit allen Adaptern läuft wieder so wie vorher.
                            Allerdings habe ich beim dist-upgrade Prozess Fehlermeldungen bekommen, bei denen ich nicht beurteilen kann, ob die wichtig oder zu ignorieren sind ... das beunruhigt mich ein bischen, deswegen stelle ich sie mal hier in's Forum ...
                            Fehlermeldungszusammenfassung:
                            Fehler traten auf beim Bearbeiten von:
                             raspberrypi-kernel
                             dphys-swapfile
                             nfs-common
                             openssh-server
                             ssh
                            E: Sub-process /usr/bin/dpkg returned an error code (1)
                            dpkg: Warnungen bzgl alter Verzeichnisse:
                            Entpacken von avahi-daemon (0.7-4+deb10u1) über (0.7-4+b1) ...
                            dpkg: Warnung: Altes Verzeichnis »/etc/resolvconf/update-libc.d« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                            dpkg: Warnung: Altes Verzeichnis »/etc/resolvconf« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                            dphys-swapfile
                            dphys-swapfile (20100506-5+rpt2) wird eingerichtet ...
                            Job for dphys-swapfile.service failed because the control process exited with error code.
                            See "systemctl status dphys-swapfile.service" and "journalctl -xe" for details.
                            invoke-rc.d: initscript dphys-swapfile, action "restart" failed.
                            ● dphys-swapfile.service - dphys-swapfile - set up, mount/unmount, and delete a swap file
                            Loaded: loaded (/lib/systemd/system/dphys-swapfile.service; enabled; vendor preset: enabled)
                            Active: failed (Result: exit-code) since Tue 2021-04-06 09:54:25 CEST; 21ms ago
                            Docs: man:dphys-swapfile(8)
                            Process: 7741 ExecStart=/sbin/dphys-swapfile setup (code=exited, status=139)
                            Main PID: 7741 (code=exited, status=139)
                            Apr 06 09:54:25 ioBroker-4 systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                            Apr 06 09:54:25 ioBroker-4 dphys-swapfile[7741]: want /var/swap=100MByte, checking existingSegmentation fault
                            Apr 06 09:54:25 ioBroker-4 dphys-swapfile[7741]: ls: Schreibfehler: Datenübergabe unterbrochen (broken pipe)
                            Apr 06 09:54:25 ioBroker-4 systemd[1]: dphys-swapfile.service: Main process exited, code=exited, status=139/n/a
                            Apr 06 09:54:25 ioBroker-4 systemd[1]: dphys-swapfile.service: Failed with result 'exit-code'.
                            Apr 06 09:54:25 ioBroker-4 systemd[1]: Failed to start dphys-swapfile - set up, mount/unmount, and delete a swap file.
                            dpkg: Fehler beim Bearbeiten des Paketes dphys-swapfile (--configure):
                            »installiertes dphys-swapfile-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
                            nfs-common etc.
                            dpkg: Fehler beim Bearbeiten des Paketes nfs-common (--configure):
                            »installiertes nfs-common-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 139 zurück
                            openssh-sftp-server (1:7.9p1-10+deb10u2+rpt1) wird eingerichtet ...
                            openssh-server (1:7.9p1-10+deb10u2+rpt1) wird eingerichtet ...
                            dpkg: Fehler beim Bearbeiten des Paketes openssh-server (--configure):
                            »installiertes openssh-server-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 139 zurück
                            dpkg: Abhängigkeitsprobleme verhindern Konfiguration von ssh:
                            ssh hängt ab von openssh-server (>= 1:7.9p1-10+deb10u2+rpt1); aber:
                            Paket openssh-server ist noch nicht konfiguriert.
                            dpkg: Fehler beim Bearbeiten des Paketes ssh (--configure):
                            Abhängigkeitsprobleme - verbleibt unkonfiguriert
                            Irgendwie werde ich das Gefühl nicht los, daß in meinem ursprünglichen Filesystem irgendwelche Inkonsistenzen versteckt sind, die auch jetzt nach dem Upgrade zu Fehlermeldungen führen ...🙄
                            das ist aber jetzt schon ein bischen "off topic" ... sollte vielleicht einen neuen Topic aufmachen...
                              @willyiobrok
                              Das hatte ich befürchtet. Da ist schon 'tiefer im System' was krumm und das führt dann im Obergeschoss (ioBroker) auch zu Problemen.
                              sudo apt update
                              liefert nun? Vollständige Ein- und Ausgabe ist erforderlich, nix weglöschen oder zusammenfassen!
                                aktuell, wenn ich "sudo apt update" eingebe kommt folgendes:
                                 sudo apt update
                                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                OK:3 https://deb.nodesource.com/node_10.x buster InRelease
                                OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                                OK:5 https://deb.nodesource.com/node_14.x buster InRelease
                                Alle Pakete sind aktuell.
                                (nix zusammengefasst oder weggelöscht 😊 )
                                war das die gewünschte info?
                                DIe Ausgabe von vorher oder direkt vom update habe ich leider nur mehr in Teilen ...
                                  @willyiobrok
                                  Hast du mal manuell an der
                                  /etc/resolv.conf
                                  und am swap herumgedoktort?
                                  sudo apt install nfs-common --reinstall
                                  Und bitte wirklich die komplette Ein- und Ausgabe posten, inkl. login prompt wie
                                  user@host usw....
                                    WillyIobrok @Thomas Braun last edited by WillyIobrok
                                    Nein, nicht dass ich wüsste. Ich habe das iobroker-System länger als ein 3/4 Jahr nicht mehr verändert, es lief wunderbar.
                                    Wie komme ich auf mögliche SD-Card - Probleme ? Hintergrundinfo:
                                    Ich führe regelmäßig ein Backup der gesamten SD-Karte durch. Das dauert zwar (16GB) aber ist mir so am liebsten. Es wird "DD" benutzt -> 16GB und dann mit Pishrink.sh (e2fsk) auf ca. 3,9GB reduziert.
                                    Vor ca. einem Monat hat jetzt e2fsk erstmalig einen Fehler im Filesystem diagnostiziert und erfolgreich (!?) repariert.
                                    Dieses Backup (mit dem reparierten Filesystem) habe ich dann auf eine neue SD Card geschrieben und das ist jetzt die Arbeitsbasis für meinen iobroker ...
                                    Hier die Antwort auf "sudo apt install nfs-common --reinstall"
                                    login as: pi
                                    pi@192.168.27.147's password:
                                    Linux ioBroker-4 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l
                                    The programs included with the Debian GNU/Linux system are free software;
                                    the exact distribution terms for each program are described in the
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Tue Apr  6 10:56:24 2021 from 192.168.27.135
                                    pi@ioBroker-4:~ $ sudo apt install nfs-common --reinstall
                                    0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                    5 nicht vollständig installiert oder entfernt.
                                    Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                                    E: Internal Error, No file name for nfs-common:armhf
                                    pi@ioBroker-4:~ $
                                    Was ich machen könnte : Aus meinem heutigen Backup nochmal eine SD-Karte bauen und den Linux-Kernel upgrade Prozess nochmal durchlaufen lassen - dann kann ich die vollständige Original-Ausgabe in Putty nochmal posten. Das dauert natürlich etwas ...
                                      @willyiobrok sagte in [solved] MQTT adapter update problems V2.1.14->2.3.4->2.3.5:
                                      Die 5 machen dir jetzt Probleme.
                                      Versuch mal
                                      sudo apt update
                                      sudo apt-get --fix-broken dist-upgrade
                                      Wenn das durch ist mal mit
                                      dpkg -l | grep -v ^ii
                                      schauen welche Pakete das sind.
                                        @thomas-braun said in [solved] MQTT adapter update problems V2.1.14->2.3.4->2.3.5:
                                        Jo, das hat's irgendwie gebracht 🙂
                                        Jetzt gibt's ne gute / vollständige Fehlerausgabe:
                                        pi@ioBroker-4:~ $ sudo apt update
                                        Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                        Es wurden 15,0 kB in 2 s geholt (8.291 B/s).
                                        pi@ioBroker-4:~ $ sudo apt-get --fix-broken dist-upgrade
                                        Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        Möchten Sie fortfahren? [J/n] J
                                        raspberrypi-kernel (1.20210303-1) wird eingerichtet ...
                                        Segmentation fault
                                        Segmentation fault
                                        /var/lib/dpkg/info/raspberrypi-kernel.postinst: 26: [: Illegal number:
                                        run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.10.17+ /boot/kernel.img
                                        /etc/kernel/postinst.d/apt-auto-removal:
                                        Segmentation fault
                                        Segmentation fault
                                        run-parts: /etc/kernel/postinst.d/apt-auto-removal exited with return code 139
                                        dpkg: Fehler beim Bearbeiten des Paketes raspberrypi-kernel (--configure):
                                        »installiertes raspberrypi-kernel-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
                                        nfs-common (1:1.3.4-2.5+deb10u1) wird eingerichtet ...
                                        Active: failed (Result: exit-code) since Tue 2021-04-06 11:59:07 CEST; 24ms ago
                                        Process: 2537 ExecStart=/sbin/dphys-swapfile setup (code=exited, status=139)
                                        Main PID: 2537 (code=exited, status=139)
                                        Apr 06 11:59:07 ioBroker-4 systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                                        Apr 06 11:59:07 ioBroker-4 dphys-swapfile[2537]: want /var/swap=100MByte, checking existingSegmentation fault
                                        Apr 06 11:59:07 ioBroker-4 dphys-swapfile[2537]: ls: Schreibfehler: Datenübergabe unterbrochen (broken pipe)
                                        Apr 06 11:59:07 ioBroker-4 systemd[1]: dphys-swapfile.service: Main process exited, code=exited, status=139/n/a
                                        Apr 06 11:59:07 ioBroker-4 systemd[1]: dphys-swapfile.service: Failed with result 'exit-code'.
                                        Apr 06 11:59:07 ioBroker-4 systemd[1]: Failed to start dphys-swapfile - set up, mount/unmount, and delete a swap file.
                                        openssh-server
                                        raspberrypi-kernel
                                        nfs-common
                                        dphys-swapfile
                                        ssh
                                        pi@ioBroker-4:~ $ dpkg -l | grep -v ^ii
                                        Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
                                        | Status=Nicht/Installiert/Config/U=Entpackt/halb konFiguriert/
                                        Halb installiert/Trigger erWartet/Trigger anhängig
                                        |/ Fehler?=(kein)/R=Neuinstallation notwendig (Status, Fehler: GROSS=schlecht)
                                        ||/ Name Version Architektur Beschreibung
                                        iF dphys-swapfile 20100506-5+rpt2 all Autogenerate and use a swap file
                                        rc libreadline5:armhf 5.2+dfsg-3 armhf GNU readline and history libraries, run-time libraries
                                        iF nfs-common 1:1.3.4-2.5+deb10u1 armhf NFS support files common to client and server
                                        iF openssh-server 1:7.9p1-10+deb10u2+rpt1 armhf secure shell (SSH) server, for secure access from remote machines
                                        iF raspberrypi-kernel 1.20210303-1 armhf Raspberry Pi bootloader
                                        iU ssh 1:7.9p1-10+deb10u2+rpt1 all secure shell client and server (metapackage)
                                        pi@ioBroker-4:~ $
                                        das Problem ist jetzt, dass ich bestenfalls rudimentäre Grundkenntnisse in Linux habe (die jedesmal in Zeiten von Linux-Inaktivität verschwinden) und zwar verstehe, was "segmentation fault" bedeuten könnte, aber kein Rezept habe, was ich dagegen tun könnte 😞 🙄
                                          @willyiobrok
                                          Ich ehrlich gesagt auch nicht so ad hoc.
                                          Warum das da gleich bei 5 Paketen 'knallt' kann ich dir auch nicht sagen.
                                          Ist jedenfalls 'nicht gut'.
                                          Mal probieren:
                                          sudo apt update
                                          sudo apt install openssh-server ssh --reinstall
                                            @thomas-braun Ohje, jetzt wird's immer mysteriöser ...
                                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                            OK:2 https://deb.nodesource.com/node_10.x buster InRelease
                                            OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                                            OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                                            OK:5 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                            pi@ioBroker-4:~ $ sudo apt install openssh-server ssh --reinstall
                                            0 aktualisiert, 0 neu installiert, 2 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                            E: Internal Error, No file name for openssh-server:armhf
                                            pi@ioBroker-4:~ $
                                            ich überlege mir, ob es nicht sinnvoller ist, das ganze System "von scratch" neu aufzusetzen...
                                            Allerdings möchte ich meine iobroker Konfiguration möglichst nicht verlieren - da steckt sehr viel Arbeit drin...
                                            Ich habe gelesen, daß es keine fertigen images mehr gibt (so habe ich den iobroker vor 2 Jahren aufgesetzt), aber es gibt sicher Anleitungen hier im Forum, wie das alles geht, da werde ich mich mal aufschlauen. Ausser einer "normalen" ioBroker Installation habe ich lediglich zwei mountpunkte (USBStick für die history Daten und mount auf's NAS für die Backups) zusätzlich, das werde ich hoffentlich schon noch hinkriegen 😓
                                            Auf jeden Fall schönen Dank für die super Hilfestellung 👍
                                            2448
