    4. kleines Projekt Z-Wave und Zigbee gleichzeitig auf PI4
      AMagnum @paul53 last edited by
      @paul53 nun habe ich das System neu aufgesetzt.
      pi@SmartHomePi4:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v12.22.0
      /usr/bin/node
      v12.22.0
      /usr/bin/npm
      6.14.11
      nodejs:
        Installed: 12.22.0-1nodesource1
        Candidate: 12.22.0-1nodesource1
        Version table:
       *** 12.22.0-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      pi@SmartHomePi4:~ $ uname -a
      Linux SmartHomePi4 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
      pi@SmartHomePi4:~ $ sudo lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 10 (buster)
      Release:        10
      Codename:       buster
      pi@SmartHomePi4:~ $ ls -l /dev/ttyA*
      crw-rw---- 1 root dialout 166,  0 Apr  5 21:03 /dev/ttyACM0
      crw-rw---- 1 root dialout 204, 64 Apr  5 20:28 /dev/ttyAMA0
      pi@SmartHomePi4:~ $ sudo grep dialout /etc/group
      dialout:x:20:pi,iobroker
      pi@SmartHomePi4:~ $ iobroker -v
      3.2.16
      Der Adapter zeigt nun
      Das Logfile im ioBroker gibt folgendes nun aus:
      zwave2.0	2021-04-05 21:07:20.395	info	(8247) starting. Version 1.8.11 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.0, js-controller: 3.2.16
      host.SmartHomePi4	2021-04-05 21:07:18.335	info	instance system.adapter.zwave2.0 started with pid 8247
      host.SmartHomePi4	2021-04-05 21:07:15.811	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zwave2.0	2021-04-05 21:07:15.254	info	(8228) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zwave2.0	2021-04-05 21:07:15.253	info	(8228) terminating
      zwave2.0	2021-04-05 21:07:15.251	info	(8228) Shutting down driver...
      zwave2.0	2021-04-05 21:07:15.249	info	(8228) Got terminate signal TERMINATE_YOURSELF
      host.SmartHomePi4	2021-04-05 21:07:15.249	info	stopInstance system.adapter.zwave2.0 send kill signal
      host.SmartHomePi4	2021-04-05 21:07:15.241	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
      zwave2.0	2021-04-05 21:06:21.183	warn	(8228) No serial port configured. Please select one in the adapter settings!
      zwave2.0	2021-04-05 21:06:21.132	info	(8228) starting. Version 1.8.11 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.0, js-controller: 3.2.16
      host.SmartHomePi4	2021-04-05 21:06:19.095	info	instance system.adapter.zwave2.0 started with pid 8228
      host.SmartHomePi4	2021-04-05 21:06:17.099	info	iobroker exit 0
      host.SmartHomePi4	2021-04-05 21:06:16.013	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0 created
      host.SmartHomePi4	2021-04-05 21:06:15.908	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.connection: false
      host.SmartHomePi4	2021-04-05 21:06:15.878	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.inclusion: 0
      host.SmartHomePi4	2021-04-05 21:06:15.849	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.exclusion: false
      host.SmartHomePi4	2021-04-05 21:06:15.819	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.healingNetwork: false
      host.SmartHomePi4	2021-04-05 21:06:15.786	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.alive created
      host.SmartHomePi4	2021-04-05 21:06:15.755	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.connected created
      host.SmartHomePi4	2021-04-05 21:06:15.725	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.compactMode created
      host.SmartHomePi4	2021-04-05 21:06:15.697	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.cpu created
      host.SmartHomePi4	2021-04-05 21:06:15.666	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.cputime created
      host.SmartHomePi4	2021-04-05 21:06:15.637	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.memHeapUsed created
      host.SmartHomePi4	2021-04-05 21:06:15.607	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.memHeapTotal created
      host.SmartHomePi4	2021-04-05 21:06:15.578	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.memRss created
      host.SmartHomePi4	2021-04-05 21:06:15.550	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.uptime created
      host.SmartHomePi4	2021-04-05 21:06:15.521	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.inputCount created
      host.SmartHomePi4	2021-04-05 21:06:15.491	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.outputCount created
      host.SmartHomePi4	2021-04-05 21:06:15.463	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.eventLoopLag created
      host.SmartHomePi4	2021-04-05 21:06:15.434	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.sigKill created
      host.SmartHomePi4	2021-04-05 21:06:15.404	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.logLevel created
      host.SmartHomePi4	2021-04-05 21:06:15.375	info	iobroker host.SmartHomePi4 object zwave2.0.info created
      host.SmartHomePi4	2021-04-05 21:06:15.347	info	iobroker host.SmartHomePi4 object zwave2.0.info.connection created
      host.SmartHomePi4	2021-04-05 21:06:15.318	info	iobroker host.SmartHomePi4 object zwave2.0.info.inclusion created
      host.SmartHomePi4	2021-04-05 21:06:15.289	info	iobroker host.SmartHomePi4 object zwave2.0.info.exclusion created
      host.SmartHomePi4	2021-04-05 21:06:15.261	info	iobroker host.SmartHomePi4 object zwave2.0.info.healingNetwork created
      host.SmartHomePi4	2021-04-05 21:06:15.249	info	iobroker host.SmartHomePi4 create instance zwave2
      Was mache ich nur falsch? Habe nun kein Z-WAY installiert, also ganz ohne! Und alles nur unter pi-User und sudo.
        Thomas Braun Most Active @AMagnum last edited by
        @amagnum
        Das gemacht?
          AMagnum @Thomas Braun last edited by
          @thomas-braun Ja hatte ich gemacht. Habe dort /dev/ttyAMA0 eingetragen und Adapter auch neu gestartet. Das Logfile oben ist nach dem Eintrag des TTY.
            AMagnum @AMagnum last edited by
              @amagnum
              Und auf ttyACM0 läuft der zigbee?
                pi@SmartHomePi4:~ $ npx @serialport/list
                /dev/ttyACM0    usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2427885-if00   dresden elektronik ingenieurtechnik GmbH
                /dev/ttyAMA0
                /dev/ttyS0
                Ja auf dem Port ttyACM0 läuft der ConBee_II Stick. Mich wundert es, dass mit dem o.g. Befehl keine Ausgabe für ttyAMA0 gemacht wird. Ich hätte irgendwie gedacht, dass dort auch was stehen sollte.
                  @amagnum
                  Da kann ich nicht weiterhelfen, ich kenne die Hardware nicht.
                    @thomas-braun trotzdem vielen Dank für Deine Hilfe
                    • AlCalzone
                      AlCalzone Developer @AMagnum last edited by
                      @amagnum sagte in kleines Projekt Z-Wave und Zigbee gleichzeitig auf PI4:
                      npm i zwave-js@3.2.0 aufgerufen
                      Ahhhh - NEIN! Niemals manuell eine eigene Version der Library installieren. Die ist eng mit dem Adapter verzahnt.
                      Zeig mal deine detaillierte Logdatei (die neueste): https://github.com/AlCalzone/ioBroker.zwave2/blob/master/docs/de/bei-problemen.md#notwendige-informationen-für-ein-issue
                      • tugsi
                        tugsi last edited by
                        @amagnum
                        ich habe den ZWave2.0 noch nicht installiert bei mir, steht noch auf meiner ToDo-Liste.
                        Aber ich kann Dir sagen, dass mit dem alten ZWave und den Razberry ich auch das Device auf
                        /dev/ttyAMA0
                        habe.
                        Aber hast Du bei dem neuaufsetzen das beherzigt, was @paul53 geschrieben hat:
                        • Z-Way? Dann greift die sich den Razberry und der Zugriff ist blockiert.
                        Es kann immer nur ein Tool auf ein serielles Gerät zugreifen, ausser es wird jedesmal extra abgemeldet, dies wäre aber hier nicht der Fall.
                        Ist schon lange her, dass ich den Razberry installiert habe, damals hatte ich auch erst noch getestet und mir glaub ich auch Z-Way oder so draufgemacht, um zu schauen, ob das Teil funzt.
                        Ich habe gerade mal den ZWave2.0 installiert und meinen ZWave ausgeschaltet und den einfach mit /dev/ttyAMA0 gestartet und er läuft, findet allerdings die alten Geräte nicht mehr, da ja jetzt ein anderer Schlüssel da ist, aber er hat den Razberry als NODE1 drin.
                          AMagnum @AlCalzone last edited by
                          @alcalzone Guten Morgen,
                          Habe keine eigene Version der Library installiert, alles ist Standard. Ich hatte das System ja neu aufgesetzt. Alles ganz frisch, im ioBroker nur admin.0, discovery.0 und info.0 und den zwave2. Kein Z-WAY installiert, damit der Port nicht durch eine andere SW belegt wird.
                          Hier meine aktuelle Konfiguration:
                          /usr/bin/nodejs
                          v12.22.0
                          /usr/bin/node
                          v12.22.0
                          /usr/bin/npm
                          6.14.11
                          nodejs:
                            Version table:
                          Release:        10
                          Codename:       buster
                          crw-rw---- 1 root dialout 166,  0 Apr  5 21:03 /dev/ttyACM0   << das ist mein Connbee2 zigbee
                          3.2.16
                          Habe jetzt mal den zwave2 Adapter im ioBroker gelöscht und neu hinzugefügt. Wenn man ihn hinzugügt, kommt zwar im ioBroker-Log die Meldung No serial port configured, aber dann trage ich ja den Port ein. Ist eventuell nur bem Hinzugügen so. Dann habe ich den Adaper mal beendet (08:05 Uhr) und neu gestartet (08:07 Uhr).
                          Hier das Log beim beenden:
                          08:03:21.387 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                          08:03:21.391 DRIVER   version 6.6.3
                          08:03:21.392 DRIVER
                          08:03:21.392 DRIVER   starting driver...
                          08:03:21.419 DRIVER   opening serial port /dev/ttyAMA0
                          08:03:21.444 DRIVER   serial port opened
                          08:03:21.446 SERIAL » [NAK]        (0x15)
                          08:05:36.670 DRIVER   destroying driver instance...
                          und hier beim Starten
                          08:07:41.415 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                          08:07:41.419 DRIVER   version 6.6.3
                          08:07:41.420 DRIVER
                          08:07:41.420 DRIVER   starting driver...
                          08:07:41.447 DRIVER   opening serial port /dev/ttyAMA0
                          08:07:41.467 DRIVER   serial port opened
                          08:07:41.468 SERIAL » [NAK]        (0x15)
                          Das NAK wundert mich. Ich muss dazu sagen, es gibt bisher keine Geräte im Z-Wave-Netz, die ich angelernt habe, alles noch ganz leer.
                          Komisch ist auch, dass unter /opt/iobroker/iobroker-data es kein zwave2.0/cache Verzeichnis gibt. Liegt aber vielleicht auch daran, weil keine Verbindung zustande kommt. Der Adapter bleibt im Status gelb, also true, true, false.
                          In Deinem angegebenen Link beschreibst Du, dass bei einem NAK wohl die Kommunikation mit dem Gerät nicht geklappt hat und eventuell eine Geräte-Konfiguration fehlt und man einen Pull-Request im zwave-js repo anlegen sollte. Dort gibt es auch einen Link zu einer Doku, leider funktioniert der Link nicht (https://alcalzone.github.io/node-zwave-js/#/development/config-files). Vielleicht würde ich mit der Beschreibung weiterkommen?
                          Danke für Deine Hilfe.
                          • AlCalzone
                            @amagnum Das NAK ist das erste Kommando, was nach dem Start an den Stick gesendet wird, um die Kommunikation zu initialisieren. Kurz danach sollte der Adapter aber mit dem Laden der Konfiguration beginnen - das passiert bei dir nicht. Zeig bitte mal die Ausgabe von:
                            cd /opt/iobroker/node_modules/iobroker.zwave2
                            npm ls
                              @alcalzone sagte in kleines Projekt Z-Wave und Zigbee gleichzeitig auf PI4:
                              pi@SmartHomePi4:/opt/iobroker/node_modules/iobroker.zwave2 $ npm ls
                              iobroker.zwave2@1.8.11 /opt/iobroker/node_modules/iobroker.zwave2
                              ├── UNMET DEPENDENCY @iobroker/adapter-core@^2.4.0
                              ├── UNMET DEPENDENCY alcalzone-shared@^3.0.2
                              ├── UNMET DEPENDENCY fs-extra@^9.1.0
                              └── UNMET DEPENDENCY zwave-js@^6.3.0
                              npm ERR! missing: @iobroker/adapter-core@^2.4.0, required by iobroker.zwave2@1.8.11
                              npm ERR! missing: alcalzone-shared@^3.0.2, required by iobroker.zwave2@1.8.11
                              npm ERR! missing: fs-extra@^9.1.0, required by iobroker.zwave2@1.8.11
                              npm ERR! missing: zwave-js@^6.3.0, required by iobroker.zwave2@1.8.11
                              oh, sieht nicht gut aus.
                              A tugsi 2 Replies Last reply Reply Quote 0
                                @amagnum Was soll ich nun machen?
                                • tugsi
                                  tugsi @AMagnum last edited by
                                  @amagnum
                                  Also ich habe da keine großartig andere Leistung, einzig benutze ich die Version 1.9.0 schon.
                                  Stell mal unter Haupteinstellungen des iObrokers unter Verwahrungsort auf BETA, dann bekommst auch die 1.9.0.
                                  Wobei ich jetzt nicht geschaut habe, welche Änderungen da gemacht wurden seitdem.
                                  iobroker.zwave2@1.9.0 /opt/iobroker/node_modules/iobroker.zwave2
                                  ├─┬ fs-extra@9.1.0
                                  │ ├── UNMET DEPENDENCY at-least-node@^1.0.0
                                  │ ├── graceful-fs@4.2.6
                                  │ ├─┬ jsonfile@6.1.0
                                  │ │ ├── graceful-fs@4.2.6 deduped
                                  │ │ └── universalify@2.0.0 deduped
                                  └── UNMET DEPENDENCY zwave-js@^7.0.0-beta.1
                                  npm ERR! missing: @iobroker/adapter-core@^2.4.0, required by iobroker.zwave2@1.9.0
                                  npm ERR! missing: alcalzone-shared@^3.0.2, required by iobroker.zwave2@1.9.0
                                  npm ERR! missing: zwave-js@^7.0.0-beta.1, required by iobroker.zwave2@1.9.0
                                  npm ERR! missing: at-least-node@^1.0.0, required by fs-extra@9.1.0
                                  Auch wenn Du noch keine Geräte hast, es gibt ja das "Hauptgerät" also NODE1, Dein Razberry
                                    AMagnum @tugsi last edited by AMagnum
                                    @alcalzone
                                    Habe nun im Verzeichnis /opt/iobroker/node_modules/iobroker.zwave2 den Befehl npm install --production aufgerufen (bin mir aber gerade unsicher, ob ich hier das richtige gemacht habe, Verzweiflungstat). Es wurde sehr viel geladen und übersetzt, es gibt aber gerade im Bereich von serialport viele Warnungen. Ich denke das ist der native Anteil des Treibers. Eventuell kann daher der Adapter nicht mit dem tty kommunizieren.
                                    Hier die Ausgaben, leider etwas viel Output:
                                    pi@SmartHomePi4:/opt/iobroker/node_modules/iobroker.zwave2 $ npm install --production
                                    npm WARN deprecated parcel-bundler@1.12.5: Parcel v1 is no longer maintained. Please migrate to v2, which is published under the 'parcel' package. See https://v2.parceljs.org/getting-started/migration for details.
                                    npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                                    npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
                                    npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
                                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                    > @serialport/bindings@9.0.7 install /opt/iobroker/node_modules/iobroker.zwave2/node_modules/@serialport/bindings
                                    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                    prebuild-install WARN install No prebuilt binaries found (target=12.22.0 runtime=node arch=arm libc= platform=linux)
                                    make: Entering directory '/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@serialport/bindings/build'
                                      CXX(target) Release/obj.target/bindings/src/serialport.o
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                    ../src/serialport.cpp: At global scope:
                                    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                    In file included from ../../../nan/nan.h:56,
                                                     from ../src/./serialport.h:6,
                                                     from ../src/serialport.cpp:1:
                                    /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                           (node::addon_register_func) (regfunc),                          \
                                    /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
                                       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                                     NODE_MODULE(serialport, init);
                                      CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                                         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                                    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                                    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                                         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                                    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                                      CXX(target) Release/obj.target/bindings/src/poller.o
                                      CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                                      SOLINK_MODULE(target) Release/obj.target/bindings.node
                                      COPY Release/bindings.node
                                    make: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@serialport/bindings/build'
                                    npm notice created a lockfile as package-lock.json. You should commit this file.
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/glob-watcher/node_modules/chokidar/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/@parcel/watcher/node_modules/chokidar/node_modules/fsevents):
                                    added 147 packages from 179 contributors and audited 1836 packages in 84.352s
                                    24 packages are looking for funding
                                      run `npm fund` for details
                                    found 0 vulnerabilities
                                    Wenn ich nun aber npm ls aufrufe, dann kommt folgende Ausgabe.
                                    ├─┬ @iobroker/adapter-core@2.4.0
                                    │ └─┬ @types/iobroker@3.2.8
                                    │   └── @types/node@14.14.37 deduped
                                    ├── @types/node@14.14.37
                                    ├─┬ alcalzone-shared@3.0.3
                                    │ └─┬ debug@4.3.1
                                    │   └── ms@2.1.2
                                    ├─┬ fs-extra@9.1.0
                                    │ ├── at-least-node@1.0.0
                                    ├─┬ source-map-support@0.5.19
                                    │ ├── buffer-from@1.1.1
                                    │ └── source-map@0.6.1
                                    └─┬ zwave-js@6.6.3
                                      ├─┬ @alcalzone/jsonl-db@1.2.4
                                      │ ├── alcalzone-shared@3.0.3 deduped
                                      │ └── fs-extra@9.1.0 deduped
                                      ├─┬ @sentry/integrations@6.2.5
                                      │ ├── @sentry/types@6.2.5
                                      │ ├─┬ @sentry/utils@6.2.5
                                      │ │ ├── @sentry/types@6.2.5 deduped
                                      │ │ └── tslib@1.14.1 deduped
                                      │ ├─┬ localforage@1.9.0
                                      │ │ └─┬ lie@3.1.1
                                      │ │   └── immediate@3.0.6
                                      │ └── tslib@1.14.1
                                      ├─┬ @sentry/node@6.2.5
                                      │ ├─┬ @sentry/core@6.2.5
                                      │ │ ├── @sentry/hub@6.2.5 deduped
                                      │ │ ├─┬ @sentry/minimal@6.2.5
                                      │ │ │ ├── @sentry/hub@6.2.5 deduped
                                      │ │ │ ├── @sentry/types@6.2.5 deduped
                                      │ │ │ └── tslib@1.14.1 deduped
                                      │ │ ├── @sentry/utils@6.2.5 deduped
                                      │ ├─┬ @sentry/hub@6.2.5
                                      │ ├─┬ @sentry/tracing@6.2.5
                                      │ │ ├── @sentry/minimal@6.2.5 deduped
                                      │ ├── cookie@0.4.1
                                      │ ├─┬ https-proxy-agent@5.0.0
                                      │ │ ├─┬ agent-base@6.0.2
                                      │ │ │ └── debug@4.3.1 deduped
                                      │ ├── lru_map@0.3.3
                                      ├─┬ @zwave-js/config@6.6.3
                                      │ ├── @zwave-js/core@6.6.3 deduped
                                      │ ├── @zwave-js/shared@6.6.3 deduped
                                      │ ├── ansi-colors@4.1.1 deduped
                                      │ ├── fs-extra@9.1.0 deduped
                                      │ ├── json-logic-js@2.0.1
                                      │ ├─┬ json5@2.2.0
                                      │ │ └── minimist@1.2.5
                                      │ ├─┬ semver@7.3.5
                                      │ │ └─┬ lru-cache@6.0.0
                                      │ │   └── yallist@4.0.0
                                      │ └── winston@3.3.3 deduped
                                      ├─┬ @zwave-js/core@6.6.3
                                      │ ├── @alcalzone/jsonl-db@1.2.4 deduped
                                      │ ├── moment@2.29.1
                                      │ ├─┬ moment-timezone@0.5.33
                                      │ │ └── moment@2.29.1 deduped
                                      │ ├── nrf-intel-hex@1.3.0
                                      ├─┬ @zwave-js/serial@6.6.3
                                      │ ├── serialport@9.0.7 deduped
                                      ├─┬ @zwave-js/shared@6.6.3
                                      │ └── alcalzone-shared@3.0.3 deduped
                                      ├── reflect-metadata@0.1.13
                                      ├─┬ serialport@9.0.7
                                      │ ├─┬ @serialport/binding-mock@9.0.7
                                      │ │ ├─┬ @serialport/binding-abstract@9.0.7
                                      │ ├─┬ @serialport/bindings@9.0.7
                                      │ │ ├── @serialport/binding-abstract@9.0.7 deduped
                                      │ │ ├── @serialport/parser-readline@9.0.7 deduped
                                      │ │ ├─┬ bindings@1.5.0
                                      │ │ │ └── file-uri-to-path@1.0.0
                                      │ │ ├── debug@4.3.1 deduped
                                      │ │ ├── nan@2.14.2
                                      │ │ └─┬ prebuild-install@6.1.1
                                      │ │   ├── detect-libc@1.0.3
                                      │ │   ├── expand-template@2.0.3
                                      │ │   ├── github-from-package@0.0.0
                                      │ │   ├── minimist@1.2.5 deduped
                                      │ │   ├── mkdirp-classic@0.5.3
                                      │ │   ├── napi-build-utils@1.0.2
                                      │ │   ├─┬ node-abi@2.21.0
                                      │ │   │ └── semver@5.7.1
                                      │ │   ├── noop-logger@0.1.1
                                      │ │   ├─┬ npmlog@4.1.2
                                      │ │   │ ├─┬ are-we-there-yet@1.1.5
                                      │ │   │ │ ├── delegates@1.0.0
                                      │ │   │ │ └─┬ readable-stream@2.3.7
                                      │ │   │ │   ├── core-util-is@1.0.2 deduped
                                      │ │   │ │   ├── inherits@2.0.4 deduped
                                      │ │   │ │   ├── isarray@1.0.0 deduped
                                      │ │   │ │   ├── process-nextick-args@2.0.1 deduped
                                      │ │   │ │   ├── safe-buffer@5.1.2
                                      │ │   │ │   ├─┬ string_decoder@1.1.1
                                      │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                                      │ │   │ │   └── util-deprecate@1.0.2 deduped
                                      │ │   │ ├── console-control-strings@1.1.0
                                      │ │   │ ├─┬ gauge@2.7.4
                                      │ │   │ │ ├── aproba@1.2.0
                                      │ │   │ │ ├── console-control-strings@1.1.0 deduped
                                      │ │   │ │ ├── has-unicode@2.0.1
                                      │ │   │ │ ├── object-assign@4.1.1
                                      │ │   │ │ ├── signal-exit@3.0.3
                                      │ │   │ │ ├─┬ string-width@1.0.2
                                      │ │   │ │ │ ├── code-point-at@1.1.0
                                      │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                                      │ │   │ │ │ │ └── number-is-nan@1.0.1
                                      │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                                      │ │   │ │ ├─┬ strip-ansi@3.0.1
                                      │ │   │ │ │ └── ansi-regex@2.1.1
                                      │ │   │ │ └─┬ wide-align@1.1.3
                                      │ │   │ │   └── string-width@1.0.2 deduped
                                      │ │   │ └── set-blocking@2.0.0
                                      │ │   ├─┬ pump@3.0.0
                                      │ │   │ ├─┬ end-of-stream@1.4.4
                                      │ │   │ │ └── once@1.4.0 deduped
                                      │ │   │ └─┬ once@1.4.0
                                      │ │   │   └── wrappy@1.0.2
                                      │ │   ├─┬ rc@1.2.8
                                      │ │   │ ├── deep-extend@0.6.0
                                      │ │   │ ├── ini@1.3.8
                                      │ │   │ ├── minimist@1.2.5 deduped
                                      │ │   │ └── strip-json-comments@2.0.1
                                      │ │   ├─┬ simple-get@3.1.0
                                      │ │   │ ├─┬ decompress-response@4.2.1
                                      │ │   │ │ └── mimic-response@2.1.0
                                      │ │   │ ├── once@1.4.0 deduped
                                      │ │   │ └── simple-concat@1.0.1
                                      │ │   ├─┬ tar-fs@2.1.1
                                      │ │   │ ├── chownr@1.1.4
                                      │ │   │ ├── mkdirp-classic@0.5.3 deduped
                                      │ │   │ ├── pump@3.0.0 deduped
                                      │ │   │ └─┬ tar-stream@2.2.0
                                      │ │   │   ├─┬ bl@4.1.0
                                      │ │   │   │ ├─┬ buffer@5.7.1
                                      │ │   │   │ │ ├── base64-js@1.5.1
                                      │ │   │   │ │ └── ieee754@1.2.1
                                      │ │   │   │ └── readable-stream@3.6.0 deduped
                                      │ │   │   ├── end-of-stream@1.4.4 deduped
                                      │ │   │   ├── fs-constants@1.0.0
                                      │ │   └─┬ tunnel-agent@0.6.0
                                      │ │     └── safe-buffer@5.2.1 deduped
                                      │ ├── @serialport/parser-byte-length@9.0.7
                                      │ ├── @serialport/parser-cctalk@9.0.7
                                      │ ├── @serialport/parser-delimiter@9.0.7
                                      │ ├── @serialport/parser-inter-byte-timeout@9.0.7
                                      │ ├─┬ @serialport/parser-readline@9.0.7
                                      │ │ └── @serialport/parser-delimiter@9.0.7 deduped
                                      │ ├── @serialport/parser-ready@9.0.7
                                      │ ├── @serialport/parser-regex@9.0.7
                                      │ ├─┬ @serialport/stream@9.0.7
                                      ├── source-map-support@0.5.19 deduped
                                      ├─┬ winston@3.3.3
                                      │ ├─┬ @dabh/diagnostics@2.0.2
                                      │ │ ├─┬ colorspace@1.1.2
                                      │ │ │ ├─┬ color@3.0.0
                                      │ │ │ │ ├─┬ color-convert@1.9.3
                                      │ │ │ │ │ └── color-name@1.1.3
                                      │ │ │ │ └─┬ color-string@1.5.5
                                      │ │ │ │   ├── color-name@1.1.3 deduped
                                      │ │ │ │   └─┬ simple-swizzle@0.2.2
                                      │ │ │ │     └── is-arrayish@0.3.2
                                      │ │ │ └── text-hex@1.0.0
                                      │ │ ├── enabled@2.0.0
                                      │ │ └── kuler@2.0.0
                                      │ ├── async@3.2.0
                                      │ ├── is-stream@2.0.0
                                      │ ├─┬ logform@2.2.0
                                      │ │ ├── colors@1.4.0
                                      │ │ ├── fast-safe-stringify@2.0.7
                                      │ │ ├── fecha@4.2.1
                                      │ │ ├── ms@2.1.2 deduped
                                      │ │ └── triple-beam@1.3.0 deduped
                                      │ ├─┬ one-time@1.0.0
                                      │ │ └── fn.name@1.1.0
                                      │ ├─┬ readable-stream@3.6.0
                                      │ │ ├─┬ string_decoder@1.3.0
                                      │ │ │ └── safe-buffer@5.2.1
                                      │ ├── stack-trace@0.0.10
                                      │ ├── triple-beam@1.3.0
                                      │ └─┬ winston-transport@4.4.0
                                      │   ├─┬ readable-stream@2.3.7
                                      └── xstate@4.17.1
                                    Adapter-Logfile sieht nicht bessere aus. Nach dem NAK kommt nichts weiter raus.
                                    mikeal created this issue in request/request
                                    open Request’s Past, Present and Future #3142
                                    AlCalzone tugsi 2 Replies Last reply Reply Quote 0
                                    • AlCalzone
                                      Das sieht zwar erschreckend aus, ist aber okay so. Kannst du mal eine andere Adapter-Version ausprobieren? Am besten gleich die aktuellste. Adapter stoppen, dann:
                                      cd /opt/iobroker
                                      npm i iobroker.zwave2@latest
                                      iobroker upload zwave2
                                        @alcalzone Habe die latest Version (1.9.2) geladen, bleibt aber bei NAK immer noch stehen.
                                        iobroker.zwave2@1.9.2 /opt/iobroker/node_modules/iobroker.zwave2
                                        ├── UNMET DEPENDENCY alcalzone-shared@^3.0.3
                                        └── UNMET DEPENDENCY zwave-js@^7.1.0
                                        npm ERR! missing: @iobroker/adapter-core@^2.4.0, required by iobroker.zwave2@1.9.2
                                        npm ERR! missing: alcalzone-shared@^3.0.3, required by iobroker.zwave2@1.9.2
                                        npm ERR! missing: fs-extra@^9.1.0, required by iobroker.zwave2@1.9.2
                                        npm ERR! missing: zwave-js@^7.1.0, required by iobroker.zwave2@1.9.2
                                        Vielleicht ist ja das RaZberry 2 Modul defekt. Ich habe nun einen Z-Wave USB Stick gekauft, wird demnächst geliefert (Modell Aeotec AEOEZW090-C). Dann nehme ich das RaZberry runter und versuche es mit dem Stick.
                                        Oder gibt es eine simple Methode, um mal etwas an das tty zu Senden und zu Empfangen. Früher hatte ich das mit alten Modemverbindungen gemacht. Da gab es immer so einen AT-Befehlssatz, das waren aber reine ASCII-Schnittstellen, hatte früher mit 300 bit/s angefangen. Oh man, das waren noch Zeiten.
                                        • tugsi
                                          @amagnum
                                          Es gab auch mal ein Beitrag, wo es um den Serialport ging:
                                          https://forum.iobroker.net/topic/6230/zwave-raspberrypi3-und-razberry-zwave-platine/4?_=1617715888271
                                          Lediglich der Serialport muss umkonfiguriert werden:
                                          sudo nano /boot/cmdline.txt
                                          -> console=serial0,115200 entfernen
                                          sudo nano /boot/config.txt
                                          -> folgendes einfügen bzw Auskommentierung entfernen:
                                          dtoverlay=pi3-miniuart-bt
                                          enable_uart=1
                                          force_turbo=1
                                          reboot
                                          Das habe ich bei mir auch drin.
                                          Ist leider schon zu lange her, dass ich mein RazBerry in Betrieb genommen habe, aber da ich in der config.txt die Einträge habe, gehe ich mal davon aus, dass ich das gemacht habe.
                                          Ist allerdings bei mir ein PI3 auch.
                                          • AlCalzone
                                            AlCalzone Developer @tugsi last edited by
                                            @tugsi Inzwischen geht das auch per raspi-config meine ich.
                                            2809
