    4. [neuer Adapter] smartgarden adapter for Gardena smart system
      Thomas Braun Most Active @Flexer last edited by
      @flexer
      Bitte log text auch als Text (in CodeTags </> eingebettet) posten, keine Screenshots.
      Flexer 1 Reply Last reply Reply Quote 0
      • Flexer
        Flexer @Thomas Braun last edited by
        smartgarden.0	2021-04-01 12:18:59.483	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.482	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ getConnection: trying to connect again in 300 seconds
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ getConnection: returned connection error: request returned 403 Forbidden
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:59.476	error	(22147) Error: request returned 403 Forbidden
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ get_locations failure:..return with error
        smartgarden.0	2021-04-01 12:18:59.475	info	(22147) 3/ get_locations failure: response.statusCode/Message=403/Forbidden
        smartgarden.0	2021-04-01 12:18:59.475	info	(22147) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:59.391	info	(22147) 3/ get_locations ...
        smartgarden.0	2021-04-01 12:18:59.391	info	(22147) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0	2021-04-01 12:18:59.391	info	(22147) 3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
        smartgarden.0	2021-04-01 12:18:59.390	info	(22147) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0	2021-04-01 12:18:59.190	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.revision changed: Main: 2466 / API: 2466 (ack = true)
        smartgarden.0	2021-04-01 12:18:59.189	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.187	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.181	info	(22147) 3/ sgSetState: info.revision value=Main: 2466 / API: 2466 ack=true
        smartgarden.0	2021-04-01 12:18:59.159	info	(22147) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0	2021-04-01 12:18:59.159	info	(22147) 3/ connecting to Gardena Smart System Service ...
        smartgarden.0	2021-04-01 12:18:59.158	info	(22147) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:59.157	info	(22147) 3/ connectToGardena...
        smartgarden.0	2021-04-01 12:18:59.156	info	(22147) 3/ getConnection...
        smartgarden.0	2021-04-01 12:18:59.131	info	(22147) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.19.0, js-controller: 3.2.16
        smartgarden.0	2021-04-01 12:18:55.044	info	(21554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        smartgarden.0	2021-04-01 12:18:55.044	info	(21554) terminating
        smartgarden.0	2021-04-01 12:18:55.044	info	(21554) 3/ cleaned everything up...
        smartgarden.0	2021-04-01 12:18:55.043	info	(21554) Got terminate signal TERMINATE_YOURSELF
        smartgarden.0	2021-04-01 12:18:36.036	info	(21554) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:36.034	info	(21554) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:35.817	info	(21554) 3/ getConnection: trying to connect again in 300 seconds
        smartgarden.0	2021-04-01 12:18:35.817	info	(21554) 3/ getConnection: returned connection error: request returned 403 Forbidden
        smartgarden.0	2021-04-01 12:18:35.817	info	(21554) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:35.817	error	(21554) Error: request returned 403 Forbidden
          @flexer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
          Da sag der gardena-Server: Du kummst hier ned rein...
          Passwort korrekt? Ggf. muss da auch ein neues angelegt werden.
          node: v12.19.0
          Mein Hobby: Halte das System aktuell.
          • Flexer
            @thomas-braun Passwort habe ich auch geändert. Keine Änderung
              @flexer
              Auch key zur Hand?
              To use this adapter you need two things:
              an GARDENA smart system account
              an GARDENA application key
              To get both things please go to https://developer.husqvarnagroup.cloud/docs#/docs/getting-started/.
              • Flexer
                @thomas-braun Bin nochmal alles in ruhe durchgegangen jetzt hat es geklappt. Muss nur noch rausfinden wie ich das Watercontrol steuer! Super jetzt habe ich wieder einen Adapter mehr der läuft
                jpgorganizer 1 Reply Last reply Reply Quote 0
                • jpgorganizer
                  jpgorganizer @Flexer last edited by
                  @flexer
                  schön, dass es nun klappt bei dir.
                  kannst du verraten, was die Ursache war, dass es zunächst nicht funktioniert hat? Das würde mir und evtl. anderen Usern helfen.
                  den Water Control musst du als SERVICE_VALVE steuern. Kannst im readme einfach nach Water Control suchen, dann solltest du fündig werden.
                  VG jpgorganizer
                  Flexer 1 Reply Last reply Reply Quote 1
                  • Flexer
                    Flexer @jpgorganizer last edited by Flexer
                    @jpgorganizer Ich hatte nicht auf Connect new Api geklickt. Das hat natürlich dann nicht geklappt.
                    Super dann suche ich das mal in der readme. Aktuell habe ich das zwar über eine alexaroutine noch am laufen aber das baue ich dann um.
                    Vielen dank für die tolle arbeit
                    EDIT: Valve an und aus klappt! Klasse!
                      dany198300 last edited by
                      Hi jpgorganizer
                      Leider verbindet sich meine Smartgarden Instanz nicht mit dem API vom Gardena.
                      Application key sowie Benutzername habe ich eingetragen. Wo könnte das Problem noch liegen? Lg Dani
                      Bildschirmfoto 2021-04-06 um 14.46.53.png Bildschirmfoto 2021-04-06 um 14.46.32.png Bildschirmfoto 2021-04-06 um 14.46.02.png
                      Qualle888 jpgorganizer 2 Replies Last reply Reply Quote 0
                      • Qualle888
                        Qualle888 @dany198300 last edited by
                        @dany198300 Ich wollte den Adapter gerade testen und habe das gleiche Problem.
                        • jpgorganizer
                          jpgorganizer @dany198300 last edited by jpgorganizer
                          @dany198300 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          Hi jpgorganizer
                          @dany198300 dir empfehle ich einen neuen Application key zu generieren, den key solltest du geheim halten und möglichst nicht in Foren posten
                          @qualle888 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          naja, ich vermute es liegt an Application key / Benutzername / Passwort
                          und ohne Log kann man nur vermuten 🙂
                          VG jpgorganizer
                            dany198300 last edited by dany198300
                            Hallo @jpgorganizer
                            Ja, da hast Du natürlich Recht, sehr fahrlässig von mir. Hab den Key erneuert.
                            Danke für den Hinweis 🙂
                            Mit löschen des Adapters und neu installieren hat es geklappt 🙂
                            • jpgorganizer
                              @dany198300
                              gut dass es nun geht, aber ich bin immer etwas erstaunt, was eine Neuinstallation wohl so anderes macht wie die erste Installation. Es werden nur Files kopiert.
                              Falls du sagen kannst woran es lag, dann her damit. Dann haben alle was davon 🙂
                              lt. dem Screenshot, den du vorhin noch geposted hattest, kam ein 403 Forbidden. Klares Zeichen für Fehler bei der Authentifizierung, also war mind. ein Element aus Api-Key, Username, Passwort falsch.
                              @all: wenn ihr Log's posted, dann bitte als Text als
                              Code
                              posten (in CodeTags </> eingebettet) . Und seid nicht zu geizig mit dem Log. Es sollte auch sichtbar sein, was vor dem Fehler passierte. Eine Fehlermeldung kommt erst, wenn der Fehler passiert ist. Die Ursache lag i.d.R. davor.
                              Wie wenn Ihr vom Fahrrad stürzt. Ein Bild dass Ihr auf dem Boden liegt, bringt nichts mehr um die Ursache zu finden. Ein Bild von den 10 m zugefrorener Straße davor, kann das aber erklären.
                              VG jpgorganizer
                              • Flexer
                                @jpgorganizer Kurze Zwischenfrage. Hat jemand das Smart irrigation Modul mit dem Adapter am laufen?
                                dslraser jpgorganizer 2 Replies Last reply Reply Quote 0
                                • dslraser
                                  dslraser Forum Testing Most Active @Flexer last edited by dslraser
                                  Ich habe das Irrigation Control, das lief die ganze letzte Saison mit diesem Adapter. Dieses Jahr ist es noch nicht angeschlossen.
                                  Warum fragst Du ?
                                  Edit: bedient habe ich es damit
                                  https://forum.iobroker.net/post/408094
                                  • Flexer
                                    Flexer @dslraser last edited by
                                    @dslraser Ich überlege dieses Jahr eine Bewässerung einzubauen. Ich habe im Trockenaufbau mal eine Steuerung mit einen Sonoff 4 Pro aufgebaut, jedoch kommt jetzt ein Kreislauf mehr dazu und bin bei 5 Ventilen. Deshalb überlege ich das Smart Irrigation zu holen.
                                    • jpgorganizer
                                      jpgorganizer @Flexer last edited by jpgorganizer
                                      ja, ich, das war der initiale Grund, dass ich den Adapter entwickelt habe 🙂
                                      ich hab 6 Ventile dran
                                      • Flexer
                                        @jpgorganizer Hallo und schönen Abend. Bin von deinem Adapter echt begeistert. Vielen Dank.
                                        Ich habe aber festgestellt dass dieser Sensor wohl keine Korrekten Werte zur Batterie hergibt. Hast du eine Idee? Habe mehrfach die Batterien gewechselt aber er zeigt immer einen Wert von 37% an.
                                        GARDENA smart Sensor: https://www.amazon.de/dp/B08LNQGB99/ref=cm_sw_r_cp_api_glc_i_16E128SH87WV8YGZ4ZNS
                                        Ps habe heute meine Visualisierung angepasst und die Bewässerung eingebaut. Hier ein paar Bilder.
                                        IMG_8102.MP4 E2D07A70-135D-4D7B-8E65-792FD88747E7.jpeg ABAFE23B-E6E8-46EB-9777-FDD1748508CA.jpeg DBDA31A8-81F9-4DA1-8987-035FE87FD29A.jpeg
                                        jpgorganizer dslraser 2 Replies Last reply Reply Quote 0
                                        • jpgorganizer
                                          ich würde schon erwarten, dass verschiedene Werte kommen.
                                          Ich habe keinen Sensor, somit kann ich im Detail dazu aber nichts sagen. Aber es gibt hier einige Leute, die einen Sensor betreiben. Vielleicht sagt einer was dazu
                                          JohGre 1 Reply Last reply Reply Quote 0
                                          • dslraser
                                            Ich habe einen Sensor, allerdings sieht meiner anders aus als der von Dir verlinkte. Deiner scheint eine neuere Generation zu sein.
                                            Zeigt Dein Sensor denn passende Werte in der App ?
                                            Bei meinem Sensor war es so (letzte Saison) das der nur selten die Werte aktualisiert. Wenn man es in der App "erzwingen" wollte, dann kam auch eine Meldung das es nur so und so oft in einem gewissen Zeitraum möglich ist. Wie oft genau kann ich aus dem Kopf nicht mehr sagen. Dieses Jahr habe ich noch nichts in Betrieb.
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            291124
